[PATCH 3/3] merge error fixes
Vijay Kumar Banerjee vijay at rtems.org
Sat Apr 24 16:36:44 UTC 2021
Hi Robin,
On Sat, Apr 24, 2021 at 5:56 AM Robin Mueller <robin.mueller.m at gmail.com> wrote:
> A function was defined twice due to a merge error.
> This patch fixes this.
Please squash these into one, since they're not upstream yet, it's not
a problem to squash them into the patch that cased the merge error.
This way it will be fixed and we won't need an extra commit.
>  lwip/ports/drivers/rtems_lwip.c | 30 ------------------------------
>  1 file changed, 30 deletions(-)
> diff --git a/lwip/ports/drivers/rtems_lwip.c b/lwip/ports/drivers/rtems_lwip.c
> index a106616..7e2771c 100644
> --- a/lwip/ports/drivers/rtems_lwip.c
> +++ b/lwip/ports/drivers/rtems_lwip.c
> @@ -196,36 +196,6 @@ rtems_lwip_get_hwaddr_str(struct netif *netif, uint8_t *mac_str)
>    mac_str[outindex] = 0;
> -void
> -rtems_lwip_determine_static_ipv4_address(ip4_addr_t* ip_addr, ip4_addr_t* netmask,
> -    ip4_addr_t* gw_addr) {
> -#if STATIC_IP_ADDRESS == 1
> -#if CALCULATE_ETH_IP_ADDR == 1
> -  IP_ADDR4(ip_addr, IP_ADDR0, IP_ADDR1, IP_ADDR2, IP_ADDR3);
> -#else
> -  ip_addr->addr = htonl(ETH_IP_ADDR);
> -#endif
> -#if CALCULATE_ETH_NETMASK == 1
> -  IP_ADDR4(net_mask, NETMASK_ADDR0, NETMASK_ADDR1, NETMASK_ADDR2, NETMASK_ADDR3);
> -#else
> -  net_mask->addr = htonl(ETH_NETMASK);
> -#endif
> -#if CALCULATE_GW_ADDRESS == 1
> -  IP_ADDR4(gw_addr, GW_ADDR0, GW_ADDR1, GW_ADDR2, GW_ADDR3);
> -#else
> -  gw_addr->addr = htonl(ETH_GW);
> -#endif
> -#else
> -  ip_addr_set_zero_ip4(ip_addr);
> -  ip_addr_set_zero_ip4(netmask);
> -  ip_addr_set_zero_ip4(gw_addr);
> -#endif /* STATIC_IP_ADDRESS == 0 */
>  void
>  rtems_lwip_convert_ip_to_decimal_str(ip_addr_t ip, uint8_t *ip_str)
> 2.25.1
> devel mailing list
> devel at rtems.org
