Booting a rtems exe on Zynq UltraScale+ MPSoC ZCU106 board
    Kinsey Moore
    kinsey.moore at oarcorp.com
    Tue Apr 20 12:24:14 UTC 2021
Unfortunately, that's not something I've done so I don't have any
particular guidance or instructions for you at this point other than
recommending that you find the generic build instructions for u-boot on
the ZynqMP platform.
Kinsey
On 4/20/2021 07:00, Richi Dubey wrote:
> Thanks!
> Can you please tell me more about:
>     build a new u-boot that can do what you need and then package it
>     into BOOT.bin using bootgen (the code is available on github).
> this? How do I build a new uboot that defaults to AArch32 at EL1?
> On Mon, Apr 19, 2021 at 6:11 PM Kinsey Moore <kinsey.moore at oarcorp.com
> <mailto:kinsey.moore at oarcorp.com>> wrote:
>     I'll start by saying that AArch64 RTEMS on QEMU (for which there
>     is a ZynqMP hardware model) works great and is what the current
>     BSP targets.
>     The current status of AArch64 RTEMS on real hardware is not as
>     simple as I'd like, but it's possible and I've run the
>     uniprocessor testsuite tests on an an Avnet dev board (ZU3EG). The
>     complications are caused by lack of support for the MMU on AArch64
>     leading to all memory requiring strict alignment for accesses. Due
>     to this, the toolchain needs to be recompiled with additional flags:
>      --targetcflags="-DPREFER_SIZE_OVER_SPEED -mstrict-align"
>     --targetcxxflags="-mstrict-align"
>     To deal with an EL2 start, optstarthyp.yml needs to be added to
>     the BSP definition and -mstrict-align needs to be added to abi.yml.
>     Unfortunately, these changes are unfit for inclusion in RTEMS and
>     my next step is to work on the MMU driver to avoid these alignment
>     problems.
>     Kinsey
>     On 4/19/2021 00:19, Richi Dubey wrote:
>>     Thanks!
>>     Can I get rtems to build images as an AArch64 code, so that I
>>     don't have to change anything for uboot?
>>     On Thu, Apr 15, 2021 at 12:01 AM Kinsey Moore
>>     <kinsey.moore at oarcorp.com <mailto:kinsey.moore at oarcorp.com>> wrote:
>>         That exception dump doesn't say a lot other than the ELR
>>         pointing at the very first instruction in your image, so I
>>         suspect that u-boot is trying to start your image as AArch64
>>         code instead of AArch32/ARMv7 code. The ESR just specifies
>>         that it was a 32-bit instruction that blew up (both AArch32
>>         and AArch64 use 32-bit instructions) instead of a 16-bit
>>         instruction.
>>         The u-boot images that come with the PetaLinux distributions
>>         default to starting code as AArch64 at EL2, so you either
>>         need to figure out how to make u-boot default to
>>         AArch32/ARMv7 at EL1 or build a new u-boot that can do what
>>         you need and then package it into BOOT.bin using bootgen (the
>>         code is available on github). From what I remember, the ARMv7
>>         BSP for ZynqMP mentions booting over JTAG.
>>         Kinsey
>>         On 4/14/2021 13:18, Richi Dubey wrote:
>>>         Hi Jan, Kinsey,
>>>         Thanks for your quick responses.
>>>         I rebuilt the .img file with  -O rtems option, and I think
>>>         it is the standard uboot available from PetaLinux. It still
>>>         fails, but I think it is related to RTEMS now:
>>>         Welcome to minicom 2.7.1
>>>         OPTIONS: I18n
>>>         Compiled on May  6 2018, 08:02:47.Welcome to minicom 2.7.1
>>>         OPTIONS: I18n
>>>         Port /dev/ttyUSB32, 18:14:14
>>>         Press CTRL-K Z for help on special keys
>>>         Xilinx Zynq MP First Stage Boot Loader
>>>         Release 2020.1   Jan  1 2021  -  07:33:16
>>>         NOTICE:  ATF running on XCZU7EV/silicon v4/RTL5.1 at 0xfffea000
>>>         NOTICE:  BL31: Secure code at 0x60000000
>>>         NOTICE:  BL31: Non secure code at 0x10080000
>>>         NOTICE:  BL31: v2.0(release):xilinx-v2019.1-12-g713dace9
>>>         NOTICE:  BL31: Built : 08:36:10, Sep  1 2020
>>>         PMUFW:  v1.1
>>>         U-Boot 2019.01 (Sep 01 2020 - 08:36:54 +0000)
>>>         Model: ZynqMP ZCU106 RevA
>>>         Board: Xilinx ZynqMP
>>>         DRAM:  4 GiB
>>>         EL Level:       EL2
>>>         Chip ID:        zu7ev
>>>         MMC:   mmc at ff170000: 0
>>>         Loading Environment from SPI Flash... SF: Detected n25q512a
>>>         with page size 512 B
>>>         ytes, erase size 128 KiB, total 128 MiB
>>>         OK
>>>         In:    serial at ff000000
>>>         Out:   serial at ff000000
>>>         Err:   serial at ff000000
>>>         Net:   ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
>>>         Warning: ethernet at ff0e0000 MAC addresses don't match:
>>>         Address in ROM is  00:0a:35:05:2f:ec
>>>         Address in environment is  00:0a:35:00:22:19
>>>         eth0: ethernet at ff0e0000
>>>         Hit any key to stop autoboot:  0
>>>         ZynqMP> tftpboot 0x3000000 rdubey/sp01new.img
>>>         Using ethernet at ff0e0000 device
>>>         TFTP from server 172.19.0.3; our IP address is 172.19.2.40
>>>         Filename 'rdubey/sp01new.img'.
