[PATCH 1/2] c-user: Generate rate-monotonic manager docs
Sebastian Huber
Thu Apr 22 14:06:53 UTC 2021
The documentation is a consolidation of the comments in Doxygen markup
and the documentation sources in Sphinx markup. The documentation was
transfered to interface specification items. The documentation source
files were generated from the items by a script.
Update #3993.
c-user/rate-monotonic/directives.rst | 949 ++++++++++++++++---------
c-user/rate-monotonic/introduction.rst | 71 +-
2 files changed, 654 insertions(+), 366 deletions(-)
diff --git a/c-user/rate-monotonic/directives.rst b/c-user/rate-monotonic/directives.rst
index d100c81..1935e8a 100644
--- a/c-user/rate-monotonic/directives.rst
+++ b/c-user/rate-monotonic/directives.rst
@@ -1,474 +1,719 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2020, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2017 Kuan-Hsun Chen
.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
-.. Copyright (C) 2017 Kuan-Hsun Chen.
+.. This file is part of the RTEMS quality process and was automatically
+.. generated. If you find something that needs to be fixed or
+.. worded better please post a report or patch to an RTEMS mailing list
+.. or raise a bug report:
+.. https://www.rtems.org/bugs.html
+.. For information on updating and regenerating please refer to the How-To
+.. section in the Software Requirements Engineering chapter of the
+.. RTEMS Software Engineering manual. The manual is provided as a part of
+.. a release. For development sources please refer to the online
+.. documentation at:
+.. https://docs.rtems.org
+.. _RateMonotonicManagerDirectives:
Directives
-This section details the rate monotonic manager's directives. A subsection is
-dedicated to each of this manager's directives and describes the calling
-sequence, related constants, usage, and status codes.
+This section details the directives of the Rate-Monotonic Manager. A subsection
+is dedicated to each of this manager's directives and lists the calling
+sequence, parameters, description, return values, and notes of the directive.
+.. Generated from spec:/rtems/ratemon/if/create
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_rate_monotonic_create()
.. index:: create a period
-.. index:: rtems_rate_monotonic_create
-.. _rtems_rate_monotonic_create:
+.. _InterfaceRtemsRateMonotonicCreate:
+rtems_rate_monotonic_create()
+Creates a period.
+.. rubric:: CALLING SEQUENCE:
+.. code-block:: c
+ rtems_status_code rtems_rate_monotonic_create( rtems_name name, rtems_id *id );
+.. rubric:: PARAMETERS:
+``name``
+ This parameter is the object name of the period.
+``id``
+ This parameter is the pointer to an object identifier variable. When the
+ directive call is successful, the identifier of the created period will be
+ stored in this variable.
+.. rubric:: DESCRIPTION:
+This directive creates a period which resides on the local node. The period
+has the user-defined object name specified in ``name`` The assigned object
+identifier is returned in ``id``. This identifier is used to access the period
+with other rate monotonic related directives.
-RATE_MONOTONIC_CREATE - Create a rate monotonic period
+.. rubric:: RETURN VALUES:
-CALLING SEQUENCE:
- .. code-block:: c
+:c:macro:`RTEMS_SUCCESSFUL`
+ The requested operation was successful.
- rtems_status_code rtems_rate_monotonic_create(
- rtems_name name,
- rtems_id *id
+:c:macro:`RTEMS_INVALID_NAME`
+ The ``name`` parameter was invalid.
-DIRECTIVE STATUS CODES:
- .. list-table::
- :class: rtems-table
+:c:macro:`RTEMS_TOO_MANY`
+ There was no inactive object available to create a period. The number of
+ periods available to the application is configured through the
+ :ref:`CONFIGURE_MAXIMUM_PERIODS` application configuration option.
