[PATCH] Patch to avoid nameclash of PAGESIZE define
Robin Mueller
robin.mueller.m at gmail.com
Tue Apr 20 18:11:05 UTC 2021
This commit excludes the PAGESIZE legacy define
because there is a nameclash with a define of the same name
coming from the RTEMS header limits.h.
All other changes come from loading the file from a Unix system.
.../stm32h7/include/Legacy/stm32_hal_legacy.h | 172 +++++++++---------
1 file changed, 88 insertions(+), 84 deletions(-)
diff --git a/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h b/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
index c311c1618e..804a4c87da 100644
--- a/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
+++ b/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
@@ -31,7 +31,7 @@
/* Exported constants --------------------------------------------------------*/
/** @defgroup HAL_AES_Aliased_Defines HAL CRYP Aliased Defines maintained for legacy purpose
- * @ingroup RTEMSBSPsARMSTM32H7
+ * @ingroup RTEMSBSPsARMSTM32H7
#define AES_FLAG_RDERR CRYP_FLAG_RDERR
@@ -45,7 +45,7 @@
/** @defgroup HAL_ADC_Aliased_Defines HAL ADC Aliased Defines maintained for legacy purpose
#define ADC_RESOLUTION12b ADC_RESOLUTION_12B
@@ -105,7 +105,7 @@
/** @defgroup HAL_CEC_Aliased_Defines HAL CEC Aliased Defines maintained for legacy purpose
@@ -116,7 +116,7 @@
/** @defgroup HAL_COMP_Aliased_Defines HAL COMP Aliased Defines maintained for legacy purpose
#define COMP_WINDOWMODE_DISABLED COMP_WINDOWMODE_DISABLE
@@ -208,7 +208,7 @@
/** @defgroup HAL_CORTEX_Aliased_Defines HAL CORTEX Aliased Defines maintained for legacy purpose
#define __HAL_CORTEX_SYSTICKCLK_CONFIG HAL_SYSTICK_CLKSourceConfig
@@ -217,7 +217,7 @@
/** @defgroup HAL_CRC_Aliased_Defines HAL CRC Aliased Defines maintained for legacy purpose
@@ -229,7 +229,7 @@
/** @defgroup HAL_DAC_Aliased_Defines HAL DAC Aliased Defines maintained for legacy purpose
@@ -258,7 +258,7 @@
/** @defgroup HAL_DMA_Aliased_Defines HAL DMA Aliased Defines maintained for legacy purpose
#define HAL_REMAPDMA_ADC_DMA_CH2 DMA_REMAP_ADC_DMA_CH2
@@ -392,7 +392,7 @@
/** @defgroup HAL_FLASH_Aliased_Defines HAL FLASH Aliased Defines maintained for legacy purpose
@@ -420,7 +420,11 @@
#define TYPEPROGRAMDATA_FASTBYTE FLASH_TYPEPROGRAMDATA_FASTBYTE
#define TYPEPROGRAMDATA_FASTHALFWORD FLASH_TYPEPROGRAMDATA_FASTHALFWORD
#define TYPEPROGRAMDATA_FASTWORD FLASH_TYPEPROGRAMDATA_FASTWORD
+#ifndef __rtems__
+/* Commented out for the RTEMS BSP because there can be nameclashes with another
+similar defininition in limits.h */
#define PAGESIZE FLASH_PAGE_SIZE
+#endif /* __rtems__ */
#define TYPEPROGRAM_FASTBYTE FLASH_TYPEPROGRAM_BYTE
#define TYPEPROGRAM_FASTHALFWORD FLASH_TYPEPROGRAM_HALFWORD
#define TYPEPROGRAM_FASTWORD FLASH_TYPEPROGRAM_WORD
@@ -490,7 +494,7 @@
/** @defgroup HAL_JPEG_Aliased_Macros HAL JPEG Aliased Macros maintained for legacy purpose
@@ -508,7 +512,7 @@