>>>         Load address: 0x3000000
>>>         Loading: ####
>>>                  1.7 MiB/s
>>>         done
>>>         Bytes transferred = 50978 (c722 hex)
>>>         ZynqMP> bootm  0x3000000  ; reset
>>>         ## Booting kernel from Legacy Image at 03000000 ...
>>>            Image Name:   RTEMS
>>>            Image Type:   ARM RTEMS Kernel Image (gzip compressed)
>>>            Data Size:    50914 Bytes = 49.7 KiB
>>>            Load Address: 00300000
>>>            Entry Point:  00300000
>>>            Verifying Checksum ... OK
>>>            Uncompressing Kernel Image ... OK
>>>         ## Transferring control to RTEMS (at address 00300000) ...
>>>         "Synchronous Abort" handler, esr 0x02000000
>>>         elr: ffffffff90593000 lr : 0000000010097a90 (reloc)
>>>         elr: 0000000000300000 lr : 000000007fe04a90
>>>         x0 : 000000007ddacf58 x1 : 0000000000000000
>>>         x2 : 0000000000006802 x3 : 0000000000000020
>>>         x4 : 0000000000000000 x5 : 0000000000000030
>>>         x6 : 000000007fe7e9cd x7 : 000000000000000f
>>>         x8 : 0000000000000038 x9 : 0000000000000008
>>>         x10: 000000007ddbd530 x11: 00000000ffffffd0
>>>         x12: 0000000000000000 x13: 0000000000000200
>>>         x14: 0000000000000001 x15: 0000000000000008
>>>         x16: 000000000000003f x17: 000000000000009a
>>>         x18: 000000007ddacde8 x19: 0000000000300000
>>>         x20: 000000007fead720 x21: 000000007fe04a20
>>>         x22: 000000000000071f x23: 000000007fe04a20
>>>         x24: 0000000000000001 x25: 000000007ddbd2f8
>>>         x26: 000000007fe9ac18 x27: 0000000000300000
>>>         x28: 0000000003000040 x29: 000000007dda07c0
>>>         Resetting CPU ...
>>>         ### ERROR ### Please RESET the board ###
>>>         Can this be about the load address being at 0x00300000 and
>>>         the .img being fetched at 0x3000000?
>>>         On Wed, Apr 14, 2021 at 7:08 PM <Jan.Sommer at dlr.de
>>>         <mailto:Jan.Sommer at dlr.de>> wrote:
>>>             Hi Richi,
>>>             In your log it says:
>>>             Image Type:   ARM Linux Kernel Image (gzip compressed)
>>>             At least for our zedboard devices we use the following
>>>             main options for mkimage.
>>>             mkimage  -A arm -O rtems -T kernel
>>>             Which yields  for me:
>>>             IIRC the difference between -O rtems  and -O linux is
>>>             subtle, but maybe that helps.
>>>             Best regards,
>>>             Jan
>>>             *From:* devel <devel-bounces at rtems.org
>>>             <mailto:devel-bounces at rtems.org>> *On Behalf Of *Richi Dubey
>>>             *Sent:* Wednesday, April 14, 2021 3:22 PM
>>>             *To:* Kinsey Moore <kinsey.moore at oarcorp.com
>>>             *Cc:* rtems-devel at rtems.org
>>>             <mailto:rtems-devel at rtems.org> <devel at rtems.org
>>>             <mailto:devel at rtems.org>>
>>>             *Subject:* Re: Booting a rtems exe on Zynq UltraScale+
>>>             MPSoC ZCU106 board
>>>             Trying to boot directly from the .img  file also fails:
>>>             ZynqMP> tftpboot 0x3000000 rdubey/sp01.img
>>>             Filename 'rdubey/sp01.img'.