- * - ``RTEMS_SUCCESSFUL``
- - rate monotonic period created successfully
- * - ``RTEMS_INVALID_NAME``
- - invalid period name
- * - ``RTEMS_TOO_MANY``
- - too many periods created
+.. rubric:: NOTES:
-DESCRIPTION:
- This directive creates a rate monotonic period. The assigned rate
- monotonic id is returned in id. This id is used to access the period with
- other rate monotonic manager directives. For control and maintenance of
- the rate monotonic period, RTEMS allocates a PCB from the local PCB free
- pool and initializes it.
+The calling task is registered as the owner of the created period. Some
+directives can be only used by this task for the created period.
-NOTES:
- This directive may cause the calling task to be preempted due to an
- obtain and release of the object allocator mutex.
+For control and maintenance of the period, RTEMS allocates a :term:`PCB` from
+the local PCB free pool and initializes it.
+.. rubric:: CONSTRAINTS:
+The following constraints apply to this directive:
+* The directive may be called from within device driver initialization context.
+* The directive may be called from within task context.
+* The directive may obtain and release the object allocator mutex. This may
+ cause the calling task to be preempted.
+* The number of periods available to the application is configured through the
+* Where the object class corresponding to the directive is configured to use
+ unlimited objects, the directive may allocate memory from the RTEMS
+ Workspace.
+.. Generated from spec:/rtems/ratemon/if/ident
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_rate_monotonic_ident()
+.. _InterfaceRtemsRateMonotonicIdent:
+rtems_rate_monotonic_ident()
-.. index:: get ID of a period
-.. index:: obtain ID of a period
-.. index:: rtems_rate_monotonic_ident
+Identifies a period by the object name.
-.. _rtems_rate_monotonic_ident:
-RATE_MONOTONIC_IDENT - Get ID of a period
+.. code-block:: c
-CALLING SEQUENCE:
- .. code-block:: c
+ rtems_status_code rtems_rate_monotonic_ident( rtems_name name, rtems_id *id );
- rtems_status_code rtems_rate_monotonic_ident(
- rtems_name name,
- rtems_id *id
- .. list-table::
+``name``
+ This parameter is the object name to look up.
- - period identified successfully
- - period name not found
+``id``
+ directive call is successful, the object identifier of an object with the
+ specified name will be stored in this variable.
-DESCRIPTION:
- This directive obtains the period id associated with the period name to be
- acquired. If the period name is not unique, then the period id will match
- one of the periods with that name. However, this period id is not
- guaranteed to correspond to the desired period. The period id is used to
- access this period in other rate monotonic manager directives.
-NOTES:
- This directive will not cause the running task to be preempted.
+This directive obtains a period identifier associated with the period name
+specified in ``name``.
+:c:macro:`RTEMS_INVALID_ADDRESS`
+ The ``id`` parameter was `NULL
+ <https://en.cppreference.com/w/c/types/NULL>`_.
+ The ``name`` parameter was 0.
+ There was no object with the specified name on the local node.
+.. rubric:: NOTES:
+If the period name is not unique, then the period identifier will match the
+first period with that name in the search order. However, this period
+identifier is not guaranteed to correspond to the desired period.
+The objects are searched from lowest to the highest index. Only the local node
+is searched.
+The period identifier is used with other rate monotonic related directives to
+access the period.
+* The directive may be called from within any runtime context.
+* The directive will not cause the calling task to be preempted.
+.. Generated from spec:/rtems/ratemon/if/cancel
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_rate_monotonic_cancel()
.. index:: cancel a period
-.. index:: rtems_rate_monotonic_cancel
-.. _rtems_rate_monotonic_cancel:
+.. _InterfaceRtemsRateMonotonicCancel:
-RATE_MONOTONIC_CANCEL - Cancel a period
+rtems_rate_monotonic_cancel()
+Cancels the period.
+.. code-block:: c
+ rtems_status_code rtems_rate_monotonic_cancel( rtems_id id );
+``id``
+ This parameter is the rate monotonic period identifier.
-CALLING SEQUENCE:
- .. code-block:: c
+This directive cancels the rate monotonic period specified by ``id``. This
+period may be reinitiated by the next invocation of
+:ref:`InterfaceRtemsRateMonotonicPeriod`.