/** @defgroup HAL_SYSCFG_Aliased_Defines HAL SYSCFG Aliased Defines maintained for legacy purpose
@@ -534,7 +538,7 @@
/** @defgroup LL_FMC_Aliased_Defines LL FMC Aliased Defines maintained for compatibility purpose
#if defined(STM32L4) || defined(STM32F7) || defined(STM32H7) || defined(STM32G4)
@@ -553,7 +557,7 @@
/** @defgroup LL_FSMC_Aliased_Defines LL FSMC Aliased Defines maintained for legacy purpose
@@ -564,7 +568,7 @@
/** @defgroup HAL_GPIO_Aliased_Macros HAL GPIO Aliased Macros maintained for legacy purpose
#define GET_GPIO_SOURCE GPIO_GET_INDEX
@@ -631,7 +635,7 @@
/** @defgroup HAL_HRTIM_Aliased_Macros HAL HRTIM Aliased Macros maintained for legacy purpose
#define HRTIM_TIMDELAYEDPROTECTION_DISABLED HRTIM_TIMER_A_B_C_DELAYEDPROTECTION_DISABLED
@@ -836,7 +840,7 @@
/** @defgroup HAL_I2C_Aliased_Defines HAL I2C Aliased Defines maintained for legacy purpose
#define I2C_DUALADDRESS_DISABLED I2C_DUALADDRESS_DISABLE
@@ -860,7 +864,7 @@
/** @defgroup HAL_IRDA_Aliased_Defines HAL IRDA Aliased Defines maintained for legacy purpose
#define IRDA_ONE_BIT_SAMPLE_DISABLED IRDA_ONE_BIT_SAMPLE_DISABLE
@@ -871,7 +875,7 @@
/** @defgroup HAL_IWDG_Aliased_Defines HAL IWDG Aliased Defines maintained for legacy purpose
#define KR_KEY_RELOAD IWDG_KEY_RELOAD
@@ -883,7 +887,7 @@
/** @defgroup HAL_LPTIM_Aliased_Defines HAL LPTIM Aliased Defines maintained for legacy purpose
@@ -912,7 +916,7 @@
/** @defgroup HAL_NAND_Aliased_Defines HAL NAND Aliased Defines maintained for legacy purpose
#define HAL_NAND_Read_Page HAL_NAND_Read_Page_8b
@@ -932,7 +936,7 @@
/** @defgroup HAL_NOR_Aliased_Defines HAL NOR Aliased Defines maintained for legacy purpose
#define NOR_StatusTypedef HAL_NOR_StatusTypeDef
@@ -948,7 +952,7 @@
/** @defgroup HAL_OPAMP_Aliased_Defines HAL OPAMP Aliased Defines maintained for legacy purpose
@@ -988,7 +992,7 @@
/** @defgroup HAL_I2S_Aliased_Defines HAL I2S Aliased Defines maintained for legacy purpose
#define I2S_STANDARD_PHILLIPS I2S_STANDARD_PHILIPS
@@ -1009,7 +1013,7 @@
/** @defgroup HAL_PCCARD_Aliased_Defines HAL PCCARD Aliased Defines maintained for legacy purpose
@@ -1040,7 +1044,7 @@
/** @defgroup HAL_RTC_Aliased_Defines HAL RTC Aliased Defines maintained for legacy purpose
@@ -1087,7 +1091,7 @@
/** @defgroup HAL_SMARTCARD_Aliased_Defines HAL SMARTCARD Aliased Defines maintained for legacy purpose
#define SMARTCARD_NACK_ENABLED SMARTCARD_NACK_ENABLE
@@ -1109,7 +1113,7 @@
/** @defgroup HAL_SMBUS_Aliased_Defines HAL SMBUS Aliased Defines maintained for legacy purpose
#define SMBUS_DUALADDRESS_DISABLED SMBUS_DUALADDRESS_DISABLE
@@ -1128,7 +1132,7 @@
/** @defgroup HAL_SPI_Aliased_Defines HAL SPI Aliased Defines maintained for legacy purpose
#define SPI_TIMODE_DISABLED SPI_TIMODE_DISABLE
@@ -1160,7 +1164,7 @@
/** @defgroup HAL_TIM_Aliased_Defines HAL TIM Aliased Defines maintained for legacy purpose
#define CCER_CCxE_MASK TIM_CCER_CCxE_MASK
@@ -1255,7 +1259,7 @@
