[PATCH v1 1/3] cpukit: Add signal mapping support
Tue Apr 20 05:54:09 UTC 2021
On 20/04/2021 07:30, Chris Johns wrote:
> We need a way for libdebugger or any other piece of software to capture and
> cascade the call. If this can be done on aarch64 then I am happy.
The fatal error extensions execute in a user controllable order. You can
for example register a libdebugger handler which deals with break point
exceptions before the signal mapping handler is called.
Synchronous exceptions should end up in an RTEMS_FATAL_SOURCE_EXCEPTION
fatal error. The fatal code is a pointer to rtems_exception_frame
(CPU_Exception_frame). In this data structure should be the complete
state of the interrupted context (which could be also an interrupt
handler). If you want to resume execution of the interrupted context,
then we need an API for this (setters/getters and some sort of a longjmp()).
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
