[PATCH] psx13: Reworked and relicensed
Joel Sherrill
joel at rtems.org
Fri Apr 23 20:25:24 UTC 2021
On Fri, Apr 23, 2021 at 3:09 PM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Apr 23, 2021 at 3:08 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Thu, Apr 22, 2021 at 11:06 AM Ryan Long <ryan.long at oarcorp.com> wrote:
>>> >> +#ifdef __sparc__
>>> >What's this for?
>>> Joel said this was a special case, and that it needed to be put in, so
>>> I'm not sure.
>> https://git.rtems.org/rtems/tree/cpukit/posix/src/sysconf.c#n57
>> This was to support code in GCC which had hard-coded calls to this
>> sysconf()
>> in the SPARC backend but I grep'ed for them and didn't find them on
>> master.
>> Admittedly, I checked all the way back to egcs 1.1 and didn't find it
>> there either
>> so I am probably not looking right.
>> If we are sure this isn't in GCC anymore, then it can be removed in a
>> follow up
>> patch.
OK. Archeology update. The code in GCC requiring this was removed (drumroll
please......) 21 years ago!!!!
I have filed a ticket for this.
https://devel.rtems.org/ticket/4391#ticket
Ryan.. once this is merged, follow up with a simple patch to delete this
code.
#4391 is yours. :)
Thanks for triggering the investigation Gedare. Twenty years is a long time
to
carry this around and not need it.
>>> For the printf's in test_main(), I should take out all of the print
>>> statements saying
>>> "Testing <function>.....Success"?
>>> -----Original Message-----
>>> From: Gedare Bloom <gedare at rtems.org>
>>> Sent: Thursday, April 22, 2021 8:45 AM
>>> To: Ryan Long <ryan.long at oarcorp.com>
>>> Cc: devel at rtems.org
>>> Subject: Re: [PATCH] psx13: Reworked and relicensed
>>> See below for comments. This test suite might be a good candidate for
>>> conversion to T_TEST_CASE framework. At any rate, this refactor is a marked
>>> improvement.
>>> On Wed, Apr 21, 2021 at 2:57 PM Ryan Long <ryan.long at oarcorp.com> wrote:
>>> > Changed the way the tests were structured, added
>>> > rtems_test_assert()'s, updated psx13.scn and the license.
>>> relicense changes should generally Update #3899.
> You can have two lines for ticket updates in the git commit (I think).
> close
> updates
>>> > testsuites/psxtests/psx13/psx13.scn | 24 +-
>>> > testsuites/psxtests/psx13/test.c | 879
>>> > 2 files changed, 335 insertions(+), 568 deletions(-)
>>> > diff --git a/testsuites/psxtests/psx13/psx13.scn
>>> > b/testsuites/psxtests/psx13/psx13.scn
>>> > index 428a931..ee99867 100644
>>> > --- a/testsuites/psxtests/psx13/psx13.scn
>>> > +++ b/testsuites/psxtests/psx13/psx13.scn
>>> > @@ -1,16 +1,16 @@
>>> > *** POSIX TEST 13 ***
>>> > Files initialized successfully.
>>> > -Testing device_lseek()... Failed!!!
>>> > -Testing dup()............ Failed!!!
>>> > -Testing dup2()........... Success.
>>> > -Testing fdatasync()...... Success.
>>> > -Testing umask().......... Success.
>>> > -Testing utime().......... Success.
>>> > -Testing utimes().......... Success.
>>> > -Testing fsync().......... Success.
>>> > -Testing pathconf()....... Success.
>>> > -Testing fpathconf()...... Success.
>>> > -Testing sync()......
>>> > +Testing lseek() on device... Success.
>>> > +Testing dup()............... Success.
>>> > +Testing dup2().............. Success.
>>> > +Testing fdatasync()......... Success.
>>> > +Testing umask()............. Success.
>>> > +Testing utime()............. Success.
>>> > +Testing utimes()............ Success.
>>> > +Testing fsync()............. Success.
>>> > +Testing pathconf().......... Success.
>>> > +Testing fpathconf()......... Success.
>>> > +Testing sync().............. Success.