/** @defgroup HAL_TSC_Aliased_Defines HAL TSC Aliased Defines maintained for legacy purpose
#define TSC_SYNC_POL_FALL TSC_SYNC_POLARITY_FALLING
@@ -1265,7 +1269,7 @@
/** @defgroup HAL_UART_Aliased_Defines HAL UART Aliased Defines maintained for legacy purpose
#define UART_ONEBIT_SAMPLING_DISABLED UART_ONE_BIT_SAMPLE_DISABLE
@@ -1297,7 +1301,7 @@
/** @defgroup HAL_USART_Aliased_Defines HAL USART Aliased Defines maintained for legacy purpose
@@ -1311,7 +1315,7 @@
/** @defgroup HAL_WWDG_Aliased_Defines HAL WWDG Aliased Defines maintained for legacy purpose
#define CFR_BASE WWDG_CFR_BASE
@@ -1321,7 +1325,7 @@
/** @defgroup HAL_CAN_Aliased_Defines HAL CAN Aliased Defines maintained for legacy purpose
#define CAN_FilterFIFO0 CAN_FILTER_FIFO0
@@ -1340,7 +1344,7 @@
/** @defgroup HAL_ETH_Aliased_Defines HAL ETH Aliased Defines maintained for legacy purpose
@@ -1401,7 +1405,7 @@
/** @defgroup HAL_DCMI_Aliased_Defines HAL DCMI Aliased Defines maintained for legacy purpose
#define HAL_DCMI_ERROR_OVF HAL_DCMI_ERROR_OVR
@@ -1421,7 +1425,7 @@
|| defined(STM32F429xx) || defined(STM32F439xx) || defined(STM32F469xx) || defined(STM32F479xx) \
|| defined(STM32H7)
/** @defgroup HAL_DMA2D_Aliased_Defines HAL DMA2D Aliased Defines maintained for legacy purpose
#define DMA2D_ARGB8888 DMA2D_OUTPUT_ARGB8888
@@ -1447,7 +1451,7 @@
#endif /* STM32L4 || STM32F7 || STM32F4 || STM32H7 */
/** @defgroup HAL_PPP_Aliased_Defines HAL PPP Aliased Defines maintained for legacy purpose
@@ -1458,7 +1462,7 @@
/* Exported functions --------------------------------------------------------*/
/** @defgroup HAL_CRYP_Aliased_Functions HAL CRYP Aliased Functions maintained for legacy purpose
#define HAL_CRYP_ComputationCpltCallback HAL_CRYPEx_ComputationCpltCallback
@@ -1467,7 +1471,7 @@
/** @defgroup HAL_HASH_Aliased_Functions HAL HASH Aliased Functions maintained for legacy purpose
#define HAL_HASH_STATETypeDef HAL_HASH_StateTypeDef
@@ -1518,7 +1522,7 @@
/** @defgroup HAL_Aliased_Functions HAL Generic Aliased Functions maintained for legacy purpose
#define HAL_EnableDBGSleepMode HAL_DBGMCU_EnableDBGSleepMode
@@ -1548,7 +1552,7 @@
/** @defgroup HAL_FLASH_Aliased_Functions HAL FLASH Aliased Functions maintained for legacy purpose
#define FLASH_HalfPageProgram HAL_FLASHEx_HalfPageProgram
@@ -1564,7 +1568,7 @@
/** @defgroup HAL_I2C_Aliased_Functions HAL I2C Aliased Functions maintained for legacy purpose
#define HAL_I2CEx_AnalogFilter_Config HAL_I2CEx_ConfigAnalogFilter
@@ -1602,7 +1606,7 @@
/** @defgroup HAL_PWR_Aliased HAL PWR Aliased maintained for legacy purpose
@@ -1660,7 +1664,7 @@
/** @defgroup HAL_SMBUS_Aliased_Functions HAL SMBUS Aliased Functions maintained for legacy purpose
#define HAL_SMBUS_Slave_Listen_IT HAL_SMBUS_EnableListen_IT
@@ -1671,7 +1675,7 @@
/** @defgroup HAL_SPI_Aliased_Functions HAL SPI Aliased Functions maintained for legacy purpose
#define HAL_SPI_FlushRxFifo HAL_SPIEx_FlushRxFifo
@@ -1680,7 +1684,7 @@
