[PATCH] score: Allways check if a prio ceiling is defined
Gedare Bloom
gedare at rtems.org
Fri Apr 16 19:32:19 UTC 2021
On Fri, Apr 16, 2021 at 10:01 AM Joel Sherrill <joel at rtems.org> wrote:
> Allways -> Always
or All ways
> On Fri, Apr 16, 2021 at 9:04 AM Gedare Bloom <gedare at rtems.org> wrote:
>> ok. also good if you want to open a ticket and backport to 5.
>> On Fri, Apr 16, 2021 at 1:30 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>> > Priority ceiling semaphores (in contrast to MrsP semaphores) have only
>> > one priority ceiling which is defined for the home scheduler of the task
>> > which created the semaphore. Always check during a semaphore seize that
>> > the home scheduler of the calling task is equal to this scheduler.
>> > This avoids a scheduler mismatch if the semphore is acquired after the
>> > calling thread blocked on the semaphore.
>> > cpukit/include/rtems/score/coremuteximpl.h | 20 ++++++++++----------
>> > 1 file changed, 10 insertions(+), 10 deletions(-)
>> > diff --git a/cpukit/include/rtems/score/coremuteximpl.h b/cpukit/include/rtems/score/coremuteximpl.h
>> > index cbc1e720fb..6b5c240105 100644
>> > --- a/cpukit/include/rtems/score/coremuteximpl.h
>> > +++ b/cpukit/include/rtems/score/coremuteximpl.h
>> > @@ -475,19 +475,19 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_ceiling_mutex_Seize(
>> > _CORE_mutex_Acquire_critical( &the_mutex->Recursive.Mutex, queue_context );
>> > - owner = _CORE_mutex_Get_owner( &the_mutex->Recursive.Mutex );
>> > - if ( owner == NULL ) {
>> > #if defined(RTEMS_SMP)
>> > - if (
>> > - _Thread_Scheduler_get_home( executing )
>> > - != _CORE_ceiling_mutex_Get_scheduler( the_mutex )
>> > - _CORE_mutex_Release( &the_mutex->Recursive.Mutex, queue_context );
>> > - return STATUS_NOT_DEFINED;
>> > + if (
>> > + _Thread_Scheduler_get_home( executing )
>> > + != _CORE_ceiling_mutex_Get_scheduler( the_mutex )
>> > + _CORE_mutex_Release( &the_mutex->Recursive.Mutex, queue_context );
>> > + return STATUS_NOT_DEFINED;
>> > #endif
>> > + owner = _CORE_mutex_Get_owner( &the_mutex->Recursive.Mutex );
>> > + if ( owner == NULL ) {
>> > _Thread_queue_Context_clear_priority_updates( queue_context );
>> > return _CORE_ceiling_mutex_Set_owner(
>> > the_mutex,
>> > 2.26.2
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