>>> > -*** END OF TEST PSX13 ***
>>> > +*** END OF TEST PSX 13 ***
>>> > diff --git a/testsuites/psxtests/psx13/test.c
>>> > b/testsuites/psxtests/psx13/test.c
>>> > index 79b24c2..2d25b02 100644
>>> > --- a/testsuites/psxtests/psx13/test.c
>>> > +++ b/testsuites/psxtests/psx13/test.c
>>> > @@ -1,26 +1,49 @@
>>> > - * Psx13
>>> > - * Chris Bond (working under Jennifer's account)
>>> > + * @file
>>> > + * @brief This tests various file system functions.
>>> > * This test exercises the following routines:
>>> > - * device_lseek - test implemented
>>> > - * dup - test implemented
>>> > - * dup2 - test implemented
>>> > - * fdatasync - test implemented
>>> > - * fsync - test implemented
>>> > - * pathconf - test implemented
>>> > - * fpathconf - test implemented
>>> > - * umask - test implemented
>>> > - * utime - test implemented
>>> > - * utimes - test implemented
>>> > + * - lseek()
>>> > + * - dup()
>>> > + * - dup2()
>>> > + * - fdatasync()
>>> > + * - fsync()
>>> > + * - pathconf()
>>> > + * - fpathconf()
>>> > + * - umask()
>>> > + * - utime()
>>> > + * - utimes()
>>> > + * - sync()
>>> While you're at it, please conform to
>>> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#c-c-header-file-template
>>> > + * SPDX-License-Identifier: BSD-2-Clause
>>> > - * COPYRIGHT (c) 1989-2009.
>>> > + * COPYRIGHT (c) 1989-2009, 2021.
>>> > * On-Line Applications Research Corporation (OAR).
>>> > - * The license and distribution terms for this file may be
>>> > - * found in the file LICENSE in this distribution or at
>>> > - * http://www.rtems.org/license/LICENSE.
>>> > + * Redistribution and use in source and binary forms, with or without
>>> > + * modification, are permitted provided that the following conditions
>>> > + * are met:
>>> > + * 1. Redistributions of source code must retain the above copyright
>>> > + * notice, this list of conditions and the following disclaimer.
>>> > + * 2. Redistributions in binary form must reproduce the above
>>> copyright
>>> > + * notice, this list of conditions and the following disclaimer in
>>> the
>>> > + * documentation and/or other materials provided with the
>>> distribution.
>>> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>> CONTRIBUTORS "AS IS"
>>> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>> > + TO, THE
>>> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>> > + PURPOSE
>>> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>>> > + CONTRIBUTORS BE
>>> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
>>> > + OR
>>> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>>> > + OF
>>> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>> > + BUSINESS
>>> > + * * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>> > + WHETHER IN
>>> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>> > + OTHERWISE)
>>> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>> > + ADVISED OF THE
>>> > + * POSSIBILITY OF SUCH DAMAGE.
>>> > #ifdef HAVE_CONFIG_H
>>> > @@ -34,6 +57,7 @@
>>> > #include <unistd.h>
>>> > #include <errno.h>
>>> > #include <utime.h>
>>> > +#include <tmacros.h>
>>> > #include <stdio.h>
>>> > #include <unistd.h>
>>> > @@ -42,685 +66,428 @@
>>> > const char rtems_test_name[] = "PSX 13";
>>> > -int InitFiles(void);
>>> > -int DeviceLSeekTest(void);
>>> > -int DupTest(void);
>>> > -int Dup2Test(void);
>>> > -int FDataSyncTest(void);
>>> > -int UMaskTest(void);
>>> > -int UTimeTest(void);
>>> > -int UTimesTest(void);
>>> > -int PathConfTest(void);
>>> > -int FPathConfTest(void);
>>> > -int FSyncTest(void);
>>> > - * InitFiles function
>>> > - * Initializes the three files to be used in the test.
>>> > - * arguments: none
>>> > - * assumptions: fopen, fprintf, fwrite, FILE are available
>>> > - * actions: creates testfile1, a text file with 'a'..'z' listed 4
>>> times.
>>> > - * creates testfile2, a text file with 'a'..'z' listed 4
>>> times.
>>> > - * creates testfile3, a binary file with 0..9 listed 4 times.
>>> > - * returns: TRUE if files opened successfully.
>>> > - * FALSE if fail on file open for write.
>>> > + * @brief Initializes the three files to be used for the test.
