[PATCH v2] c-user: Generate interrupt manager documentation
Sebastian Huber
Tue Apr 27 05:38:54 UTC 2021
The documentation is a consolidation of the comments in Doxygen markup
and the documentation sources in Sphinx markup. The documentation was
transfered to interface specification items. The documentation source
files were generated from the items by a script.
Update #3993.
Here is the updated document for review:
https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
v2:
* Clarify service of pending interrupts in the interrupt enable
directives.
c-user/glossary.rst | 5 +
c-user/interrupt/directives.rst | 1250 +++++++++++++++++++++--------
c-user/interrupt/introduction.rst | 101 ++-
3 files changed, 1012 insertions(+), 344 deletions(-)
diff --git a/c-user/glossary.rst b/c-user/glossary.rst
index 33d3097..b3527a7 100644
--- a/c-user/glossary.rst
+++ b/c-user/glossary.rst
@@ -928,6 +928,11 @@ Glossary
target
The system on which the application will ultimately execute.
+ target architecture
+ The target architecture is the instruction set architecture (ISA) of the
+ :term:`target`. Some RTEMS features depend on the target architecture. For
+ the details consult the *RTEMS CPU Architecture Supplement*.
TAS
This term is an acronym for Test-And-Set.
diff --git a/c-user/interrupt/directives.rst b/c-user/interrupt/directives.rst
index 95181db..2b15fd6 100644
--- a/c-user/interrupt/directives.rst
+++ b/c-user/interrupt/directives.rst
@@ -1,521 +1,1111 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+.. This file is part of the RTEMS quality process and was automatically
+.. generated. If you find something that needs to be fixed or
+.. worded better please post a report or patch to an RTEMS mailing list
+.. or raise a bug report:
+.. https://www.rtems.org/bugs.html
+.. For information on updating and regenerating please refer to the How-To
+.. section in the Software Requirements Engineering chapter of the
+.. RTEMS Software Engineering manual. The manual is provided as a part of
+.. a release. For development sources please refer to the online
+.. documentation at:
+.. https://docs.rtems.org
+.. _InterruptManagerDirectives:
Directives
-This section details the interrupt manager's directives. A subsection is
-dedicated to each of this manager's directives and describes the calling
-sequence, related constants, usage, and status codes.
+This section details the directives of the Interrupt Manager. A subsection is
+dedicated to each of this manager's directives and lists the calling sequence,
+parameters, description, return values, and notes of the directive.
+.. Generated from spec:/rtems/intr/if/catch
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_interrupt_catch()
.. index:: establish an ISR
.. index:: install an ISR
-.. index:: rtems_interrupt_catch
-.. _rtems_interrupt_catch:
+.. _InterfaceRtemsInterruptCatch:
-INTERRUPT_CATCH - Establish an ISR
+rtems_interrupt_catch()
+Establishes an interrupt service routine.
+.. rubric:: CALLING SEQUENCE:
+.. code-block:: c
+ rtems_status_code rtems_interrupt_catch(
+ rtems_isr_entry new_isr_handler,
+ rtems_vector_number vector,
+ rtems_isr_entry *old_isr_handler
+.. rubric:: PARAMETERS:
+``new_isr_handler``
+ This parameter is the new interrupt service routine.
+``vector``
+ This parameter is the interrupt vector number.
+``old_isr_handler``
+ This parameter is the pointer to an :c:type:`rtems_isr_entry` variable.
+ When the directive call is successful, the previous interrupt service
+ routine established for this interrupt vector will be stored in this
+ variable.
+.. rubric:: DESCRIPTION:
+This directive establishes an interrupt service routine (ISR) for the interrupt
+specified by the ``vector`` number. The ``new_isr_handler`` parameter
+specifies the entry point of the ISR. The entry point of the previous ISR for
+the specified vector is returned in ``old_isr_handler``.
+To release an interrupt vector, pass the old handler's address obtained when
+the vector was first capture.
+.. rubric:: RETURN VALUES:
+:c:macro:`RTEMS_SUCCESSFUL`
+ The requested operation was successful.
+:c:macro:`RTEMS_INVALID_NUMBER`
+ The interrupt vector number was illegal.
+:c:macro:`RTEMS_INVALID_ADDRESS`
+ The ``new_isr_handler`` parameter was `NULL
+ <https://en.cppreference.com/w/c/types/NULL>`_.
