[PATCH] psx13: Reworked and relicensed
Thu Apr 22 16:12:51 UTC 2021
On Thu, Apr 22, 2021 at 10:06 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> >> +#ifdef __sparc__
> >What's this for?
> Joel said this was a special case, and that it needed to be put in, so I'm not sure.
Joel: Please address.
> For the printf's in test_main(), I should take out all of the print statements saying
> "Testing <function>.....Success"?
Remove all the explicit printf statements.
Ideally, there should only be TEST_BEGIN() banner and TEST_END()
banner for a successful test, and if there is an error then it is easy
to find between the banners since only rtems_test_assert() will print
anything there.
> -----Original Message-----
> From: Gedare Bloom <gedare at rtems.org>
> Sent: Thursday, April 22, 2021 8:45 AM
> To: Ryan Long <ryan.long at oarcorp.com>
> Cc: devel at rtems.org
> Subject: Re: [PATCH] psx13: Reworked and relicensed
> See below for comments. This test suite might be a good candidate for conversion to T_TEST_CASE framework. At any rate, this refactor is a marked improvement.
> On Wed, Apr 21, 2021 at 2:57 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> > Changed the way the tests were structured, added
> > rtems_test_assert()'s, updated psx13.scn and the license.
> relicense changes should generally Update #3899.
> >  testsuites/psxtests/psx13/psx13.scn |  24 +-
> >  testsuites/psxtests/psx13/test.c    | 879 +++++++++++++-----------------------
> >  2 files changed, 335 insertions(+), 568 deletions(-)
> > diff --git a/testsuites/psxtests/psx13/psx13.scn
> > b/testsuites/psxtests/psx13/psx13.scn
> > index 428a931..ee99867 100644
> > --- a/testsuites/psxtests/psx13/psx13.scn
> > +++ b/testsuites/psxtests/psx13/psx13.scn
> > @@ -1,16 +1,16 @@
> >  *** POSIX TEST 13 ***
> >  Files initialized successfully.
> > -Testing device_lseek()... Failed!!!
> > -Testing dup()............ Failed!!!
> > -Testing dup2()........... Success.
> > -Testing fdatasync()...... Success.
> > -Testing umask().......... Success.
> > -Testing utime().......... Success.
> > -Testing utimes().......... Success.
> > -Testing fsync().......... Success.
> > -Testing pathconf()....... Success.
> > -Testing fpathconf()...... Success.
> > -Testing sync()......
> > +Testing lseek() on device... Success.
> > +Testing dup()............... Success.
> > +Testing dup2().............. Success.
> > +Testing fdatasync()......... Success.
> > +Testing umask()............. Success.
> > +Testing utime()............. Success.
> > +Testing utimes()............ Success.
> > +Testing fsync()............. Success.
> > +Testing pathconf().......... Success.
> > +Testing fpathconf()......... Success.
> > +Testing sync().............. Success.
> > -*** END OF TEST PSX13 ***
> > +*** END OF TEST PSX 13 ***
> > diff --git a/testsuites/psxtests/psx13/test.c
> > b/testsuites/psxtests/psx13/test.c
> > index 79b24c2..2d25b02 100644
> > --- a/testsuites/psxtests/psx13/test.c
> > +++ b/testsuites/psxtests/psx13/test.c
> > @@ -1,26 +1,49 @@
> > - *  Psx13
> > - *  Chris Bond (working under Jennifer's account)
> > + *  @file
> > + *  @brief This tests various file system functions.
> >   *  This test exercises the following routines:
> > - *     device_lseek - test implemented
> > - *     dup          - test implemented
> > - *     dup2         - test implemented
> > - *     fdatasync    - test implemented
> > - *     fsync        - test implemented
> > - *     pathconf     - test implemented
> > - *     fpathconf    - test implemented
> > - *     umask        - test implemented
> > - *     utime        - test implemented
> > - *     utimes       - test implemented
> > + *     - lseek()
> > + *     - dup()
> > + *     - dup2()
> > + *     - fdatasync()
> > + *     - fsync()
> > + *     - pathconf()
> > + *     - fpathconf()
> > + *     - umask()
> > + *     - utime()
> > + *     - utimes()
> > + *     - sync()
> While you're at it, please conform to
> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#c-c-header-file-template
> > + *  SPDX-License-Identifier: BSD-2-Clause
> > - *  COPYRIGHT (c) 1989-2009.