>>> > -int InitFiles (void)
>>> > +static void InitFiles( void )
>>> > int count;
>>> > + int rv;
>>> > FILE *fp1, *fp2, *fp3;
>>> > char letter;
>>> > int number;
>>> > - int retval;
>>> > - fp1 = fopen("testfile1.tst", "wt");
>>> > - fp2 = fopen("testfile2.tst", "wt");
>>> > - fp3 = fopen("testfile4.tst", "wb");
>>> > - if ((fp1 != NULL) && (fp2 != NULL) && (fp3 !=NULL)) {
>>> > + fp1 = fopen( "testfile1.tst", "wt" ); rtems_test_assert( fp1 !=
>>> > + NULL );
>>> > - letter = 'a';
>>> > + fp2 = fopen( "testfile2.tst", "wt" ); rtems_test_assert( fp2 !=
>>> > + NULL );
>>> > - for (count=0 ; count<(26*4); ++count) {
>>> > - fprintf (fp1, "%c", letter);
>>> > - fprintf (fp2, "%c", letter);
>>> > + fp3 = fopen( "testfile4.tst", "wb" ); rtems_test_assert( fp3 !=
>>> > + NULL );
>>> > - ++letter;
>>> > - if (letter > 'z')
>>> > - letter = 'a';
>>> > + letter = 'a';
>>> > - number = 0;
>>> > + for( count = 0 ; count < (26*4); ++count) {
>>> > + fprintf( fp1, "%c", letter );
>>> > + fprintf( fp2, "%c", letter );
>>> > - for (count = 0; count <40; ++count) {
>>> > - fwrite (&number, 1, sizeof(int), fp3);
>>> > + ++letter;
>>> > + if( letter > 'z' )
>>> > + letter = 'a';
>>> > - ++number;
>>> > - if (number > 9)
>>> > - number = 0;
>>> > + number = 0;
>>> > - fclose(fp1);
>>> > - fclose(fp2);
>>> > - fclose(fp3);
>>> > + for( count = 0; count < 40; ++count ) {
>>> > + fwrite( &number, 1, sizeof(int), fp3 );
>>> > - retval = TRUE;
>>> > + ++number;
>>> > + if( number > 9 )
>>> > + number = 0;
>>> > - else
>>> > - retval = FALSE;
>>> > + rv = fclose( fp1 );
>>> > + rtems_test_assert( rv != EOF );
>>> > - /* assert (retval == TRUE);*/
>>> > + rv = fclose( fp2 );
>>> > - return (retval);
>>> > + rv = fclose( fp3 );
>>> > - * DeviceLSeekTest function
>>> > - * Hits the device_lseek code by lseeking on the console.
>>> > - * arguments: none
>>> > - * assumptions: lseek available
>>> > - * actions: hits lseek with some dummy arguments.
>>> > - * returns: value of return from lseek.
>>> > + * @brief Hits the device_lseek code by lseeking on the console.
>>> > -int DeviceLSeekTest (void)
>>> > +static void DeviceLSeekTest( void )
>>> > - int error = -1, retval = FALSE;
>>> > + int rv;
>>> > + int fd;
>>> > - int fd = open ("/dev/console", O_RDONLY);
>>> > + fd = open( "/dev/console", O_RDONLY ); rtems_test_assert( fd != -1
>>> > - error = lseek(fd, 5, SEEK_SET);
>>> > + rv = lseek( fd, 5, SEEK_SET );
>>> > + rtems_test_assert( rv == -1 );
>>> > + rtems_test_assert( errno == ESPIPE );
>>> > - if (error == 0)
>>> > - retval = TRUE;
>>> > - else
>>> > - retval = FALSE;
>>> > - close( fd ); /* assert (retval == TRUE);*/
>>> > - return (retval);
>>> > + rv = close( fd );
>>> > + rtems_test_assert( rv == 0 );
>>> > - * DupTest function
>>> > - * Hits the dup code.
>>> > - * arguments: none
>>> > - * assumptions: dup, open, close, fcntl available.
>>> > - * actions: Gets a file descriptor(fd1) for test file1.
>>> > - * dups fd1 to fd2.
>>> > - * sets fd1 to append mode
>>> > - * checks fd2 to ensure it's in append mode, also.
>>> > - * returns: success if fd2 is indeed a copy of fd1.
