[PATCH] psx13: Reworked and relicensed
Gedare Bloom
gedare at rtems.org
Thu Apr 22 13:44:53 UTC 2021
See below for comments. This test suite might be a good candidate for
conversion to T_TEST_CASE framework. At any rate, this refactor is a
marked improvement.
On Wed, Apr 21, 2021 at 2:57 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> Changed the way the tests were structured, added rtems_test_assert()'s,
> updated psx13.scn and the license.
relicense changes should generally Update #3899.
> testsuites/psxtests/psx13/psx13.scn | 24 +-
> testsuites/psxtests/psx13/test.c | 879 +++++++++++++-----------------------
> 2 files changed, 335 insertions(+), 568 deletions(-)
> diff --git a/testsuites/psxtests/psx13/psx13.scn b/testsuites/psxtests/psx13/psx13.scn
> index 428a931..ee99867 100644
> --- a/testsuites/psxtests/psx13/psx13.scn
> +++ b/testsuites/psxtests/psx13/psx13.scn
> @@ -1,16 +1,16 @@
> *** POSIX TEST 13 ***
> Files initialized successfully.
> -Testing device_lseek()... Failed!!!
> -Testing dup()............ Failed!!!
> -Testing dup2()........... Success.
> -Testing fdatasync()...... Success.
> -Testing umask().......... Success.
> -Testing utime().......... Success.
> -Testing utimes().......... Success.
> -Testing fsync().......... Success.
> -Testing pathconf()....... Success.
> -Testing fpathconf()...... Success.
> -Testing sync()......
> +Testing lseek() on device... Success.
> +Testing dup()............... Success.
> +Testing dup2().............. Success.
> +Testing fdatasync()......... Success.
> +Testing umask()............. Success.
> +Testing utime()............. Success.
> +Testing utimes()............ Success.
> +Testing fsync()............. Success.
> +Testing pathconf().......... Success.
> +Testing fpathconf()......... Success.
> +Testing sync().............. Success.
> -*** END OF TEST PSX13 ***
> +*** END OF TEST PSX 13 ***
> diff --git a/testsuites/psxtests/psx13/test.c b/testsuites/psxtests/psx13/test.c
> index 79b24c2..2d25b02 100644
> --- a/testsuites/psxtests/psx13/test.c
> +++ b/testsuites/psxtests/psx13/test.c
> @@ -1,26 +1,49 @@
> - * Psx13
> - * Chris Bond (working under Jennifer's account)
> + * @file
> + * @brief This tests various file system functions.
> * This test exercises the following routines:
> - * device_lseek - test implemented
> - * dup - test implemented
> - * dup2 - test implemented
> - * fdatasync - test implemented
> - * fsync - test implemented
> - * pathconf - test implemented
> - * fpathconf - test implemented
> - * umask - test implemented
> - * utime - test implemented
> - * utimes - test implemented
> + * - lseek()
> + * - dup()
> + * - dup2()
> + * - fdatasync()
> + * - fsync()
> + * - pathconf()
> + * - fpathconf()
> + * - umask()
> + * - utime()
> + * - utimes()
> + * - sync()
While you're at it, please conform to
https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#c-c-header-file-template
> + * SPDX-License-Identifier: BSD-2-Clause
> - * COPYRIGHT (c) 1989-2009.
> + * COPYRIGHT (c) 1989-2009, 2021.
> * On-Line Applications Research Corporation (OAR).
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> #ifdef HAVE_CONFIG_H
> @@ -34,6 +57,7 @@
> #include <unistd.h>
> #include <errno.h>
> #include <utime.h>
> +#include <tmacros.h>
> #include <stdio.h>
> #include <unistd.h>
> @@ -42,685 +66,428 @@
> const char rtems_test_name[] = "PSX 13";
> -int InitFiles(void);
> -int DeviceLSeekTest(void);
> -int DupTest(void);
> -int Dup2Test(void);
> -int FDataSyncTest(void);
> -int UMaskTest(void);
> -int UTimeTest(void);
> -int UTimesTest(void);
> -int PathConfTest(void);
> -int FPathConfTest(void);
> -int FSyncTest(void);
> - * InitFiles function
> - * Initializes the three files to be used in the test.
