[PATCH 2/3] libcsupport: Move rtems_calloc()
Sebastian Huber
Tue Apr 20 10:53:44 UTC 2021
Move rtems_calloc() since it only depends on rtems_malloc(). This may
make it easier to customize the heap allocator.
Change licence to BSD-2-Clause according to file history.
Update #3053.
cpukit/Makefile.am | 1 +
cpukit/libcsupport/src/malloc_deferred.c | 15 -------
cpukit/libcsupport/src/rtemscalloc.c | 57 ++++++++++++++++++++++++
spec/build/cpukit/librtemscpu.yml | 1 +
4 files changed, 59 insertions(+), 15 deletions(-)
create mode 100644 cpukit/libcsupport/src/rtemscalloc.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index d6b636bf2a..a8cce3c287 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -213,6 +213,7 @@ librtemscpu_a_SOURCES += libcsupport/src/realpath.c
librtemscpu_a_SOURCES += libcsupport/src/_rename_r.c
librtemscpu_a_SOURCES += libcsupport/src/resource_snapshot.c
librtemscpu_a_SOURCES += libcsupport/src/rmdir.c
+librtemscpu_a_SOURCES += libcsupport/src/rtemscalloc.c
librtemscpu_a_SOURCES += libcsupport/src/rtems_heap_extend.c
librtemscpu_a_SOURCES += libcsupport/src/rtems_heap_extend_via_sbrk.c
librtemscpu_a_SOURCES += libcsupport/src/rtems_heap_greedy.c
diff --git a/cpukit/libcsupport/src/malloc_deferred.c b/cpukit/libcsupport/src/malloc_deferred.c
index f66dd54676..b319d1213e 100644
--- a/cpukit/libcsupport/src/malloc_deferred.c
+++ b/cpukit/libcsupport/src/malloc_deferred.c
@@ -112,19 +112,4 @@ void *rtems_malloc( size_t size )
return rtems_heap_allocate_aligned_with_boundary( size, 0, 0 );
-void *rtems_calloc( size_t nelem, size_t elsize )
- size_t length;
- void *p;
- length = nelem * elsize;
- p = rtems_malloc( length );
- RTEMS_OBFUSCATE_VARIABLE( p );
- if ( RTEMS_PREDICT_FALSE( p == NULL ) ) {
- return p;
- return memset( p, 0, length );
#endif
diff --git a/cpukit/libcsupport/src/rtemscalloc.c b/cpukit/libcsupport/src/rtemscalloc.c
new file mode 100644
index 0000000000..4e189e8367
--- /dev/null
+++ b/cpukit/libcsupport/src/rtemscalloc.c
@@ -0,0 +1,57 @@
+ * @file
+ * @ingroup libcsupport
+ * @brief This source file contains the implementation of rtems_calloc().
+ * Copyright (C) 2018 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/malloc.h>
+#include <string.h>
+void *rtems_calloc( size_t nelem, size_t elsize )
+ size_t length;
+ void *p;
+ length = nelem * elsize;
+ p = rtems_malloc( length );
+ RTEMS_OBFUSCATE_VARIABLE( p );
+ if ( RTEMS_PREDICT_FALSE( p == NULL ) ) {
+ return p;
+ return memset( p, 0, length );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 6de764cd04..a3a9ee42e3 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -708,6 +708,7 @@ source:
- cpukit/libcsupport/src/realpath.c
- cpukit/libcsupport/src/resource_snapshot.c
- cpukit/libcsupport/src/rmdir.c
+- cpukit/libcsupport/src/rtemscalloc.c
- cpukit/libcsupport/src/rtems_heap_extend.c
- cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c
- cpukit/libcsupport/src/rtems_heap_greedy.c
2.26.2