>>> > + * @brief Exercises dup().
>>> > -int DupTest(void)
>>> > +static void DupTest( void )
>>> > int fd1, fd2;
>>> > + int flags;
>>> > + int rv;
>>> > - int flags = 0, retval = FALSE;
>>> > - fd1 = open ("testfile1.tst", O_RDONLY);
>>> > - fd2 = dup(fd1);
>>> > - if (fd2 != -1) {
>>> > + fd1 = open( "testfile1.tst", O_RDONLY ); rtems_test_assert( fd1 !=
>>> > + -1 );
>>> > - fcntl(fd1, F_SETFL, O_APPEND);
>>> > - flags = fcntl(fd2, F_GETFL);
>>> > + fd2 = dup( fd1 );
>>> > + rtems_test_assert( fd2 != -1 );
>>> > - close (fd1);
>>> > + rv = fcntl( fd1, F_SETFL, O_APPEND ); rtems_test_assert( rv != -1
>>> > - flags = (flags & O_APPEND);
>>> > + flags = fcntl( fd2, F_GETFL );
>>> > + flags = ( flags & O_APPEND );
>>> minor nit, this could be more concise
>>> flags = fcntl( fd2, F_GETFL) & O_APPEND;
>>> > + rtems_test_assert( flags == 0 );
>>> > - retval = (flags == O_APPEND);
>>> > - else
>>> > - retval = FALSE;
>>> > + rv = close( fd1 );
>>> Just curious, why be inconsistent how you check for the return from
>>> close? Above using != EOF, here using == 0. It doesn't matter greatly.
>>> > - close( fd1 );
>>> > - close( fd2 );
>>> > - return (retval);
>>> > + rv = close( fd2 );
>>> > - * Dup2Test function
>>> > - * Hits the dup2 code.
>>> > - * arguments: none
>>> > - * assumptions: dup, dup2, open, close, fcntl available.
>>> > - * sets fd1 to invalid value, fd2 to valid, tries to dup2.
>>> > - * sets fd2 to invalid value, fd1 to valid tries to dup2.
>>> > - * returns: success if fd2 is a copy of fd1, and invalid fd1 or fd2
>>> produce errors.
>>> > + * @brief Exercises dup2().
>>> > -int Dup2Test(void)
>>> > +static void Dup2Test( void )
>>> > int fd1, fd2;
>>> > + int flags;
>>> > + int rv;
>>> > - int error = 0;
>>> > + -1 );
>>> > - fd2 = open ("testfile2.tst", O_RDONLY);
>>> > - error = dup2(fd1, fd2);
>>> > + fd2 = open( "testfile2.tst", O_RDONLY ); rtems_test_assert( fd2 !=
>>> > + -1 );
>>> > /* make sure dup2 works if both fd1 and fd2 are valid file
>>> > descriptors. */
>>> > + rv = dup2( fd1, fd2 );
>>> > + rtems_test_assert( rv != -1 );
>>> > - if (error != -1) {
>>> > - flags = fcntl(fd1, F_GETFL);
>>> > + flags = fcntl( fd1, F_GETFL );
>>> > + rtems_test_assert( flags == O_APPEND );
>>> ditto on both conciseness and consistency here.
>>> > - else {
>>> > - retval = FALSE;
>>> > - close(fd2);
>>> > - if (retval == TRUE) {
>>> > + /* make sure dup2 fails correctly if one or the other arguments are
>>> > + invalid. */
>>> > + /* this assumes -1 is an invalid value for a file descriptor!!!
>>> > + (POSIX book, p.135) */ rv = close( fd1 ); rtems_test_assert( rv ==
>>> > + 0 );
>>> > - /* make sure dup2 fails correctly if one or the other arguments
>>> are invalid. */
>>> > - /* this assumes -1 is an invalid value for a file descriptor!!!
>>> > + fd1 = -1;
>>> > - fd1 = -1;
>>> > - if (dup2 (fd1, fd2) != -1)
>>> > - retval = FALSE;
>>> > - else {
>>> > - fd1 = dup(fd2);
>>> > - fd2 = -1;
>>> > + fd1 = dup( fd2 );
>>> > + fd2 = -1;
>>> > - if (dup2(fd1, fd2) != -1)
>>> > - retval = FALSE;
>>> > - close (fd1);
>>> > - close (fd2);
>>> > - return (retval);
>>> > - * FDataSyncTest function
>>> > - * Hits the fdatasync code. Does NOT test the functionality of the
>>> > - * underlying fdatasync entry in the IMFS op table.
