[PATCH 8/8] c-user: Generate dual-ported memory manager docs
Wed Apr 21 15:28:51 UTC 2021
On Wed, Apr 21, 2021 at 7:50 AM Sebastian Huber
> The documentation is a consolidation of the comments in Doxygen markup
> and the documentation sources in Sphinx markup.  The documentation was
> transfered to interface specification items.  The documentation source
> files were generated from the items by a script.
> Update #3993.
>  c-user/dual-ported-memory/directives.rst   | 500 ++++++++++++++-------
>  c-user/dual-ported-memory/introduction.rst |  43 +-
>  2 files changed, 373 insertions(+), 170 deletions(-)
> diff --git a/c-user/dual-ported-memory/directives.rst b/c-user/dual-ported-memory/directives.rst
> index fb21a4f..d701a2b 100644
> --- a/c-user/dual-ported-memory/directives.rst
> +++ b/c-user/dual-ported-memory/directives.rst
> @@ -1,229 +1,403 @@
>  .. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020, 2021 embedded brains GmbH (http://www.embedded-brains.de)
>  .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
> +.. This file is part of the RTEMS quality process and was automatically
> +.. generated.  If you find something that needs to be fixed or
> +.. worded better please post a report or patch to an RTEMS mailing list
> +.. or raise a bug report:
> +.. https://www.rtems.org/bugs.html
> +.. For information on updating and regenerating please refer to the How-To
> +.. section in the Software Requirements Engineering chapter of the
> +.. RTEMS Software Engineering manual.  The manual is provided as a part of
> +.. a release.  For development sources please refer to the online
> +.. documentation at:
> +.. https://docs.rtems.org
> +.. _DualPortedMemoryManagerDirectives:
>  Directives
> -This section details the dual-ported memory manager's directives.  A subsection
> -is dedicated to each of this manager's directives and describes the calling
> -sequence, related constants, usage, and status codes.
> +This section details the directives of the Dual-Ported Memory Manager. A
> +subsection is dedicated to each of this manager's directives and lists the
> +calling sequence, parameters, description, return values, and notes of the
> +directive.
> +.. Generated from spec:/rtems/dpmem/if/create
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_port_create()
>  .. index:: create a port
> -.. index:: rtems_port_create
> -.. _rtems_port_create:
> -PORT_CREATE - Create a port
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        rtems_status_code rtems_port_create(
> -            rtems_name  name,
> -            void       *internal_start,
> -            void       *external_start,
> -            uint32_t    length,
> -            rtems_id   *id
> -DIRECTIVE STATUS CODES:
> -    .. list-table::
> -     :class: rtems-table
> -     * - ``RTEMS_SUCCESSFUL``
> -       - port created successfully
> -     * - ``RTEMS_INVALID_NAME``
> -       - invalid port name
> -     * - ``RTEMS_INVALID_ADDRESS``
> -       - address not on four byte boundary
> -       - ``id`` is NULL
> -     * - ``RTEMS_TOO_MANY``
> -       - too many DP memory areas created
> -DESCRIPTION:
> -    This directive creates a port which resides on the local node for the
> -    specified DPMA.  The assigned port id is returned in id.  This port id is
> -    used as an argument to other dual-ported memory manager directives to
> -    convert addresses within this DPMA.
> -    For control and maintenance of the port, RTEMS allocates and initializes an
> -    DPCB from the DPCB free pool.  Thus memory from the dual-ported memory area
> -    is not used to store the DPCB.
> -NOTES:
> -    This directive may cause the calling task to be preempted due to an
> -    obtain and release of the object allocator mutex.
> -    The internal_address and external_address parameters must be on a four byte
> -    boundary.
> +.. _InterfaceRtemsPortCreate:
> +rtems_port_create()
> +Creates a port.
> +.. rubric:: CALLING SEQUENCE:
> +.. code-block:: c
> +    rtems_status_code rtems_port_create(
> +      rtems_name name,
> +      void      *internal_start,
> +      void      *external_start,
> +      uint32_t   length,
> +      rtems_id  *id
> +.. rubric:: PARAMETERS:
> +``name``
> +    This parameter is the object name of the port.
> +``internal_start``
> +    This parameter is the internal start address of the memory area.
> +``external_start``
> +    This parameter is the external start address of the memory area.
> +``length``
> +    This parameter is the length in bytes of the memory area.
> +``id``
> +    This parameter is the pointer to an object identifier variable.  When the
> +    directive call is successful, the identifier of the created port will be
> +    stored in this variable.
> +.. rubric:: DESCRIPTION:
> +This directive creates a port which resides on the local node.  The port has
> +the user-defined object name specified in ``name``.  The assigned object
> +identifier is returned in ``id``.  This identifier is used to access the port
> +with other dual-ported memory port related directives.
> +.. rubric:: RETURN VALUES:
> +:c:macro:`RTEMS_SUCCESSFUL`
> +    The requested operation was successful.
> +:c:macro:`RTEMS_INVALID_NAME`
> +    The ``name`` parameter was invalid.