+ The ``old_isr_handler`` parameter was `NULL
-CALLING SEQUENCE:
- .. code-block:: c
+.. rubric:: CONSTRAINTS:
- rtems_status_code rtems_interrupt_catch(
- rtems_isr_entry new_isr_handler,
- rtems_vector_number vector,
- rtems_isr_entry *old_isr_handler
+The following constraints apply to this directive:
-DIRECTIVE STATUS CODES:
- .. list-table::
- :class: rtems-wrap
+* The directive may be called from within interrupt context.
- * - ``RTEMS_SUCCESSFUL``
- - ISR established successfully
- * - ``RTEMS_INVALID_NUMBER``
- - illegal vector number
- * - ``RTEMS_INVALID_ADDRESS``
- - illegal ISR entry point or invalid ``old_isr_handler``
+* The directive may be called from within device driver initialization context.
-DESCRIPTION:
- This directive establishes an interrupt service routine (ISR) for the
- specified interrupt vector number. The ``new_isr_handler`` parameter
- specifies the entry point of the ISR. The entry point of the previous ISR
- for the specified vector is returned in ``old_isr_handler``.
+* The directive may be called from within task context.
- To release an interrupt vector, pass the old handler's address obtained
- when the vector was first capture.
+* The directive will not cause the calling task to be preempted.
-NOTES:
- This directive will not cause the calling task to be preempted.
+* The directive is only available where the :term:`target architecture` support
+ enabled simple vectored interrupts.
+.. Generated from spec:/rtems/intr/if/disable
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_interrupt_disable()
.. index:: disable interrupts
-.. index:: rtems_interrupt_disable
-.. _rtems_interrupt_disable:
+.. _InterfaceRtemsInterruptDisable:
+rtems_interrupt_disable()
+Disables the maskable interrupts on the current processor.
+.. code-block:: c
+ #define rtems_interrupt_disable( isr_cookie )
+``isr_cookie``
+ This parameter is a variable of type :c:type:`rtems_interrupt_level` which
+ will be used to save the previous interrupt level.
-INTERRUPT_DISABLE - Disable Interrupts
+This directive disables all maskable interrupts on the current processor and
+returns the previous interrupt level in ``isr_cookie``.
-CALLING SEQUENCE:
- .. code-block:: c
+.. rubric:: NOTES:
- void rtems_interrupt_disable(
- rtems_interrupt_level level
+A later invocation of the :ref:`InterfaceRtemsInterruptEnable` directive should
+be used to restore the previous interrupt level.
- NONE
+This directive is implemented as a macro which sets the ``isr_cookie``
+parameter.
-DESCRIPTION:
- This directive disables all maskable interrupts and returns the previous
- interrupt level in ``level``.
+.. code-block:: c
+ :linenos:
-NOTES:
- A later invocation of the ``rtems_interrupt_enable`` directive should be
- used to restore the interrupt level.
+ #include <rtems.h>
- This directive is implemented as a macro which sets the ``level``
- parameter.
+ void local_critical_section( void )
+ rtems_interrupt_level level;
+ // Please note that the rtems_interrupt_disable() is a macro. The
+ // previous interrupt level (before the maskable interrupts are
+ // disabled) is returned here in the level macro parameter. This
+ // would be wrong:
+ // rtems_interrupt_disable( &level );
+ rtems_interrupt_disable( level );
- This directive is only available in uniprocessor configurations. The
- directive ``rtems_interrupt_local_disable`` is available in all
- configurations.
+ // Here is the critical section: maskable interrupts are disabled
- .. code-block:: c
+ rtems_interrupt_level nested_level;
- void critical_section( void )
- rtems_interrupt_level level;
+ rtems_interrupt_disable( nested_level );
- * Please note that the rtems_interrupt_disable() is a macro. The
- * previous interrupt level (before the maskable interrupts are
- * disabled) is returned here in the level macro parameter. This
- * would be wrong:
- * rtems_interrupt_disable( &level );
- rtems_interrupt_disable( level );
+ // Here is a nested critical section
- /* Critical section, maskable interrupts are disabled */
+ rtems_interrupt_enable( nested_level );
- rtems_interrupt_level level2;
+ // Maskable interrupts are still disabled
- rtems_interrupt_disable( level2 );
+ rtems_interrupt_enable( level );
- /* Nested critical section */
- rtems_interrupt_enable( level2 );
- /* Maskable interrupts are still disabled */
+* The directive may be called from within any runtime context.
