[PATCH rtems-net-legacy v3] netlegacy: Use os.path instead of hardcoded Unix like path
Vijay Kumar Banerjee
vijay at rtems.org
Wed Apr 14 18:36:13 UTC 2021
netlegacy.py | 27 +++++++++++++--------------
1 file changed, 13 insertions(+), 14 deletions(-)
diff --git a/netlegacy.py b/netlegacy.py
index 05cb78a..2936b8f 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -37,7 +37,7 @@ exclude_headers = ['rtems-bsd-user-space.h', 'rtems-bsd-kernel-space.h']
for root, dirs, files in os.walk("."):
[dirs.remove(d) for d in list(dirs) if d in exclude_dirs]
- dirs.append('./bsps/shared/net')
+ dirs.append(os.path.join('bsps', 'shared', 'net'))
include_files[root[2:]] = []
for name in files:
ext = os.path.splitext(name)[1]
@@ -59,10 +59,9 @@ def build(bld):
include_path = []
ip = ''
bsp = bld.env.RTEMS_ARCH_BSP.split('-')[-1]
- pppd_source = [os.path.join('./pppd', s)
- for s in os.listdir('./pppd') if s[-2:] == '.c']
- telnetd_source = [os.path.join('./telnetd', s)
- for s in os.listdir('telnetd') if s[-2:] == '.c']
+ pppd_source = [os.path.join('pppd', s)
+ for s in os.listdir('pppd')
+ if os.path.splitext(s)[1] == '.c']
nfs_source = []
for root, dirs, files in os.walk('nfsclient'):
for name in files:
@@ -74,12 +73,12 @@ def build(bld):
bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
include_path.extend(['.',
- './include',
+ 'include',
os.path.relpath(bld.env.PREFIX),
- './testsuites/include',
+ os.path.join('testsuites', 'include'),
os.path.relpath(os.path.join(bld.env.PREFIX,
'include')),
- './bsps/include'])
+ os.path.join('bsps', 'include')])
arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
bld.env.RTEMS_ARCH_BSP)
lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
@@ -132,17 +131,17 @@ def build(bld):
use=['rtemsbsp', 'networking'],
source=nfs_source)
- bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
- ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
- bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
+ bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path),
+ ["libnetworking.a", 'libpppd.a', 'libnfs.a'])
+ bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path,
'include', 'libchip'),
install_file_list('bsps', 'include', 'libchip'))
for i in include_files:
- if 'include' in i.split('/'):
+ if 'include' in os.path.split(i):
arch_lib_path, i),
include_files[i])
else:
arch_lib_path, 'include', i),
include_files[i])
2.26.2