- rtems_status_code rtems_rate_monotonic_cancel(
- rtems_id id
- .. list-table::
- - period canceled successfully
- * - ``RTEMS_INVALID_ID``
- - invalid rate monotonic period id
- * - ``RTEMS_NOT_OWNER_OF_RESOURCE``
- - rate monotonic period not created by calling task
+:c:macro:`RTEMS_INVALID_ID`
+ There was no rate monotonic period associated with the identifier specified
+ by ``id``.
-DESCRIPTION:
+:c:macro:`RTEMS_NOT_OWNER_OF_RESOURCE`
+ The rate monotonic period was not created by the calling task.
- This directive cancels the rate monotonic period id. This period will be
- reinitiated by the next invocation of ``rtems_rate_monotonic_period``
- with id.
-NOTES:
- The rate monotonic period specified by id must have been created by the
- calling task.
+* The directive may be used exclusively by the task which created the
+ associated object.
+.. Generated from spec:/rtems/ratemon/if/delete
.. raw:: latex
- \clearpage
+ \clearpage
-.. index:: rtems_rate_monotonic_delete
+.. index:: rtems_rate_monotonic_delete()
.. index:: delete a period
-.. _rtems_rate_monotonic_delete:
+.. _InterfaceRtemsRateMonotonicDelete:
+rtems_rate_monotonic_delete()
+Deletes the period.
+.. code-block:: c
+ rtems_status_code rtems_rate_monotonic_delete( rtems_id id );
+``id``
+ This parameter is the period identifier.
+This directive deletes the period specified by ``id``. If the period is
+running, it is automatically canceled.
-RATE_MONOTONIC_DELETE - Delete a rate monotonic period
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_rate_monotonic_delete(
- rtems_id id
+ There was no period associated with the identifier specified by ``id``.
- .. list-table::
+.. rubric:: NOTES:
- - period deleted successfully
+The :term:`PCB` for the deleted period is reclaimed by RTEMS.
-DESCRIPTION:
- This directive deletes the rate monotonic period specified by id. If the
- period is running, it is automatically canceled. The PCB for the deleted
- period is reclaimed by RTEMS.
-NOTES:
- A rate monotonic period can be deleted by a task other than the task which
- created the period.
+* The calling task does not have to be the task that created the object. Any
+ local task that knows the object identifier can delete the object.
+ unlimited objects, the directive may free memory to the RTEMS Workspace.
+.. Generated from spec:/rtems/ratemon/if/period
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_rate_monotonic_period()
.. index:: conclude current period
.. index:: start current period
.. index:: period initiation
-.. index:: rtems_rate_monotonic_period
-.. _rtems_rate_monotonic_period:
-RATE_MONOTONIC_PERIOD - Conclude current/Start next period
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_rate_monotonic_period(
- rtems_id id,
- rtems_interval length
- .. list-table::
- - period initiated successfully
- - period not created by calling task
- * - ``RTEMS_NOT_DEFINED``
- - period has never been initiated (only possible when period is set to PERIOD_STATUS)
- * - ``RTEMS_TIMEOUT``
- - period has expired
-DESCRIPTION:
- This directive initiates the rate monotonic period id with a length of
- period ticks. If id is running, then the calling task will block for the
- remainder of the period before reinitiating the period with the specified
- period. If id was not running (either expired or never initiated), the
- period is immediately initiated and the directive returns immediately.
- If id has expired its period, the postponed job will be released immediately
- and the following calls of this directive will release postponed
- jobs until there is no more deadline miss.
- If invoked with a period of ``RTEMS_PERIOD_STATUS`` ticks, the current
- state of id will be returned. The directive status indicates the current
- state of the period. This does not alter the state or period of the
- period.
-NOTES:
+.. _InterfaceRtemsRateMonotonicPeriod:
+rtems_rate_monotonic_period()
+Concludes the current period and start the next period, or gets the period
+status.
