[PATCH v1 1/3] cpukit: Add signal mapping support
Gedare Bloom
gedare at rtems.org
Fri Apr 16 13:48:25 UTC 2021
On Fri, Apr 16, 2021 at 1:19 AM Sebastian Huber
> Hello Kinsey,
> why don't you use a fatal error extension for this? You can save all the
> processor state to a structure and use it to jump to previous or next
> instruction it if needed in a custom fatal error handler which deals
> with RTEMS_FATAL_EXCEPTION. I think libdebugger uses this approach.
+1
This is otherwise a major overhaul/addition to the CPU port
requirements. I'd lean in favor of adding any CPU_* API that is
necessary to support vectoring from an exception to a signal. I don't
think we can make this kind of intrusive modification to basic
interrupt handling capabilities across all ports easily. Some of that
code is old and very stable.