> > + *  COPYRIGHT (c) 1989-2009, 2021.
> >   *  On-Line Applications Research Corporation (OAR).
> > - *  The license and distribution terms for this file may be
> > - *  found in the file LICENSE in this distribution or at
> > - *  http://www.rtems.org/license/LICENSE.
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in the
> > + *    documentation and/or other materials provided with the distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> > + TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> > + PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> > + CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
> > + OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
> > + OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> > + BUSINESS
> > + * * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> > + WHETHER IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> > + OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> > + ADVISED OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> >  #ifdef HAVE_CONFIG_H
> > @@ -34,6 +57,7 @@
> >  #include <unistd.h>
> >  #include <errno.h>
> >  #include <utime.h>
> > +#include <tmacros.h>
> >  #include <stdio.h>
> >  #include <unistd.h>
> > @@ -42,685 +66,428 @@
> >  const char rtems_test_name[] = "PSX 13";
> > -int InitFiles(void);
> > -int DeviceLSeekTest(void);
> > -int DupTest(void);
> > -int Dup2Test(void);
> > -int FDataSyncTest(void);
> > -int UMaskTest(void);
> > -int UTimeTest(void);
> > -int UTimesTest(void);
> > -int PathConfTest(void);
> > -int FPathConfTest(void);
> > -int FSyncTest(void);
> > - * InitFiles function
> > - * Initializes the three files to be used in the test.
> > - * arguments: none
> > - * assumptions: fopen, fprintf, fwrite, FILE are available
> > - * actions: creates testfile1, a text file with 'a'..'z' listed 4 times.
> > - *          creates testfile2, a text file with 'a'..'z' listed 4 times.
> > - *          creates testfile3, a binary file with 0..9 listed 4 times.
> > - * returns: TRUE if files opened successfully.
> > - *          FALSE if fail on file open for write.
> > + * @brief Initializes the three files to be used for the test.
> > -int InitFiles (void)
> > +static void InitFiles( void )
> >    int count;
> > +  int rv;
> >    FILE *fp1, *fp2, *fp3;
> >    char letter;
> >    int number;
> > -  int retval;
> > -  fp1 = fopen("testfile1.tst", "wt");
> > -  fp2 = fopen("testfile2.tst", "wt");
> > -  fp3 = fopen("testfile4.tst", "wb");
> > -  if ((fp1 != NULL) && (fp2 != NULL) && (fp3 !=NULL)) {
> > +  fp1 = fopen( "testfile1.tst", "wt" );  rtems_test_assert( fp1 !=
> > + NULL );
> > -    letter = 'a';
> > +  fp2 = fopen( "testfile2.tst", "wt" );  rtems_test_assert( fp2 !=
> > + NULL );
> > -    for (count=0 ; count<(26*4); ++count) {
> > -      fprintf (fp1, "%c", letter);
> > -      fprintf (fp2, "%c", letter);
> > +  fp3 = fopen( "testfile4.tst", "wb" );  rtems_test_assert( fp3 !=
> > + NULL );
> > -      ++letter;
> > -      if (letter > 'z')
> > -       letter = 'a';
> > +  letter = 'a';
> > -    number = 0;
> > +  for( count = 0 ; count < (26*4); ++count) {
> > +    fprintf( fp1, "%c", letter );
> > +    fprintf( fp2, "%c", letter );
> > -    for (count = 0; count <40; ++count) {
> > -      fwrite (&number, 1, sizeof(int), fp3);
> > +    ++letter;
> > +    if( letter > 'z' )
> > +      letter = 'a';
> > -      ++number;
> > -      if (number > 9)
> > -       number = 0;
> > +  number = 0;
> > -    fclose(fp1);
> > -    fclose(fp2);
> > -    fclose(fp3);
> > +  for( count = 0; count < 40; ++count ) {
> > +    fwrite( &number, 1, sizeof(int), fp3 );
> > -    retval = TRUE;
> > +    ++number;
> > +    if( number > 9 )
> > +      number = 0;
> > -  else
> > -    retval = FALSE;
> > +  rv = fclose( fp1 );
> > +  rtems_test_assert( rv != EOF );
> > -  /* assert (retval == TRUE);*/
> > +  rv = fclose( fp2 );
> > -  return (retval);
> > +  rv = fclose( fp3 );
> > - * DeviceLSeekTest function
> > - * Hits the device_lseek code by lseeking on the console.
