[PATCH rtems-net-legacy] bsp_drivers: Use os.path for compatibility with non Unix host
Thu Apr 15 20:51:28 UTC 2021
On Thu, Apr 15, 2021 at 2:49 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> On Thu, Apr 15, 2021 at 2:46 PM Gedare Bloom <gedare at rtems.org> wrote:
> > On Thu, Apr 15, 2021 at 12:01 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > > It has been less than 3 days, still pinging it. :)
> > > On Tue, Apr 13, 2021 at 11:49 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > > >  bsp_drivers.py | 26 +++++++++++++-------------
> > > >  1 file changed, 13 insertions(+), 13 deletions(-)
> > > > diff --git a/bsp_drivers.py b/bsp_drivers.py
> > > > index 3ca10c6..4a07847 100644
> > > > --- a/bsp_drivers.py
> > > > +++ b/bsp_drivers.py
> > > > @@ -36,18 +36,18 @@ def bsp_files(bld):
> > > >      include_dirs = {}
> > > >      include_files = []
> > > > -    special_case_dirs = {'atsamv': './bsps/arm/atsam',
> > > > -                         'lm32_evr': './bsps/lm32',
> > > > -                         'lpc24xx_ea': './bsps/arm/shared/'}
> > > > +    special_case_dirs = {'atsamv': 'bsps/arm/atsam',
> > should these be using also os.path.join(...)?
> I have used os.path.expanduser to handle this below ...
> > > > +                         'lm32_evr': 'bsps/lm32',
> > > > +                         'lpc24xx_ea': 'bsps/arm/shared/'}
> > > >      special_case_sources = {'leon2':
> > > > -                            ['./bsps/shared/grlib/net/network_interface_add.c',
> > > > -                             './bsps/shared/grlib/net/greth.c'],
> > > > +                            ['bsps/shared/grlib/net/network_interface_add.c',
> > > > +                             'bsps/shared/grlib/net/greth.c'],
> > > >                              'leon3':
> > > >                              'griscv':
> > > > -                             './bsps/shared/grlib/net/greth.c']}
> > > > +                             'bsps/shared/grlib/net/greth.c']}
> > > >      bsp_list = bld.env.RTEMS_ARCH_BSP_LIST
> > > > @@ -57,9 +57,9 @@ def bsp_files(bld):
> > > >          include_dirs[bsp] = []
> > > >          source_files[bsp] = []
> > > >          if bsp not in special_case_dirs:
> > > > -            source_dir = os.walk(os.path.join('./bsps', arch, bsp))
> > > > +            source_dir = os.walk(os.path.join('bsps', arch, bsp))
> > > >          else:
> > > > -            source_dir = os.walk(special_case_dirs[bsp])
> > > > +            source_dir = os.walk(os.path.expanduser(special_case_dirs[bsp]))
> Here ^
> Is this approach alright? expanduser will handle the path according to
> the host and give the right kind of output.
Can you use the expanduser call at the definition site? It is easier
then to audit/review code that way.
> > > >          for root, dirs, files in source_dir:
> > > >              for name in files:
> > > >                  ext = os.path.splitext(name)[1]
> > > > @@ -69,6 +69,6 @@ def bsp_files(bld):
> > > >                      if root not in include_dirs[bsp]:
> > > >                          include_dirs[bsp].append(root)
> > > >              if bsp in special_case_sources:
> > > > -                source_files[bsp].extend(special_case_sources[bsp])
> > > > -        include_dirs[bsp].append(os.path.join('./bsps', arch, bsp, 'net'))
> > > > +                source_files[bsp].extend([os.path.expanduser(f) for f in special_case_sources[bsp]])
> > > > +        include_dirs[bsp].append(os.path.join('bsps', arch, bsp, 'net'))
> > > >      return (include_dirs, source_files)
> > > > 2.26.2
