[PATCH] covoar: Use range-based for loops in ReportsBase
Wed Apr 7 15:07:18 UTC 2021
looks good to me
On Tue, Apr 6, 2021 at 4:37 PM Alex White <alex.white at oarcorp.com> wrote:
> Some of the loops in the ReportsBase::Write* methods contained both
> regular and range-based for loops. This changes them to use only range-
> based for loops.
> Closes #4374
>  tester/covoar/Explanations.cc |  2 +-
>  tester/covoar/Explanations.h  |  2 +-
>  tester/covoar/ReportsBase.cc  | 87 ++++++++++++++---------------------
>  tester/covoar/ReportsBase.h   | 12 ++---
>  tester/covoar/ReportsHtml.cc  | 54 +++++++++++-----------
>  tester/covoar/ReportsHtml.h   |  6 +--
>  tester/covoar/ReportsText.cc  | 38 +++++++--------
>  tester/covoar/ReportsText.h   |  6 +--
>  8 files changed, 95 insertions(+), 112 deletions(-)
> diff --git a/tester/covoar/Explanations.cc b/tester/covoar/Explanations.cc
> index 2050b84..7b0f95a 100644
> --- a/tester/covoar/Explanations.cc
> +++ b/tester/covoar/Explanations.cc
> @@ -115,7 +115,7 @@ done:
>    const Explanation *Explanations::lookupExplanation(
> -    std::string& start
> +    const std::string& start
>      if (set.find( start ) == set.end()) {
> diff --git a/tester/covoar/Explanations.h b/tester/covoar/Explanations.h
> index ce0e4d4..de0c051 100644
> --- a/tester/covoar/Explanations.h
> +++ b/tester/covoar/Explanations.h
> @@ -99,7 +99,7 @@ namespace Coverage {
>       *             which to search
>      const Explanation *lookupExplanation(
> diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
> index fea776c..d904f8d 100644
> --- a/tester/covoar/ReportsBase.cc
> +++ b/tester/covoar/ReportsBase.cc
> @@ -197,15 +197,12 @@ std::string expand_tabs(const std::string& in) {
>  void ReportsBase::WriteAnnotatedReport(
>    const char* const fileName
> -  FILE*                                                          aFile = NULL;
> -  Coverage::CoverageRanges*                                      theBranches;
> -  Coverage::CoverageRanges*                                      theRanges;
> -  Coverage::CoverageMapBase*                                     theCoverageMap = NULL;
> -  uint32_t                                                       bAddress = 0;
> -  AnnotatedLineState_t                                           state;
> -  const std::list<Coverage::ObjdumpProcessor::objdumpLine_t>*    theInstructions;
> -  std::list<
> -    Coverage::ObjdumpProcessor::objdumpLine_t>::const_iterator   itr;
> +  FILE*                      aFile = NULL;
> +  Coverage::CoverageRanges*  theBranches;
> +  Coverage::CoverageRanges*  theRanges;
> +  Coverage::CoverageMapBase* theCoverageMap = NULL;
> +  uint32_t                   bAddress = 0;
> +  AnnotatedLineState_t       state;
>    aFile = OpenAnnotatedFile(fileName);
>    if (!aFile)
> @@ -231,16 +228,12 @@ void ReportsBase::WriteAnnotatedReport(
>      theCoverageMap = info.unifiedCoverageMap;
>      bAddress = info.baseAddress;
> -    theInstructions = &(info.instructions);
>      theRanges = info.uncoveredRanges;
>      theBranches = info.uncoveredBranches;
>      // Add annotations to each line where necessary
>      AnnotatedStart( aFile );
> -    for (itr = theInstructions->begin();
> -         itr != theInstructions->end();
> -         itr++ ) {
> +    for (const auto& instruction : info.instructions) {
>        uint32_t           id = 0;
>        std::string        annotation = "";
>        std::string        line;
> @@ -249,17 +242,19 @@ void ReportsBase::WriteAnnotatedReport(
>        state = A_SOURCE;
> -      if ( itr->isInstruction ) {
> -        if (!theCoverageMap->wasExecuted( itr->address - bAddress )){
> +      if ( instruction.isInstruction ) {
> +        if (!theCoverageMap->wasExecuted( instruction.address - bAddress )){
>            annotation = "<== NOT EXECUTED";
>            state = A_NEVER_EXECUTED;
> -          id = theRanges->getId( itr->address );
> -        } else if (theCoverageMap->isBranch( itr->address - bAddress )) {