> - * arguments: none
> - * assumptions: fopen, fprintf, fwrite, FILE are available
> - * actions: creates testfile1, a text file with 'a'..'z' listed 4 times.
> - * creates testfile2, a text file with 'a'..'z' listed 4 times.
> - * creates testfile3, a binary file with 0..9 listed 4 times.
> - * returns: TRUE if files opened successfully.
> - * FALSE if fail on file open for write.
> + * @brief Initializes the three files to be used for the test.
> -int InitFiles (void)
> +static void InitFiles( void )
> int count;
> + int rv;
> FILE *fp1, *fp2, *fp3;
> char letter;
> int number;
> - int retval;
> - fp1 = fopen("testfile1.tst", "wt");
> - fp2 = fopen("testfile2.tst", "wt");
> - fp3 = fopen("testfile4.tst", "wb");
> - if ((fp1 != NULL) && (fp2 != NULL) && (fp3 !=NULL)) {
> + fp1 = fopen( "testfile1.tst", "wt" );
> + rtems_test_assert( fp1 != NULL );
> - letter = 'a';
> + fp2 = fopen( "testfile2.tst", "wt" );
> + rtems_test_assert( fp2 != NULL );
> - for (count=0 ; count<(26*4); ++count) {
> - fprintf (fp1, "%c", letter);
> - fprintf (fp2, "%c", letter);
> + fp3 = fopen( "testfile4.tst", "wb" );
> + rtems_test_assert( fp3 != NULL );
> - ++letter;
> - if (letter > 'z')
> - letter = 'a';
> + letter = 'a';
> - number = 0;
> + for( count = 0 ; count < (26*4); ++count) {
> + fprintf( fp1, "%c", letter );
> + fprintf( fp2, "%c", letter );
> - for (count = 0; count <40; ++count) {
> - fwrite (&number, 1, sizeof(int), fp3);
> + ++letter;
> + if( letter > 'z' )
> + letter = 'a';
> - ++number;
> - if (number > 9)
> - number = 0;
> + number = 0;
> - fclose(fp1);
> - fclose(fp2);
> - fclose(fp3);
> + for( count = 0; count < 40; ++count ) {
> + fwrite( &number, 1, sizeof(int), fp3 );
> - retval = TRUE;
> + ++number;
> + if( number > 9 )
> + number = 0;
> - else
> - retval = FALSE;
> + rv = fclose( fp1 );
> + rtems_test_assert( rv != EOF );
> - /* assert (retval == TRUE);*/
> + rv = fclose( fp2 );
> - return (retval);
> + rv = fclose( fp3 );
> - * DeviceLSeekTest function
> - * Hits the device_lseek code by lseeking on the console.
> - * arguments: none
> - * assumptions: lseek available
> - * actions: hits lseek with some dummy arguments.
> - * returns: value of return from lseek.
> + * @brief Hits the device_lseek code by lseeking on the console.
> -int DeviceLSeekTest (void)
> +static void DeviceLSeekTest( void )
> - int error = -1, retval = FALSE;
> + int rv;
> + int fd;
> - int fd = open ("/dev/console", O_RDONLY);
> + fd = open( "/dev/console", O_RDONLY );
> + rtems_test_assert( fd != -1 );
> - error = lseek(fd, 5, SEEK_SET);
> + rv = lseek( fd, 5, SEEK_SET );
> + rtems_test_assert( rv == -1 );
> + rtems_test_assert( errno == ESPIPE );
> - if (error == 0)
> - retval = TRUE;
> - else
> - retval = FALSE;
> - close( fd ); /* assert (retval == TRUE);*/
> - return (retval);
> + rv = close( fd );
> + rtems_test_assert( rv == 0 );
> - * DupTest function
> - * Hits the dup code.
> - * arguments: none
> - * assumptions: dup, open, close, fcntl available.
> - * actions: Gets a file descriptor(fd1) for test file1.
> - * dups fd1 to fd2.
> - * sets fd1 to append mode
> - * checks fd2 to ensure it's in append mode, also.
> - * returns: success if fd2 is indeed a copy of fd1.
