[PATCH] covoar: Fix NULL check of wrong variable
Alex White
alex.white at oarcorp.com
Wed Apr 7 15:37:35 UTC 2021
In Explanations::writeNotFound() there were two NULL checks of the
`fileName` variable where only one is needed. The second check has been
changed to a NULL check of `notFoundFile` to match the original intent.
Closes #4377
tester/covoar/Explanations.cc | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/tester/covoar/Explanations.cc b/tester/covoar/Explanations.cc
index 7b0f95a..12bd809 100644
--- a/tester/covoar/Explanations.cc
+++ b/tester/covoar/Explanations.cc
@@ -140,10 +140,10 @@ done:
return;
notFoundFile = fopen( fileName, "w" );
- if (!fileName) {
+ if (notFoundFile == nullptr) {
std::ostringstream what;
what << "Unable to open " << fileName
- << "out of sync at the explanation";
+ << " out of sync at the explanation";
throw rld::error( what, "Explanations::writeNotFound" );
2.27.0