> -          id = theBranches->getId( itr->address );
> -          if (theCoverageMap->wasAlwaysTaken( itr->address - bAddress )){
> +          id = theRanges->getId( instruction.address );
> +        } else if (theCoverageMap->isBranch( instruction.address - bAddress )) {
> +          id = theBranches->getId( instruction.address );
> +          if (theCoverageMap->wasAlwaysTaken( instruction.address - bAddress )){
>              annotation = "<== ALWAYS TAKEN";
>              state = A_BRANCH_TAKEN;
> -          } else if (theCoverageMap->wasNeverTaken( itr->address - bAddress )){
> +          } else if (
> +            theCoverageMap->wasNeverTaken( instruction.address - bAddress )
>              annotation = "<== NEVER TAKEN";
>              state = A_BRANCH_NOT_TAKEN;
> @@ -268,7 +263,7 @@ void ReportsBase::WriteAnnotatedReport(
> -      std::string textLineWithoutTabs = expand_tabs(itr->line);
> +      std::string textLineWithoutTabs = expand_tabs(instruction.line);
>        snprintf( textLine, LINE_LENGTH, "%-90s", textLineWithoutTabs.c_str() );
>        line = textLine + annotation;
> @@ -287,11 +282,10 @@ void ReportsBase::WriteAnnotatedReport(
>  void ReportsBase::WriteBranchReport(
> -  FILE*                                           report = NULL;
> -  Coverage::CoverageRanges::ranges_t::iterator    ritr;
> -  unsigned int                                    count;
> -  bool                                            hasBranches = true;
> +  FILE*                     report = NULL;
> +  unsigned int              count;
> +  bool                      hasBranches = true;
>    if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) == 0) ||
>        (BranchInfoAvailable == false) )
> @@ -315,12 +309,9 @@ void ReportsBase::WriteBranchReport(
>        if (theBranches && !theBranches->set.empty()) {
> -        for (ritr =  theBranches->set.begin() ;
> -             ritr != theBranches->set.end() ;
> -             ritr++ ) {
> +        for (const auto& range : theBranches->set) {
>            count++;
> -          PutBranchEntry( report, count, symbol, info, ritr );
> +          PutBranchEntry( report, count, symbol, info, range );
> @@ -336,12 +327,11 @@ void ReportsBase::WriteCoverageReport(
> -  FILE*                                           report;
> -  FILE*                                           NoRangeFile;
> -  std::string                                     NoRangeName;
> +  FILE*                     report;
> +  FILE*                     NoRangeFile;
> +  std::string               NoRangeName;
>    // Open special file that captures NoRange informaiton
>    NoRangeName = "no_range_";
> @@ -374,11 +364,8 @@ void ReportsBase::WriteCoverageReport(
>        putCoverageNoRange( report, NoRangeFile, count, symbol );
>        count++;
>      }  else if (!theRanges->set.empty()) {
> -      for (ritr =  theRanges->set.begin() ;
> -           ritr != theRanges->set.end() ;
> -           ritr++ ) {
> -        PutCoverageLine( report, count, symbol, info, ritr );
> +      for (const auto& range : theRanges->set) {
> +        PutCoverageLine( report, count, symbol, info, range );
>          count++;
> @@ -396,10 +383,9 @@ void ReportsBase::WriteSizeReport(
> -  FILE*                                           report;
> +  FILE*                     report;
>    // Open the report file.
>    report = OpenSizeFile( fileName );
> @@ -417,11 +403,8 @@ void ReportsBase::WriteSizeReport(
>      if (theRanges && !theRanges->set.empty()) {
> -           ritr++ ) {
> -        PutSizeLine( report, count, symbol, ritr );
> +        PutSizeLine( report, count, symbol, range );
>          count++;
> diff --git a/tester/covoar/ReportsBase.h b/tester/covoar/ReportsBase.h
> index 5eff76c..ab8f8dd 100644
> --- a/tester/covoar/ReportsBase.h
> +++ b/tester/covoar/ReportsBase.h
> @@ -328,14 +328,14 @@ class ReportsBase {
>       *  @param[in] number identifies the line number.