- rtems_interrupt_enable( level );
+* Where the system was built with SMP support enabled, the directive is not
+ available. Its use will result in compiler warnings and linker errors. The
+ :ref:`InterfaceRtemsInterruptLocalDisable` and
+ :ref:`InterfaceRtemsInterruptLocalEnable` directives are available in all
+ build configurations.
+.. Generated from spec:/rtems/intr/if/enable
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_interrupt_enable()
.. index:: enable interrupts
.. index:: restore interrupt level
-.. index:: rtems_interrupt_enable
-.. _rtems_interrupt_enable:
+.. _InterfaceRtemsInterruptEnable:
+rtems_interrupt_enable()
+Restores the previous interrupt level on the current processor.
+.. code-block:: c
+ #define rtems_interrupt_enable( isr_cookie )
+``isr_cookie``
+ This parameter is the previous interrupt level to restore. The value must
+ be obtained by a previous call to :ref:`InterfaceRtemsInterruptDisable` or
+ :ref:`InterfaceRtemsInterruptFlash`.
-INTERRUPT_ENABLE - Restore Interrupt Level
-CALLING SEQUENCE:
- .. code-block:: c
+This directive restores the interrupt level specified by ``isr_cookie`` on the
+current processor.
- void rtems_interrupt_enable(
+.. rubric:: NOTES:
- NONE
+The ``isr_cookie`` parameter value must be obtained by a previous call to
+:ref:`InterfaceRtemsInterruptDisable` or :ref:`InterfaceRtemsInterruptFlash`.
+Using an otherwise obtained value is undefined behaviour.
-DESCRIPTION:
- This directive restores the interrupt level specified by ``level``.
+This directive is unsuitable to enable particular interrupt sources, for
+example in an interrupt controller.
-NOTES:
- The ``level`` parameter value must be obtained by a previous call to
- ``rtems_interrupt_disable`` or ``rtems_interrupt_flash``. Using an
- otherwise obtained value is undefined behaviour.
- This directive is unsuitable to enable particular interrupt sources, for
- example in an interrupt controller.
- directive ``rtems_interrupt_local_enable`` is available in all
- configurations.
+* While at least one maskable interrupt is pending, when the directive enables
+ maskable interrupts, the pending interrupts are immediately serviced. The
+ interrupt service routines may unblock higher priority tasks which may
+ preempt the calling task.
+.. Generated from spec:/rtems/intr/if/flash
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_interrupt_flash()
.. index:: flash interrupts
-.. index:: rtems_interrupt_flash
-.. _rtems_interrupt_flash:
+.. _InterfaceRtemsInterruptFlash:
-INTERRUPT_FLASH - Flash Interrupts
+rtems_interrupt_flash()
+Flashes interrupts on the current processor.
+.. code-block:: c
+ #define rtems_interrupt_flash( isr_cookie )
-CALLING SEQUENCE:
- .. code-block:: c
+``isr_cookie``
+ This parameter is the previous interrupt level.
- void rtems_interrupt_flash(
- NONE
+This directive is functionally equivalent to a calling
+:ref:`InterfaceRtemsInterruptEnable` immediately followed by a
+:ref:`InterfaceRtemsInterruptDisable`. On some architectures it is possible to
+provide an optimized implementation for this sequence.
-DESCRIPTION:
- This directive is functionally equivalent to a
- ``rtems_interrupt_enable( level )`` immediately followed by a
- ``rtems_interrupt_disable( level )``. On some
- architectures it is possible to provide an optimized implementation for
- this sequence.
+.. rubric:: NOTES:
-NOTES:
+Historically, the interrupt flash directive was heavily used in the operating
+system implementation. However, this is no longer the case. The interrupt
+flash directive is provided for backward compatibility reasons.
- directives ``rtems_interrupt_local_disable`` and
- ``rtems_interrupt_local_enable`` are available in all configurations.
- Historically, the interrupt flash directive was heavily used in the
- operating system implementation. However, this is no longer the case. The
- interrupt flash directive is provided for backward compatibility reasons.