> > - * arguments: none
> > - * assumptions: lseek available
> > - * actions: hits lseek with some dummy arguments.
> > - * returns: value of return from lseek.
> > + * @brief Hits the device_lseek code by lseeking on the console.
> > -int DeviceLSeekTest (void)
> > +static void DeviceLSeekTest( void )
> > -  int error = -1, retval = FALSE;
> > +  int rv;
> > +  int fd;
> > -  int fd = open ("/dev/console", O_RDONLY);
> > +  fd = open( "/dev/console", O_RDONLY );  rtems_test_assert( fd != -1
> > -  error = lseek(fd, 5, SEEK_SET);
> > +  rv = lseek( fd, 5, SEEK_SET );
> > +  rtems_test_assert( rv == -1 );
> > +  rtems_test_assert( errno == ESPIPE );
> > -  if (error == 0)
> > -    retval = TRUE;
> > -  else
> > -    retval = FALSE;
> > -  close( fd );  /* assert (retval == TRUE);*/
> > -  return (retval);
> > +  rv = close( fd );
> > +  rtems_test_assert( rv == 0 );
> > - * DupTest function
> > - * Hits the dup code.
> > - * arguments: none
> > - * assumptions: dup, open, close, fcntl available.
> > - * actions: Gets a file descriptor(fd1) for test file1.
> > - *          dups fd1 to fd2.
> > - *          sets fd1 to append mode
> > - *          checks fd2 to ensure it's in append mode, also.
> > - * returns: success if fd2 is indeed a copy of fd1.
> > + * @brief Exercises dup().
> > -int DupTest(void)
> > +static void DupTest( void )
> >    int fd1, fd2;
> > +  int flags;
> > +  int rv;
> > -  int flags = 0, retval = FALSE;
> > -  fd1 = open ("testfile1.tst", O_RDONLY);
> > -  fd2 = dup(fd1);
> > -  if (fd2 != -1) {
> > +  fd1 = open( "testfile1.tst", O_RDONLY );  rtems_test_assert( fd1 !=
> > + -1 );
> > -    fcntl(fd1, F_SETFL, O_APPEND);
> > -    flags = fcntl(fd2, F_GETFL);
> > +  fd2 = dup( fd1 );
> > +  rtems_test_assert( fd2 != -1 );
> > -    close (fd1);
> > +  rv = fcntl( fd1, F_SETFL, O_APPEND );  rtems_test_assert( rv != -1
> > -    flags = (flags & O_APPEND);
> > +  flags = fcntl( fd2, F_GETFL );
> > +  flags = ( flags & O_APPEND );
> minor nit, this could be more concise
> flags = fcntl( fd2, F_GETFL) & O_APPEND;
> > +  rtems_test_assert( flags == 0 );
> > -    retval = (flags == O_APPEND);
> > -  else
> > -    retval = FALSE;
> > +  rv = close( fd1 );
> Just curious, why be inconsistent how you check for the return from close? Above using != EOF, here using == 0. It doesn't matter greatly.
> > -  close( fd1 );
> > -  close( fd2 );
> > -  return (retval);
> > +  rv = close( fd2 );
> > - * Dup2Test function
> > - * Hits the dup2 code.
> > - * arguments: none
> > - * assumptions: dup, dup2, open, close, fcntl available.
> > - *          sets fd1 to invalid value, fd2 to valid, tries to dup2.
> > - *          sets fd2 to invalid value, fd1 to valid tries to dup2.
> > - * returns: success if fd2 is a copy of fd1, and invalid fd1 or fd2 produce errors.
> > + * @brief Exercises dup2().
> > -int Dup2Test(void)
> > +static void Dup2Test( void )
> >    int fd1, fd2;
> > +  int flags;
> > +  int rv;
> > -  int error = 0;
> > + -1 );
> > -  fd2 = open ("testfile2.tst", O_RDONLY);
> > -  error = dup2(fd1, fd2);
> > +  fd2 = open( "testfile2.tst", O_RDONLY );  rtems_test_assert( fd2 !=
> > + -1 );
> >    /* make sure dup2 works if both fd1 and fd2 are valid file
> > descriptors. */
> > +  rv = dup2( fd1, fd2 );
> > +  rtems_test_assert( rv != -1 );
> > -  if (error != -1) {
> > -    flags = fcntl(fd1, F_GETFL);
> > +  flags = fcntl( fd1, F_GETFL );
> > +  rtems_test_assert( flags == O_APPEND );
> ditto on both conciseness and consistency here.
