[PATCH v1 2/3] aarch64: Add support for mapping exceptions
Fri Apr 16 14:00:02 UTC 2021
On Wed, Apr 14, 2021 at 9:47 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> This adds support for mapping AArch64 machine exceptions to POSIX
> signals as necessary for running Ada applications.
>  bsps/aarch64/shared/exceptions.c              |  89 +++++++++++++++
>  .../cpu/aarch64/aarch64-exception-default.S   |  81 ++-----------
>  .../cpu/aarch64/aarch64-exception-interrupt.S | 106 +-----------------
>  .../score/cpu/aarch64/aarch64-exception-map.S |  90 +++++++++++++++
>  cpukit/score/cpu/aarch64/include/rtems/asm.h  |  97 ++++++++++++++++
>  .../cpu/aarch64/include/rtems/score/cpu.h     |   5 +
>  spec/build/bsps/aarch64/grp.yml               |   4 +-
>  spec/build/bsps/aarch64/objexceptions.yml     |  14 +++
>  spec/build/cpukit/cpuaarch64.yml              |   1 +
>  9 files changed, 313 insertions(+), 174 deletions(-)
>  create mode 100644 bsps/aarch64/shared/exceptions.c
>  create mode 100644 cpukit/score/cpu/aarch64/aarch64-exception-map.S
>  create mode 100644 spec/build/bsps/aarch64/objexceptions.yml
> diff --git a/bsps/aarch64/shared/exceptions.c b/bsps/aarch64/shared/exceptions.c
> new file mode 100644
> index 0000000000..808a3bf62a
> --- /dev/null
> +++ b/bsps/aarch64/shared/exceptions.c
> @@ -0,0 +1,89 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSBSPsAArch64Shared
> + * @brief AArch64 machine exception to POSIX signal mapping.
> + * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
> + * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <unistd.h> /* getpid */
> +#include <bsp.h>
> +#include <rtems/bspIo.h>
> +#include <signal.h>
> +#include <stdlib.h>
> +#include <rtems/exceptions.h>
> + * Synchronous trap handler. Map the trap number of SIGFPE, SIGSEGV
> + * or SIGILL to generate the corresponding Ada exception.
> +#include <bsp/utility.h>
> +#define ESR_EC_GET(reg) BSP_FLD64GET(reg, 26, 31)
> +void AArch64_map_exception( uint64_t syndrome )
> +  uint32_t         signal;
> +  uint64_t EC = ESR_EC_GET(syndrome);
> +  switch (EC)
> +    case 0x28:                 /* FPU exception */
> +    case 0x2c:                 /* FPU exception */
> +    case 0x0A:                 /* tagged arithmetic overflow */
> +    case 0x82:                 /* divide by zero */
> +      signal = SIGFPE;
> +      break;
> +    case 0x20:                 /* Data abort */
> +    case 0x21:                 /* Data abort */
> +    case 0x24:                 /* Instruction abort */
> +    case 0x25:                 /* Instruction abort */
> +      signal = SIGSEGV;
> +      break;
> +    default:                   /* Anything else ... */
> +       * Covers unknown, trapped instructions including SVC, illegal execution
> +       * state, PC or SP alignment faults, debugging exceptions, etc. */
> +      signal = SIGILL;
> +      break;
> +  kill(getpid(), signal);
Not just map it, but actually send it. I'm not convinced this design
is the right way to deal with this problem. In addition to Sebastian's
suggestion on using a fatal error handler, you may consider a user
task to handle this. I think that kill() can have quite a large stack
consumption? It is a very complex call to include in the 'normal'
exception handling path with a giant switch to turn it on/off.
If you have some analysis or justification for this design, I'd be
glad to consider it. However, at a glance, it adds kill() to the
WCET/latency of all synchronous exception handling when this option is
enabled. Something about this feels off.
