[rtems5 PATCH 0/5] Backport zynq SPI drivers to rtems5
Jan.Sommer at dlr.de
Tue Apr 6 13:20:43 UTC 2021
> -----Original Message-----
> From: Chris Johns <chrisj at rtems.org>
> Sent: Thursday, April 1, 2021 2:15 AM
> To: Sommer, Jan <Jan.Sommer at dlr.de>; devel at rtems.org
> Subject: Re: [rtems5 PATCH 0/5] Backport zynq SPI drivers to rtems5
> Hi Jan,
> This looks good. Has this been tested on zync hardware? If no then some
> testing is needed and if yes then please push.
Yes, I tested it this morning on a Zynq device and pushed.
Best regards,
Jan
> Thanks
> Chris
> On 31/3/21 8:06 pm, Jan Sommer wrote:
> > This patchset backports:
> > - The cadence SPI driver (see: https://devel.rtems.org/ticket/4369)
> > - The xilinx axi SPI driver (see: https://devel.rtems.org/ticket/4370)
> > - The i2c and spi shell commands (see:
> > https://devel.rtems.org/ticket/4371)
> > For the SPI drivers I didn't change any code (except the include
> > paths) I put them in bsps/arm/shared instead of bsps/shared, since
> > rtems5 has no aarch64 BSPs which could use them.
> > From Christian's commit I only stripped the part for the waf build
> > system. I found the commands quite handy during driver development and
> > testing.
> > Best regards,
> > Jan
> > Christian Mauderer (1):
> > shell: Add i2c and spi commands
> > Jan Sommer (4):
> > bsps/xilinx_zynq: Add SPI driver for cadence-spi
> > bsps/xilinx_zynq: Add cadence SPI driver to build system
> > bsps/xilinx_zynq: Add SPI driver for xilinx-axi-spi
> > bsps/xilinx_zynq: Add Xilinx AXI SPI driver to build
> > bsps/arm/headers.am | 4 +
> > bsps/arm/include/bsp/cadence-spi-regs.h | 84 ++++
> > bsps/arm/include/bsp/cadence-spi.h | 63 +++
> > bsps/arm/include/bsp/xilinx-axi-spi-regs.h | 88 ++++
> > bsps/arm/include/bsp/xilinx-axi-spi.h | 67 +++
> > bsps/arm/shared/spi/cadence-spi.c | 444 ++++++++++++++++++
> > bsps/arm/shared/spi/xilinx-axi-spi.c | 402 ++++++++++++++++
> > c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 4 +
> > .../lib/libbsp/arm/xilinx-zynqmp/Makefile.am | 4 +
> > cpukit/Makefile.am | 4 +
> > cpukit/include/rtems/shellconfig.h | 28 ++
> > cpukit/libmisc/shell/main_i2cdetect.c | 107 +++++
> > cpukit/libmisc/shell/main_i2cget.c | 145 ++++++
> > cpukit/libmisc/shell/main_i2cset.c | 124 +++++
> > cpukit/libmisc/shell/main_spi.c | 157 +++++++
> > 15 files changed, 1725 insertions(+)
> > create mode 100644 bsps/arm/include/bsp/cadence-spi-regs.h
> > create mode 100644 bsps/arm/include/bsp/cadence-spi.h
> > create mode 100644 bsps/arm/include/bsp/xilinx-axi-spi-regs.h
> > create mode 100644 bsps/arm/include/bsp/xilinx-axi-spi.h
> > create mode 100644 bsps/arm/shared/spi/cadence-spi.c create mode
> > 100644 bsps/arm/shared/spi/xilinx-axi-spi.c
> > create mode 100644 cpukit/libmisc/shell/main_i2cdetect.c
> > create mode 100644 cpukit/libmisc/shell/main_i2cget.c
> > create mode 100644 cpukit/libmisc/shell/main_i2cset.c
> > create mode 100644 cpukit/libmisc/shell/main_spi.c