> > -  else {
> > -    retval = FALSE;
> > -    close(fd2);
> > -  if (retval == TRUE) {
> > +  /* make sure dup2 fails correctly if one or the other arguments are
> > + invalid. */
> > +  /* this assumes -1 is an invalid value for a file descriptor!!!
> > + (POSIX book, p.135) */  rv = close( fd1 );  rtems_test_assert( rv ==
> > + 0 );
> > -    /* make sure dup2 fails correctly if one or the other arguments are invalid. */
> > -    /* this assumes -1 is an invalid value for a file descriptor!!! (POSIX book, p.135) */
> > +  fd1 = -1;
> > -    fd1 = -1;
> > -    if (dup2 (fd1, fd2) != -1)
> > -      retval = FALSE;
> > -    else {
> > -      fd1 = dup(fd2);
> > -      fd2 = -1;
> > +  fd1 = dup( fd2 );
> > +  fd2 = -1;
> > -      if (dup2(fd1, fd2) != -1)
> > -       retval = FALSE;
> > -  close (fd1);
> > -  close (fd2);
> > -  return (retval);
> > - * FDataSyncTest function
> > - * Hits the fdatasync code. Does NOT test the functionality of the
> > - * underlying fdatasync entry in the IMFS op table.
> > - * arguments: none
> > - * assumptions: open, close, fdatasync functions available.
> > - * actions: attempts to fdatasync a file descriptor flagged as read-only.
> > - *          attempts to fdatasync an invalid file descriptor (-1).
> > - *          attempts to fdatasync a perfectly valid fd opened as RDWR
> > - * returns: TRUE if attempt to fdatasync invalid and read-only filed
> > - *           descriptor fail, and fdatasync succeeds on valid fd.
> > - *          FALSE otherwise.
> > + * @brief Exercises fdatasync(). Does NOT test the functionality of the
> > + *        underlying fdatasync entry in the IMFS op table.
> > +static void FDataSyncTest( void )
> > -  int fd = -1;
> > -  int error = 0, retval = TRUE;
> > +  int fd;
> > +  int rv;
> >    /* Try it with a RD_ONLY file. */
> > +  fd = open( "testfile1.tst", O_RDONLY );  rtems_test_assert( fd !=
> > + -1 );
> > -  fd = open ("testfile1.tst", O_RDONLY);
> > -  error = fdatasync(fd);
> > -  if ((error == -1) && (errno == EINVAL))
> > -    retval = TRUE;
> > -  else
> > -    retval = FALSE;
> > +  rv = fdatasync( fd );
> > +  rtems_test_assert( errno == EBADF );
> > -  close (fd);
> > +  rv = close(fd);
> > +  /* Try it with a bad file descriptor */  fd = -1;
> > -    /* Try it with a bad file descriptor */
> > -    fd = -1;
> > -    if ((errno == EBADF) && (error == -1))
> > -      retval = TRUE;
> > -    else
> > -      retval = FALSE;
> >    /* Okay - now the success case... */
> > +  fd = open( "testfile1.tst", O_RDWR );  rv = fdatasync( fd );
> > -    fd = open ("testfile1.tst", O_RDWR);
> > -    if (error == 0)
> > -      retval = TRUE;
> > -    else
> > -      retval = FALSE;
> > -    close (fd);
> > -  return (retval);
> > +  rv = close( fd );
> > - * UMaskTest function
> > - * Hits the umask code.
> > - * arguments: none
> > - * assumptions: umask function available.
> > - * actions: set umask to 0ctal 23.
> > - *          set umask to Octal 22, retrieve the old value.
> > - * returns: TRUE if old value is 23,
> > + * @brief Hits the umask code.