> +void
> +_Exception_initialize_signal_mapping(void)
> +  AArch64_set_exception_handler(
> +    AARCH64_EXCEPTION_SPx_SYNCHRONOUS,
> +    _AArch64_Exception_synchronous_map
> diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.S b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
> index d139fdc6a4..047eab984c 100644
> --- a/cpukit/score/cpu/aarch64/aarch64-exception-default.S
> +++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
> @@ -49,6 +49,8 @@
>  .globl bsp_start_vector_table_end
>  .globl bsp_start_vector_table_size
>  .globl bsp_vector_table_size
> +.globl _AArch64_push_exception_context_start
> +.globl _AArch64_push_exception_context_finish
>  .section ".text"
> @@ -337,13 +339,13 @@ bsp_start_vector_table_end:
>  /* Save LR */
>         str lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET]
>  /* Push the start of the context */
> -       bl .push_exception_context_start
> -/* Save original sp in x0 for .push_exception_context_finish */
> +       bl _AArch64_push_exception_context_start
> +/* Save original sp in x0 for _AArch64_push_exception_context_finish */
>         msr spsel, #1
>         mov x0, sp
>         msr spsel, #0
>  /* Push the remainder of the context */
> -       bl .push_exception_context_finish
> +       bl _AArch64_push_exception_context_finish
>  /* Save sp into x0 for handler */
>         mov x0, sp
>  /* Jump into the handler */
> @@ -368,11 +370,11 @@ bsp_start_vector_table_end:
>  /* Save LR */
>         add x0, sp, #(AARCH64_EXCEPTION_FRAME_SIZE + 0x10)
>  /* Save sp (exception frame) into x0 for handler */
>         mov x0, sp
> @@ -383,7 +385,7 @@ twiddle:
>         b       twiddle
>  /* Assumes SP is at the base of the context and LR has already been pushed */
> -.push_exception_context_start:
> +_AArch64_push_exception_context_start:
>  /* Push x0-x29(fp) */
>         stp x0,  x1,  [sp, #0x00]
>         stp x2,  x3,  [sp, #0x10]
> @@ -403,7 +405,7 @@ twiddle:
>         ret
>  /* Expects original SP to be stored in x0 */
> -.push_exception_context_finish:
> +_AArch64_push_exception_context_finish:
>  /* Get exception LR for PC */
>         mrs x1, ELR_EL1
>  /* Push sp and pc */
> @@ -443,67 +445,4 @@ twiddle:
>  /* Done, return to exception handler */
>         ret
> - * Apply the exception frame to the current register status, SP points to the EF
> -.pop_exception_context_and_ret:
> -/* Pop daif and spsr */
> -       ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET]
> -/* Restore daif and spsr */
> -       msr DAIF, x2
> -       msr SPSR_EL1, x3
> -/* Pop FAR and ESR */
> -       ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET]
> -/* Restore ESR and FAR */
> -       msr ESR_EL1, x2
> -       msr FAR_EL1, x3
> -/* Pop fpcr and fpsr */
> -       ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET]
> -/* Restore fpcr and fpsr */
> -       msr FPSR, x2
> -       msr FPCR, x3
> -/* Restore LR */
> -       ldr lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET]
> -/* Pop VFP registers */
> -       ldp q0,  q1,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x000)]
> -       ldp q2,  q3,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x020)]
> -       ldp q4,  q5,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x040)]
> -       ldp q6,  q7,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x060)]
> -       ldp q8,  q9,  [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x080)]
> -       ldp q10, q11, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0a0)]
> -       ldp q12, q13, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0c0)]
> -       ldp q14, q15, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0e0)]
> -       ldp q16, q17, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x100)]
> -       ldp q18, q19, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x120)]
> -       ldp q20, q21, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x140)]
> -       ldp q22, q23, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x160)]
> -       ldp q24, q25, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x180)]
> -       ldp q26, q27, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1a0)]
