[PATCH 2/3] Consistent library name used now
Robin Mueller
robin.mueller.m at gmail.com
Sat Apr 24 11:54:31 UTC 2021
Important fix for CMake build system
CMakeLists.txt | 10 +++++-----
lwip/src/api/CMakeLists.txt | 2 +-
lwip/src/core/CMakeLists.txt | 2 +-
lwip/src/core/ipv4/CMakeLists.txt | 2 +-
lwip/src/core/ipv6/CMakeLists.txt | 2 +-
lwip/src/netif/CMakeLists.txt | 2 +-
6 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/CMakeLists.txt b/CMakeLists.txt
index e1ef8f0..59cc7e9 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -32,8 +32,8 @@ include("${LWIP_CMAKE_CONFIG_DIR}/PortSelect.cmake")
rtems_lwip_port_select(${RTEMS_BSP})
-set(LWIP_LIB_NAME lwip)
-add_library(${LWIP_LIB_NAME})
+set(LIB_LWIP_NAME lwip)
+add_library(${LIB_LWIP_NAME})
add_subdirectory(lwip)
@@ -55,21 +55,21 @@ if(CMAKE_VERBOSE)
message(STATUS "lwIP configuration path: ${LWIP_CONFIG_PATH}")
endif()
-target_include_directories(${LWIP_LIB_NAME} PRIVATE
+target_include_directories(${LIB_LWIP_NAME} PRIVATE
${LWIP_CONFIG_PATH_ABS}
# Remove unused sections
if(CMAKE_C_COMPILER_ID STREQUAL "GNU")
if(LWIP_GENERATE_SECTIONS)
- target_compile_options(${LWIP_LIB_NAME} PRIVATE
+ target_compile_options(${LIB_LWIP_NAME} PRIVATE
"-ffunction-sections"
"-fdata-sections"
endif()
if(LWIP_REMOVE_UNUSED_CODE)
- target_link_options(${LWIP_LIB_NAME} PRIVATE
+ target_link_options(${LIB_LWIP_NAME} PRIVATE
"Wl,--gc-sections"
endif()
diff --git a/lwip/src/api/CMakeLists.txt b/lwip/src/api/CMakeLists.txt
index 9b2e34c..7150ade 100644
--- a/lwip/src/api/CMakeLists.txt
+++ b/lwip/src/api/CMakeLists.txt
@@ -1,4 +1,4 @@
-target_sources(${LWIP_LIB_NAME} PRIVATE
+target_sources(${LIB_LWIP_NAME} PRIVATE
api_lib.c
api_msg.c
err.c
diff --git a/lwip/src/core/CMakeLists.txt b/lwip/src/core/CMakeLists.txt
index 4e879ea..f7f17a7 100644
--- a/lwip/src/core/CMakeLists.txt
+++ b/lwip/src/core/CMakeLists.txt
@@ -1,4 +1,4 @@
altcp_alloc.c
altcp_tcp.c
altcp.c
diff --git a/lwip/src/core/ipv4/CMakeLists.txt b/lwip/src/core/ipv4/CMakeLists.txt
index e0f9e58..a47fa5d 100644
--- a/lwip/src/core/ipv4/CMakeLists.txt
+++ b/lwip/src/core/ipv4/CMakeLists.txt
@@ -1,4 +1,4 @@
autoip.c
dhcp.c
etharp.c
diff --git a/lwip/src/core/ipv6/CMakeLists.txt b/lwip/src/core/ipv6/CMakeLists.txt
index fce0b11..391a05b 100644
--- a/lwip/src/core/ipv6/CMakeLists.txt
+++ b/lwip/src/core/ipv6/CMakeLists.txt
@@ -1,4 +1,4 @@
ethip6.c
dhcp6.c
icmp6.c
diff --git a/lwip/src/netif/CMakeLists.txt b/lwip/src/netif/CMakeLists.txt
index 7c233ae..47f7242 100644
--- a/lwip/src/netif/CMakeLists.txt
+++ b/lwip/src/netif/CMakeLists.txt
@@ -1,4 +1,4 @@
bridgeif_fdb.c
bridgeif.c
ethernet.c
2.25.1
