[PATCH RTEMS] bsps/beagle: Refactored i2c driver
Christian MAUDERER christian.mauderer at embedded-brains.de
Thu Apr 8 06:24:50 UTC 2021
Hello Vijay and Niteesh,
Am 08.04.21 um 04:17 schrieb Vijay Kumar Banerjee:
> On Wed, Apr 7, 2021 at 7:56 PM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>> Hello Vijay,
>> On Sun, Mar 28, 2021 at 1:42 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>>> Hi Niteesh,
>>> Thanks for the patch. I have some questions below.
>>> On Mon, Mar 22, 2021 at 11:48 AM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
>>>> Refactored the i2c driver to parse register values from the device
>>>> tree rather than hardcoding them. But still the clocks have to
>>>> initialized manually.
>>>>   bsps/arm/beagle/i2c/bbb-i2c.c     | 100 ++++++++++++++++--------------
>>>>   bsps/arm/beagle/include/bsp.h     |   4 ++
>>>>   bsps/arm/beagle/include/bsp/i2c.h |  32 +---------
>>>>   bsps/arm/beagle/start/bspstart.c  |  53 +++++++++++-----
>>>>   4 files changed, 96 insertions(+), 93 deletions(-)
>>>> diff --git a/bsps/arm/beagle/i2c/bbb-i2c.c b/bsps/arm/beagle/i2c/bbb-i2c.c
>>>> index b2a7cf814d..c315b6fc3b 100644
>>>> --- a/bsps/arm/beagle/i2c/bbb-i2c.c
>>>> +++ b/bsps/arm/beagle/i2c/bbb-i2c.c
>>>> @@ -25,6 +25,7 @@
>>>>   #include <bsp/bbb-gpio.h>
>>>>   #include <rtems/score/assert.h>
>>>>   #include <dev/i2c/i2c.h>
>>>> +#include <ofw/ofw.h>
>>>>   typedef struct bbb_i2c_bus {
>>>>     i2c_bus base;
>>>> @@ -34,12 +35,6 @@ typedef struct bbb_i2c_bus {
>>>>       volatile uint32_t *i2c_clkctrl;
>>>>       volatile uint32_t *clkstctrl;
>>>>     } clkregs;
>>>> -  struct {
>>>> -    volatile uint32_t *conf_sda;
>>>> -    uint32_t mmode_sda;
>>>> -    volatile uint32_t *conf_scl;
>>>> -    uint32_t mmode_scl;
>>>> -  } pinregs;
>>>>     rtems_id task_id;
>>>>     rtems_vector_number irq;
>>>>     i2c_msg *buffer;
>>>> @@ -56,19 +51,29 @@ typedef struct bbb_i2c_bus {
>>>>   #else
>>>>   #define debug_print(fmt, args...)
>>>>   #endif
>>>> + * Here we assume the number of i2c nodes
>>>> + * will be less than 100.
>>>> +#define PATH_LEN strlen("/dev/i2c-xx")
>>>>   static int am335x_i2c_fill_registers(
>>>>     bbb_i2c_bus *bus,
>>>> -  uintptr_t register_base
>>>> +  phandle_t    node
>>>> -  /* FIXME: The pin handling should be replaced by a proper pin handling during
>>>> -   * initialization. This one is heavily board specific. */
>>>> -#if ! IS_AM335X
>>>> -  printk ("The I2C driver currently only works on Beagle Bone. Please add your pin configs.");
>>>> -  return EINVAL;
>>>> -#endif
>>>> -  bus->regs = (volatile bbb_i2c_regs *) register_base;
>>>> +  ssize_t rv;
>>>> +  rtems_ofw_memory_area reg;
>>>> +  rv = rtems_ofw_get_reg(node, &reg, sizeof(reg));
>>>> +  if (rv <= 0)
>>>> +    return EINVAL;
>>>> +  bus->regs = (volatile bbb_i2c_regs *)reg.start;
>>>> +   * FIXME: Implement a clock driver to parse and setup clocks
>>>>     switch ((intptr_t) bus->regs) {
>>>>     case AM335X_I2C0_BASE:
>>>>       bus->clkregs.ctrl_clkctrl = &REG(AM335X_SOC_CM_WKUP_REGS +
>>>> @@ -77,10 +82,6 @@ static int am335x_i2c_fill_registers(
>>>>                                    AM335X_CM_WKUP_I2C0_CLKCTRL);
>>>>       bus->clkregs.clkstctrl = &REG(AM335X_SOC_CM_WKUP_REGS +
>>>>                                      AM335X_CM_WKUP_CLKSTCTRL);
>>>> -    bus->pinregs.conf_sda = &REG(AM335X_PADCONF_BASE + AM335X_CONF_I2C0_SDA);
>>>> -    bus->pinregs.mmode_sda = 0;
>>>> -    bus->pinregs.conf_scl = &REG(AM335X_PADCONF_BASE + AM335X_CONF_I2C0_SCL);
>>>> -    bus->pinregs.mmode_scl = 0;
>>>>       break;
>>>>     case AM335X_I2C1_BASE:
>>>> @@ -88,10 +89,6 @@ static int am335x_i2c_fill_registers(
>>>>       bus->clkregs.i2c_clkctrl = &REG(AM335X_CM_PER_ADDR +
>>>>                                    AM335X_CM_PER_I2C1_CLKCTRL);
>>>>       bus->clkregs.clkstctrl = NULL;
