[PATCH 1/2] Return status code for _Scheduler_Get_affinity()
Sebastian Huber
Mon Apr 26 08:40:56 UTC 2021
This avoids having conditional expressions to the API-specific status
code.
cpukit/include/rtems/score/schedulerimpl.h | 7 ++++---
cpukit/posix/src/pthreadgetaffinitynp.c | 7 ++++---
cpukit/posix/src/pthreadgetattrnp.c | 7 ++++---
cpukit/rtems/src/taskgetaffinity.c | 7 ++++---
cpukit/score/src/schedulergetaffinity.c | 9 +++++++--
5 files changed, 23 insertions(+), 14 deletions(-)
diff --git a/cpukit/include/rtems/score/schedulerimpl.h b/cpukit/include/rtems/score/schedulerimpl.h
index c545615919..397789372c 100644
--- a/cpukit/include/rtems/score/schedulerimpl.h
+++ b/cpukit/include/rtems/score/schedulerimpl.h
@@ -693,10 +693,11 @@ RTEMS_INLINE_ROUTINE const Processor_mask *_Scheduler_Get_processors(
* @param cpusetsize The size of @a cpuset.
* @param[out] cpuset The cpuset that serves as destination for the copy operation
- * @retval true The copy operation was lossless.
- * @retval false The copy operation was not lossless
+ * @retval STATUS_SUCCESSFUL The operation succeeded.
+ * @retval STATUS_INVALID_NUMBER The processor set was too small.
-bool _Scheduler_Get_affinity(
+Status_Control _Scheduler_Get_affinity(
Thread_Control *the_thread,
size_t cpusetsize,
cpu_set_t *cpuset
diff --git a/cpukit/posix/src/pthreadgetaffinitynp.c b/cpukit/posix/src/pthreadgetaffinitynp.c
index 977f82c69b..b904aea36c 100644
--- a/cpukit/posix/src/pthreadgetaffinitynp.c
+++ b/cpukit/posix/src/pthreadgetaffinitynp.c
@@ -28,6 +28,7 @@
+#include <rtems/posix/posixapi.h>
int pthread_getaffinity_np(
pthread_t thread,
@@ -38,7 +39,7 @@ int pthread_getaffinity_np(
Thread_Control *the_thread;
ISR_lock_Context lock_context;
Per_CPU_Control *cpu_self;
- bool ok;
+ Status_Control status;
if ( cpuset == NULL ) {
return EFAULT;
@@ -53,7 +54,7 @@ int pthread_getaffinity_np(
cpu_self = _Thread_Dispatch_disable_critical( &lock_context );
_Thread_State_acquire_critical( the_thread, &lock_context );
- ok = _Scheduler_Get_affinity(
+ status = _Scheduler_Get_affinity(
the_thread,
cpusetsize,
cpuset
@@ -61,7 +62,7 @@ int pthread_getaffinity_np(
_Thread_State_release( the_thread, &lock_context );
_Thread_Dispatch_enable( cpu_self );
- return ok ? 0 : EINVAL;
+ return _POSIX_Get_error( status );
#endif
diff --git a/cpukit/posix/src/pthreadgetattrnp.c b/cpukit/posix/src/pthreadgetattrnp.c
index eae29d1de7..5572fb98a5 100644
--- a/cpukit/posix/src/pthreadgetattrnp.c
+++ b/cpukit/posix/src/pthreadgetattrnp.c
@@ -26,6 +26,7 @@
#include <rtems/posix/pthreadattrimpl.h>
@@ -41,7 +42,7 @@ int pthread_getattr_np(
Thread_CPU_budget_algorithms budget_algorithm;
const Scheduler_Control *scheduler;
Priority_Control priority;
- bool ok;
if ( attr == NULL ) {
return EINVAL;
@@ -82,7 +83,7 @@ int pthread_getattr_np(
attr->affinityset = &attr->affinitysetpreallocated;
attr->affinitysetsize = sizeof( attr->affinitysetpreallocated );
the_thread,
attr->affinitysetsize,
attr->affinityset
@@ -102,5 +103,5 @@ int pthread_getattr_np(
attr->schedpolicy =
_POSIX_Thread_Translate_to_sched_policy( budget_algorithm );
diff --git a/cpukit/rtems/src/taskgetaffinity.c b/cpukit/rtems/src/taskgetaffinity.c
index d08c2d6835..6ced283393 100644
--- a/cpukit/rtems/src/taskgetaffinity.c
+++ b/cpukit/rtems/src/taskgetaffinity.c
@@ -21,6 +21,7 @@
#endif
+#include <rtems/rtems/statusimpl.h>
@@ -33,7 +34,7 @@ rtems_status_code rtems_task_get_affinity(
- bool ok;
return RTEMS_INVALID_ADDRESS;
@@ -54,7 +55,7 @@ rtems_status_code rtems_task_get_affinity(
the_thread,
cpusetsize,
cpuset
@@ -62,5 +63,5 @@ rtems_status_code rtems_task_get_affinity(
- return ok ? RTEMS_SUCCESSFUL : RTEMS_INVALID_NUMBER;
+ return _Status_Get( status );
diff --git a/cpukit/score/src/schedulergetaffinity.c b/cpukit/score/src/schedulergetaffinity.c
index 87be699f5b..99dc53609d 100644
--- a/cpukit/score/src/schedulergetaffinity.c
+++ b/cpukit/score/src/schedulergetaffinity.c
@@ -27,7 +27,7 @@
size_t cpusetsize,
cpu_set_t *cpuset
@@ -49,5 +49,10 @@ bool _Scheduler_Get_affinity(
status = _Processor_mask_To_cpu_set_t( affinity, cpusetsize, cpuset );
_Scheduler_Release_critical( scheduler, &lock_context );
- return status == PROCESSOR_MASK_COPY_LOSSLESS;
+ if ( status == PROCESSOR_MASK_COPY_LOSSLESS ) {
+ return STATUS_INVALID_NUMBER;
+ return STATUS_SUCCESSFUL;
2.26.2