> + * @brief Exercises dup().
> -int DupTest(void)
> +static void DupTest( void )
> int fd1, fd2;
> + int flags;
> + int rv;
> - int flags = 0, retval = FALSE;
> - fd1 = open ("testfile1.tst", O_RDONLY);
> - fd2 = dup(fd1);
> - if (fd2 != -1) {
> + fd1 = open( "testfile1.tst", O_RDONLY );
> + rtems_test_assert( fd1 != -1 );
> - fcntl(fd1, F_SETFL, O_APPEND);
> - flags = fcntl(fd2, F_GETFL);
> + fd2 = dup( fd1 );
> + rtems_test_assert( fd2 != -1 );
> - close (fd1);
> + rv = fcntl( fd1, F_SETFL, O_APPEND );
> + rtems_test_assert( rv != -1 );
> - flags = (flags & O_APPEND);
> + flags = fcntl( fd2, F_GETFL );
> + flags = ( flags & O_APPEND );
minor nit, this could be more concise
flags = fcntl( fd2, F_GETFL) & O_APPEND;
> + rtems_test_assert( flags == 0 );
> - retval = (flags == O_APPEND);
> - else
> - retval = FALSE;
> + rv = close( fd1 );
Just curious, why be inconsistent how you check for the return from
close? Above using != EOF, here using == 0. It doesn't matter greatly.
> - close( fd1 );
> - close( fd2 );
> - return (retval);
> + rv = close( fd2 );
> - * Dup2Test function
> - * Hits the dup2 code.
> - * arguments: none
> - * assumptions: dup, dup2, open, close, fcntl available.
> - * sets fd1 to invalid value, fd2 to valid, tries to dup2.
> - * sets fd2 to invalid value, fd1 to valid tries to dup2.
> - * returns: success if fd2 is a copy of fd1, and invalid fd1 or fd2 produce errors.
> + * @brief Exercises dup2().
> -int Dup2Test(void)
> +static void Dup2Test( void )
> int fd1, fd2;
> + int flags;
> + int rv;
> - int error = 0;
> - fd2 = open ("testfile2.tst", O_RDONLY);
> - error = dup2(fd1, fd2);
> + fd2 = open( "testfile2.tst", O_RDONLY );
> /* make sure dup2 works if both fd1 and fd2 are valid file descriptors. */
> + rv = dup2( fd1, fd2 );
> - if (error != -1) {
> - flags = fcntl(fd1, F_GETFL);
> + flags = fcntl( fd1, F_GETFL );
> + rtems_test_assert( flags == O_APPEND );
ditto on both conciseness and consistency here.
> - else {
> - retval = FALSE;
> - close(fd2);
> - if (retval == TRUE) {
> + /* make sure dup2 fails correctly if one or the other arguments are invalid. */
> + /* this assumes -1 is an invalid value for a file descriptor!!! (POSIX book, p.135) */
> - /* make sure dup2 fails correctly if one or the other arguments are invalid. */
> - /* this assumes -1 is an invalid value for a file descriptor!!! (POSIX book, p.135) */
> + fd1 = -1;
> - fd1 = -1;
> - if (dup2 (fd1, fd2) != -1)
> - retval = FALSE;
> - else {
> - fd1 = dup(fd2);
> - fd2 = -1;
> + fd1 = dup( fd2 );
> + fd2 = -1;
> - if (dup2(fd1, fd2) != -1)
> - retval = FALSE;
> - close (fd1);
> - close (fd2);
> - return (retval);
> - * FDataSyncTest function
> - * Hits the fdatasync code. Does NOT test the functionality of the
> - * underlying fdatasync entry in the IMFS op table.
> - * arguments: none
> - * assumptions: open, close, fdatasync functions available.
> - * actions: attempts to fdatasync a file descriptor flagged as read-only.
> - * attempts to fdatasync an invalid file descriptor (-1).
> - * attempts to fdatasync a perfectly valid fd opened as RDWR
> - * returns: TRUE if attempt to fdatasync invalid and read-only filed
> - * descriptor fail, and fdatasync succeeds on valid fd.
> - * FALSE otherwise.