>>> > - * arguments: none
>>> > - * assumptions: open, close, fdatasync functions available.
>>> > - * actions: attempts to fdatasync a file descriptor flagged as
>>> read-only.
>>> > - * attempts to fdatasync an invalid file descriptor (-1).
>>> > - * attempts to fdatasync a perfectly valid fd opened as RDWR
>>> > - * returns: TRUE if attempt to fdatasync invalid and read-only filed
>>> > - * descriptor fail, and fdatasync succeeds on valid fd.
>>> > - * FALSE otherwise.
>>> > + * @brief Exercises fdatasync(). Does NOT test the functionality of
>>> the
>>> > + * underlying fdatasync entry in the IMFS op table.
>>> > +static void FDataSyncTest( void )
>>> > - int fd = -1;
>>> > - int error = 0, retval = TRUE;
>>> > + int fd;
>>> > + int rv;
>>> > /* Try it with a RD_ONLY file. */
>>> > + fd = open( "testfile1.tst", O_RDONLY ); rtems_test_assert( fd !=
>>> > + -1 );
>>> > - fd = open ("testfile1.tst", O_RDONLY);
>>> > - error = fdatasync(fd);
>>> > - if ((error == -1) && (errno == EINVAL))
>>> > - retval = TRUE;
>>> > - else
>>> > - retval = FALSE;
>>> > + rv = fdatasync( fd );
>>> > + rtems_test_assert( errno == EBADF );
>>> > - close (fd);
>>> > + rv = close(fd);
>>> > + /* Try it with a bad file descriptor */ fd = -1;
>>> > - /* Try it with a bad file descriptor */
>>> > - fd = -1;
>>> > - if ((errno == EBADF) && (error == -1))
>>> > - retval = TRUE;
>>> > - else
>>> > - retval = FALSE;
>>> > /* Okay - now the success case... */
>>> > + fd = open( "testfile1.tst", O_RDWR ); rv = fdatasync( fd );
>>> > - fd = open ("testfile1.tst", O_RDWR);
>>> > - if (error == 0)
>>> > - retval = TRUE;
>>> > - else
>>> > - retval = FALSE;
>>> > - close (fd);
>>> > - return (retval);
>>> > + rv = close( fd );
>>> > - * UMaskTest function
>>> > - * Hits the umask code.
>>> > - * arguments: none
>>> > - * assumptions: umask function available.
>>> > - * actions: set umask to 0ctal 23.
>>> > - * set umask to Octal 22, retrieve the old value.
>>> > - * returns: TRUE if old value is 23,
>>> > + * @brief Hits the umask code.
>>> > -int UMaskTest (void)
>>> > +static void UMaskTest( void )
>>> > - mode_t error = 0;
>>> > - int retval = FALSE;
>>> > - umask(023);
>>> > - error = umask(022);
>>> > + mode_t rv;
>>> > - if (error == 023)
>>> > - retval = TRUE;
>>> > - else
>>> > - retval = FALSE;
>>> > + (void)umask( 023 );
>>> nit: add a space after (void)
>>> > - return(retval);
>>> > + rv = umask( 022 );
>>> > + rtems_test_assert( rv == 023 );
>>> > - * UTimeTest function
>>> > - * Hits the utime code. Does NOT test the functionality of the
>>> > underlying utime
>>> > - * entry in the IMFS op table.
>>> > - * arguments: none
>>> > - * assumptions: utime function available.
>>> > - * actions: set utime for an invalid filename.
>>> > - * set utime for a valid filename.
>>> > - * returns: TRUE if time on valid file is set correctly and utime
>>> failed on
>>> > - * an invalid filename.
>>> > + * @brief Hits the utime code. Does not test the functionality of the
>>> > + * underlying utime entry in the IMFS op table.
