[PATCH] sb: Merge mailer changes from rtems-tools
Alex White alex.white at oarcorp.com
Thu Apr 22 01:48:53 UTC 2021
On Wed, Apr 21, 2021 at 5:06 PM Chris Johns <chrisj at rtems.org> wrote:
> Hi Alex,
> Is there a chance the password can end up in a log file?
I did not see the command line options in the email when I sent it to myself so it wasn't on my radar, but it could have ended up in a log file, yes.
I should do the same thing to this that I did in rtems-tools here: https://git.rtems.org/rtems-tools/commit/?id=92f7f67297b9053e6846760e6c8059be0fa1c86c
Would that change to remove sensitive command line options make this patch acceptable?
Thanks,
Alex
> See...
> https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/options.py#n584
> Chris
> On 22/4/21 8:00 am, Alex White wrote:
> > This adds the improved mailer.py script from rtems-tools.
> > Closes #4388
> >  source-builder/sb/mailer.py     | 192 ++++++++++++++++++++++++++------
> >  source-builder/sb/options.py    |   9 ++
> >  source-builder/sb/setbuilder.py |   2 +
> >  3 files changed, 171 insertions(+), 32 deletions(-)
> > diff --git a/source-builder/sb/mailer.py b/source-builder/sb/mailer.py
> > index ff25df5..ee5bf07 100644
> > --- a/source-builder/sb/mailer.py
> > +++ b/source-builder/sb/mailer.py
> > @@ -1,21 +1,32 @@
> >  # RTEMS Tools Project (http://www.rtems.org/)
> > -# Copyright 2013 Chris Johns (chrisj at rtems.org)
> > +# Copyright 2013-2016 Chris Johns (chrisj at rtems.org)
> >  # All rights reserved.
> >  # This file is part of the RTEMS Tools package in 'rtems-tools'.
> > -# Permission to use, copy, modify, and/or distribute this software for any
> > -# purpose with or without fee is hereby granted, provided that the above
> > -# copyright notice and this permission notice appear in all copies.
> > +# Redistribution and use in source and binary forms, with or without
> > +# modification, are permitted provided that the following conditions are met:
> > +# 1. Redistributions of source code must retain the above copyright notice,
> > +# this list of conditions and the following disclaimer.
> > +# 2. Redistributions in binary form must reproduce the above copyright notice,
> > +# this list of conditions and the following disclaimer in the documentation
> > +# and/or other materials provided with the distribution.
> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> > +# POSSIBILITY OF SUCH DAMAGE.
> > -# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
> > -# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
> > -# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
> > -# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
> > -# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
> > -# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
> > -# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
> >  # Manage emailing results or reports.
> > @@ -28,18 +39,71 @@ import smtplib
> >  import socket
> >  from . import error
> > +from . import execute
> >  from . import options
> >  from . import path
> > +_options = {
> > +    '--mail'         : 'Send email report or results.',
> > +    '--use-gitconfig': 'Use mail configuration from git config.',
> > +    '--mail-to'      : 'Email address to send the email to.',
> > +    '--mail-from'    : 'Email address the report is from.',
> > +    '--smtp-host'    : 'SMTP host to send via.',
> > +    '--smtp-port'    : 'SMTP port to send via.',
> > +    '--smtp-user'    : 'User for SMTP authentication.',
> > +    '--smtp-password': 'Password for SMTP authentication.'
> >  def append_options(opts):
> > -    opts['--mail'] = 'Send email report or results.'
> > -    opts['--smtp-host'] = 'SMTP host to send via.'
> > -    opts['--mail-to'] = 'Email address to send the email too.'
> > -    opts['--mail-from'] = 'Email address the report is from.'
> > +    for o in _options:
> > +        opts[o] = _options[o]
> > +def add_arguments(argsp):
> > +    argsp.add_argument('--mail', help = _options['--mail'], action = 'store_true')
> > +    argsp.add_argument('--use-gitconfig', help = _options['--use-gitconfig'], action = 'store_true')
> > +    for o in list(_options)[1:]:
> > +        argsp.add_argument(o, help = _options[o], type = str)
> >  class mail:
> >      def __init__(self, opts):
> >          self.opts = opts
> > +        self.gitconfig_lines = None
> > +        if opts.find_arg('--use-gitconfig') is not None:
> > +            # Read the output of `git config --list` instead of reading the
> > +            # .gitconfig file directly because Python 2 ConfigParser does not
> > +            # accept tabs at the beginning of lines.
