[PATCH] Fix calloc() behaviour in case of overflow
Gedare Bloom
gedare at rtems.org
Tue Apr 20 18:37:26 UTC 2021
Looks good.
On Tue, Apr 20, 2021, 12:33 PM Sebastian Huber <
> The multiplication to calculate the length of the memory area to
> allocate may overflow. Return NULL in case of an overflow.
> Close #4389.
> cpukit/libcsupport/src/calloc.c | 13 ++++++++++++-
> cpukit/libcsupport/src/rtemscalloc.c | 9 ++++++++-
> testsuites/libtests/malloctest/init.c | 23 +++++++++++++----------
> 3 files changed, 33 insertions(+), 12 deletions(-)
> diff --git a/cpukit/libcsupport/src/calloc.c
> b/cpukit/libcsupport/src/calloc.c
> index e015f30d6c..693aa21453 100644
> --- a/cpukit/libcsupport/src/calloc.c
> +++ b/cpukit/libcsupport/src/calloc.c
> @@ -20,7 +20,10 @@
> #if defined(RTEMS_NEWLIB) && !defined(HAVE_CALLOC)
> #include <stdlib.h>
> +#include <errno.h>
> #include <string.h>
> #include <rtems/score/basedefs.h>
> void *calloc(
> @@ -31,7 +34,15 @@ void *calloc(
> void *cptr;
> size_t length;
> - length = nelem * elsize;
> + if ( nelem == 0 ) {
> + length = 0;
> + } else if ( elsize > SIZE_MAX / nelem ) {
> + errno = ENOMEM;
> + return NULL;
> + } else {
> + length = nelem * elsize;
> cptr = malloc( length );
> RTEMS_OBFUSCATE_VARIABLE( cptr );
> if ( RTEMS_PREDICT_FALSE( cptr == NULL ) ) {
> diff --git a/cpukit/libcsupport/src/rtemscalloc.c
> b/cpukit/libcsupport/src/rtemscalloc.c
> index 4e189e8367..836f1da64d 100644
> --- a/cpukit/libcsupport/src/rtemscalloc.c
> +++ b/cpukit/libcsupport/src/rtemscalloc.c
> @@ -46,7 +46,14 @@ void *rtems_calloc( size_t nelem, size_t elsize )
> size_t length;
> void *p;
> + length = 0;
> + return NULL;
> + } else {
> p = rtems_malloc( length );
> RTEMS_OBFUSCATE_VARIABLE( p );
> if ( RTEMS_PREDICT_FALSE( p == NULL ) ) {
> diff --git a/testsuites/libtests/malloctest/init.c
> b/testsuites/libtests/malloctest/init.c
> index 1d91385683..4d0f421c02 100644
> --- a/testsuites/libtests/malloctest/init.c
> +++ b/testsuites/libtests/malloctest/init.c
> @@ -1190,6 +1190,14 @@ static void test_rtems_calloc(void)
> rtems_test_assert(p == NULL);
> rtems_test_assert(errno == 0);
> +#pragma GCC diagnostic push
> +#pragma GCC diagnostic ignored "-Walloc-size-larger-than=N"
> + errno = 0;
> + p = rtems_calloc(SIZE_MAX, SIZE_MAX);
> + rtems_test_assert(p == NULL);
> + rtems_test_assert(errno == 0);
> +#pragma GCC diagnostic pop
> i = rtems_calloc(1, sizeof(*i));
> rtems_test_assert(i != NULL);
> rtems_test_assert(*i == 0);
> @@ -1313,22 +1321,17 @@ rtems_task Init(
> p1 = calloc( 1, SIZE_MAX );
> + rtems_test_assert( p1 == NULL );
> + p1 = calloc( SIZE_MAX, SIZE_MAX );
> - if (p1) {
> - printf("ERROR on attempt to calloc SIZE_MAX block expected failure.");
> - free( p1 );
> * Verify error case where malloc of size 0.
> p1 = malloc( 0 );
> - if (p1) {
> - printf("ERROR on attempt to malloc size 0 block expected failure.");
> - free( p1 );
> test_heap_initialize();
> test_heap_block_allocate();
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210420/d55edffa/attachment.html>