+.. Generated from spec:/rtems/intr/if/local-disable
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_interrupt_local_disable()
-.. index:: rtems_interrupt_local_disable
-.. _rtems_interrupt_local_disable:
+.. _InterfaceRtemsInterruptLocalDisable:
+rtems_interrupt_local_disable()
+.. code-block:: c
+ #define rtems_interrupt_local_disable( isr_cookie )
-INTERRUPT_LOCAL_DISABLE - Disable Interrupts on Current Processor
-CALLING SEQUENCE:
- .. code-block:: c
+``isr_cookie``
- void rtems_interrupt_local_disable(
- NONE
-DESCRIPTION:
- This directive disables all maskable interrupts on the current processor
- and returns the previous interrupt level in ``level``.
+.. rubric:: NOTES:
-NOTES:
- A later invocation of the ``rtems_interrupt_local_enable`` directive should
- be used to restore the interrupt level.
+A later invocation of the :ref:`InterfaceRtemsInterruptLocalEnable` directive
+should be used to restore the previous interrupt level.
- parameter.
+parameter.
+Where the system was built with SMP support enabled, this will not ensure
+system wide mutual exclusion. Use interrupt locks instead, see
+:ref:`InterfaceRtemsInterruptLockAcquire`. Interrupt disabled critical
+sections may be used to access processor-specific data structures or disable
+thread dispatching.
- In SMP configurations, this will not ensure system wide mutual exclusion.
- Use interrupt locks instead.
+.. code-block:: c
+ :linenos:
- .. code-block:: c
- void local_critical_section( void )
- * Please note that the rtems_interrupt_local_disable() is a macro.
- * The previous interrupt level (before the maskable interrupts are
- * would be wrong:
- * rtems_interrupt_local_disable( &level );
- rtems_interrupt_local_disable( level );
+ // Please note that the rtems_interrupt_local_disable() is a macro.
+ // The previous interrupt level (before the maskable interrupts are
+ // disabled) is returned here in the level macro parameter. This would
+ // be wrong:
+ // rtems_interrupt_local_disable( &level );
+ rtems_interrupt_local_disable( level );
- * Local critical section, maskable interrupts on the current
- * processor are disabled.
- rtems_interrupt_local_disable( level2 );
+ rtems_interrupt_local_disable( nested_level );
- /* Nested local critical section */
- rtems_interrupt_local_enable( level2 );
+ rtems_interrupt_local_enable( nested_level );
- rtems_interrupt_local_enable( level );
+ rtems_interrupt_local_enable( level );
+.. Generated from spec:/rtems/intr/if/local-enable
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_interrupt_local_enable()
-.. index:: rtems_interrupt_local_enable
-.. _rtems_interrupt_local_enable:
+.. _InterfaceRtemsInterruptLocalEnable:
+rtems_interrupt_local_enable()
+.. code-block:: c
-INTERRUPT_LOCAL_ENABLE - Restore Interrupt Level on Current Processor
+ #define rtems_interrupt_local_enable( isr_cookie )
-CALLING SEQUENCE:
- .. code-block:: c
- void rtems_interrupt_local_enable(
+``isr_cookie``
+ :ref:`InterfaceRtemsInterruptLocalDisable`.
- NONE
-DESCRIPTION:
- This directive restores the interrupt level specified by ``level`` on the
- current processor.
+current processor.
-NOTES:
- ``rtems_interrupt_local_disable``. Using an otherwise obtained value is
- undefined behaviour.
+.. rubric:: NOTES:
+:ref:`InterfaceRtemsInterruptLocalDisable`. Using an otherwise obtained value
+is undefined behaviour.
+.. Generated from spec:/rtems/intr/if/is-in-progress
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_interrupt_is_in_progress()
+.. index:: is interrupt in progress
+.. _InterfaceRtemsInterruptIsInProgress:
-.. index:: rtems_interrupt_lock_initialize
+rtems_interrupt_is_in_progress()
-.. _rtems_interrupt_lock_initialize:
+Checks if an ISR is in progress on the current processor.
-INTERRUPT_LOCK_INITIALIZE - Initialize an ISR Lock
-CALLING SEQUENCE:
- .. code-block:: c
+.. code-block:: c
- void rtems_interrupt_lock_initialize(
- rtems_interrupt_lock *lock,
- const char *name
+ #define rtems_interrupt_is_in_progress()
- NONE
-DESCRIPTION:
- Initializes an interrupt lock. The name must be persistent throughout the
- lifetime of the lock.