/** @defgroup HAL_TIM_Aliased_Functions HAL TIM Aliased Functions maintained for legacy purpose
#define HAL_TIM_DMADelayPulseCplt TIM_DMADelayPulseCplt
@@ -1700,7 +1704,7 @@
/** @defgroup HAL_UART_Aliased_Functions HAL UART Aliased Functions maintained for legacy purpose
#define HAL_UART_WakeupCallback HAL_UARTEx_WakeupCallback
@@ -1709,7 +1713,7 @@
/** @defgroup HAL_LTDC_Aliased_Functions HAL LTDC Aliased Functions maintained for legacy purpose
#define HAL_LTDC_LineEvenCallback HAL_LTDC_LineEventCallback
@@ -1722,7 +1726,7 @@
/** @defgroup HAL_PPP_Aliased_Functions HAL PPP Aliased Functions maintained for legacy purpose
@@ -1733,7 +1737,7 @@
/* Exported macros ------------------------------------------------------------*/
/** @defgroup HAL_AES_Aliased_Macros HAL CRYP Aliased Macros maintained for legacy purpose
#define AES_IT_CC CRYP_IT_CC
@@ -1744,7 +1748,7 @@
/** @defgroup HAL_Aliased_Macros HAL Generic Aliased Macros maintained for legacy purpose
#define __HAL_GET_BOOT_MODE __HAL_SYSCFG_GET_BOOT_MODE
@@ -1774,7 +1778,7 @@
/** @defgroup HAL_ADC_Aliased_Macros HAL ADC Aliased Macros maintained for legacy purpose
#define __ADC_ENABLE __HAL_ADC_ENABLE
@@ -1859,7 +1863,7 @@
/** @defgroup HAL_DAC_Aliased_Macros HAL DAC Aliased Macros maintained for legacy purpose
#define __HAL_DHR12R1_ALIGNEMENT DAC_DHR12R1_ALIGNMENT
@@ -1872,7 +1876,7 @@
/** @defgroup HAL_DBGMCU_Aliased_Macros HAL DBGMCU Aliased Macros maintained for legacy purpose
#define __HAL_FREEZE_TIM1_DBGMCU __HAL_DBGMCU_FREEZE_TIM1
@@ -1945,7 +1949,7 @@
/** @defgroup HAL_COMP_Aliased_Macros HAL COMP Aliased Macros maintained for legacy purpose
#if defined(STM32F3)
@@ -2123,7 +2127,7 @@
#if defined(STM32L0) || defined(STM32L4)
/** @defgroup HAL_COMP_Aliased_Functions HAL COMP Aliased Functions maintained for legacy purpose
#define HAL_COMP_Start_IT HAL_COMP_Start /* Function considered as legacy as EXTI event or IT configuration is done into HAL_COMP_Init() */
@@ -2134,7 +2138,7 @@
#endif
@@ -2147,7 +2151,7 @@
/** @defgroup HAL_FLASH_Aliased_Macros HAL FLASH Aliased Macros maintained for legacy purpose
@@ -2163,7 +2167,7 @@
/** @defgroup HAL_I2C_Aliased_Macros HAL I2C Aliased Macros maintained for legacy purpose
@@ -2191,7 +2195,7 @@
/** @defgroup HAL_I2S_Aliased_Macros HAL I2S Aliased Macros maintained for legacy purpose
@@ -2207,7 +2211,7 @@
/** @defgroup HAL_IRDA_Aliased_Macros HAL IRDA Aliased Macros maintained for legacy purpose
@@ -2228,7 +2232,7 @@
/** @defgroup HAL_IWDG_Aliased_Macros HAL IWDG Aliased Macros maintained for legacy purpose
#define __HAL_IWDG_ENABLE_WRITE_ACCESS IWDG_ENABLE_WRITE_ACCESS
@@ -2239,7 +2243,7 @@
/** @defgroup HAL_LPTIM_Aliased_Macros HAL LPTIM Aliased Macros maintained for legacy purpose
@@ -2253,7 +2257,7 @@
/** @defgroup HAL_OPAMP_Aliased_Macros HAL OPAMP Aliased Macros maintained for legacy purpose
#define __OPAMP_CSR_OPAXPD OPAMP_CSR_OPAXPD
@@ -2276,7 +2280,7 @@