>>>> -    bus->pinregs.conf_sda = &REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D1);
>>>> -    bus->pinregs.mmode_sda = 2;
>>>> -    bus->pinregs.conf_scl = &REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_CS0);
>>>> -    bus->pinregs.mmode_scl = 2;
>>>>       break;
>>>>     case AM335X_I2C2_BASE:
>>>> @@ -99,24 +96,12 @@ static int am335x_i2c_fill_registers(
>>>>                                    AM335X_CM_PER_I2C2_CLKCTRL);
>>>> -    bus->pinregs.conf_sda = &REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_CTSN);
>>>> -    bus->pinregs.mmode_sda = 3;
>>>> -    bus->pinregs.conf_scl = &REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RTSN);
>>>> -    bus->pinregs.mmode_scl = 3;
>>>>       break;
>>>>     default:
>>>>       return EINVAL;
>>>> -  return 0;
>>>> -static void am335x_i2c_pinmux( bbb_i2c_bus *bus )
>>>> -  *bus->pinregs.conf_sda =
>>>> -    ( BBB_RXACTIVE | BBB_SLEWCTRL | bus->pinregs.mmode_sda);
>>>> -  *bus->pinregs.conf_scl =
>>>> -    ( BBB_RXACTIVE | BBB_SLEWCTRL | bus->pinregs.mmode_scl);
>>>> +  return 0;
>>>>   static void am335x_i2c_module_clk_enable( bbb_i2c_bus *bus )
>>>> @@ -453,18 +438,16 @@ static void am335x_i2c_destroy( i2c_bus *base )
>>>>     i2c_bus_destroy_and_free( &bus->base );
>>>> -int am335x_i2c_bus_register(
>>>> -  const char         *bus_path,
>>>> -  uintptr_t           register_base,
>>>> -  uint32_t            input_clock,
>>>> -  rtems_vector_number irq
>>>> +static int am335x_i2c_bus_register(
>>>> +  phandle_t           node
>>> This is method can be used by the application to register i2c device, why is it being removed? It is also documented here: https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#id2
>>> If we really want to make it static, then it at least needs to be removed from the documentation. But I'm not sure if we want to make it static.
>> The registration of the devices will happen based on the device tree, if a user wants to add any device it is
>> expected from him to provide an overlay or enable the device node in the FDT. This removes the need for
>> registration functions.
>> https://devel.rtems.org/ticket/3784
>> https://lists.rtems.org/pipermail/devel/2019-August/027288.html
> Ok, thanks for the links. Please update the documentation accordingly.
>>>> -  bbb_i2c_bus      *bus;
>>>> -  rtems_status_code sc;
>>>> -  int               err;
>>>> -  (void) input_clock; /* FIXME: Unused. Left for compatibility. */
>>>> +  bbb_i2c_bus        *bus;
>>>> +  rtems_status_code   sc;
>>>> +  rtems_vector_number irq;
>>>> +  int                 err;
>>>> +  int                 unit;
>>>> +  char                bus_path[PATH_LEN];
>>>>     bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init( sizeof( *bus ) );
>>>> @@ -472,15 +455,24 @@ int am335x_i2c_bus_register(
>>>>       return -1;
>>>> +  unit = beagle_get_node_unit(node);
>>> How would a user register a custom path? Does it mean that the only way to register a custom path is through device tree?
>> Currently, one cannot, the bus path is determined based on the node index. This can be fixed by allowing the user to pass
>> the path in the device tree as you said.
>> something like
>> i2c0 {
>> rtems-bus-path = "/dev/i2c-eeprom"
>> If this is OK, I'll add this feature to the patch?
> Node index works and it would also be nice if you add an
> rtems-bus-path field for FDT. Please document that and make sure that
> it works based on node index even when the rtems-bus-path is absent.
Please follow the usual FDT conventions for the name. System or vendor
specific names are normally separated with a ','. For Example:
     linux,keymap
     ibm,opal-rtc
So in this case it should be a
     rtems,bus-path
or maybe
     rtems,device-path
or just
     rtems,path
I used the last one in the imxrt BSP.
