[PATCH] psx13: Reworked and relicensed
Thu Apr 22 14:21:08 UTC 2021
While you are updating the license on the OAR authored code, you should
pick up the other file in this directory.
On Thu, Apr 22, 2021, 9:09 AM Sebastian Huber <
> On 22/04/2021 15:44, Gedare Bloom wrote:
> >> +  rv = close( fd1 );
> >> +  rtems_test_assert( rv == 0 );
> > Just curious, why be inconsistent how you check for the return from
> > close? Above using != EOF, here using == 0. It doesn't matter greatly.
> Different APIs are tested. One uses 0, the other uses EOF.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210422/62059a86/attachment.html>
