[PATCH] score/aarch64: Align context validation frame
Mon Apr 12 18:51:09 UTC 2021
On Fri, Apr 9, 2021 at 4:34 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Ensure the stack remains aligned when validating the context frame to
> avoid stack alignment exceptions.
the commit message is a little vague,
>  .../cpu/aarch64/aarch64-context-validate.S     | 18 +++++++++---------
>  1 file changed, 9 insertions(+), 9 deletions(-)
> diff --git a/cpukit/score/cpu/aarch64/aarch64-context-validate.S b/cpukit/score/cpu/aarch64/aarch64-context-validate.S
> index 57f634934b..fb4fbd6379 100644
> --- a/cpukit/score/cpu/aarch64/aarch64-context-validate.S
> +++ b/cpukit/score/cpu/aarch64/aarch64-context-validate.S
> @@ -54,18 +54,18 @@
>  #define FRAME_OFFSET_LR  0x40
>  #ifdef AARCH64_MULTILIB_VFP
> -  #define FRAME_OFFSET_V8  0x48
> -  #define FRAME_OFFSET_V9  0x58
> -  #define FRAME_OFFSET_V10 0x68
> -  #define FRAME_OFFSET_V11 0x78
> -  #define FRAME_OFFSET_V12 0x88
> -  #define FRAME_OFFSET_V13 0x98
> -  #define FRAME_OFFSET_V14 0xA8
> -  #define FRAME_OFFSET_V15 0xB8
> +  #define FRAME_OFFSET_V8  0x50
if this has an adjustment because of alignment, then a comment should
be included. If someone changes something earlier in the structure
(unlikely, but still) that would make a problem here if the alignment
padding changes from 2B to something else.
> +  #define FRAME_OFFSET_V9  0x60
> +  #define FRAME_OFFSET_V10 0x70
> +  #define FRAME_OFFSET_V11 0x80
> +  #define FRAME_OFFSET_V12 0x90
> +  #define FRAME_OFFSET_V13 0xA0
> +  #define FRAME_OFFSET_V14 0xB0
> +  #define FRAME_OFFSET_V15 0xC0
>    #define FRAME_SIZE (FRAME_OFFSET_V15 + 0x10)
>  #else
> -  #define FRAME_SIZE (FRAME_OFFSET_LR + 0x08)
> +  #define FRAME_SIZE (FRAME_OFFSET_LR + 0x10)
>  #endif
>         .section        .text
> 2.20.1
> devel mailing list
> devel at rtems.org