> > +            e = execute.capture_execution()
> > +            exit_code, proc, output = e.open('git config --list', shell=True)
> > +            if exit_code == 0:
> > +                self.gitconfig_lines = output.split(os.linesep)
> > +    def _args_are_macros(self):
> > +        return isinstance(self.opts, options.command_line)
> > +    def _get_arg(self, arg):
> > +        if self._args_are_macros():
> > +            value = self.opts.find_arg(arg)
> > +            if value is not None:
> > +                value = self.opts.find_arg(arg)[1]
> > +        else:
> > +            if arg.startswith('--'):
> > +                arg = arg[2:]
> > +            arg = arg.replace('-', '_')
> > +            if arg in vars(self.opts):
> > +                value = vars(self.opts)[arg]
> > +            else:
> > +                value = None
> > +        return value
> > +    def _get_from_gitconfig(self, variable_name):
> > +        if self.gitconfig_lines is None:
> > +            return None
> > +        for line in self.gitconfig_lines:
> > +            if line.startswith(variable_name):
> > +                ls = line.split('=')
> > +                if len(ls) >= 2:
> > +                    return ls[1]
> >      def from_address(self):
> > @@ -52,9 +116,15 @@ class mail:
> >                  l = l[:l.index('\n')]
> >              return l.strip()
> > -        addr = self.opts.get_arg('--mail-from')
> > +        addr = self._get_arg('--mail-from')
> >          if addr is not None:
> > -            return addr[1]
> > +            return addr
> > +        addr = self._get_from_gitconfig('user.email')
> > +        if addr is not None:
> > +            name = self._get_from_gitconfig('user.name')
> > +            if name is not None:
> > +                addr = '%s <%s>' % (name, addr)
> > +            return addr
> >          mailrc = None
> >          if 'MAILRC' in os.environ:
> >              mailrc = os.environ['MAILRC']
> > @@ -63,9 +133,8 @@ class mail:
> >          if mailrc is not None and path.exists(mailrc):
> >              # set from="Joe Blow <joe at blow.org>"
> >              try:
> > -                mrc = open(mailrc, 'r')
> > -                lines = mrc.readlines()
> > -                mrc.close()
> > +                with open(mailrc, 'r') as mrc:
> > +                    lines = mrc.readlines()
> >              except IOError as err:
> >                  raise error.general('error reading: %s' % (mailrc))
> >              for l in lines:
> > @@ -76,40 +145,99 @@ class mail:
> >                          addr = fa[fa.index('=') + 1:].replace('"', ' ').strip()
> >                  return addr
> > -        addr = self.opts.defaults.get_value('%{_sbgit_mail}')
> > +            addr = self.opts.defaults.get_value('%{_sbgit_mail}')
> > +        else:
> > +            raise error.general('no valid from address for mail')
> >          return addr
> >      def smtp_host(self):
> > -        host = self.opts.get_arg('--smtp-host')
> > +        host = self._get_arg('--smtp-host')
> >          if host is not None:
> > -            return host[1]
> > -        host = self.opts.defaults.get_value('%{_mail_smtp_host}')
> > +            return host
> > +        host = self._get_from_gitconfig('sendemail.smtpserver')
> > +        if host is not None:
> > +            return host
> > +            host = self.opts.defaults.get_value('%{_mail_smtp_host}')
> >              return host
> >          return 'localhost'
> > +    def smtp_port(self):
> > +        port = self._get_arg('--smtp-port')
> > +        if port is not None:
> > +            return port
> > +        port = self._get_from_gitconfig('sendemail.smtpserverport')
> > +            return port
> > +            port = self.opts.defaults.get_value('%{_mail_smtp_port}')
> > +        return port
> > +    def smtp_user(self):
> > +        user = self._get_arg('--smtp-user')
> > +        if user is not None:
> > +            return user
> > +        user = self._get_from_gitconfig('sendemail.smtpuser')
> > +        return user
> > +    def smtp_password(self):
> > +        password = self._get_arg('--smtp-password')
> > +        if password is not None:
> > +            return password
> > +        password = self._get_from_gitconfig('sendemail.smtppass')
> > +        return password
> >      def send(self, to_addr, subject, body):
> >          from_addr = self.from_address()
> >          msg = "From: %s\r\nTo: %s\r\nSubject: %s\r\n\r\n" % \
> >              (from_addr, to_addr, subject) + body
> > -        if type(to_addr) is str:
> > -            to_addr = to_addr.split(',')
> > -        if type(to_addr) is not list:
> > -            raise error.general('invalid to_addr type')
> > +        port = self.smtp_port()
> >          try:
> > -            s = smtplib.SMTP(self.smtp_host())
> > -            s.sendmail(from_addr, to_addr, msg)
> > +            s = smtplib.SMTP(self.smtp_host(), port, timeout=10)
> > +            password = self.smtp_password()
> > +            # If a password is provided, assume that authentication is required.
