[PATCH 3/4] fastlz.c: Unused value (CID #1399751)
Ryan Long
ryan.long at oarcorp.com
Mon Apr 5 19:37:52 UTC 2021
CID 1399751: Unused value in fastlz2_compress().
Closes #4341
cpukit/libdl/fastlz.c | 10 +++++++++-
1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/cpukit/libdl/fastlz.c b/cpukit/libdl/fastlz.c
index 3c9d6f6..7257c98 100644
--- a/cpukit/libdl/fastlz.c
+++ b/cpukit/libdl/fastlz.c
@@ -219,7 +219,15 @@ static FASTLZ_INLINE int FASTLZ_COMPRESSOR(const void* input, int length, void*
if(ip[0] == ip[-1] && FASTLZ_READU16(ip-1)==FASTLZ_READU16(ip+1))
distance = 1;
- ip += 3;
+ #ifndef __rtems__
+ * ip is assigned a value here, but is immediately assigned another
+ * value when it goes to match (line 269). The value that was initially
+ * assigned is not used, and this results in a Coverity issue. See CID
+ * 1399751
+ ip += 3;
+ #endif
ref = anchor - 1 + 3;
goto match;
1.8.3.1
