This adds a confdef option allowing an application to request mapping
machine exceptions to POSIX signals. This is required for some languages
such as Ada.
cpukit/doxygen/appl-config.h | 25 +++++++-
cpukit/include/rtems/confdefs.h | 1 +
cpukit/include/rtems/confdefs/exceptions.h | 71 ++++++++++++++++++++++
cpukit/include/rtems/exceptions.h | 57 +++++++++++++++++
spec/build/cpukit/librtemscpu.yml | 2 +
5 files changed, 155 insertions(+), 1 deletion(-)
create mode 100644 cpukit/include/rtems/confdefs/exceptions.h
create mode 100644 cpukit/include/rtems/exceptions.h
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index 4b18ac29a7..b007a03a25 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -3,7 +3,7 @@
* Copyright (C) 2019, 2020 embedded brains GmbH (http://www.embedded-brains.de)
* Copyright (C) 2010 Gedare Bloom
- * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+ * Copyright (C) 1988, 2021 On-Line Applications Research Corporation (OAR)
* modification, are permitted provided that the following conditions
@@ -1414,6 +1414,29 @@
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-exception-to-signal-mapping */
+ * @brief This configuration option is a boolean feature define.
+ * In case this configuration option is defined, then the machine exception to
+ * POSIX signal mapping is configured during system initialization.
+ * @par Default Configuration
+ * If this configuration option is undefined, then the described feature is not
+ * enabled.
+ * @par Notes
+ * @parblock
+ * This device driver is responsible for setting up a mapping from machine
+ * exceptions to POSIX signals so that applications may consume them and alter
+ * task execution as necessary.
+ * This is especially useful for applications written in Ada or C++.
+ * @endparblock
+#define CONFIGURE_APPLICATION_NEEDS_EXCEPTION_TO_SIGNAL_MAPPING
/* Generated from spec:/acfg/if/appl-needs-framebuffer-driver */
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index e6dd3d70ee..8770aa673d 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -64,6 +64,7 @@
#include <rtems/confdefs/clock.h>
#include <rtems/confdefs/console.h>
#include <rtems/confdefs/extensions.h>
+#include <rtems/confdefs/exceptions.h>
#include <rtems/confdefs/inittask.h>
#include <rtems/confdefs/initthread.h>
#include <rtems/confdefs/iodrivers.h>
diff --git a/cpukit/include/rtems/confdefs/exceptions.h b/cpukit/include/rtems/confdefs/exceptions.h
new file mode 100644
index 0000000000..b60143a900
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/exceptions.h
@@ -0,0 +1,71 @@
+ * @file
+ * @ingroup RTEMSImplApplConfig
+ * @brief This header file evaluates configuration options related to
+ * handling of machine exceptions.
+ * Copyright (C) 2021 On-Line Applications Research
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _RTEMS_CONFDEFS_EXCEPTIONS_H
+#define _RTEMS_CONFDEFS_EXCEPTIONS_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#include <rtems/exceptions.h>
+#include <rtems/sysinit.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifdef CONFIGURE_APPLICATION_NEEDS_EXCEPTION_TO_SIGNAL_MAPPING
+ RTEMS_SYSINIT_ITEM(
+ _Exception_initialize_signal_mapping,
+ RTEMS_SYSINIT_DEVICE_DRIVERS,
+ * This is called as early as possible to set defaults so that later
+ * initialization can override them without being wiped out.
+ RTEMS_SYSINIT_ORDER_FIRST
+#endif
+#ifdef __cplusplus
+#endif
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_EXCEPTIONS_H */
diff --git a/cpukit/include/rtems/exceptions.h b/cpukit/include/rtems/exceptions.h
index 0000000000..5e43827d11
--- /dev/null
+++ b/cpukit/include/rtems/exceptions.h
@@ -0,0 +1,57 @@
+ * @file
+ * @brief Exception mapping
+ * This file describes the hooks necessary for mapping machine exceptions to
+ * POSIX signals.
+ * are met:
+#ifndef _RTEMS_EXCEPTIONS_H
+#define _RTEMS_EXCEPTIONS_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @brief Configures the desired mapping for machine exceptions to POSIX
+ * signals.
+ * See CONFIGURE_APPLICATION_NEEDS_EXCEPTION_TO_SIGNAL_MAPPING documentation in the
+ * "RTEMS Classic API Guide".
+void _Exception_initialize_signal_mapping( void );
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_EXCEPTIONS_H */
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 4ed91562f8..9af110fc24 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -99,6 +99,7 @@ install:
- cpukit/include/rtems/dumpbuf.h
- cpukit/include/rtems/endian.h
- cpukit/include/rtems/error.h
+ - cpukit/include/rtems/exceptions.h
- cpukit/include/rtems/extension.h
- cpukit/include/rtems/extensiondata.h
- cpukit/include/rtems/extensionimpl.h
@@ -193,6 +194,7 @@ install:
- cpukit/include/rtems/confdefs/bsp.h
- cpukit/include/rtems/confdefs/clock.h
- cpukit/include/rtems/confdefs/console.h
+ - cpukit/include/rtems/confdefs/exceptions.h
- cpukit/include/rtems/confdefs/extensions.h
- cpukit/include/rtems/confdefs/inittask.h
- cpukit/include/rtems/confdefs/initthread.h
2.20.1