+.. code-block:: c
+ rtems_status_code rtems_rate_monotonic_period(
+ rtems_id id,
+ rtems_interval length
+``id``
+``length``
+ This parameter is the period length in :term:`clock ticks <clock tick>` or
+ :c:macro:`RTEMS_PERIOD_STATUS` to get the period status.
+This directive initiates the rate monotonic period specified by ``id`` with a
+length of period ticks specified by ``length``. If the period is running, then
+the calling task will block for the remainder of the period before reinitiating
+the period with the specified period length. If the period was not running
+(either expired or never initiated), the period is immediately initiated and
+the directive returns immediately. If the period has expired, the postponed
+job will be released immediately and the following calls of this directive will
+release postponed jobs until there is no more deadline miss.
+If invoked with a period length of :c:macro:`RTEMS_PERIOD_STATUS` ticks, the
+current state of the period will be returned. The directive status indicates
+the current state of the period. This does not alter the state or period
+length of the period.
+ by ``id``.
+:c:macro:`RTEMS_NOT_DEFINED`
+ The rate monotonic period has never been initiated (only possible when the
+ ``length`` parameter was equal to :c:macro:`RTEMS_PERIOD_STATUS`).
+:c:macro:`RTEMS_TIMEOUT`
+ The rate monotonic period has expired.
+.. Generated from spec:/rtems/ratemon/if/get-status
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_rate_monotonic_get_status()
.. index:: get status of period
.. index:: obtain status of period
-.. index:: rtems_rate_monotonic_get_status
-.. _rtems_rate_monotonic_get_status:
-RATE_MONOTONIC_GET_STATUS - Obtain status from a period
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_rate_monotonic_get_status(
- rtems_id id,
- rtems_rate_monotonic_period_status *status
- .. list-table::
- - period status retrieved successfully
- * - ``RTEMS_INVALID_ADDRESS``
- - invalid address of status
- - no status is available due to the cpu usage of the task having been
- reset since the period initiated
-*DESCRIPTION:
- This directive returns status information associated with the rate
- monotonic period id in the following data structure:
- .. index:: rtems_rate_monotonic_period_status
- .. code-block:: c
- typedef struct {
- rtems_id owner;
- rtems_rate_monotonic_period_states state;
- rtems_rate_monotonic_period_time_t since_last_period;
- rtems_thread_cpu_usage_t executed_since_last_period;
- uint32_t postponed_jobs_count;
- } rtems_rate_monotonic_period_status;
- .. COMMENT: RATE_MONOTONIC_INACTIVE does not have RTEMS in front of it.
- A configure time option can be used to select whether the time information
- is given in ticks or seconds and nanoseconds. The default is seconds and
- nanoseconds. If the period's state is ``RATE_MONOTONIC_INACTIVE``, both
- time values will be set to 0. Otherwise, both time values will contain
- time information since the last invocation of the
- ``rtems_rate_monotonic_period`` directive. More specifically, the
- since_last_period value contains the elapsed time which has occurred since
- the last invocation of the ``rtems_rate_monotonic_period`` directive and
- the ``executed_since_last_period`` contains how much processor time the
- owning task has consumed since the invocation of the
- ``rtems_rate_monotonic_period`` directive. In addition, the
- ``postponed_jobs_count value`` contains the count of jobs which are not
- released yet.
-NOTES:
+.. _InterfaceRtemsRateMonotonicGetStatus:
+rtems_rate_monotonic_get_status()
+Gets the detailed status of the period.
+.. code-block:: c
+ rtems_status_code rtems_rate_monotonic_get_status(
+ rtems_id id,
+ rtems_rate_monotonic_period_status *status
+``id``
+``status``
+ :c:type:`rtems_rate_monotonic_period_status` variable. When the directive
+ call is successful, the detailed period status will be stored in this
+ variable.
