[PATCH libBSD] iicbus/rtems-i2c.c: Add rtems, path as an additional bus path
G S Niteesh Babu
niteesh.gs at gmail.com
Sun Apr 18 15:12:24 UTC 2021
Adds "rtems,path" as an additional bus path for the i2c driver.
Previously the bus path was provided in "rtems,i2c-path" property
only.
rtemsbsd/sys/dev/iicbus/rtems-i2c.c | 9 ++++++---
1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/rtemsbsd/sys/dev/iicbus/rtems-i2c.c b/rtemsbsd/sys/dev/iicbus/rtems-i2c.c
index b965f248..7ac7a7c4 100644
--- a/rtemsbsd/sys/dev/iicbus/rtems-i2c.c
+++ b/rtemsbsd/sys/dev/iicbus/rtems-i2c.c
@@ -87,9 +87,12 @@ rtems_i2c_attach(device_t dev)
len = OF_getprop_alloc(node, "rtems,i2c-path", &sc->path);
if (len == -1){
- device_printf(sc->dev, "Path not found in Device Tree");
- OF_prop_free(sc->path);
- return (ENXIO);
+ len = OF_getprop_alloc(node, "rtems,path", &sc->path);
+ if (len == -1) {
+ device_printf(sc->dev, "Path not found in Device Tree");
+ OF_prop_free(sc->path);
+ return (ENXIO);
if ((sc->sc_iicbus = device_add_child(sc->dev, "iicbus", -1)) == NULL) {
2.17.1