> -       ldp q28, q29, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1c0)]
> -       ldp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
> -/* Pop x0-x29(fp) */
> -       ldp x2,  x3,  [sp, #0x10]
> -       ldp x4,  x5,  [sp, #0x20]
> -       ldp x6,  x7,  [sp, #0x30]
> -       ldp x8,  x9,  [sp, #0x40]
> -       ldp x10, x11, [sp, #0x50]
> -       ldp x12, x13, [sp, #0x60]
> -       ldp x14, x15, [sp, #0x70]
> -       ldp x16, x17, [sp, #0x80]
> -       ldp x18, x19, [sp, #0x90]
> -       ldp x20, x21, [sp, #0xa0]
> -       ldp x22, x23, [sp, #0xb0]
> -       ldp x24, x25, [sp, #0xc0]
> -       ldp x26, x27, [sp, #0xd0]
> -       ldp x28, x29, [sp, #0xe0]
> -/* Pop sp (ignored since sp should be shortly restored anyway) and ELR */
> -       ldp x0, x1, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET]
> -/* Restore exception LR */
> -       msr ELR_EL1, x1
> -       ldp x0,  x1,  [sp, #0x00]
> -       add sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE
> -/* We must clear reservations to ensure consistency with atomic operations */
> -       clrex
> -       ret
> diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> index cb0954a29b..2def18bef7 100644
> --- a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> +++ b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> @@ -45,6 +45,7 @@
>  .globl _AArch64_Exception_interrupt_no_nest
>  .globl _AArch64_Exception_interrupt_nest
> +.globl _AArch64_Perform_Thread_Dispatch
>  #ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
>    #define SELF_CPU_CONTROL_GET_REG w19
> @@ -106,7 +107,7 @@
>  /* NOTE: This function does not follow the AArch64 procedure call specification
>   * because all relevant state is known to be saved in the interrupt context,
>   * hence the blind usage of x19, x20, and x21 */
> -.AArch64_Perform_Thread_Dispatch:
> +_AArch64_Perform_Thread_Dispatch:
>  /* Get per-CPU control of current processor */
>         GET_SELF_CPU_CONTROL    SELF_CPU_CONTROL_GET_REG
> @@ -125,9 +126,7 @@
>  /* Call _Thread_Do_dispatch(), this function will enable interrupts */
>         mov     x0, SELF_CPU_CONTROL
> -       mov     x1, NON_VOLATILE_SCRATCH
> -       mov     x2, #0x80
> -       bic     x1, x1, x2
> +       mov     x1, #0x0
>         bl      _Thread_Do_dispatch
>  /* Restore LR */
> @@ -152,103 +151,6 @@
>  /* Return from thread dispatch */
>         ret
> - * Must save corruptible registers and non-corruptible registers expected to be
> - * used, x0 and lr expected to be already saved on the stack
> -.macro push_interrupt_context
> - * Push x1-x21 on to the stack, need 19-21 because they're modified without
> - * obeying PCS
> -       stp lr,         x1,     [sp, #-0x10]!
> -       stp x2,         x3,     [sp, #-0x10]!
> -       stp x4,         x5,     [sp, #-0x10]!
> -       stp x6,         x7,     [sp, #-0x10]!
> -       stp x8,         x9,     [sp, #-0x10]!
> -       stp x10,        x11,    [sp, #-0x10]!
> -       stp x12,        x13,    [sp, #-0x10]!
> -       stp x14,        x15,    [sp, #-0x10]!
> -       stp x16,        x17,    [sp, #-0x10]!
> -       stp x18,        x19,    [sp, #-0x10]!
> -       stp x20,        x21,    [sp, #-0x10]!
> - * Push q0-q31 on to the stack, need everything because parts of every register
> - * are volatile/corruptible
> -       stp q0,         q1,     [sp, #-0x20]!
> -       stp q2,         q3,     [sp, #-0x20]!
> -       stp q4,         q5,     [sp, #-0x20]!
> -       stp q6,         q7,     [sp, #-0x20]!
> -       stp q8,         q9,     [sp, #-0x20]!
> -       stp q10,        q11,    [sp, #-0x20]!
> -       stp q12,        q13,    [sp, #-0x20]!
> -       stp q14,        q15,    [sp, #-0x20]!
> -       stp q16,        q17,    [sp, #-0x20]!
> -       stp q18,        q19,    [sp, #-0x20]!
> -       stp q20,        q21,    [sp, #-0x20]!
> -       stp q22,        q23,    [sp, #-0x20]!
> -       stp q24,        q25,    [sp, #-0x20]!
> -       stp q26,        q27,    [sp, #-0x20]!
> -       stp q28,        q29,    [sp, #-0x20]!
> -       stp q30,        q31,    [sp, #-0x20]!
> -/* Get exception LR for PC and spsr */
> -       mrs x0, ELR_EL1
> -       mrs x1, SPSR_EL1
> -/* Push pc and spsr */
> -       stp x0,         x1,     [sp, #-0x10]!
