[PATCH rtems-net-legacy v3] netlegacy: Use os.path instead of hardcoded Unix like path
Vijay Kumar Banerjee vijay at rtems.org
Wed Apr 14 19:22:14 UTC 2021
On Wed, Apr 14, 2021 at 1:10 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Apr 14, 2021 at 12:36 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> >  netlegacy.py | 27 +++++++++++++--------------
> >  1 file changed, 13 insertions(+), 14 deletions(-)
> > diff --git a/netlegacy.py b/netlegacy.py
> > index 05cb78a..2936b8f 100644
> > --- a/netlegacy.py
> > +++ b/netlegacy.py
> > @@ -37,7 +37,7 @@ exclude_headers = ['rtems-bsd-user-space.h', 'rtems-bsd-kernel-space.h']
> >  for root, dirs, files in os.walk("."):
> >      [dirs.remove(d) for d in list(dirs) if d in exclude_dirs]
> > -    dirs.append('./bsps/shared/net')
> > +    dirs.append(os.path.join('bsps', 'shared', 'net'))
> >      include_files[root[2:]] = []
> >      for name in files:
> >          ext = os.path.splitext(name)[1]
> > @@ -59,10 +59,9 @@ def build(bld):
> >      include_path = []
> >      ip = ''
> >      bsp = bld.env.RTEMS_ARCH_BSP.split('-')[-1]
> > -    pppd_source = [os.path.join('./pppd', s)
> > -                   for s in os.listdir('./pppd') if s[-2:] == '.c']
> > -    telnetd_source = [os.path.join('./telnetd', s)
> > -                      for s in os.listdir('telnetd') if s[-2:] == '.c']
> > +    pppd_source = [os.path.join('pppd', s)
> > +                   for s in os.listdir('pppd')
> > +                   if os.path.splitext(s)[1] == '.c']
> This indentation looks wrong?
This looks good with git show. I'm not sure what happened here, maybe
it looks weird due to email formatting?
> >      nfs_source = []
> >      for root, dirs, files in os.walk('nfsclient'):
> >          for name in files:
> > @@ -74,12 +73,12 @@ def build(bld):
> >      bsp_dirs, bsp_sources = bsp_drivers.bsp_files(bld)
> >      include_path.extend(['.',
> > -                         './include',
> > +                         'include',
> >                           os.path.relpath(bld.env.PREFIX),
> > -                         './testsuites/include',
> > +                         os.path.join('testsuites', 'include'),
> >                           os.path.relpath(os.path.join(bld.env.PREFIX,
> >                                                        'include')),
> > -                         './bsps/include'])
> > +                         os.path.join('bsps', 'include')])
> >      arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> >                                              bld.env.RTEMS_ARCH_BSP)
> >      lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
> > @@ -132,17 +131,17 @@ def build(bld):
> >                use=['rtemsbsp', 'networking'],
> >                source=nfs_source)
> > -    bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> > -                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
> > -    bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
> > +    bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path),
> > +                      ["libnetworking.a", 'libpppd.a', 'libnfs.a'])
> > +    bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path,
> >                                     'include', 'libchip'),
> >                        install_file_list('bsps', 'include', 'libchip'))
> >      for i in include_files:
> > -        if 'include' in i.split('/'):
> > +        if 'include' in os.path.split(i):
> >                                             arch_lib_path, i),
> >                                include_files[i])
> >          else:
> >                                             arch_lib_path, 'include', i),
> >                                include_files[i])
> > 2.26.2
