[PATCH 2/2] c-user: Generate message manager documentation
Sebastian Huber
Fri Apr 23 06:26:36 UTC 2021
On 22/04/2021 20:00, Gedare Bloom wrote:
> On Thu, Apr 22, 2021 at 11:33 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 22/04/2021 17:44, Gedare Bloom wrote:
>>> Also not related to the documentation, but it seems that
>>> rtems_message_queue_construct() will not handle a NULL configuration.
>>> Is this intentional, or a bug to fix in the code and an error status
>>> to add? If it is intentional, an assert(config) should be added to the
>>> code path.
>> From my point of view it was intentional to not check for NULL. I can
>> add an _Assert( config != NULL ) or return an error status.
> assert makes sense to me at this level, it is a misuse of the API by the user.
Since we already have excessive NULL pointer checks in the Classic API,
I changed it to return RTEMS_INVALID_ADDRESS if the configuration is
NULL in rtems_task_construct() and rtems_message_queue_construct().
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