> + * @brief Exercises fdatasync(). Does NOT test the functionality of the
> + * underlying fdatasync entry in the IMFS op table.
> +static void FDataSyncTest( void )
> - int fd = -1;
> - int error = 0, retval = TRUE;
> + int fd;
> + int rv;
> /* Try it with a RD_ONLY file. */
> + fd = open( "testfile1.tst", O_RDONLY );
> - fd = open ("testfile1.tst", O_RDONLY);
> - error = fdatasync(fd);
> - if ((error == -1) && (errno == EINVAL))
> - retval = TRUE;
> - else
> - retval = FALSE;
> + rv = fdatasync( fd );
> + rtems_test_assert( errno == EBADF );
> - close (fd);
> + rv = close(fd);
> + /* Try it with a bad file descriptor */
> + fd = -1;
> - /* Try it with a bad file descriptor */
> - fd = -1;
> - if ((errno == EBADF) && (error == -1))
> - retval = TRUE;
> - else
> - retval = FALSE;
> /* Okay - now the success case... */
> + fd = open( "testfile1.tst", O_RDWR );
> - fd = open ("testfile1.tst", O_RDWR);
> - if (error == 0)
> - retval = TRUE;
> - else
> - retval = FALSE;
> - close (fd);
> - return (retval);
> + rv = close( fd );
> - * UMaskTest function
> - * Hits the umask code.
> - * arguments: none
> - * assumptions: umask function available.
> - * actions: set umask to 0ctal 23.
> - * set umask to Octal 22, retrieve the old value.
> - * returns: TRUE if old value is 23,
> + * @brief Hits the umask code.
> -int UMaskTest (void)
> +static void UMaskTest( void )
> - mode_t error = 0;
> - int retval = FALSE;
> - umask(023);
> - error = umask(022);
> + mode_t rv;
> - if (error == 023)
> - retval = TRUE;
> - else
> - retval = FALSE;
> + (void)umask( 023 );
nit: add a space after (void)
> - return(retval);
> + rv = umask( 022 );
> + rtems_test_assert( rv == 023 );
> - * UTimeTest function
> - * Hits the utime code. Does NOT test the functionality of the underlying utime
> - * entry in the IMFS op table.
> - * arguments: none
> - * assumptions: utime function available.
> - * actions: set utime for an invalid filename.
> - * set utime for a valid filename.
> - * returns: TRUE if time on valid file is set correctly and utime failed on
> - * an invalid filename.
> + * @brief Hits the utime code. Does not test the functionality of the
> + * underlying utime entry in the IMFS op table.
> -int UTimeTest (void)
> +static void UTimeTest( void )
> - int error = 0, retval = FALSE;
> + int rv;
> struct utimbuf time;
> struct stat fstat;
> /* First, an invalid filename. */
> - error = utime("!This is an =invalid p at thname!!! :)", NULL);
> - if (error == -1)
> - retval = TRUE;
> - else
> - retval = FALSE;
> + rv = utime( "!This is an =invalid p at thname!!! :)", NULL );
> + rtems_test_assert( errno == ENOENT );
> /* Now, the success test. */
> - time.actime = 12345;
> - time.modtime = 54321;
> - error = utime("testfile1.tst", &time);
> + time.actime = 12345;
> + time.modtime = 54321;
> - if (error == 0) {
> - /* But, did it set the time? */
> - stat ("testfile1.tst", &fstat);
> - if ((fstat.st_atime == 12345) && (fstat.st_mtime == 54321 ))
> - retval = TRUE;
> - else
> - retval = FALSE;
> - else
> - retval = FALSE;
> - error = utime("testfile1.tst", NULL );
> - retval &= (error == 0) ? TRUE : FALSE;
> + rv = utime( "testfile1.tst", &time );
> + /* But, did it set the time? */
> + rv = stat( "testfile1.tst", &fstat );
> + rtems_test_assert( fstat.st_atime == 12345 );
> + rtems_test_assert( fstat.st_mtime == 54321 );
> - return (retval);
> + rv = utime( "testfile1.tst", NULL );
> - * UTimesTest function
> - * Hits the utimes code. Does NOT test the functionality of the underlying utime
> - * arguments: none
> - * assumptions: utimes function available.
