[PATCH v3] c-user: Add scheduler glossary terms
Gedare Bloom
gedare at rtems.org
Tue Apr 13 20:38:53 UTC 2021
I like it, thanks.
On Tue, Apr 13, 2021 at 12:20 PM Sebastian Huber
> Add glossary terms which characterize the relationship of a scheduler to
> a task.
> v3:
> Address review comments. Use "ineligible" instead of "alien" or
> "foreign".
> c-user/glossary.rst | 24 ++++++++++++++++++++++++
> 1 file changed, 24 insertions(+)
> diff --git a/c-user/glossary.rst b/c-user/glossary.rst
> index 4e375de..6149368 100644
> --- a/c-user/glossary.rst
> +++ b/c-user/glossary.rst
> @@ -240,6 +240,10 @@ Glossary
> This term is an acronym for
> `Executable and Linkable Format <https://en.wikipedia.org/wiki/Executable_and_Linkable_Format>`_.
> + eligible scheduler
> + An eligible scheduler of a :term:`task` is a :term:`scheduler` which can be
> + used by the task to allocate a processor for the task.
> embedded
> An application that is delivered as a hidden part of a larger system.
> For example, the software in a fuel-injection control system is an
> @@ -340,9 +344,20 @@ Glossary
> dispatch is marked as necessary, then the next thread dispatch will make
> the heir task the executing task.
> + helping scheduler
> + A helping scheduler of a :term:`task` is a :term:`scheduler` which is a
> + :term:`eligible scheduler` and which is not the :term:`home scheduler` of
> + the task.
> heterogeneous
> A multiprocessor computer system composed of dissimilar processors.
> + home scheduler
> + The home scheduler of a :term:`task` is a :term:`scheduler` which is a
> + :term:`eligible scheduler` and which is assigned to the task during the
> + initialization or explicitly via a directive call such as
> + :c:func:`rtems_task_set_scheduler`.
> homogeneous
> A multiprocessor computer system composed of a single type of processor.
> @@ -356,6 +371,10 @@ Glossary
> A special low priority task which assumes control of the CPU when no
> other task is able to execute.
> + ineligible scheduler
> + An ineligible scheduler of a :term:`task` is a :term:`scheduler` which is
> + not an :term:`eligible scheduler`.
> interface
> A specification of the methodology used to connect multiple independent
> subsystems.
> @@ -728,6 +747,11 @@ Glossary
> priority number and assign the tasks with the lowest priority number to
> one processor of the set of processors owned by a scheduler instance.
> + A scheduler is either an :term:`eligible scheduler` or a
> + :term:`ineligible scheduler` for a task. An :term:`eligible scheduler` is
> + either the :term:`home scheduler` or a :term:`helping scheduler` for a
> + task.
> scheduler instance
> A scheduler instance is a scheduling algorithm with a corresponding
> context to store its internal state. Each processor in the system is
> 2.26.2
> devel mailing list
> devel at rtems.org
