[PATCH] c-user: Generate interrupt manager documentation
Mon Apr 26 18:35:57 UTC 2021
On 26/04/2021 20:30, Gedare Bloom wrote:
> I need clarification on a subtle point, which exists prior to your
> change. It may be that I just don't understand what we mean by "The
> directive will not cause the calling task to be preempted.", but does
> rtems_interrupt_enable() and rtems_interrupt_flash() introduce a
> preemption point? The documentation suggests it does not, but I am not
> so clear. What about rtems_interrupt_lock_acquire() and
> rtems_interrupt_lock_release()? Similar kind of thinking applies.
> Calling these directives can cause a scheduling invocation due to, for
> example, a deferred clock tick interrupt or a block/unblock operation.
> This can cause the task to be preempted? Or do I misunderstand.
Maybe we should give a hint, that enabling maskable interrupts may
result immediately in an interrupt service which may result in a
preemption of the calling task. Strictly, this preemption is not done by
the calling task. The calling task doesn't invoke the scheduler or
perform a thread dispatch directly.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