+This directive returns the detailed status of the rate monotonic period
+specified by ``id``. The detailed status of the period will be returned in the
+members of the period status object referenced by ``status``:
+* The ``owner`` member is set to the identifier of the owner task of the
+ period.
+* The ``state`` member is set to the current state of the period.
+* The ``postponed_jobs_count`` member is set to the count of jobs which are not
+ released yet.
+* If the current state of the period is :c:macro:`RATE_MONOTONIC_INACTIVE`, the
+ ``since_last_period`` and ``executed_since_last_period`` members will be set
+ to zero. Otherwise, both members will contain time information since the
+ last successful invocation of the :ref:`InterfaceRtemsRateMonotonicPeriod`
+ directive by the owner task. More specifically, the ``since_last_period``
+ member will be set to the time elapsed since the last successful invocation.
+ The ``executed_since_last_period`` member will be set to the processor time
+ consumed by the owner task since the last successful invocation.
+ by ``id``.
+ The ``status`` parameter was `NULL
+ There was no status available due to a reset of the processor time usage of
+ the owner task of the period.
+* The directive may be called from within interrupt context.
+.. Generated from spec:/rtems/ratemon/if/get-statistics
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_rate_monotonic_get_statistics()
.. index:: get statistics of period
.. index:: obtain statistics of period
-.. index:: rtems_rate_monotonic_get_statistics
-.. _rtems_rate_monotonic_get_statistics:
-RATE_MONOTONIC_GET_STATISTICS - Obtain statistics from a period
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_rate_monotonic_get_statistics(
- rtems_id id,
- rtems_rate_monotonic_period_statistics *statistics
- .. list-table::
- - period statistics retrieved successfully
- - invalid address of statistics
-DESCRIPTION:
- This directive returns statistics information associated with the rate
- .. index:: rtems_rate_monotonic_period_statistics
- .. code-block:: c
- typedef struct {
- uint32_t count;
- uint32_t missed_count;
- #ifdef RTEMS_ENABLE_NANOSECOND_CPU_USAGE_STATISTICS
- struct timespec min_cpu_time;
- struct timespec max_cpu_time;
- struct timespec total_cpu_time;
- #else
- uint32_t min_cpu_time;
- uint32_t max_cpu_time;
- uint32_t total_cpu_time;
- #endif
- #ifdef RTEMS_ENABLE_NANOSECOND_RATE_MONOTONIC_STATISTICS
- struct timespec min_wall_time;
- struct timespec max_wall_time;
- struct timespec total_wall_time;
- #else
- uint32_t min_wall_time;
- uint32_t max_wall_time;
- uint32_t total_wall_time;
- #endif
- } rtems_rate_monotonic_period_statistics;
- This directive returns the current statistics information for the period
- instance assocaited with ``id``. The information returned is indicated by
- the structure above.
-NOTES:
+.. _InterfaceRtemsRateMonotonicGetStatistics:
+rtems_rate_monotonic_get_statistics()
+Gets the statistics of the period.
+.. code-block:: c
+ rtems_status_code rtems_rate_monotonic_get_statistics(
+ rtems_id id,
+ rtems_rate_monotonic_period_statistics *status
+``id``
+``status``
+ :c:type:`rtems_rate_monotonic_period_statistics` variable. When the
+ directive call is successful, the period statistics will be stored in this
+ variable.
+This directive returns the statistics of the rate monotonic period specified by
+``id``. The statistics of the period will be returned in the members of the
+period statistics object referenced by ``status``:
+* The ``count`` member is set to the number of periods executed.
+* The ``missed_count`` member is set to the number of periods missed.
+* The ``min_cpu_time`` member is set to the least amount of processor time used
+ in the period.
+* The ``max_cpu_time`` member is set to the highest amount of processor time
+ used in the period.
+* The ``total_cpu_time`` member is set to the total amount of processor time
+* The ``min_wall_time`` member is set to the least amount of
+ :term:`CLOCK_MONOTONIC` time used in the period.