>>>> +  snprintf(bus_path, PATH_LEN, "/dev/i2c-%d", unit);
>>> If suppose the unit is 99, I think it'll still return "/dev/i2c-9.
>>> Should this be PATH_LEN + 1 here (or +1 can be added in the macro definition itself) to accommodate the 2 digit unit?
>>>> +  err = rtems_ofw_get_interrupts(node, &irq, sizeof(irq));
>>> Can this be done from the application and then pass irq as an argument to am335x_i2c_bus_register, in order to keep the function signature same?
>> A similar approach to the bus path can be done here. Or if possible we can let the user reinitialize the IRQ at runtime
>> by calling something like beagle_i2c_set_irq()
> My concern was removing the am335x_* call, I think it's Ok since that
> would be removed. It'll be a more general approach.
>>>> +  if (err < 1) {
>>>> +    ( *bus->base.destroy )( &bus->base );
>>>> +    rtems_set_errno_and_return_minus_one( err );
>>>>     bus->irq = irq;
>>>> -  err = am335x_i2c_fill_registers(bus, register_base);
>>>> +  err = am335x_i2c_fill_registers(bus, node);
>>>>     if (err != 0) {
>>>> -  am335x_i2c_module_clk_enable(bus);
>>>> -  am335x_i2c_pinmux( bus );
>>>> +  am335x_i2c_module_clk_enable( bus );
>>>>     err = am335x_i2c_reset( bus );
>>>>     if (err != 0) {
>>>> @@ -506,3 +498,15 @@ int am335x_i2c_bus_register(
>>>>     return i2c_bus_register( &bus->base, bus_path );
>>>> +void beagle_i2c_init(phandle_t node)
>>> This is a nice wrapper and maybe you could add all the needed ofw calls here to get the values and then call am335x_i2c_bus_register. Please also document this function so that it also acts as a reference for someone on how to use the am335x_i2c_bus_register.
>> OK. I'll refactor and document this.
> Thanks.
>>>> +  int rv;
>>>> +  if (!rtems_ofw_is_node_compatible(node, "ti,omap4-i2c"))
>>>> +    return ;
>>>> +  rv = am335x_i2c_bus_register(node);
>>>> +  if (rv != 0)
>>>> +    printk("i2c: Could not register device (%d)\n", rv);
>>>> diff --git a/bsps/arm/beagle/include/bsp.h b/bsps/arm/beagle/include/bsp.h
>>>> index cb415fda89..80a9cc291d 100644
>>>> --- a/bsps/arm/beagle/include/bsp.h
>>>> +++ b/bsps/arm/beagle/include/bsp.h
>>>> @@ -49,6 +49,8 @@
>>>>   #include <libcpu/omap3.h>
>>>>   #include <libcpu/am335x.h>
>>>>   #define BSP_FEATURE_IRQ_EXTENSION
>>>>   /* UART base clock frequency */
>>>> @@ -68,6 +70,8 @@
>>>>   #define udelay(u) rtems_task_wake_after(1 + ((u)/rtems_configuration_get_microseconds_per_tick()))
>>>> +int beagle_get_node_unit(phandle_t node);
>>>>   /* Write a uint32_t value to a memory address. */
>>>>   static inline void
>>>>   write32(uint32_t address, uint32_t value)
>>>> diff --git a/bsps/arm/beagle/include/bsp/i2c.h b/bsps/arm/beagle/include/bsp/i2c.h
>>>> index 60f71194bf..d80b376fa0 100644
>>>> --- a/bsps/arm/beagle/include/bsp/i2c.h
>>>> +++ b/bsps/arm/beagle/include/bsp/i2c.h
>>>> @@ -26,6 +26,7 @@
>>>>   #include <rtems.h>
>>>>   #include <bsp.h>
>>>>   #ifdef __cplusplus
>>>>   extern "C" {
>>>> @@ -38,10 +39,6 @@ extern "C" {
>>>>   #define BBB_I2C_1_BUS_PATH "/dev/i2c-1"
>>>>   #define BBB_I2C_2_BUS_PATH "/dev/i2c-2"
>>>> -#define BBB_I2C0_IRQ 70
>>>> -#define BBB_I2C1_IRQ 71
>>>> -#define BBB_I2C2_IRQ 30
>>>>   typedef enum {
>>>>     I2C0,
>>>>     I2C1,
>>>> @@ -87,32 +84,7 @@ typedef struct i2c_regs {
>>>>     uint32_t BBB_I2C_SBLOCK;
>>>>   } bbb_i2c_regs;
>>>> -  uint32_t            input_clock, /* FIXME: Unused. Left for compatibility. */
>>>> -static inline int bbb_register_i2c_1( void )
>>> Instead of removing these wrappers, could you use these to register the i2c-1 or i2c-2 paths, just for compatibility reasons?