>       *  @param[in] symbolName is the symbol's name.
>       *  @param[in] symbolInfo is the symbol's information.
> -     *  @param[in] rangePtr is a pointer to the range information.
> +     *  @param[in] range is the range information.
>      virtual bool PutBranchEntry(
>        FILE*                                            report,
>        unsigned int                                     number,
>        const std::string&                               symbolName,
>        const SymbolInformation&                         symbolInfo,
> -      Coverage::CoverageRanges::ranges_t::iterator     rangePtr
> +      const CoverageRanges::coverageRange_t&           range
>      )=0;
> @@ -360,14 +360,14 @@ class ReportsBase {
> -     *  @param[in] ritr is a iterator to the range information.
>      virtual bool PutCoverageLine(
>        FILE*                                           report,
>      )=0;
> @@ -376,13 +376,13 @@ class ReportsBase {
>       *  @param[in] report identifies the size report file name
> -     *  @param[in] range is a iterator to the range information.
>      virtual bool PutSizeLine(
>        FILE*                                           report,
>      )=0;
> diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
> index fa1ebf6..fe75cdd 100644
> --- a/tester/covoar/ReportsHtml.cc
> +++ b/tester/covoar/ReportsHtml.cc
> @@ -501,7 +501,7 @@ namespace Coverage {
>      unsigned int                                     count,
>      const Coverage::Explanation* explanation;
> @@ -528,13 +528,13 @@ namespace Coverage {
>      fprintf(
>        report,
>        "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s</td>\n",
> -      rangePtr->id,
> -      rangePtr->lowSourceLine.c_str()
> +      range.id,
> +      range.lowSourceLine.c_str()
>      // File
> -    i = rangePtr->lowSourceLine.find(":");
> -    temp =  rangePtr->lowSourceLine.substr (0, i);
> +    i = range.lowSourceLine.find(":");
> +    temp =  range.lowSourceLine.substr (0, i);
>      fprintf(
>        report,
>        "<td class=\"covoar-td\" align=\"center\">%s</td>\n",
> @@ -545,17 +545,17 @@ namespace Coverage {
>      fprintf(
>        report,
>        "<td class=\"covoar-td\" align=\"center\">%d</td>\n",
> -      rangePtr->highAddress - rangePtr->lowAddress + 1
> +      range.highAddress - range.lowAddress + 1
>      // Reason Branch was uncovered
> -    if (rangePtr->reason ==
> +    if (range.reason ==
>        Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN)
>        fprintf(
>          report,
>          "<td class=\"covoar-td\" align=\"center\">Always Taken</td>\n"
> -    else if (rangePtr->reason ==
> +    else if (range.reason ==
>        Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN)
>        fprintf(
>          report,
> @@ -563,7 +563,7 @@ namespace Coverage {
>      // Taken / Not taken counts
> -    lowAddress = rangePtr->lowAddress;
> +    lowAddress = range.lowAddress;
>      bAddress = symbolInfo.baseAddress;
>      theCoverageMap = symbolInfo.unifiedCoverageMap;
>      fprintf(
> @@ -579,7 +579,7 @@ namespace Coverage {
>      // See if an explanation is available and write the Classification and
>      // the Explination Columns.
