[PATCH] powerpc/shared/console: Make console baud rate configurable.
dufault at hda.com dufault at hda.com
Fri Apr 9 15:55:49 UTC 2021
> On Apr 9, 2021, at 11:53 , Peter Dufault <dufault at hda.com> wrote:
> The "powerpc/shared/console" code has the start-up console value fixed
> at 9600 baud.  This changes the hard-wired constant "9600" in the code
> to the configuration setting "BSP_CONSOLE_BAUD" and adds configuration
> support in both the "waf" and the legacy configuration systems.
> Note that the VME BSPs beatnik, mvme3100, and mve5100 can be improved
> by adding a "mvmexxxx" BSP family. This configuration change, as well
> as future configuration changes, could then be made in a "grp.yml" file.
My first "git format-patch" for RTEMS, sent using an Apple mailer yet.  I hope it's OK.
I've made a resolution to get my local changes back ASAP.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210409/f095dac8/attachment.bin>