>> If we have these registration functions, we will have to remove the automatic initialization of the i2c driver during boot time right?
>> I am not sure of how can we have both user-based registration and Device Tree based registration at the same time.
>> As per this ticket, I think the goal is to remove these kinds of registration functions so that the user doesn't have to
>> worry about the number of devices or type of the board.
> The discussions and the tickets make it clear that these need to go.
> So this is Ok. Thanks for explaining.
Please add a
     Update #3784
line in the commit description to make it clear that the change belongs
to that ticket.
>>> Once again, thank you for working on the patch. The bbb-i2c does need refactoring to work with the update ofw changes.
>> Really sorry for the delay, I have been working with QEMU to participate in GSoC this year. And it is really hard to manage
>> between this and other academic activities.
> Thanks for the good work and good luck for your GSoC application.
+1
Best regards
Christian
>>> Best regards,
>>> Vijay
>>>> -  return am335x_i2c_bus_register(
>>>> -    BBB_I2C_1_BUS_PATH,
>>>> -    AM335X_I2C1_BASE,
>>>> -    I2C_BUS_CLOCK_DEFAULT,
>>>> -    BBB_I2C1_IRQ
>>>> -static inline int bbb_register_i2c_2( void )
>>>> -    BBB_I2C_2_BUS_PATH,
>>>> -    AM335X_I2C2_BASE,
>>>> -    BBB_I2C2_IRQ
>>>> +void beagle_i2c_init( phandle_t node );
>>>>   #ifdef __cplusplus
>>>> diff --git a/bsps/arm/beagle/start/bspstart.c b/bsps/arm/beagle/start/bspstart.c
>>>> index a0736294c9..d45eec9e92 100644
>>>> --- a/bsps/arm/beagle/start/bspstart.c
>>>> +++ b/bsps/arm/beagle/start/bspstart.c
>>>> @@ -22,9 +22,15 @@
>>>>   #include "bsp-soc-detect.h"
>>>>   #include <arm/ti/ti_pinmux.h>
>>>> +#include <bsp/i2c.h>
>>>> +#include <string.h>
>>>> +#include <stdlib.h>
>>>> +#include <ctype.h>
>>>>   #include "bspdebug.h"
>>>> +#define MIN(l,r) ((l) < (r) ? (l) : (r))
>>> Where is it used?
>> Used it during testing. Will be removed.
> :) Thanks
> Best regards,
> Vijay
>>>>   void bsp_start(void)
>>>>     const char *type;
>>>> @@ -70,6 +76,7 @@ static void traverse_fdt_nodes( phandle_t node )
>>>>        * Put all driver initialization functions here
>>>>       beagle_pinmux_init(node);
>>>> +    beagle_i2c_init(node);
>>>> @@ -80,24 +87,40 @@ static void bbb_drivers_initialize(void)
>>>>     traverse_fdt_nodes(node);
>>>> -static void bbb_i2c_0_initialize(void)
>>>> -  int err;
>>>> -  err = am335x_i2c_bus_register(BBB_I2C_0_BUS_PATH,
>>>> -                                AM335X_I2C0_BASE,
>>>> -                                BBB_I2C0_IRQ);
>>>> -  if (err != 0) {
>>>> -    printk("rtems i2c-0: Device could not be registered (%d)", err);
>>>> +  char name[30];
>>>> +  char prop[30];
>>>> +  char prop_val[30];
>>>> +  static int unit;
>>>> +  phandle_t aliases;
>>>> +  int rv;
>>>> +  int i;
>>>> +  rv = rtems_ofw_get_prop(node, "name", name, sizeof(name));
>>>> +  if (rv <= 0)
>>>> +    return unit++;
>>>> +  aliases = rtems_ofw_find_device("/aliases");
>>>> +  rv = rtems_ofw_next_prop(aliases, NULL, &prop[0], sizeof(prop));
>>>> +  while (rv > 0) {
>>>> +    rv = rtems_ofw_get_prop(aliases, prop, prop_val, sizeof(prop_val));
>>>> +    if (strstr(prop_val, name) != NULL) {
>>>> +      for (i = strlen(prop) - 1; i >= 0; i--) {
>>>> +        if (!isdigit(prop[i]))
>>>> +          break;
>>>> +      return strtol(&prop[i + 1], NULL, 10);
>>>> +    rv = rtems_ofw_next_prop(aliases, prop, prop, sizeof(prop));
>>>> -RTEMS_SYSINIT_ITEM(
>>>> -  bbb_i2c_0_initialize,
>>>> -  RTEMS_SYSINIT_LAST,
>>>> -  RTEMS_SYSINIT_ORDER_LAST_BUT_5
>>>> +  return unit++;
>>>>   RTEMS_SYSINIT_ITEM(
>>>>          bbb_drivers_initialize,
>>>> 2.17.1
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