> -    explanation = AllExplanations->lookupExplanation( rangePtr->lowSourceLine );
> +    explanation = AllExplanations->lookupExplanation( range.lowSourceLine );
>      if ( !explanation ) {
>        // Write Classificationditr->second.baseAddress
>        fprintf(
> @@ -589,7 +589,7 @@ namespace Coverage {
>      } else {
>        char explanationFile[48];
> -      sprintf( explanationFile, "explanation%d.html", rangePtr->id );
> +      sprintf( explanationFile, "explanation%d.html", range.id );
>        fprintf(
>          report,
> @@ -707,7 +707,7 @@ namespace Coverage {
>      unsigned int                                     count,
> @@ -731,14 +731,14 @@ namespace Coverage {
>      fprintf(
>        report,
>        "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s <br>%s</td>\n",
> -      rangePtr->id,
> -      rangePtr->lowSourceLine.c_str(),
> -      rangePtr->highSourceLine.c_str()
> +      range.id,
> +      range.lowSourceLine.c_str(),
> +      range.highSourceLine.c_str()
>      // File
>      fprintf(
>        report,
> @@ -749,18 +749,18 @@ namespace Coverage {
>      fprintf(
>        report,
>      // Size in instructions
>      fprintf(
>        report,
> -      rangePtr->instructionCount
> +      range.instructionCount
>        fprintf(
>          report,
> @@ -773,7 +773,7 @@ namespace Coverage {
>      } else {
>        fprintf(
>          report,
> @@ -794,7 +794,7 @@ namespace Coverage {
>      FILE*                                           report,
>      unsigned int                                    count,
>      std::string  temp;
> @@ -810,7 +810,7 @@ namespace Coverage {
>      fprintf(
>        report,
> -      range->highAddress - range->lowAddress + 1
>      // symbol
> @@ -824,13 +824,13 @@ namespace Coverage {
>      fprintf(
>        report,
> -      range->id,
> -      range->lowSourceLine.c_str()
> +      range.id,
>      // File
> -    i = range->lowSourceLine.find(":");
> -    temp =  range->lowSourceLine.substr (0, i);
>      fprintf(
>        report,
> diff --git a/tester/covoar/ReportsHtml.h b/tester/covoar/ReportsHtml.h
> index 60c5dc8..8d209ae 100644
> --- a/tester/covoar/ReportsHtml.h
> +++ b/tester/covoar/ReportsHtml.h
> @@ -165,7 +165,7 @@ class ReportsHtml: public ReportsBase {
>      /* Inherit documentation from base class. */
> @@ -182,7 +182,7 @@ class ReportsHtml: public ReportsBase {
> @@ -190,7 +190,7 @@ class ReportsHtml: public ReportsBase {
>        FILE*                                           report,
> diff --git a/tester/covoar/ReportsText.cc b/tester/covoar/ReportsText.cc
> index f56580a..33be32f 100644
> --- a/tester/covoar/ReportsText.cc
> +++ b/tester/covoar/ReportsText.cc
> @@ -66,7 +66,7 @@ bool ReportsText::PutBranchEntry(
> @@ -80,22 +80,22 @@ bool ReportsText::PutBranchEntry(
>      "Size in Bytes : %d\n",
>      symbolName.c_str(),
>      symbolInfo.baseAddress,
> -    rangePtr->lowAddress,
> +    range.lowAddress,
>      fprintf(
>        report, "Reason        : %s\n\n", "ALWAYS TAKEN"
>      fprintf( report, "Reason        : %s\n\n", "NEVER TAKEN" );
>      fprintf(
> @@ -159,7 +159,7 @@ bool ReportsText::PutCoverageLine(
> @@ -173,18 +173,18 @@ bool ReportsText::PutCoverageLine(
>      "Ending Line          : %s (0x%x)\n"
>      "Size in Instructions : %d\n\n",
> -    ritr->id,
> +    range.id,
>      symbolName.c_str(),
> -    ritr->lowSourceLine.c_str(),
> -    ritr->lowAddress,
> -    ritr->highSourceLine.c_str(),
> -    ritr->highAddress,
> -    ritr->highAddress - ritr->lowAddress + 1,
> -    ritr->instructionCount
> +    range.lowAddress,
> +    range.highSourceLine.c_str(),
> +    range.highAddress,
> +    range.highAddress - range.lowAddress + 1,
> -  explanation = AllExplanations->lookupExplanation( ritr->lowSourceLine );
>      fprintf(
> @@ -216,15 +216,15 @@ bool  ReportsText::PutSizeLine(
>    FILE*                                           report,
>    fprintf(
>      report,
>      "%d\t%s\t%s\n",
> -    range->highAddress - range->lowAddress + 1,
>      symbolName.c_str(),
>    return true;
> diff --git a/tester/covoar/ReportsText.h b/tester/covoar/ReportsText.h
> index 91366b5..23a1003 100644
> --- a/tester/covoar/ReportsText.h
> +++ b/tester/covoar/ReportsText.h
> @@ -85,7 +85,7 @@ class ReportsText: public ReportsBase {
> @@ -102,7 +102,7 @@ class ReportsText: public ReportsBase {
> @@ -110,7 +110,7 @@ class ReportsText: public ReportsBase {
>        FILE*                                           report,
> 2.27.0
> devel mailing list
> devel at rtems.org