>>> > -int UTimeTest (void)
>>> > +static void UTimeTest( void )
>>> > - int error = 0, retval = FALSE;
>>> > + int rv;
>>> > struct utimbuf time;
>>> > struct stat fstat;
>>> > /* First, an invalid filename. */
>>> > - error = utime("!This is an =invalid p at thname!!! :)", NULL);
>>> > - if (error == -1)
>>> > - retval = TRUE;
>>> > - else
>>> > - retval = FALSE;
>>> > + rv = utime( "!This is an =invalid p at thname!!! :)", NULL );
>>> > + rtems_test_assert( rv == -1 ); rtems_test_assert( errno == ENOENT
>>> > /* Now, the success test. */
>>> > - time.actime = 12345;
>>> > - time.modtime = 54321;
>>> > - error = utime("testfile1.tst", &time);
>>> > + time.actime = 12345;
>>> > + time.modtime = 54321;
>>> > - if (error == 0) {
>>> > - /* But, did it set the time? */
>>> > - stat ("testfile1.tst", &fstat);
>>> > - if ((fstat.st_atime == 12345) && (fstat.st_mtime == 54321 ))
>>> > - retval = TRUE;
>>> > - else
>>> > - retval = FALSE;
>>> > - else
>>> > - retval = FALSE;
>>> > - error = utime("testfile1.tst", NULL );
>>> > - retval &= (error == 0) ? TRUE : FALSE;
>>> > + rv = utime( "testfile1.tst", &time ); rtems_test_assert( rv == 0
>>> > + /* But, did it set the time? */
>>> > + rv = stat( "testfile1.tst", &fstat ); rtems_test_assert( rv == 0
>>> > + ); rtems_test_assert( fstat.st_atime == 12345 );
>>> > + rtems_test_assert( fstat.st_mtime == 54321 );
>>> > - return (retval);
>>> > + rv = utime( "testfile1.tst", NULL ); rtems_test_assert( rv == 0 );
>>> > - * UTimesTest function
>>> > - * Hits the utimes code. Does NOT test the functionality of the
>>> > underlying utime
>>> > - * arguments: none
>>> > - * assumptions: utimes function available.
>>> > - * actions: set utimes for an invalid filename.
>>> > - * set utimes for a valid filename.
>>> > - * returns: TRUE if time on valid file is set correctly and utimes
>>> failed on
>>> > + * @brief Hits the utimes code. Does NOT test the functionality of the
>>> > -int UTimesTest (void)
>>> > +static void UTimesTest( void )
>>> > + int rv;
>>> > struct timeval time[2];
>>> > struct stat fstat;
>>> > - error = utimes("!This is an =invalid p at thname!!! :)", NULL);
>>> > - if (error == -1)
>>> > - retval = TRUE;
>>> > - else
>>> > - retval = FALSE;
>>> > + rv = utimes( "!This is an =invalid p at thname!!! : )", NULL);
>>> > + time[0].tv_sec = 12345;
>>> > + time[1].tv_sec = 54321;
>>> > - time[0].tv_sec = 12345;
>>> > - time[1].tv_sec = 54321;
>>> > + rv = utimes( "testfile1.tst", (struct timeval *)&time );
>>> > - error = utimes("testfile1.tst", (struct timeval *)&time);
>>> > + rtems_test_assert( fstat.st_atime == 12345 );
>>> > + rtems_test_assert( fstat.st_mtime == 54321 ); }
>>> > - if (error == 0) {
>>> > + * @brief Hits the pathconf code.
>>> > +static void PathConfTest( void )
>>> > + int rv;
>>> > + rv = pathconf( "thisfiledoesnotexist", _PC_LINK_MAX );
>>> > - retval = TRUE;
>>> > - else
>>> > - retval = FALSE;
>>> > + rv = pathconf( "testfile1.tst", _PC_LINK_MAX );
>>> > - else
>>> > - retval = FALSE;
>>> > + * @brief Hits the fpathconf code.
>>> > +static void FPathConfTest( void )
>>> > + int rv;
>>> > + int fd;
>>> > + fd = -1;
>>> > + rv = fpathconf( fd, _PC_LINK_MAX ); rtems_test_assert( rv == -1 );
>>> > - return (retval);
>>> > + fd = open( "testfile1.tst", O_RDWR ); rtems_test_assert( fd != -1
>>> > - * PathConfTest function
>>> > - * Hits the pathconf code.
>>> > - * arguments: none
>>> > - * assumptions: pathconf function available.
