[PATCH rtems 2/2] testsuites: Remove telnetd01
Vijay Kumar Banerjee
vijay at rtems.org
Wed Apr 14 05:45:40 UTC 2021
spec/build/testsuites/libtests/grp.yml | 2 -
spec/build/testsuites/libtests/telnetd01.yml | 22 ----
testsuites/libtests/telnetd01/init.c | 120 -------------------
testsuites/libtests/telnetd01/telnetd01.doc | 24 ----
testsuites/libtests/telnetd01/telnetd01.scn | 11 --
5 files changed, 179 deletions(-)
delete mode 100644 spec/build/testsuites/libtests/telnetd01.yml
delete mode 100644 testsuites/libtests/telnetd01/init.c
delete mode 100644 testsuites/libtests/telnetd01/telnetd01.doc
delete mode 100644 testsuites/libtests/telnetd01/telnetd01.scn
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index 5695fc7f06..20a593a5d3 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -258,8 +258,6 @@ links:
uid: tar02
- role: build-dependency
uid: tar03
-- role: build-dependency
- uid: telnetd01
uid: termios
diff --git a/spec/build/testsuites/libtests/telnetd01.yml b/spec/build/testsuites/libtests/telnetd01.yml
deleted file mode 100644
index 9f5bda84d9..0000000000
--- a/spec/build/testsuites/libtests/telnetd01.yml
+++ /dev/null
@@ -1,22 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-build-type: test-program
-cflags: []
-copyrights:
-- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-cppflags: []
-cxxflags: []
-enabled-by:
-- RTEMS_NETWORKING
-features: c cprogram
-includes:
-- cpukit/libnetworking
-ldflags: []
-links: []
-source:
-- testsuites/libtests/telnetd01/init.c
-stlib: []
-target: testsuites/libtests/telnetd01.exe
-type: build
-use-after:
-- telnetd
-use-before: []
diff --git a/testsuites/libtests/telnetd01/init.c b/testsuites/libtests/telnetd01/init.c
index a17126bf41..0000000000
--- a/testsuites/libtests/telnetd01/init.c
+++ /dev/null
@@ -1,120 +0,0 @@
- * Copyright (c) 2018 embedded brains GmbH. All rights reserved.
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <sys/stat.h>
-#include <fcntl.h>
-#include <string.h>
-#include <rtems.h>
-#include <rtems/rtems_bsdnet.h>
-#include <rtems/telnetd.h>
-#include <tmacros.h>
-const char rtems_test_name[] = "TELNETD 1";
-struct rtems_bsdnet_config rtems_bsdnet_config;
-static void command(char *device_name, void *arg)
-static void test_command_null(void)
- static const rtems_telnetd_config_table config = {
- .command = NULL
- rtems_status_code sc;
- sc = rtems_telnetd_start(&config);
- rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
-static void test_cannot_start_server_task(void)
- .command = command,
- .priority = UINT32_MAX
- rtems_test_assert(sc == RTEMS_UNSATISFIED);
-static void test_successful_start(void)
- .stack_size = RTEMS_MINIMUM_STACK_SIZE
- rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-static void test_already_started(void)
- rtems_test_assert(sc == RTEMS_RESOURCE_IN_USE);
-static rtems_task Init(rtems_task_argument argument)
- int rv;
- TEST_BEGIN();
- rv = rtems_bsdnet_initialize_network();
- rtems_test_assert(rv == 0);
- test_command_null();
- test_cannot_start_server_task();
- test_successful_start();
- test_already_started();
- TEST_END();
- rtems_test_exit(0);
-#define CONFIGURE_INIT
-#define CONFIGURE_MICROSECONDS_PER_TICK 10000
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS (3 + 1 + 5 * 4)
-#define CONFIGURE_MAXIMUM_TASKS 8
-#define CONFIGURE_MAXIMUM_POSIX_KEYS 1
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
-#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/telnetd01/telnetd01.doc b/testsuites/libtests/telnetd01/telnetd01.doc
index fe1a4d31a3..0000000000
--- a/testsuites/libtests/telnetd01/telnetd01.doc
+++ /dev/null
@@ -1,24 +0,0 @@
-# Copyright (c) 2018 embedded brains GmbH. All rights reserved.
-# embedded brains GmbH
-# Dornierstr. 4
-# 82178 Puchheim
-# Germany
-# <rtems at embedded-brains.de>
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
-This file describes the directives and concepts tested by this test set.
-test set name: telnetd01
-directives:
- - rtems_telnetd_start()
-concepts:
-+ Check if Telnet server works.
diff --git a/testsuites/libtests/telnetd01/telnetd01.scn b/testsuites/libtests/telnetd01/telnetd01.scn
index 3e9cc0007a..0000000000
--- a/testsuites/libtests/telnetd01/telnetd01.scn
+++ /dev/null
@@ -1,11 +0,0 @@
-*** BEGIN OF TEST TELNETD 1 ***
-*** TEST VERSION: 5.0.0.dc32b6aa0807fb70f9b26bc0bc6e164ddb49bd3a
-*** TEST STATE: EXPECTED_PASS
-*** TEST BUILD: RTEMS_NETWORKING
-*** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB 9670d7541e0621915e521fe76e7bb33de8cee661, Newlib d13c84eb07e35984bf7a974cd786a6cdac29e6b9)
-syslog: telnetd: configuration with invalid command
-syslog: telnetd: cannot create session task
-syslog: telnetd: started successfully on port 23
-syslog: telnetd: cannot bind server socket
-*** END OF TEST TELNETD 1 ***
2.26.2
