[PATCH v2] c-user: Add scheduler glossary terms
Sebastian Huber
Tue Apr 13 07:31:02 UTC 2021
Add glossary terms which characterize the relationship of a scheduler to
a task.
v2:
Address review comments. Use "foreign" instead of "alien".
c-user/glossary.rst | 24 ++++++++++++++++++++++++
1 file changed, 24 insertions(+)
diff --git a/c-user/glossary.rst b/c-user/glossary.rst
index 4e375de..0350033 100644
--- a/c-user/glossary.rst
+++ b/c-user/glossary.rst
@@ -240,6 +240,10 @@ Glossary
This term is an acronym for
`Executable and Linkable Format <https://en.wikipedia.org/wiki/Executable_and_Linkable_Format>`_.
+ eligible scheduler
+ An eligible scheduler of a :term:`task` is a :term:`scheduler` which can be
+ used by the task to allocate a processor for the task.
embedded
An application that is delivered as a hidden part of a larger system.
For example, the software in a fuel-injection control system is an
@@ -301,6 +305,10 @@ Glossary
mathematically intensive situations. It is typically viewed as a logical
extension of the primary processor.
+ foreign scheduler
+ An foreign scheduler of a :term:`task` is a :term:`scheduler` which is not
+ an :term:`eligible scheduler`.
freed
A resource that has been released by the application to RTEMS.
@@ -340,9 +348,20 @@ Glossary
dispatch is marked as necessary, then the next thread dispatch will make
the heir task the executing task.
+ helping scheduler
+ A helping scheduler of a :term:`task` is a :term:`scheduler` which is a
+ :term:`eligible scheduler` and which is not the :term:`home scheduler` of
+ the task.
heterogeneous
A multiprocessor computer system composed of dissimilar processors.
+ home scheduler
+ The home scheduler of a :term:`task` is a :term:`scheduler` which is a
+ :term:`eligible scheduler` and which is assigned to the task during the
+ initialization or explicitly via a directive call such as
+ :c:func:`rtems_task_set_scheduler`.
homogeneous
A multiprocessor computer system composed of a single type of processor.
@@ -728,6 +747,11 @@ Glossary
priority number and assign the tasks with the lowest priority number to
one processor of the set of processors owned by a scheduler instance.
+ A scheduler is either an :term:`eligible scheduler` or a
+ :term:`foreign scheduler` for a task. An :term:`eligible scheduler` is
+ either the :term:`home scheduler` or a :term:`helping scheduler` for a
+ task.
scheduler instance
A scheduler instance is a scheduling algorithm with a corresponding
context to store its internal state. Each processor in the system is
2.26.2