> - * actions: set utimes for an invalid filename.
> - * set utimes for a valid filename.
> - * returns: TRUE if time on valid file is set correctly and utimes failed on
> + * @brief Hits the utimes code. Does NOT test the functionality of the
> -int UTimesTest (void)
> +static void UTimesTest( void )
> + int rv;
> struct timeval time[2];
> struct stat fstat;
> - error = utimes("!This is an =invalid p at thname!!! :)", NULL);
> - if (error == -1)
> - retval = TRUE;
> - else
> - retval = FALSE;
> + rv = utimes( "!This is an =invalid p at thname!!! : )", NULL);
> + time[0].tv_sec = 12345;
> + time[1].tv_sec = 54321;
> - time[0].tv_sec = 12345;
> - time[1].tv_sec = 54321;
> + rv = utimes( "testfile1.tst", (struct timeval *)&time );
> - error = utimes("testfile1.tst", (struct timeval *)&time);
> - if (error == 0) {
> + * @brief Hits the pathconf code.
> +static void PathConfTest( void )
> + int rv;
> + rv = pathconf( "thisfiledoesnotexist", _PC_LINK_MAX );
> - retval = TRUE;
> - else
> - retval = FALSE;
> + rv = pathconf( "testfile1.tst", _PC_LINK_MAX );
> - else
> - retval = FALSE;
> + * @brief Hits the fpathconf code.
> +static void FPathConfTest( void )
> + int rv;
> + int fd;
> + fd = -1;
> + rv = fpathconf( fd, _PC_LINK_MAX );
> - return (retval);
> - * PathConfTest function
> - * Hits the pathconf code.
> - * arguments: none
> - * assumptions: pathconf function available.
> - * actions: Try to pathconf a bad filename.
> - * Try to pathconf a good filename.
> - * returns: TRUE if pathconf fails on bad file, succeeds on good file.
> -int PathConfTest (void)
> + rv = fpathconf( fd, _PC_MAX_CANON );
> - error = pathconf("thisfiledoesnotexist", _PC_LINK_MAX);
> + rv = fpathconf( fd, _PC_MAX_INPUT );
> - if (error == -1) {
> - error = pathconf("testfile1.tst", _PC_LINK_MAX);
> + rv = fpathconf( fd, _PC_NAME_MAX );
> - if (error != -1)
> - retval = TRUE;
> - else
> - retval = FALSE;
> + rv = fpathconf( fd, _PC_PATH_MAX );
> - else
> - retval = FALSE;
> + rv = fpathconf( fd, _PC_PIPE_BUF );
> + rv = fpathconf( fd, _PC_CHOWN_RESTRICTED );
> - return(retval);
> + rv = fpathconf( fd, _PC_NO_TRUNC );
> - * FPathConfTest function
> - * Hits the fpathconf code.
> - * arguments: none
> - * assumptions: fpathconf function available.
> - * actions: Call fpathconf with all arguments, plus an invalid.
> - * returns: TRUE always.
> + rv = fpathconf( fd, _PC_VDISABLE );
> -int FPathConfTest (void)
> + rv = fpathconf( fd, _PC_ASYNC_IO );
> - int fd = -1;
> + rv = fpathconf( fd, _PC_PRIO_IO );
> - error = fpathconf(fd, _PC_LINK_MAX);
> + rv = fpathconf( fd, _PC_SYNC_IO );
> - fd = open("testfile1.tst", O_RDWR);
> + rv = fpathconf( fd, 255 );
> +#ifdef __sparc__
What's this for?
> +#else
> +#endif
> - error = fpathconf(fd, _PC_MAX_CANON);
> - error = fpathconf(fd, _PC_MAX_INPUT);
> - error = fpathconf(fd, _PC_NAME_MAX);
> - error = fpathconf(fd, _PC_PATH_MAX);
> - error = fpathconf(fd, _PC_PIPE_BUF);
> - error = fpathconf(fd, _PC_CHOWN_RESTRICTED);
> - error = fpathconf(fd, _PC_NO_TRUNC);
> - error = fpathconf(fd, _PC_VDISABLE);
> - error = fpathconf(fd, _PC_ASYNC_IO);
> - error = fpathconf(fd, _PC_PRIO_IO);
> - error = fpathconf(fd, _PC_SYNC_IO);
> - error = fpathconf(fd, 255);
> + rv = close( fd );
> - close(fd);
> + fd = open( "testfile1.tst", O_WRONLY );
> - fd = open("testfile1.tst", O_WRONLY);
> + rv = close( fd );
> - retval = TRUE;
> + * @brief Hits the fsync code.