> +:c:macro:`RTEMS_INVALID_ADDRESS`
> +    The ``length`` parameter was `NULL
id?
everything else looks ok
> +    <https://en.cppreference.com/w/c/types/NULL>`_.
> +    The ``internal_start`` parameter was not properly aligned.
> +    The ``external_start`` parameter was not properly aligned.
> +:c:macro:`RTEMS_TOO_MANY`
> +    There was no inactive object available to create a port.  The number of
> +    port available to the application is configured through the
> +    :ref:`CONFIGURE_MAXIMUM_PORTS` application configuration option.
> +.. rubric:: NOTES:
> +The ``internal_start`` and ``external_start`` parameters must be on a boundary
> +defined by the target processor architecture.
> +For control and maintenance of the port, RTEMS allocates a :term:`DPCB` from
> +the local DPCB free pool and initializes it.
> +.. rubric:: CONSTRAINTS:
> +The following constraints apply to this directive:
> +* The directive may be called from within device driver initialization context.
> +* The directive may be called from within task context.
> +* The directive may obtain and release the object allocator mutex.  This may
> +  cause the calling task to be preempted.
> +* The number of ports available to the application is configured through the
> +* Where the object class corresponding to the directive is configured to use
> +  unlimited objects, the directive may allocate memory from the RTEMS
> +  Workspace.
> +.. Generated from spec:/rtems/dpmem/if/ident
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_port_ident()
> +.. _InterfaceRtemsPortIdent:
> +rtems_port_ident()
> +Identifies a port by the object name.
> +.. code-block:: c
> +    rtems_status_code rtems_port_ident( rtems_name name, rtems_id *id );
> +``name``
> +    This parameter is the object name to look up.
> +``id``
> +    directive call is successful, the object identifier of an object with the
> +    specified name will be stored in this variable.
> +This directive obtains a port identifier associated with the port name
> +specified in ``name``.
> -.. index:: get ID of a port
> -.. index:: obtain ID of a port
> -.. index:: rtems_port_ident
> -.. _rtems_port_ident:
> -PORT_IDENT - Get ID of a port
> +    The ``id`` parameter was `NULL
> -CALLING SEQUENCE:
> -    .. code-block:: c
> +    The ``name`` parameter was 0.
> -        rtems_status_code rtems_port_ident(
> -            rtems_name  name,
> -            rtems_id   *id
> +    There was no object with the specified name on the local node.
> -    .. list-table::
> +.. rubric:: NOTES:
> -       - port identified successfully
> -       - ``id`` is NULL
> -       - port name not found
> +If the port name is not unique, then the port identifier will match the first
> +port with that name in the search order.  However, this port identifier is not
> +guaranteed to correspond to the desired port.
> -DESCRIPTION:
> -    This directive obtains the port id associated with the specified name to be
> -    acquired.  If the port name is not unique, then the port id will match one
> -    of the DPMAs with that name.  However, this port id is not guaranteed to
> -    correspond to the desired DPMA.  The port id is used to access this DPMA in
> -    other dual-ported memory area related directives.
> +The objects are searched from lowest to the highest index.  Only the local node
> +is searched.
> -NOTES:
> -    This directive will not cause the running task to be preempted.
> +The port identifier is used with other dual-ported memory related directives to
> +access the port.
> +* The directive may be called from within any runtime context.
> +* The directive will not cause the calling task to be preempted.
> +.. Generated from spec:/rtems/dpmem/if/delete
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_port_delete()
>  .. index:: delete a port
> -.. index:: rtems_port_delete
> -.. _rtems_port_delete:
> +.. _InterfaceRtemsPortDelete:
> +rtems_port_delete()
> +Deletes the port.
> +.. code-block:: c
> +    rtems_status_code rtems_port_delete( rtems_id id );
> +``id``
> +    This parameter is the port identifier.
> -PORT_DELETE - Delete a port
> -CALLING SEQUENCE:
> -    .. code-block:: c
> +This directive deletes the port specified by ``id``.
> -        rtems_status_code rtems_port_delete(
> -            rtems_id id
> -    .. list-table::
> -       - port deleted successfully
> -     * - ``RTEMS_INVALID_ID``
> -       - invalid port id
> +:c:macro:`RTEMS_INVALID_ID`
> +    There was no port associated with the identifier specified by ``id``.
> -DESCRIPTION:
> -    This directive deletes the dual-ported memory area specified by id.  The
> -    DPCB for the deleted dual-ported memory area is reclaimed by RTEMS.
> +.. rubric:: NOTES:
> -NOTES:
> +The :term:`DPCB` for the deleted port is reclaimed by RTEMS.
> -    The calling task does not have to be the task that created the port.  Any
> -    local task that knows the port id can delete the port.
> +* The calling task does not have to be the task that created the object.  Any
> +  local task that knows the object identifier can delete the object.
> +  unlimited objects, the directive may free memory to the RTEMS Workspace.