+* The ``max_wall_time`` member is set to the highest amount of
+* The ``total_wall_time`` member is set to the total amount of
+ by ``id``.
+.. Generated from spec:/rtems/ratemon/if/reset-statistics
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_rate_monotonic_reset_statistics()
.. index:: reset statistics of period
-.. index:: rtems_rate_monotonic_reset_statistics
-.. _rtems_rate_monotonic_reset_statistics:
+.. _InterfaceRtemsRateMonotonicResetStatistics:
+rtems_rate_monotonic_reset_statistics()
+Resets the statistics of the period.
+.. code-block:: c
+ rtems_status_code rtems_rate_monotonic_reset_statistics( rtems_id id );
+``id``
-RATE_MONOTONIC_RESET_STATISTICS - Reset statistics for a period
-CALLING SEQUENCE:
- .. code-block:: c
+This directive resets the statistics of the rate monotonic period specified by
+``id``.
- rtems_status_code rtems_rate_monotonic_reset_statistics(
- rtems_id id
- .. list-table::
+ by ``id``.
-DESCRIPTION:
- This directive resets the statistics information associated with this rate
- monotonic period instance.
-NOTES:
+.. Generated from spec:/rtems/ratemon/if/reset-all-statistics
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_rate_monotonic_reset_all_statistics()
.. index:: reset statistics of all periods
-.. index:: rtems_rate_monotonic_reset_all_statistics
-.. _rtems_rate_monotonic_reset_all_statistics:
+.. _InterfaceRtemsRateMonotonicResetAllStatistics:
+rtems_rate_monotonic_reset_all_statistics()
+Resets the statistics of all periods.
-RATE_MONOTONIC_RESET_ALL_STATISTICS - Reset statistics for all periods
-CALLING SEQUENCE:
- .. code-block:: c
+.. code-block:: c
- void rtems_rate_monotonic_reset_all_statistics(void);
+ void rtems_rate_monotonic_reset_all_statistics( void );
- NONE
-DESCRIPTION:
- This directive resets the statistics information associated with all rate
- monotonic period instances.
+This directive resets the statistics information associated with all rate
+monotonic period instances.
-NOTES:
+.. Generated from spec:/rtems/ratemon/if/report-statistics
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_rate_monotonic_report_statistics()
.. index:: print period statistics report
.. index:: period statistics report
-.. index:: rtems_rate_monotonic_report_statistics
-.. _rtems_rate_monotonic_report_statistics:
+.. _InterfaceRtemsRateMonotonicReportStatistics:
+rtems_rate_monotonic_report_statistics()
+Reports the period statistics using the :c:func:`printk` printer.
+.. code-block:: c
+ void rtems_rate_monotonic_report_statistics( void );
+This directive prints a report on all active periods which have executed at
+least one period using the :c:func:`printk` printer.
+.. Generated from spec:/rtems/ratemon/if/report-statistics-with-plugin
+.. raw:: latex
+ \clearpage
+.. index:: rtems_rate_monotonic_report_statistics_with_plugin()
+.. index:: print period statistics report
+.. index:: period statistics report
+.. _InterfaceRtemsRateMonotonicReportStatisticsWithPlugin:
+rtems_rate_monotonic_report_statistics_with_plugin()
+Reports the period statistics using the printer plugin.
+.. code-block:: c
-RATE_MONOTONIC_REPORT_STATISTICS - Print period statistics report
+ void rtems_rate_monotonic_report_statistics_with_plugin(
+ const struct rtems_printer *printer
-CALLING SEQUENCE:
- .. code-block:: c
- void rtems_rate_monotonic_report_statistics(void);
+``printer``
+ This parameter is the printer plugin to output the report.
- NONE
-DESCRIPTION:
- This directive prints a report on all active periods which have executed at
- least one period. The following is an example of the output generated by
- this directive.
+least one period using the printer plugin specified by ``printer``.
