[PATCH rtems-net-legacy v2] bsp_drivers: Use os.path for compatibility with non Unix host
Vijay Kumar Banerjee
vijay at rtems.org
Mon Apr 19 17:30:32 UTC 2021
bsp_drivers.py | 22 +++++++++++-----------
1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/bsp_drivers.py b/bsp_drivers.py
index 3ca10c6..ec25c23 100644
--- a/bsp_drivers.py
+++ b/bsp_drivers.py
@@ -36,18 +36,18 @@ def bsp_files(bld):
include_dirs = {}
include_files = []
- special_case_dirs = {'atsamv': './bsps/arm/atsam',
- 'lm32_evr': './bsps/lm32',
- 'lpc24xx_ea': './bsps/arm/shared/'}
+ special_case_dirs = {'atsamv': os.path.expanduser('bsps/arm/atsam'),
+ 'lm32_evr': os.path.expanduser('bsps/lm32'),
+ 'lpc24xx_ea': os.path.expanduser('bsps/arm/shared/')}
special_case_sources = {'leon2':
- ['./bsps/shared/grlib/net/network_interface_add.c',
- './bsps/shared/grlib/net/greth.c'],
+ [os.path.expanduser('bsps/shared/grlib/net/network_interface_add.c'),
+ os.path.expanduser('bsps/shared/grlib/net/greth.c')],
'leon3':
'griscv':
- './bsps/shared/grlib/net/greth.c']}
+ os.path.expanduser('bsps/shared/grlib/net/greth.c')]}
bsp_list = bld.env.RTEMS_ARCH_BSP_LIST
@@ -57,7 +57,7 @@ def bsp_files(bld):
include_dirs[bsp] = []
source_files[bsp] = []
if bsp not in special_case_dirs:
- source_dir = os.walk(os.path.join('./bsps', arch, bsp))
+ source_dir = os.walk(os.path.join('bsps', arch, bsp))
else:
source_dir = os.walk(special_case_dirs[bsp])
for root, dirs, files in source_dir:
@@ -70,5 +70,5 @@ def bsp_files(bld):
include_dirs[bsp].append(root)
if bsp in special_case_sources:
source_files[bsp].extend(special_case_sources[bsp])
- include_dirs[bsp].append(os.path.join('./bsps', arch, bsp, 'net'))
+ include_dirs[bsp].append(os.path.join('bsps', arch, bsp, 'net'))
return (include_dirs, source_files)
2.26.2
