[PATCH libBSD] iicbus/rtems-i2c.c: Add rtems, path as an additional bus path
Niteesh G. S. niteesh.gs at gmail.com
Mon Apr 19 16:45:50 UTC 2021
On Mon, Apr 19, 2021 at 9:55 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Sun, Apr 18, 2021 at 9:12 AM G S Niteesh Babu <niteesh.gs at gmail.com>
> wrote:
> > Adds "rtems,path" as an additional bus path for the i2c driver.
> > Previously the bus path was provided in "rtems,i2c-path" property
> > only.
> >  rtemsbsd/sys/dev/iicbus/rtems-i2c.c | 9 ++++++---
> >  1 file changed, 6 insertions(+), 3 deletions(-)
> > diff --git a/rtemsbsd/sys/dev/iicbus/rtems-i2c.c
> b/rtemsbsd/sys/dev/iicbus/rtems-i2c.c
> > index b965f248..7ac7a7c4 100644
> > --- a/rtemsbsd/sys/dev/iicbus/rtems-i2c.c
> > +++ b/rtemsbsd/sys/dev/iicbus/rtems-i2c.c
> > @@ -87,9 +87,12 @@ rtems_i2c_attach(device_t dev)
> >         len = OF_getprop_alloc(node, "rtems,i2c-path", &sc->path);
> >         if (len == -1){
> > -               device_printf(sc->dev, "Path not found in Device Tree");
> > -               OF_prop_free(sc->path);
> > -               return (ENXIO);
> > +               len = OF_getprop_alloc(node, "rtems,path", &sc->path);
> > +               if (len == -1) {
> > +                       device_printf(sc->dev, "Path not found in Device
> Tree");
> > +                       OF_prop_free(sc->path);
> If OF_get_prop_alloc failed, is sc->path valid here? Or do you free(NULL)
> maybe.
OF_getprop_alloc doesn't allocate a buffer on missing properties and 0
length
properties. In other cases, if it internally fails(in OF_getprop) it frees
the buffer and
then returns.
In this case, if no path property exists we just free a null buffer.
> > +                       return (ENXIO);
> >         if ((sc->sc_iicbus = device_add_child(sc->dev, "iicbus", -1)) ==
> NULL) {
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210419/f8ad7f97/attachment.html>