> -/* Get fpcr and fpsr */
> -       mrs x0, FPSR
> -       mrs x1, FPCR
> -/* Push fpcr and fpsr */
> -.endm
> -/* Must match inverse order of .push_interrupt_context */
> -.macro pop_interrupt_context
> -       ldp x0,         x1,     [sp], #0x10
> -       msr FPCR, x1
> -       msr FPSR, x0
> -/* Pop pc and spsr */
> -/* Restore exception LR for PC and spsr */
> -       msr SPSR_EL1, x1
> -       msr ELR_EL1, x0
> -/* Pop q0-q31 */
> -       ldp q30,        q31,    [sp], #0x20
> -       ldp q28,        q29,    [sp], #0x20
> -       ldp q26,        q27,    [sp], #0x20
> -       ldp q24,        q25,    [sp], #0x20
> -       ldp q22,        q23,    [sp], #0x20
> -       ldp q20,        q21,    [sp], #0x20
> -       ldp q18,        q19,    [sp], #0x20
> -       ldp q16,        q17,    [sp], #0x20
> -       ldp q14,        q15,    [sp], #0x20
> -       ldp q12,        q13,    [sp], #0x20
> -       ldp q10,        q11,    [sp], #0x20
> -       ldp q8,         q9,     [sp], #0x20
> -       ldp q6,         q7,     [sp], #0x20
> -       ldp q4,         q5,     [sp], #0x20
> -       ldp q2,         q3,     [sp], #0x20
> -       ldp q0,         q1,     [sp], #0x20
> -/* Pop x1-x21 */
> -       ldp x20,        x21,    [sp], #0x10
> -       ldp x18,        x19,    [sp], #0x10
> -       ldp x16,        x17,    [sp], #0x10
> -       ldp x14,        x15,    [sp], #0x10
> -       ldp x12,        x13,    [sp], #0x10
> -       ldp x10,        x11,    [sp], #0x10
> -       ldp x8,         x9,     [sp], #0x10
> -       ldp x6,         x7,     [sp], #0x10
> -       ldp x4,         x5,     [sp], #0x10
> -       ldp x2,         x3,     [sp], #0x10
> -       ldp lr,         x1,     [sp], #0x10
> -/* Must clear reservations here to ensure consistency with atomic operations */
> -       clrex
> -.endm
>  _AArch64_Exception_interrupt_nest:
>  /* Execution template:
> @@ -309,7 +211,7 @@ Return to embedded exception vector code
>         cmp     x0, #0
>         bne     .Lno_need_thread_dispatch
> -       bl .AArch64_Perform_Thread_Dispatch
> +       bl _AArch64_Perform_Thread_Dispatch
>  .Lno_need_thread_dispatch:
> diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-map.S b/cpukit/score/cpu/aarch64/aarch64-exception-map.S
> index 0000000000..da79e703c9
> --- /dev/null
> +++ b/cpukit/score/cpu/aarch64/aarch64-exception-map.S
> @@ -0,0 +1,90 @@
> + * @file
> + * @ingroup RTEMSScoreCPUAArch64
> + * @brief Implementation of AArch64 exception map handler.
> + * This file implements the AArch64 exception map handler which maps machine
> + * exceptions to POSIX signals. For more information, see documentation for
> + * CONFIGURE_APPLICATION_NEEDS_EXCEPTION_TO_SIGNAL_MAPPING.
> + * are met:
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/asm.h>
> +.globl _AArch64_Exception_synchronous_map
> +_AArch64_Exception_synchronous_map:
> +/* Execution template:
> +Save volatile registers on thread stack(some x, all q, ELR, etc.)
> +Execute map handler
> +Perform thread dispatch
> +Restore volatile registers from thread stack
> +Return to embedded exception vector code
> +/* Push interrupt context */
> +       push_interrupt_context
> + * Thread dispatch can occur inside the exception map and the available code
> + * paths assume that exceptions are ensabled.
> +       msr     DAIFClr, #0x2
> +/* Set x0 and jump into the handler */
> +       mrs     x0, ESR_EL1
> +       bl AArch64_map_exception
> + * Thread dispatch via the call below assumes that exceptions are disabled upon
> + * entry.