>>> > - * actions: Try to pathconf a bad filename.
>>> > - * Try to pathconf a good filename.
>>> > - * returns: TRUE if pathconf fails on bad file, succeeds on good file.
>>> > + rv = fpathconf( fd, _PC_LINK_MAX ); rtems_test_assert( rv != -1 );
>>> > -int PathConfTest (void)
>>> > + rv = fpathconf( fd, _PC_MAX_CANON ); rtems_test_assert( rv != -1
>>> > - error = pathconf("thisfiledoesnotexist", _PC_LINK_MAX);
>>> > + rv = fpathconf( fd, _PC_MAX_INPUT ); rtems_test_assert( rv != -1
>>> > - if (error == -1) {
>>> > - error = pathconf("testfile1.tst", _PC_LINK_MAX);
>>> > + rv = fpathconf( fd, _PC_NAME_MAX ); rtems_test_assert( rv != -1 );
>>> > - if (error != -1)
>>> > - retval = TRUE;
>>> > - else
>>> > - retval = FALSE;
>>> > + rv = fpathconf( fd, _PC_PATH_MAX ); rtems_test_assert( rv != -1 );
>>> > - else
>>> > - retval = FALSE;
>>> > + rv = fpathconf( fd, _PC_PIPE_BUF ); rtems_test_assert( rv != -1 );
>>> > + rv = fpathconf( fd, _PC_CHOWN_RESTRICTED ); rtems_test_assert( rv
>>> > + != -1 );
>>> > - return(retval);
>>> > + rv = fpathconf( fd, _PC_NO_TRUNC ); rtems_test_assert( rv != -1 );
>>> > - * FPathConfTest function
>>> > - * Hits the fpathconf code.
>>> > - * arguments: none
>>> > - * assumptions: fpathconf function available.
>>> > - * actions: Call fpathconf with all arguments, plus an invalid.
>>> > - * returns: TRUE always.
>>> > + rv = fpathconf( fd, _PC_VDISABLE ); rtems_test_assert( rv != -1 );
>>> > -int FPathConfTest (void)
>>> > + rv = fpathconf( fd, _PC_ASYNC_IO ); rtems_test_assert( rv != -1 );
>>> > - int fd = -1;
>>> > + rv = fpathconf( fd, _PC_PRIO_IO );
>>> > - error = fpathconf(fd, _PC_LINK_MAX);
>>> > + rv = fpathconf( fd, _PC_SYNC_IO );
>>> > - fd = open("testfile1.tst", O_RDWR);
>>> > + rv = fpathconf( fd, 255 );
>>> > +#ifdef __sparc__
>>> What's this for?
>>> > +#else
>>> > +#endif
>>> > - error = fpathconf(fd, _PC_MAX_CANON);
>>> > - error = fpathconf(fd, _PC_MAX_INPUT);
>>> > - error = fpathconf(fd, _PC_NAME_MAX);
>>> > - error = fpathconf(fd, _PC_PATH_MAX);
>>> > - error = fpathconf(fd, _PC_PIPE_BUF);
>>> > - error = fpathconf(fd, _PC_CHOWN_RESTRICTED);
>>> > - error = fpathconf(fd, _PC_NO_TRUNC);
>>> > - error = fpathconf(fd, _PC_VDISABLE);
>>> > - error = fpathconf(fd, _PC_ASYNC_IO);
>>> > - error = fpathconf(fd, _PC_PRIO_IO);
>>> > - error = fpathconf(fd, _PC_SYNC_IO);
>>> > - error = fpathconf(fd, 255);
>>> > + rv = close( fd );
>>> > - close(fd);
>>> > + fd = open( "testfile1.tst", O_WRONLY ); rtems_test_assert( rv !=
>>> > + -1 );
>>> > - fd = open("testfile1.tst", O_WRONLY);
>>> > + rv = close( fd );
>>> > - retval = TRUE;
>>> > + * @brief Hits the fsync code.
>>> > +static void FSyncTest( void )
>>> > + int rv;
>>> > + int fd;
>>> > - else
>>> > - retval = FALSE;
>>> > + rv = fsync(fd);
>>> > - return(retval);
>>> > + rv = close( fd );
>>> > - * FSyncTest function
>>> > - * Hits the fsync code.
>>> > - * arguments: none
>>> > - * assumptions: open, fsync functions available.
