[PATCH rtems-net-legacy v2] Remove RTEMS_NETWORKING checks
Gedare Bloom
gedare at rtems.org
Mon Apr 5 16:32:54 UTC 2021
On Sat, Apr 3, 2021 at 2:13 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> On Sat, Apr 3, 2021 at 12:27 PM Gedare Bloom <gedare at rtems.org> wrote:
> > On Fri, Apr 2, 2021 at 7:32 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > > * Remove nfsclient wscript and build from netlegacy.py
> > These two different changes probably should have been two different
> > patches? I barely even noticed the nfsclient change, since it isn't
> > reflected in the first line of the commit subject, so it is harder to
> > spot. I think split them in two if that is ok.
> Thanks. I'll split them into 2 different patches.
> > > bsps/powerpc/mpc55xxevb/net/smsc9218i.c | 4 +--
> > > libmisc/dummy-networking.c | 44 ++++++++++++-------------
> > > netlegacy.py | 18 +++++++++-
> > > nfsclient/wscript | 1 +
> > > telnetd/telnetd.c | 4 ---
> > > wscript | 2 +-
> > > 6 files changed, 42 insertions(+), 31 deletions(-)
> > > diff --git a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
> > > index d88aa8a..384f9cd 100644
> > > --- a/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
> > > +++ b/bsps/powerpc/mpc55xxevb/net/smsc9218i.c
> > > @@ -24,7 +24,7 @@
> > > #include <mpc55xx/regs.h>
> > > -#if defined(RTEMS_NETWORKING) && defined(MPC55XX_HAS_SIU)
> > > +#if defined(MPC55XX_HAS_SIU)
> > > #include <machine/rtems-bsd-kernel-space.h>
> > > @@ -2121,4 +2121,4 @@ int smsc9218i_attach_detach(
> > > return 0;
> > > -#endif /* defined(RTEMS_NETWORKING) && defined(MPC55XX_HAS_SIU) */
> > > +#endif /* defined(MPC55XX_HAS_SIU) */
> > > diff --git a/libmisc/dummy-networking.c b/libmisc/dummy-networking.c
> > > index 379e23e..b7f15c8 100644
> > > --- a/libmisc/dummy-networking.c
> > > +++ b/libmisc/dummy-networking.c
> > > @@ -16,27 +16,25 @@
> > > #include <rtems.h>
> > > /* Loopback Network Configuration */
> > > - #include <rtems/rtems_bsdnet.h>
> > > - #include <sys/socket.h>
> > > - #include <netinet/in.h>
> > > +#include <rtems/rtems_bsdnet.h>
> > > +#include <sys/socket.h>
> > > +#include <netinet/in.h>
> > > - struct rtems_bsdnet_config rtems_bsdnet_config = {
> > > - NULL, /* Network interface */
> > > - NULL, /* Use fixed network configuration */
> > > - 0, /* Default network task priority */
> > > - 0, /* Default mbuf capacity */
> > > - 0, /* Default mbuf cluster capacity */
> > > - "testSystem", /* Host name */
> > > - "nowhere.com", /* Domain name */
> > > - "127.0.0.1", /* Gateway */
> > > - "127.0.0.1", /* Log host */
> > > - {"127.0.0.1" }, /* Name server(s) */
> > > - {"127.0.0.1" }, /* NTP server(s) */
> > > - 1, /* sb_efficiency */
> > > - 0, /* udp_tx_buf_size */
> > > - 0, /* udp_rx_buf_size */
> > > - 0, /* tcp_tx_buf_size */
> > > - 0 /* tcp_rx_buf_size */
> > > -#endif
> > > +struct rtems_bsdnet_config rtems_bsdnet_config = {
> > > + NULL, /* Network interface */
> > > + NULL, /* Use fixed network configuration */
> > > + 0, /* Default network task priority */
> > > + 0, /* Default mbuf capacity */
> > > + 0, /* Default mbuf cluster capacity */
> > > + "testSystem", /* Host name */
> > > + "nowhere.com", /* Domain name */
> > > + "127.0.0.1", /* Gateway */
> > > + "127.0.0.1", /* Log host */
> > > + {"127.0.0.1" }, /* Name server(s) */
> > > + {"127.0.0.1" }, /* NTP server(s) */
> > > + 1, /* sb_efficiency */
> > > + 0, /* udp_tx_buf_size */
> > > + 0, /* udp_rx_buf_size */
> > > + 0, /* tcp_tx_buf_size */
> > > + 0 /* tcp_rx_buf_size */
> > > diff --git a/netlegacy.py b/netlegacy.py
> > > index 0889548..85c523e 100644
> > > --- a/netlegacy.py
> > > +++ b/netlegacy.py
> > > @@ -54,6 +54,13 @@ def build(bld):
> > > for s in os.listdir('./pppd') if s[-2:] == '.c']