> +       msr     DAIFSet, #0x2
> + * Perform thread dispatch. A Synchronous exception occurred and there is no
> + * other way to resolve it.
> + * SP should be where it was pre-handler (pointing at the exception frame)
> + * or something has leaked stack space
> +/* Pop interrupt context */
> +       pop_interrupt_context
> +/* Return to vector for final cleanup */
> +       ret
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/asm.h b/cpukit/score/cpu/aarch64/include/rtems/asm.h
> index 35bf533c8a..fa30e45dcb 100644
> --- a/cpukit/score/cpu/aarch64/include/rtems/asm.h
> +++ b/cpukit/score/cpu/aarch64/include/rtems/asm.h
> @@ -84,6 +84,103 @@
>         ldr     \REG, =_Per_CPU_Information
>  .endm
> + * Must save corruptible registers and non-corruptible registers expected to be
> + * used, x0 and lr expected to be already saved on the stack
> +.macro push_interrupt_context
> + * Push x1-x21 on to the stack, need 19-21 because they're modified without
> + * obeying PCS
> +       stp lr,         x1,     [sp, #-0x10]!
> +       stp x2,         x3,     [sp, #-0x10]!
> +       stp x4,         x5,     [sp, #-0x10]!
> +       stp x6,         x7,     [sp, #-0x10]!
> +       stp x8,         x9,     [sp, #-0x10]!
> +       stp x10,        x11,    [sp, #-0x10]!
> +       stp x12,        x13,    [sp, #-0x10]!
> +       stp x14,        x15,    [sp, #-0x10]!
> +       stp x16,        x17,    [sp, #-0x10]!
> +       stp x18,        x19,    [sp, #-0x10]!
> +       stp x20,        x21,    [sp, #-0x10]!
> + * Push q0-q31 on to the stack, need everything because parts of every register
> + * are volatile/corruptible
> +       stp q0,         q1,     [sp, #-0x20]!
> +       stp q2,         q3,     [sp, #-0x20]!
> +       stp q4,         q5,     [sp, #-0x20]!
> +       stp q6,         q7,     [sp, #-0x20]!
> +       stp q8,         q9,     [sp, #-0x20]!
> +       stp q10,        q11,    [sp, #-0x20]!
> +       stp q12,        q13,    [sp, #-0x20]!
> +       stp q14,        q15,    [sp, #-0x20]!
> +       stp q16,        q17,    [sp, #-0x20]!
> +       stp q18,        q19,    [sp, #-0x20]!
> +       stp q20,        q21,    [sp, #-0x20]!
> +       stp q22,        q23,    [sp, #-0x20]!
> +       stp q24,        q25,    [sp, #-0x20]!
> +       stp q26,        q27,    [sp, #-0x20]!
> +       stp q28,        q29,    [sp, #-0x20]!
> +       stp q30,        q31,    [sp, #-0x20]!
> +/* Get exception LR for PC and spsr */
> +       mrs x0, ELR_EL1
> +       mrs x1, SPSR_EL1
> +/* Push pc and spsr */
> +       stp x0,         x1,     [sp, #-0x10]!