>>> > - * actions: open test file,
>>> > - * try to fsync it.
>>> > - * returns: TRUE if fsync doesn't return -1,
>>> > + * @brief Exercises sync().
>>> > +static void SyncTest( void )
>>> > + sync();
>>> > -int FSyncTest (void)
>>> > + * @brief The main entry point to the test.
>>> > +int test_main( void );
>>> > - int fd = -1;
>>> > + TEST_BEGIN();
>>> > + InitFiles();
>>> > + printf( "\nFiles initialized successfully.\n" );
>>> remove the extraneous print statements. If things are working, the test
>>> output should be minimal/quiet just the start/end banners.
>>> > - if (fd != -1) {
>>> > + printf( "Testing lseek() on device... " ); DeviceLSeekTest();
>>> > + printf( "Success.\n" );
>>> > - error = fsync(fd);
>>> > + printf( "Testing dup()............... " ); DupTest(); printf(
>>> > + "Success.\n" );
>>> > - if (error != -1)
>>> > - retval = TRUE;
>>> > - else
>>> > - retval = FALSE;
>>> > + printf( "Testing dup2().............. " ); Dup2Test(); printf(
>>> > + "Success.\n" );
>>> > - close(fd);
>>> > + printf( "Testing fdatasync()......... " ); FDataSyncTest();
>>> > - else
>>> > - retval = FALSE;
>>> > + printf( "Testing umask()............. " ); UMaskTest(); printf(
>>> > + "Success.\n" );
>>> > + printf( "Testing utime()............. " ); UTimeTest(); printf(
>>> > + "Success.\n" );
>>> > - return(retval);
>>> > + printf( "Testing utimes()............ " ); UTimesTest(); printf(
>>> > + "Success.\n" );
>>> > - * Main function
>>> > - * main entry point to the test
>>> > + printf( "Testing fsync()............. " ); FSyncTest(); printf(
>>> > + "Success.\n" );
>>> > -#if defined(__rtems__)
>>> > -int test_main(void);
>>> > -#else
>>> > -int main(
>>> > - int argc,
>>> > - char **argv
>>> > -#endif
>>> > - TEST_BEGIN();
>>> > + printf( "Testing pathconf().......... " ); PathConfTest();
>>> > - if (InitFiles() == TRUE) {
>>> > - printf ("\nFiles initialized successfully.\n");
>>> > - printf ("Testing device_lseek()... ");
>>> > - if (DeviceLSeekTest() == TRUE)
>>> > - printf ("Success.\n");
>>> > - else
>>> > - printf ("Failed!!!\n");
>>> > - printf ("Testing dup()............ ");
>>> > - if (DupTest() == TRUE)
>>> > - else
>>> > - printf ("Testing dup2()........... ");
>>> > - if (Dup2Test() == TRUE)
>>> > - else
>>> > - printf ("Testing fdatasync()...... ");
>>> > - if (FDataSyncTest() == TRUE)
>>> > - else
>>> > - printf ("Testing umask().......... ");
>>> > - if (UMaskTest() == TRUE)
>>> > - else
>>> > - printf ("Testing utime().......... ");
>>> > - if (UTimeTest() == TRUE)
>>> > - else
>>> > - printf ("Testing utimes().......... ");
>>> > - if (UTimesTest() == TRUE)
>>> > - else
>>> > - printf ("Testing fsync().......... ");
>>> > - if (FSyncTest() == TRUE)
>>> > - else
>>> > - printf ("Testing pathconf()....... ");
>>> > - if (PathConfTest() == TRUE)
>>> > - else
>>> > - printf ("Testing fpathconf()...... ");
>>> > - if (FPathConfTest() == TRUE)
>>> > - else
>>> > - printf ("Testing sync()...... ");
>>> > - sync();
>>> > - printf ("Done.\n");
>>> > - TEST_END();
>>> > + printf( "Testing fpathconf()......... " ); FPathConfTest();
>>> > + printf( "Testing sync().............. " ); SyncTest(); printf(
>>> > + "Success.\n" );
>>> > + TEST_END();
>>> > - rtems_test_exit(0);
>>> > + rtems_test_exit( 0 );
>>> > 1.8.3.1
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210423/6d170ec0/attachment-0001.html>