> > > telnetd_source = [os.path.join('./telnetd', s)
> > > for s in os.listdir('telnetd') if s[-2:] == '.c']
> > > + nfs_source = []
> > > + for root, dirs, files in os.walk('./nfsclient'):
> > > + for name in files:
> > > + ext = os.path.splitext(name)[1]
> > > + if ext == '.c':
> > > + src_root = os.path.split(root)[1]
> > > + nfs_source.append(os.path.join('./nfsclient', src_root, name))
> > > bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
> > > @@ -66,6 +73,7 @@ def build(bld):
> > > './bsps/include'])
> > > arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> > > bld.env.RTEMS_ARCH_BSP)
> > > + lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
> > > include_path.append(os.path.relpath(os.path.join(bld.env.PREFIX,
> > > arch_lib_path)))
> > > @@ -73,6 +81,8 @@ def build(bld):
> > > 'include')))
> > > include_path.append('./bsps/include/libchip')
> > > + bld.read_stlib('rtemsbsp', paths=[lib_path])
> > > if bsp in bsp_dirs:
> > > include_path.extend(bsp_dirs[bsp])
> > > @@ -107,8 +117,14 @@ def build(bld):
> > > use='networking',
> > > source=telnetd_source)
> > > + bld.stlib(target='nfs',
> > > + features='c',
> > > + includes=ip,
> > > + use=['rtemsbsp', 'networking'],
> > > + source=nfs_source)
> > > bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> > > - ["libnetworking.a", 'libpppd.a', 'libtelnetd.a'])
> > > + ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
> > > bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
> > > 'include', 'libchip'),
> > > [os.path.join('./bsps/include/libchip/', f)
> > > diff --git a/nfsclient/wscript b/nfsclient/wscript
> > > index bc2f994..c0fe420 100644
> > > --- a/nfsclient/wscript
> > > +++ b/nfsclient/wscript
> > > @@ -52,5 +52,6 @@ def build(bld):
> > > features='c',
> > > cflags=['-O2', '-g'],
> > > includes=include_path,
> > > + use=['networking'],
> > > source=source_files)
> > > bld.install_files(os.path.join('${PREFIX}', arch_lib_path), ['libnfs.a'])
> > > diff --git a/telnetd/telnetd.c b/telnetd/telnetd.c
> > > index b8adec2..3d401ff 100644
> > > --- a/telnetd/telnetd.c
> > > +++ b/telnetd/telnetd.c
> > > @@ -58,9 +58,7 @@
> > > #include <rtems/thread.h>
> > > #include <rtems/userenv.h>
> > > -#ifdef RTEMS_NETWORKING
> > > -#endif
> > > #define TELNETD_EVENT_SUCCESS RTEMS_EVENT_0
> > > @@ -401,11 +399,9 @@ rtems_status_code rtems_telnetd_start(const rtems_telnetd_config_table* config)
> > > LIST_INIT(&ctx->free_sessions);
> > > /* Check priority */
> > > if (ctx->config.priority == 0) {
> > > ctx->config.priority = rtems_bsdnet_config.network_task_priority;
> > > -#endif
> > Is this (and the header above) the only difference between the legacy
> > network stack implementation for telnetd and the libbsd one? If so, it
> > seems they could be shared easily, and it might be good to keep track
> > of where they differ.
> Yes, this is the only difference. The only small issue would be the lack of RTEMS_NETWORKING macro, making it difficult to keep it in RTEMS, so I just removed these lines and proposed a patch to add that version to libbsd:
> https://lists.rtems.org/pipermail/devel/2021-March/065872.html
ok. I'm not a fan of having duplicated code in multiple of our repos,
but since legacy stack is heading toward maintenance-only mode, I
think this is fine--if no one else complains :)
> I will send a v3 of this and another patch for nfsclient.
> > > ctx->config.priority = 100;
> > > diff --git a/wscript b/wscript
> > > index 07f774d..7af317d 100644
> > > --- a/wscript
> > > +++ b/wscript
> > > @@ -33,7 +33,7 @@ import sys
> > > top = '.'
> > > rtems_version = "6"
> > > -subdirs = ['nfsclient', 'testsuites']
> > > +subdirs = ['testsuites']
> > > try:
> > > import rtems_waf.rtems as rtems
> > > 2.26.2
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