> > -int UMaskTest (void)
> > +static void UMaskTest( void )
> > -  mode_t error = 0;
> > -  int    retval = FALSE;
> > -  umask(023);
> > -  error = umask(022);
> > +  mode_t rv;
> > -  if (error == 023)
> > -    retval = TRUE;
> > -  else
> > -    retval = FALSE;
> > +  (void)umask( 023 );
> nit: add a space after (void)
> > -  return(retval);
> > +  rv = umask( 022 );
> > +  rtems_test_assert( rv == 023 );
> > - * UTimeTest function
> > - * Hits the utime code. Does NOT test the functionality of the
> > underlying utime
> > - * entry in the IMFS op table.
> > - * arguments: none
> > - * assumptions: utime function available.
> > - * actions: set utime for an invalid filename.
> > - *          set utime for a valid filename.
> > - * returns: TRUE if time on valid file is set correctly and utime failed on
> > - *          an invalid filename.
> > + * @brief Hits the utime code. Does not test the functionality of the
> > + *        underlying utime entry in the IMFS op table.
> > -int UTimeTest (void)
> > +static void UTimeTest( void )
> > -  int error = 0, retval = FALSE;
> > +  int rv;
> >    struct utimbuf time;
> >    struct stat fstat;
> >    /* First, an invalid filename. */
> > -  error = utime("!This is an =invalid p at thname!!! :)", NULL);
> > -  if (error == -1)
> > -    retval = TRUE;
> > -  else
> > -    retval = FALSE;
> > +  rv = utime( "!This is an =invalid p at thname!!! :)", NULL );
> > + rtems_test_assert( rv == -1 );  rtems_test_assert( errno == ENOENT
> >    /* Now, the success test. */
> > -    time.actime  = 12345;
> > -    time.modtime = 54321;
> > -    error = utime("testfile1.tst", &time);
> > +  time.actime  = 12345;
> > +  time.modtime = 54321;
> > -    if (error == 0) {
> > -      /* But, did it set the time? */
> > -      stat ("testfile1.tst", &fstat);
> > -      if ((fstat.st_atime == 12345) && (fstat.st_mtime == 54321 ))
> > -       retval = TRUE;
> > -      else
> > -       retval = FALSE;
> > -    else
> > -      retval = FALSE;
> > -    error = utime("testfile1.tst", NULL );
> > -    retval &= (error == 0) ? TRUE : FALSE;
> > +  rv = utime( "testfile1.tst", &time );  rtems_test_assert( rv == 0
> > +  /* But, did it set the time? */
> > +  rv = stat( "testfile1.tst", &fstat );  rtems_test_assert( rv == 0
> > + );  rtems_test_assert( fstat.st_atime == 12345 );
> > + rtems_test_assert( fstat.st_mtime == 54321 );
> > -  return (retval);
> > +  rv = utime( "testfile1.tst", NULL );  rtems_test_assert( rv == 0 );
> > - * UTimesTest function
> > - * Hits the utimes code. Does NOT test the functionality of the
> > underlying utime
> > - * arguments: none
> > - * assumptions: utimes function available.
> > - * actions: set utimes for an invalid filename.
> > - *          set utimes for a valid filename.
> > - * returns: TRUE if time on valid file is set correctly and utimes failed on
> > + * @brief Hits the utimes code. Does NOT test the functionality of the
> > -int UTimesTest (void)
> > +static void UTimesTest( void )
> > +  int rv;
> >    struct timeval time[2];
> >    struct stat fstat;
> > -  error = utimes("!This is an =invalid p at thname!!! :)", NULL);
> > -  if (error == -1)
> > -    retval = TRUE;
> > -  else
> > -    retval = FALSE;
> > +  rv = utimes( "!This is an =invalid p at thname!!! : )", NULL);
> > +  time[0].tv_sec = 12345;
> > +  time[1].tv_sec = 54321;
> > -    time[0].tv_sec = 12345;
> > -    time[1].tv_sec = 54321;
> > +  rv = utimes( "testfile1.tst", (struct timeval *)&time );
> > -    error = utimes("testfile1.tst", (struct timeval *)&time);
> > +  rtems_test_assert( fstat.st_atime == 12345 );
> > +  rtems_test_assert( fstat.st_mtime == 54321 ); }
> > -    if (error == 0) {
> > + * @brief Hits the pathconf code.
> > +static void PathConfTest( void )
> > +  int rv;
> > +  rv = pathconf( "thisfiledoesnotexist", _PC_LINK_MAX );
> > -       retval = TRUE;
> > -      else
> > -       retval = FALSE;
> > +  rv = pathconf( "testfile1.tst", _PC_LINK_MAX );
> > -    else
> > -      retval = FALSE;
> > + * @brief Hits the fpathconf code.
