[PATCH] posix-compliance: Update tracking spreadsheet to v12
Wed Apr 7 16:31:28 UTC 2021
On Wed, Apr 7, 2021, 11:25 AM Gedare Bloom <gedare at rtems.org> wrote:
> ok, but do you need to be replacing these versions or can you provide
> one version that you update?
> I guess, the modifications will be quite bad when you add new columns,
> but updating/adding rows would be much smaller changes? Just a
> thought.
It should be obvious that I am updating this externally using a spreadsheet
and just exporting CSV. I suppose we could always have the same name but I
would still need a way to know what version of the spreadsheet it came
from. But I guess that could be a short ASCII file in this directory.
Can I submit a follow up patch doing that? A rename will be a small patch.
> On Tue, Apr 6, 2021 at 5:28 PM Joel Sherrill <joel at rtems.org> wrote:
> > The new version of the API tracking spreadsheet includes FACE
> > Technical Standard, Edition 3.1 as well as a few additions to
> > what RTEMS supports. The generation script and discussion of
> > standards was updated to reflect the inclusion of a new Edition
> > of the FACE Technical Standard.
> > Closes #4380.
> >  .../RTEMS-Standards-Compliance-v12.csv             | 1372
> >  posix-compliance/RTEMS-Standards-Compliance-v9.csv | 1356
> >  posix-compliance/posix_rst.py                      |   12 +
> >  posix-compliance/standards.rst                     |   20 +-
> >  posix-compliance/wscript                           |    2 +-
> >  5 files changed, 1398 insertions(+), 1364 deletions(-)
> >  create mode 100755 posix-compliance/RTEMS-Standards-Compliance-v12.csv
> >  delete mode 100755 posix-compliance/RTEMS-Standards-Compliance-v9.csv
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210407/7b2657ce/attachment.html>