> +static void FSyncTest( void )
> + int rv;
> + int fd;
> - else
> - retval = FALSE;
> + rv = fsync(fd);
> - return(retval);
> + rv = close( fd );
> - * FSyncTest function
> - * Hits the fsync code.
> - * arguments: none
> - * assumptions: open, fsync functions available.
> - * actions: open test file,
> - * try to fsync it.
> - * returns: TRUE if fsync doesn't return -1,
> + * @brief Exercises sync().
> +static void SyncTest( void )
> + sync();
> -int FSyncTest (void)
> + * @brief The main entry point to the test.
> +int test_main( void );
> - int fd = -1;
> + TEST_BEGIN();
> + InitFiles();
> + printf( "\nFiles initialized successfully.\n" );
remove the extraneous print statements. If things are working, the
test output should be minimal/quiet just the start/end banners.
> - if (fd != -1) {
> + printf( "Testing lseek() on device... " );
> + DeviceLSeekTest();
> + printf( "Success.\n" );
> - error = fsync(fd);
> + printf( "Testing dup()............... " );
> + DupTest();
> - if (error != -1)
> - retval = TRUE;
> - else
> - retval = FALSE;
> + printf( "Testing dup2().............. " );
> + Dup2Test();
> - close(fd);
> + printf( "Testing fdatasync()......... " );
> + FDataSyncTest();
> - else
> - retval = FALSE;
> + printf( "Testing umask()............. " );
> + UMaskTest();
> + printf( "Testing utime()............. " );
> + UTimeTest();
> - return(retval);
> + printf( "Testing utimes()............ " );
> + UTimesTest();
> - * Main function
> - * main entry point to the test
> + printf( "Testing fsync()............. " );
> + FSyncTest();
> -#if defined(__rtems__)
> -int test_main(void);
> -#else
> -int main(
> - int argc,
> - char **argv
> -#endif
> - TEST_BEGIN();
> + printf( "Testing pathconf().......... " );
> + PathConfTest();
> - if (InitFiles() == TRUE) {
> - printf ("\nFiles initialized successfully.\n");
> - printf ("Testing device_lseek()... ");
> - if (DeviceLSeekTest() == TRUE)
> - printf ("Success.\n");
> - else
> - printf ("Failed!!!\n");
> - printf ("Testing dup()............ ");
> - if (DupTest() == TRUE)
> - else
> - printf ("Testing dup2()........... ");
> - if (Dup2Test() == TRUE)
> - else
> - printf ("Testing fdatasync()...... ");
> - if (FDataSyncTest() == TRUE)
> - else
> - printf ("Testing umask().......... ");
> - if (UMaskTest() == TRUE)
> - else
> - printf ("Testing utime().......... ");
> - if (UTimeTest() == TRUE)
> - else
> - printf ("Testing utimes().......... ");
> - if (UTimesTest() == TRUE)
> - else
> - printf ("Testing fsync().......... ");
> - if (FSyncTest() == TRUE)
> - else
> - printf ("Testing pathconf()....... ");
> - if (PathConfTest() == TRUE)
> - else
> - printf ("Testing fpathconf()...... ");
> - if (FPathConfTest() == TRUE)
> - else
> - printf ("Testing sync()...... ");
> - sync();
> - printf ("Done.\n");
> - TEST_END();
> + printf( "Testing fpathconf()......... " );
> + FPathConfTest();
> + printf( "Testing sync().............. " );
> + SyncTest();
> + TEST_END();
> - rtems_test_exit(0);
> + rtems_test_exit( 0 );
> 1.8.3.1
> devel mailing list
> devel at rtems.org