> > +static void FPathConfTest( void )
> > +  int rv;
> > +  int fd;
> > +  fd = -1;
> > +  rv = fpathconf( fd, _PC_LINK_MAX );  rtems_test_assert( rv == -1 );
> > -  return (retval);
> > +  fd = open( "testfile1.tst", O_RDWR );  rtems_test_assert( fd != -1
> > - * PathConfTest function
> > - * Hits the pathconf code.
> > - * arguments: none
> > - * assumptions: pathconf function available.
> > - * actions: Try to pathconf a bad filename.
> > - *          Try to pathconf a good filename.
> > - * returns: TRUE if pathconf fails on bad file, succeeds on good file.
> > +  rv = fpathconf( fd, _PC_LINK_MAX );  rtems_test_assert( rv != -1 );
> > -int PathConfTest (void)
> > +  rv = fpathconf( fd, _PC_MAX_CANON );  rtems_test_assert( rv != -1
> > -  error = pathconf("thisfiledoesnotexist", _PC_LINK_MAX);
> > +  rv = fpathconf( fd, _PC_MAX_INPUT );  rtems_test_assert( rv != -1
> > -  if (error == -1) {
> > -    error = pathconf("testfile1.tst", _PC_LINK_MAX);
> > +  rv = fpathconf( fd, _PC_NAME_MAX );  rtems_test_assert( rv != -1 );
> > -    if (error != -1)
> > -      retval = TRUE;
> > -    else
> > -      retval = FALSE;
> > +  rv = fpathconf( fd, _PC_PATH_MAX );  rtems_test_assert( rv != -1 );
> > -  else
> > -    retval = FALSE;
> > +  rv = fpathconf( fd, _PC_PIPE_BUF );  rtems_test_assert( rv != -1 );
> > +  rv = fpathconf( fd, _PC_CHOWN_RESTRICTED );  rtems_test_assert( rv
> > + != -1 );
> > -  return(retval);
> > +  rv = fpathconf( fd, _PC_NO_TRUNC );  rtems_test_assert( rv != -1 );
> > - * FPathConfTest function
> > - * Hits the fpathconf code.
> > - * arguments: none
> > - * assumptions: fpathconf function available.
> > - * actions: Call fpathconf with all arguments, plus an invalid.
> > - * returns: TRUE always.
> > +  rv = fpathconf( fd, _PC_VDISABLE );  rtems_test_assert( rv != -1 );
> > -int FPathConfTest (void)
> > +  rv = fpathconf( fd, _PC_ASYNC_IO );  rtems_test_assert( rv != -1 );
> > -  int fd  = -1;
> > +  rv = fpathconf( fd, _PC_PRIO_IO );
> > -  error = fpathconf(fd, _PC_LINK_MAX);
> > +  rv = fpathconf( fd, _PC_SYNC_IO );
> > -    fd = open("testfile1.tst", O_RDWR);
> > +  rv = fpathconf( fd, 255 );
> > +#ifdef __sparc__
> What's this for?
> > +#else
> > +#endif
> > -    error = fpathconf(fd, _PC_MAX_CANON);
> > -    error = fpathconf(fd, _PC_MAX_INPUT);
> > -    error = fpathconf(fd, _PC_NAME_MAX);
> > -    error = fpathconf(fd, _PC_PATH_MAX);
> > -    error = fpathconf(fd, _PC_PIPE_BUF);
> > -    error = fpathconf(fd, _PC_CHOWN_RESTRICTED);
> > -    error = fpathconf(fd, _PC_NO_TRUNC);
> > -    error = fpathconf(fd, _PC_VDISABLE);
> > -    error = fpathconf(fd, _PC_ASYNC_IO);
> > -    error = fpathconf(fd, _PC_PRIO_IO);
> > -    error = fpathconf(fd, _PC_SYNC_IO);
> > -    error = fpathconf(fd, 255);
> > +  rv = close( fd );
> > -    close(fd);
> > +  fd = open( "testfile1.tst", O_WRONLY );  rtems_test_assert( rv !=
> > + -1 );
> > -    fd = open("testfile1.tst", O_WRONLY);
> > +  rv = close( fd );
> > -    retval = TRUE;
> > + * @brief Hits the fsync code.