> > +                user = self.smtp_user()
> > +                if user is None:
> > +                    user = from_addr
> > +                s.starttls()
> > +                s.login(user, password)
> > +            s.sendmail(from_addr, [to_addr], msg)
> >          except smtplib.SMTPException as se:
> >              raise error.general('sending mail: %s' % (str(se)))
> >          except socket.error as se:
> > +    def send_file_as_body(self, to_addr, subject, name, intro = None):
> > +        try:
> > +            with open(name, 'r') as f:
> > +                body = f.readlines()
> > +        except IOError as err:
> > +            raise error.general('error reading mail body: %s' % (name))
> > +        if intro is not None:
> > +            body = intro + body
> > +        self.send(to_addr, from_addr, body)
> >  if __name__ == '__main__':
> >      import sys
> > +    from . import macros
> >      optargs = {}
> > +    rtdir = 'source-builder'
> > +    defaults = '%s/defaults.mc' % (rtdir)
> >      append_options(optargs)
> > -    opts = options.load(sys.argv, optargs = optargs, defaults = 'defaults.mc')
> > +    opts = options.command_line(base_path = '.',
> > +                                argv = sys.argv,
> > +                                optargs = optargs,
> > +                                defaults = macros.macros(name = defaults, rtdir = rtdir),
> > +                                command_path = '.')
> > +    options.load(opts)
> >      m = mail(opts)
> >      print('From: %s' % (m.from_address()))
> >      print('SMTP Host: %s' % (m.smtp_host()))
> > -    m.send(m.from_address(), 'Test mailer.py', 'This is a test')
> > +    if '--mail' in sys.argv:
> > +        m.send(m.from_address(), 'Test mailer.py', 'This is a test')
> > diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
> > index d6bffd0..a74db6b 100644
> > --- a/source-builder/sb/options.py
> > +++ b/source-builder/sb/options.py
> > @@ -517,6 +517,15 @@ class command_line:
> >              return None
> >          return self.parse_args(arg)
> > +    def find_arg(self, arg):
> > +        if self.optargs is None or arg not in self.optargs:
> > +            raise error.internal('bad arg: %s' % (arg))
> > +        for a in self.args:
> > +            sa = a.split('=')
> > +            if sa[0].startswith(arg):
> > +                return sa
> > +        return None
> >      def with_arg(self, label, default = 'not-found'):
> >          # the default if there is no option for without.
> >          result = default
> > diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
> > index b0e2b23..c8c8fee 100644
> > --- a/source-builder/sb/setbuilder.py
> > +++ b/source-builder/sb/setbuilder.py
> > @@ -695,6 +695,8 @@ def run():
> >                       'log'    : '',
> >                       'reports': [],
> >                       'failure': None }
> > +            # Request this now to generate any errors.
> > +            smtp_host = mail['mail'].smtp_host()
> >              to_addr = opts.get_arg('--mail-to')
> >              if to_addr is not None:
> >                  mail['to'] = to_addr[1]
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210422/6b470eb9/attachment-0001.html>