- .. code-block:: c
- ID OWNER PERIODS MISSED CPU TIME WALL TIME
- MIN/MAX/AVG MIN/MAX/AVG
- 0x42010001 TA1 502 0 0/1/0.99 0/0/0.00
- 0x42010002 TA2 502 0 0/1/0.99 0/0/0.00
- 0x42010003 TA3 501 0 0/1/0.99 0/0/0.00
- 0x42010004 TA4 501 0 0/1/0.99 0/0/0.00
- 0x42010005 TA5 10 0 0/1/0.90 0/0/0.00
-NOTES:
diff --git a/c-user/rate-monotonic/introduction.rst b/c-user/rate-monotonic/introduction.rst
index cb09898..5b0c094 100644
--- a/c-user/rate-monotonic/introduction.rst
+++ b/c-user/rate-monotonic/introduction.rst
@@ -1,33 +1,76 @@
+.. Generated from spec:/rtems/ratemon/if/group
+.. _RateMonotonicManagerIntroduction:
Introduction
-The rate monotonic manager provides facilities to implement tasks which execute
+.. The following list was generated from:
+.. spec:/rtems/ratemon/if/create
+.. spec:/rtems/ratemon/if/ident
+.. spec:/rtems/ratemon/if/cancel
+.. spec:/rtems/ratemon/if/delete
+.. spec:/rtems/ratemon/if/period
+.. spec:/rtems/ratemon/if/get-status
+.. spec:/rtems/ratemon/if/get-statistics
+.. spec:/rtems/ratemon/if/reset-statistics
+.. spec:/rtems/ratemon/if/reset-all-statistics
+.. spec:/rtems/ratemon/if/report-statistics
+.. spec:/rtems/ratemon/if/report-statistics-with-plugin
+The Rate-Monotonic Manager provides facilities to implement tasks which execute
in a periodic fashion. Critically, it also gathers information about the
execution of those periods and can provide important statistics to the user
-which can be used to analyze and tune the application. The directives provided
-by the rate monotonic manager are:
+which can be used to analyze and tune the application. The directives provided
+by the Rate-Monotonic Manager are:
+* :ref:`InterfaceRtemsRateMonotonicCreate` - Creates a period.
-- :ref:`rtems_rate_monotonic_create`
+* :ref:`InterfaceRtemsRateMonotonicIdent` - Identifies a period by the object
+ name.
-- :ref:`rtems_rate_monotonic_ident`
+* :ref:`InterfaceRtemsRateMonotonicCancel` - Cancels the period.
-- :ref:`rtems_rate_monotonic_cancel`
+* :ref:`InterfaceRtemsRateMonotonicDelete` - Deletes the period.
-- :ref:`rtems_rate_monotonic_delete`
+* :ref:`InterfaceRtemsRateMonotonicPeriod` - Concludes the current period and
+ start the next period, or gets the period status.
-- :ref:`rtems_rate_monotonic_period`
+* :ref:`InterfaceRtemsRateMonotonicGetStatus` - Gets the detailed status of the
+ period.
-- :ref:`rtems_rate_monotonic_get_status`
+* :ref:`InterfaceRtemsRateMonotonicGetStatistics` - Gets the statistics of the
+ period.
-- :ref:`rtems_rate_monotonic_get_statistics`
+* :ref:`InterfaceRtemsRateMonotonicResetStatistics` - Resets the statistics of
+ the period.
-- :ref:`rtems_rate_monotonic_reset_statistics`
+* :ref:`InterfaceRtemsRateMonotonicResetAllStatistics` - Resets the statistics
+ of all periods.
-- :ref:`rtems_rate_monotonic_reset_all_statistics`
+* :ref:`InterfaceRtemsRateMonotonicReportStatistics` - Reports the period
+ statistics using the :c:func:`printk` printer.
-- :ref:`rtems_rate_monotonic_report_statistics`
+* :ref:`InterfaceRtemsRateMonotonicReportStatisticsWithPlugin` - Reports the
+ period statistics using the printer plugin.
2.26.2
