Uncrustify Configuration vs RTEMS Coding Style
Mon Apr 5 14:51:23 UTC 2021
Hello Joel,
On 04/04/2021 22:19, Joel Sherrill wrote:
> Hi Sebastian,
> Do you have a list or remember where uncrustify could not match the
> RTEMS Coding Style?
my uncrustify had 742 options and I didn't manage do find an option set
which produces the RTEMS Coding Style. I think using options to define a
source code formatter behaviour is broken by design. You probably need
some sort of a Turing complete domain-specific language for this.
I tried to write a configuration file for clang-format 10. It worked
well until I discovered this broken option:
https://stackoverflow.com/questions/38392889/clang-format-align-asterisk-of-pointer-declaration-with-variable-name
What we need for the RTEMS style is:
AlignConsecutiveDeclarations: true
PointerAlignment: Right
This combination seems to be unimplemented properly since 2016.
It seems there is still no tool available which is able to produce
something close to the RTEMS style.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
Language:        Cpp
# BasedOnStyle:  LLVM
AccessModifierOffset: -2
AlignAfterOpenBracket: Align
AlignConsecutiveMacros: false
AlignConsecutiveAssignments: false
AlignEscapedNewlines: Right
AlignOperands:   true
AlignTrailingComments: true
AllowAllArgumentsOnNextLine: false
AllowAllConstructorInitializersOnNextLine: true
AllowAllParametersOfDeclarationOnNextLine: false
AllowShortBlocksOnASingleLine: Never
AllowShortCaseLabelsOnASingleLine: false
AllowShortFunctionsOnASingleLine: All
AllowShortLambdasOnASingleLine: All
AllowShortIfStatementsOnASingleLine: Never
AllowShortLoopsOnASingleLine: false
AlwaysBreakAfterDefinitionReturnType: None
AlwaysBreakAfterReturnType: None
AlwaysBreakBeforeMultilineStrings: false
AlwaysBreakTemplateDeclarations: MultiLine
BinPackArguments: false
BinPackParameters: false
BraceWrapping:
  AfterCaseLabel:  false
  AfterClass:      false
  AfterControlStatement: false
  AfterEnum:       false
  AfterFunction:   true
  AfterNamespace:  false
  AfterObjCDeclaration: false
  AfterStruct:     false
  AfterUnion:      false
  AfterExternBlock: false
  BeforeCatch:     false
  BeforeElse:      false
  IndentBraces:    false
  SplitEmptyFunction: true
  SplitEmptyRecord: true
  SplitEmptyNamespace: true
BreakBeforeBinaryOperators: None
BreakBeforeBraces: Custom
BreakBeforeInheritanceComma: false
BreakInheritanceList: BeforeColon
BreakBeforeTernaryOperators: false
BreakConstructorInitializersBeforeComma: false
BreakConstructorInitializers: BeforeColon
BreakAfterJavaFieldAnnotations: false
BreakStringLiterals: true
ColumnLimit:     80
CommentPragmas:  '^ IWYU pragma:'
CompactNamespaces: false
ConstructorInitializerAllOnOneLineOrOnePerLine: false
ConstructorInitializerIndentWidth: 2
ContinuationIndentWidth: 2
Cpp11BracedListStyle: true
DeriveLineEnding: true
DerivePointerAlignment: false
DisableFormat:   false
ExperimentalAutoDetectBinPacking: false
FixNamespaceComments: true
ForEachMacros:
  - foreach
  - Q_FOREACH
  - BOOST_FOREACH
IncludeBlocks:   Preserve
IncludeCategories:
  - Regex:           '^"(llvm|llvm-c|clang|clang-c)/'
    Priority:        2
    SortPriority:    0
  - Regex:           '^(<|"(gtest|gmock|isl|json)/)'
    Priority:        3
    SortPriority:    0
  - Regex:           '.*'
    Priority:        1
    SortPriority:    0
IncludeIsMainRegex: '(Test)?$'
IncludeIsMainSourceRegex: ''
IndentCaseLabels: false
IndentGotoLabels: true
IndentPPDirectives: None
IndentWidth:     2
IndentWrappedFunctionNames: false
JavaScriptQuotes: Leave
JavaScriptWrapImports: true
KeepEmptyLinesAtTheStartOfBlocks: false
MacroBlockBegin: ''
MacroBlockEnd:   ''
MaxEmptyLinesToKeep: 1
NamespaceIndentation: None
ObjCBinPackProtocolList: Auto
ObjCBlockIndentWidth: 2
ObjCSpaceAfterProperty: false
ObjCSpaceBeforeProtocolList: true
PenaltyBreakAssignment: 2
PenaltyBreakBeforeFirstCallParameter: 19
PenaltyBreakComment: 300
PenaltyBreakFirstLessLess: 120
PenaltyBreakString: 1000
PenaltyBreakTemplateDeclaration: 10
PenaltyExcessCharacter: 1000000
PenaltyReturnTypeOnItsOwnLine: 60
ReflowComments:  true
SortIncludes:    true
SortUsingDeclarations: true
SpaceAfterCStyleCast: true
SpaceAfterLogicalNot: false
SpaceAfterTemplateKeyword: true
SpaceBeforeAssignmentOperators: true
SpaceBeforeCpp11BracedList: false
SpaceBeforeCtorInitializerColon: true
SpaceBeforeInheritanceColon: true
SpaceBeforeParens: ControlStatements
SpaceBeforeRangeBasedForLoopColon: true
SpaceInEmptyBlock: false
SpaceInEmptyParentheses: false
SpacesBeforeTrailingComments: 1
SpacesInAngles:  true
SpacesInConditionalStatement: true
SpacesInContainerLiterals: true
SpacesInCStyleCastParentheses: false
SpacesInParentheses: true
SpacesInSquareBrackets: true
SpaceBeforeSquareBrackets: false
Standard:        Latest
StatementMacros:
  - Q_UNUSED
  - QT_REQUIRE_VERSION
TabWidth:        8
UseCRLF:         false
UseTab:          Never