> +.. Generated from spec:/rtems/dpmem/if/external-to-internal
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_port_external_to_internal()
>  .. index:: convert external to internal address
> -.. index:: rtems_port_external_to_internal
> -.. _rtems_port_external_to_internal:
> +.. _InterfaceRtemsPortExternalToInternal:
> +rtems_port_external_to_internal()
> +Converts the external address to the internal address.
> +.. code-block:: c
> -PORT_EXTERNAL_TO_INTERNAL - Convert external to internal address
> +    rtems_status_code rtems_port_external_to_internal(
> +      rtems_id id,
> +      void    *external,
> +      void   **internal
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        rtems_status_code rtems_port_external_to_internal(
> -            rtems_id   id,
> -            void      *external,
> -            void     **internal
> +``id``
> -    .. list-table::
> +``external``
> +    This parameter is the external address to convert.
> -       - ``internal`` is NULL
> -       - successful conversion
> +``internal``
> +    This parameter is the pointer to a pointer variable.  When the directive
> +    call is successful, the external address associated with the internal
> +    address will be stored in this variable.
> -DESCRIPTION:
> -    This directive converts a dual-ported memory address from external to
> -    internal representation for the specified port.  If the given external
> -    address is invalid for the specified port, then the internal address is set
> -    to the given external address.
> -NOTES:
> -    This directive is callable from an ISR.
> +This directive converts a dual-ported memory address from external to internal
> +representation for the specified port.  If the given external address is
> +invalid for the specified port, then the internal address is set to the given
> +external address.
> -    This directive will not cause the calling task to be preempted.
> +    The ``id`` parameter was invalid.
> +    The ``internal`` parameter was `NULL
> +* The directive may be called from within interrupt context.
> +.. Generated from spec:/rtems/dpmem/if/internal-to-external
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_port_internal_to_external()
>  .. index:: convert internal to external address
> -.. index:: rtems_port_internal_to_external
> -.. _rtems_port_internal_to_external:
> +.. _InterfaceRtemsPortInternalToExternal:
> +rtems_port_internal_to_external()
> +Converts the internal address to the external address.
> +.. code-block:: c
> +    rtems_status_code rtems_port_internal_to_external(
> +      rtems_id id,
> +      void    *internal,
> +      void   **external
> +``id``
> +``internal``
> +    This parameter is the internal address to convert.
> +``external``
> +This directive converts a dual-ported memory address from internal to external
> +representation so that it can be passed to owner of the DPMA represented by the
> +specified port.  If the given internal address is an invalid dual-ported
> +address, then the external address is set to the given internal address.
> -PORT_INTERNAL_TO_EXTERNAL - Convert internal to external address
> -CALLING SEQUENCE:
> -    .. code-block:: c
> +    The ``external`` parameter was `NULL
> -        rtems_status_code rtems_port_internal_to_external(
> -            rtems_id   id,
> -            void      *internal,
> -            void     **external
> -    .. list-table::
> -       - ``external`` is NULL
> -DESCRIPTION:
> -    This directive converts a dual-ported memory address from internal to
> -    external representation so that it can be passed to owner of the DPMA
> -    represented by the specified port.  If the given internal address is an
> -    invalid dual-ported address, then the external address is set to the given
> -    internal address.
> -NOTES:
> diff --git a/c-user/dual-ported-memory/introduction.rst b/c-user/dual-ported-memory/introduction.rst
> index 752a162..fd7cc8e 100644
> --- a/c-user/dual-ported-memory/introduction.rst
> +++ b/c-user/dual-ported-memory/introduction.rst
> @@ -1,20 +1,49 @@
> +.. Generated from spec:/rtems/dpmem/if/group
> +.. _DualPortedMemoryManagerIntroduction:
>  Introduction
> -The dual-ported memory manager provides a mechanism for converting addresses
> +.. The following list was generated from:
> +.. spec:/rtems/dpmem/if/create
> +.. spec:/rtems/dpmem/if/ident
> +.. spec:/rtems/dpmem/if/delete
> +.. spec:/rtems/dpmem/if/external-to-internal
> +.. spec:/rtems/dpmem/if/internal-to-external
> +The Dual-Ported Memory Manager provides a mechanism for converting addresses
>  between internal and external representations for multiple dual-ported memory
> -areas (DPMA).  The directives provided by the dual-ported memory manager are:
> +areas (DPMA). The directives provided by the Dual-Ported Memory Manager are:
> -- :ref:`rtems_port_create`
> +* :ref:`InterfaceRtemsPortCreate` - Creates a port.
> -- :ref:`rtems_port_ident`
> +* :ref:`InterfaceRtemsPortIdent` - Identifies a port by the object name.
> -- :ref:`rtems_port_delete`
> +* :ref:`InterfaceRtemsPortDelete` - Deletes the port.
> -- :ref:`rtems_port_external_to_internal`
> +* :ref:`InterfaceRtemsPortExternalToInternal` - Converts the external address
> +  to the internal address.
> -- :ref:`rtems_port_internal_to_external`
> +* :ref:`InterfaceRtemsPortInternalToExternal` - Converts the internal address
> +  to the external address.
> 2.26.2
> devel mailing list
> devel at rtems.org