>>>             Loading: ####
>>>                      6.1 MiB/s
>>>             done
>>>                Image Name:   RTEMS
>>>             FDT and ATAGS support not compiled in - hanging
>>>             What can I do now?
>>>             On Wed, Apr 14, 2021 at 6:11 PM Kinsey Moore
>>>                 If you’re only running RTEMS, you should be able to
>>>                 drop the FDT commands since that what appears to be
>>>                 causing the problem and I don’t think that the
>>>                 arm/xilinx_zynqmp BSP uses it at all.
>>>                 Kinsey
>>>                 *From:*Richi Dubey <richidubey at gmail.com
>>>                 <mailto:richidubey at gmail.com>>
>>>                 *Sent:* Wednesday, April 14, 2021 01:01
>>>                 <mailto:kinsey.moore at oarcorp.com>>;
>>>                 rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
>>>                 <devel at rtems.org <mailto:devel at rtems.org>>
>>>                 *Subject:* Booting a rtems exe on Zynq UltraScale+
>>>                 MPSoC ZCU106 board
>>>                 Hi,
>>>                 I followed the 8.2.23 docs
>>>                 <https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#xilinx-zynqmp> to
>>>                 build rtems for the xilinx_zynqmp_ultra96 bsp since
>>>                 it was the only bsp corresponding to xilinx-zynqmp
>>>                 in the rtems-bsp.
>>>                 Then I followed the boot via Uboot section 8.2.1.1
>>>                 on docs
>>>                 <https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#boot-via-u-boot>,
>>>                 but the uboot on zcu106 does not have a run loadfdt
>>>                 command, and its alternative is fdt addr [address].
>>>                 But something is wrong, I cannot run the sp01.img file:
>>>                 With fdt:
>>>                 172.19.2.40
>>>                 Loading: ####
>>>                          6.9 MiB/s
>>>                 done
>>>                 ZynqMP> fdt addr 0x2A00000
>>>                 ZynqMP> bootm  0x3000000 - 0x2A00000 ; reset
>>>                    Image Name:   RTEMS
>>>                 compressed)
>>>                 ## Flattened Device Tree blob at 02a00000
>>>                    Booting using the fdt blob at 0x2a00000
>>>                    Loading Device Tree to 0000000007ff1000, end
>>>                 0000000007fff257 ... OK
>>>                 fdt_find_or_add_subnode: chosen: FDT_ERR_BADSTRUCTURE
>>>                 ERROR: /chosen node create failed
>>>                  - must RESET the board to recover.
>>>                 FDT creation failed! hanging...### ERROR ### Please
>>>                 RESET the board ###
>>>                 With loading the system.dtb that I generally use for
>>>                 loading yocto linux images:
>>>                 ZynqMP> tftpboot 0x2A00000 rdubey/system.dtb
>>>                 172.19.253.142
>>>                 Filename 'rdubey/system.dtb'.
>>>                 Load address: 0x2a00000
>>>                 Loading: ###T #
>>>                          8.8 KiB/s
>>>                 done
>>>                 Bytes transferred = 45656 (b258 hex)
>>>                 172.19.253.142
>>>                 Loading: ####
>>>                          1.7 MiB/s
>>>                 done
>>>                    Image Name:   RTEMS
>>>                 compressed)
>>>                 Starting kernel ...
>>>                 elr: ffffffff90593000 lr : 0000000010081868 (reloc)
>>>                 elr: 0000000000300000 lr : 000000007fdee868
>>>                 x0 : 0000000000000000 x1 : 0000000000000000
>>>                 x2 : 0000000007ff1000 x3 : 0000000000000000
>>>                 x4 : 0000000000300000 x5 : 0000000000000000
>>>                 x6 : 0000000000000008 x7 : 0000000000000000
>>>                 x8 : 000000007dda0650 x9 : 0000000001008000
>>>                 x10: 000000000a200023 x11: 0000000000000002
>>>                 x12: 0000000000000002 x13: 00000000000096f4
>>>                 x14: 000000007dda06ac x15: 000000007fdee224
>>>                 x16: 0000000000000002 x17: 0000000007fff258
>>>                 x18: 000000007ddacde8 x19: 000000007fead720
>>>                 x20: 0000000000000000 x21: 0000000000000400
>>>                 x22: 000000000000071f x23: 000000007fdeedb8
>>>                 x24: 0000000000000003 x25: 000000007ddbd378
>>>                 x28: 0000000003000040 x29: 000000007dda0790
>>>                 Resetting CPU ...
>>>                 What might be going wrong? zcu106 is a multi
>>>                 processor board, so do I need to do something
>>>                 special to run the sp01 test? I have not tested any
>>>                 other .exe (or .img) so far.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210420/e14ece38/attachment-0001.html>