> +/* Get fpcr and fpsr */
> +       mrs x0, FPSR
> +       mrs x1, FPCR
> +/* Push fpcr and fpsr */
> +.endm
> +/* Must match inverse order of .push_interrupt_context */
> +.macro pop_interrupt_context
> +/* Pop fpcr and fpsr */
> +       ldp x0,         x1,     [sp], #0x10
> +/* Restore fpcr and fpsr */
> +       msr FPCR, x1
> +       msr FPSR, x0
> +/* Pop pc and spsr */
> +/* Restore exception LR for PC and spsr */
> +       msr SPSR_EL1, x1
> +       msr ELR_EL1, x0
> +/* Pop q0-q31 */
> +       ldp q30,        q31,    [sp], #0x20
> +       ldp q28,        q29,    [sp], #0x20
> +       ldp q26,        q27,    [sp], #0x20
> +       ldp q24,        q25,    [sp], #0x20
> +       ldp q22,        q23,    [sp], #0x20
> +       ldp q20,        q21,    [sp], #0x20
> +       ldp q18,        q19,    [sp], #0x20
> +       ldp q16,        q17,    [sp], #0x20
> +       ldp q14,        q15,    [sp], #0x20
> +       ldp q12,        q13,    [sp], #0x20
> +       ldp q10,        q11,    [sp], #0x20
> +       ldp q8,         q9,     [sp], #0x20
> +       ldp q6,         q7,     [sp], #0x20
> +       ldp q4,         q5,     [sp], #0x20
> +       ldp q2,         q3,     [sp], #0x20
> +       ldp q0,         q1,     [sp], #0x20
> +/* Pop x1-x21 */
> +       ldp x20,        x21,    [sp], #0x10
> +       ldp x18,        x19,    [sp], #0x10
> +       ldp x16,        x17,    [sp], #0x10
> +       ldp x14,        x15,    [sp], #0x10
> +       ldp x12,        x13,    [sp], #0x10
> +       ldp x10,        x11,    [sp], #0x10
> +       ldp x8,         x9,     [sp], #0x10
> +       ldp x6,         x7,     [sp], #0x10
> +       ldp x4,         x5,     [sp], #0x10
> +       ldp x2,         x3,     [sp], #0x10
> +       ldp lr,         x1,     [sp], #0x10
> +/* Must clear reservations here to ensure consistency with atomic operations */
> +       clrex
> +.endm
>  #endif /* _RTEMS_ASM_H */
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> index 316079a6cd..eb2206ffc7 100644
> --- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> @@ -433,6 +433,10 @@ typedef enum {
>  #define VECTOR_ENTRY_SIZE 0x80
>  void _AArch64_Exception_interrupt_no_nest( void );
>  void _AArch64_Exception_interrupt_nest( void );
> +void _AArch64_Perform_Thread_Dispatch( void );
> +void _AArch64_Exception_synchronous_map( void );
> +void _AArch64_push_exception_context_start( void );
> +void _AArch64_push_exception_context_finish( void );
>  static inline void* AArch64_set_exception_handler(
>    AArch64_symbolic_exception_name exception,
>    void (*handler)(void)
> @@ -545,6 +549,7 @@ typedef struct {
>  void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
>  void _AArch64_Exception_default( CPU_Exception_frame *frame );
> +void AArch64_map_exception( uint64_t syndrome );
>  /** Type that can store a 32-bit integer or a pointer. */
>  typedef uintptr_t CPU_Uint32ptr;
> diff --git a/spec/build/bsps/aarch64/grp.yml b/spec/build/bsps/aarch64/grp.yml
> index a6bc0d5a31..24967d4841 100644
> --- a/spec/build/bsps/aarch64/grp.yml
> +++ b/spec/build/bsps/aarch64/grp.yml
> @@ -23,7 +23,9 @@ install:
>    source:
>    - bsps/aarch64/shared/start/linkcmds.base
>  ldflags: []
> -links: []
> +links:
> +- role: build-dependency
> +  uid: objexceptions
>  type: build
>  use-after: []
>  use-before: []
> diff --git a/spec/build/bsps/aarch64/objexceptions.yml b/spec/build/bsps/aarch64/objexceptions.yml
> index 0000000000..859d837271
> --- /dev/null
> +++ b/spec/build/bsps/aarch64/objexceptions.yml
> @@ -0,0 +1,14 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: objects
> +cflags: []
> +copyrights:
> +- Copyright (C) 2021 On-Line Applications Research (OAR)
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +includes: []
> +install: []
> +links: []
> +source:
> +- bsps/aarch64/shared/exceptions.c
> +type: build
> diff --git a/spec/build/cpukit/cpuaarch64.yml b/spec/build/cpukit/cpuaarch64.yml
> index 80562756ba..a984b3ee62 100644
> --- a/spec/build/cpukit/cpuaarch64.yml
> +++ b/spec/build/cpukit/cpuaarch64.yml
> @@ -30,6 +30,7 @@ source:
>  - cpukit/score/cpu/aarch64/aarch64-exception-default.c
>  - cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
>  - cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> +- cpukit/score/cpu/aarch64/aarch64-exception-map.S
>  - cpukit/score/cpu/aarch64/aarch64-thread-idle.c
>  - cpukit/score/cpu/aarch64/cpu.c
>  - cpukit/score/cpu/aarch64/cpu_asm.S
> 2.20.1
> devel mailing list
> devel at rtems.org