> > +static void FSyncTest( void )
> > +  int rv;
> > +  int fd;
> > -  else
> > -    retval = FALSE;
> > +  rv = fsync(fd);
> > -  return(retval);
> > +  rv = close( fd );
> > - * FSyncTest function
> > - * Hits the fsync code.
> > - * arguments: none
> > - * assumptions: open, fsync functions available.
> > - * actions: open test file,
> > - *          try to fsync it.
> > - * returns: TRUE if fsync doesn't return -1,
> > + * @brief Exercises sync().
> > +static void SyncTest( void )
> > +  sync();
> > -int FSyncTest (void)
> > + * @brief The main entry point to the test.
> > +int test_main( void );
> > -  int fd = -1;
> > +  TEST_BEGIN();
> > +  InitFiles();
> > +  printf( "\nFiles initialized successfully.\n" );
> remove the extraneous print statements. If things are working, the test output should be minimal/quiet just the start/end banners.
> > -  if (fd != -1) {
> > +  printf( "Testing lseek() on device... " );  DeviceLSeekTest();
> > + printf( "Success.\n" );
> > -    error = fsync(fd);
> > +  printf( "Testing dup()............... " );  DupTest();  printf(
> > + "Success.\n" );
> > -    if (error != -1)
> > -      retval = TRUE;
> > -    else
> > -      retval = FALSE;
> > +  printf( "Testing dup2().............. " );  Dup2Test();  printf(
> > + "Success.\n" );
> > -    close(fd);
> > +  printf( "Testing fdatasync()......... " );  FDataSyncTest();
> > -  else
> > -    retval = FALSE;
> > +  printf( "Testing umask()............. " );  UMaskTest();  printf(
> > + "Success.\n" );
> > +  printf( "Testing utime()............. " );  UTimeTest();  printf(
> > + "Success.\n" );
> > -  return(retval);
> > +  printf( "Testing utimes()............ " );  UTimesTest();  printf(
> > + "Success.\n" );
> > - * Main function
> > - *  main entry point to the test
> > +  printf( "Testing fsync()............. " );  FSyncTest();  printf(
> > + "Success.\n" );
> > -#if defined(__rtems__)
> > -int test_main(void);
> > -#else
> > -int main(
> > -  int    argc,
> > -  char **argv
> > -#endif
> > -  TEST_BEGIN();
> > +  printf( "Testing pathconf().......... " );  PathConfTest();
> > -  if (InitFiles() == TRUE) {
> > -    printf ("\nFiles initialized successfully.\n");
> > -    printf ("Testing device_lseek()... ");
> > -    if (DeviceLSeekTest() == TRUE)
> > -      printf ("Success.\n");
> > -    else
> > -      printf ("Failed!!!\n");
> > -    printf ("Testing dup()............ ");
> > -    if (DupTest() == TRUE)
> > -    else
> > -    printf ("Testing dup2()........... ");
> > -    if (Dup2Test() == TRUE)
> > -    else
> > -    printf ("Testing fdatasync()...... ");
> > -    if (FDataSyncTest() == TRUE)
> > -    else
> > -    printf ("Testing umask().......... ");
> > -    if (UMaskTest() == TRUE)
> > -    else
> > -   printf ("Testing utime().......... ");
> > -    if (UTimeTest() == TRUE)
> > -    else
> > -   printf ("Testing utimes().......... ");
> > -    if (UTimesTest() == TRUE)
> > -    else
> > -   printf ("Testing fsync().......... ");
> > -    if (FSyncTest() == TRUE)
> > -    else
> > -   printf ("Testing pathconf()....... ");
> > -    if (PathConfTest() == TRUE)
> > -    else
> > -   printf ("Testing fpathconf()...... ");
> > -    if (FPathConfTest() == TRUE)
> > -    else
> > -    printf ("Testing sync()...... ");
> > -    sync();
> > -    printf ("Done.\n");
> > -    TEST_END();
> > +  printf( "Testing fpathconf()......... " );  FPathConfTest();
> > +  printf( "Testing sync().............. " );  SyncTest();  printf(
> > + "Success.\n" );
> > +  TEST_END();
> > -  rtems_test_exit(0);
> > +  rtems_test_exit( 0 );
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