/** @defgroup HAL_PWR_Aliased_Macros HAL PWR Aliased Macros maintained for legacy purpose
#define __HAL_PVD_EVENT_DISABLE __HAL_PWR_PVD_EXTI_DISABLE_EVENT
@@ -2334,7 +2338,7 @@
/** @defgroup HAL_RCC_Aliased HAL RCC Aliased maintained for legacy purpose
@@ -3428,7 +3432,7 @@
/** @defgroup HAL_RNG_Aliased_Macros HAL RNG Aliased Macros maintained for legacy purpose
#define HAL_RNG_ReadyCallback(__HANDLE__) HAL_RNG_ReadyDataCallback((__HANDLE__), uint32_t random32bit)
@@ -3438,7 +3442,7 @@
/** @defgroup HAL_RTC_Aliased_Macros HAL RTC Aliased Macros maintained for legacy purpose
#if defined (STM32G0) || defined (STM32L5) || defined (STM32L412xx) || defined (STM32L422xx) || defined (STM32L4P5xx) || defined (STM32L4Q5xx) || defined (STM32G4)
@@ -3499,7 +3503,7 @@
/** @defgroup HAL_SD_Aliased_Macros HAL SD Aliased Macros maintained for legacy purpose
@@ -3581,7 +3585,7 @@
/** @defgroup HAL_SMARTCARD_Aliased_Macros HAL SMARTCARD Aliased Macros maintained for legacy purpose
@@ -3602,7 +3606,7 @@
/** @defgroup HAL_SMBUS_Aliased_Macros HAL SMBUS Aliased Macros maintained for legacy purpose
#define __HAL_SMBUS_RESET_CR1 SMBUS_RESET_CR1
@@ -3618,7 +3622,7 @@
/** @defgroup HAL_SPI_Aliased_Macros HAL SPI Aliased Macros maintained for legacy purpose
@@ -3631,7 +3635,7 @@
/** @defgroup HAL_UART_Aliased_Macros HAL UART Aliased Macros maintained for legacy purpose
@@ -3651,7 +3655,7 @@
/** @defgroup HAL_USART_Aliased_Macros HAL USART Aliased Macros maintained for legacy purpose
@@ -3668,7 +3672,7 @@
/** @defgroup HAL_USB_Aliased_Macros HAL USB Aliased Macros maintained for legacy purpose
#define USB_EXTI_LINE_WAKEUP USB_WAKEUP_EXTI_LINE
@@ -3719,7 +3723,7 @@
/** @defgroup HAL_TIM_Aliased_Macros HAL TIM Aliased Macros maintained for legacy purpose
#define __HAL_TIM_SetICPrescalerValue TIM_SET_ICPRESCALERVALUE
@@ -3749,7 +3753,7 @@
/** @defgroup HAL_ETH_Aliased_Macros HAL ETH Aliased Macros maintained for legacy purpose
@@ -3769,7 +3773,7 @@
/** @defgroup HAL_LTDC_Aliased_Macros HAL LTDC Aliased Macros maintained for legacy purpose
#define __HAL_LTDC_LAYER LTDC_LAYER
@@ -3779,7 +3783,7 @@
/** @defgroup HAL_SAI_Aliased_Macros HAL SAI Aliased Macros maintained for legacy purpose
#define SAI_OUTPUTDRIVE_DISABLED SAI_OUTPUTDRIVE_DISABLE
@@ -3801,7 +3805,7 @@
/** @defgroup HAL_SPDIFRX_Aliased_Macros HAL SPDIFRX Aliased Macros maintained for legacy purpose
#if defined(STM32H7)
@@ -3814,7 +3818,7 @@
/** @defgroup HAL_HRTIM_Aliased_Functions HAL HRTIM Aliased Functions maintained for legacy purpose
#if defined (STM32H7) || defined (STM32G4) || defined (STM32F3)
@@ -3830,7 +3834,7 @@
/** @defgroup HAL_QSPI_Aliased_Macros HAL QSPI Aliased Macros maintained for legacy purpose
#if defined (STM32L4) || defined (STM32F4) || defined (STM32F7) || defined(STM32H7)
@@ -3841,7 +3845,7 @@
/** @defgroup HAL_PPP_Aliased_Macros HAL PPP Aliased Macros maintained for legacy purpose
2.25.1