+This directive returns ``true``, if the current processor is currently
+servicing an interrupt, and ``false`` otherwise. A return value of ``true``
+indicates that the caller is an interrupt service routine, **not** a task. The
+directives available to an interrupt service routine are restricted.
-NOTES:
- Concurrent initialization leads to unpredictable results.
+Returns true, if the current processor is currently servicing an interrupt,
+otherwise false.
+.. Generated from spec:/rtems/intr/if/cause
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_interrupt_cause()
+.. _InterfaceRtemsInterruptCause:
+rtems_interrupt_cause()
-.. index:: rtems_interrupt_lock_acquire
+Causes the interrupt.
-.. _rtems_interrupt_lock_acquire:
-INTERRUPT_LOCK_ACQUIRE - Acquire an ISR Lock
+.. code-block:: c
-CALLING SEQUENCE:
- .. code-block:: c
+ #define rtems_interrupt_cause( vector )
- void rtems_interrupt_lock_acquire(
- rtems_interrupt_lock_context *lock_context
- NONE
+``vector``
+ This parameter is the vector number of the interrupt to cause.
-DESCRIPTION:
- Maskable interrupts will be disabled. In SMP configurations, this
- directive acquires an SMP lock.
-NOTES:
- A separate lock context must be provided for each acquire/release pair, for
- example an automatic variable.
- An attempt to recursively acquire the lock may result in an infinite loop
- with maskable interrupts disabled.
+* The directive is not implemented.
- This directive will not cause the calling thread to be preempted. This
- directive can be used in thread and interrupt context.
+.. Generated from spec:/rtems/intr/if/clear
.. raw:: latex
- \clearpage
+ \clearpage
-.. index:: rtems_interrupt_lock_release
+.. index:: rtems_interrupt_clear()
-.. _rtems_interrupt_lock_release:
+.. _InterfaceRtemsInterruptClear:
-INTERRUPT_LOCK_RELEASE - Release an ISR Lock
+rtems_interrupt_clear()
-CALLING SEQUENCE:
- .. code-block:: c
+Clears the interrupt.
- void rtems_interrupt_lock_release(
- NONE
+.. code-block:: c
-DESCRIPTION:
- The interrupt level will be restored. In SMP configurations, this
- directive releases an SMP lock.
+ #define rtems_interrupt_clear( vector )
-NOTES:
- The lock context must be the one used to acquire the lock, otherwise the
- result is unpredictable.
+``vector``
+ This parameter is the vector number of the interrupt to clear.
+.. Generated from spec:/rtems/intr/if/lock-initialize
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_interrupt_lock_initialize()
-.. index:: rtems_interrupt_lock_acquire_isr
+.. _InterfaceRtemsInterruptLockInitialize:
-.. _rtems_interrupt_lock_acquire_isr:
+rtems_interrupt_lock_initialize()
-INTERRUPT_LOCK_ACQUIRE_ISR - Acquire an ISR Lock from ISR
+Initializes the ISR lock.
-CALLING SEQUENCE:
- .. code-block:: c
- void rtems_interrupt_lock_acquire_isr(
+.. code-block:: c
- NONE
+ #define rtems_interrupt_lock_initialize( lock, name )
-DESCRIPTION:
- The interrupt level will remain unchanged. In SMP configurations, this
-NOTES:
+``lock``
+ This parameter is the ISR lock to initialize.
- An attempt to recursively acquire the lock may result in an infinite loop.
+``name``
+ This parameter is the ISR lock name. It shall be a string. The name is
+ only used where the system was built with profiling support enabled.
- This directive is intended for device drivers and should be called from the
- corresponding interrupt service routine.
+.. rubric:: NOTES:
- In case the corresponding interrupt service routine can be interrupted by
- higher priority interrupts and these interrupts enter the critical section
- protected by this lock, then the result is unpredictable.
+ISR locks may also be statically defined by
+:ref:`InterfaceRTEMSINTERRUPTLOCKDEFINE` or statically initialized by
+:ref:`InterfaceRTEMSINTERRUPTLOCKINITIALIZER`.
+.. Generated from spec:/rtems/intr/if/lock-destroy
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_interrupt_lock_destroy()
+.. _InterfaceRtemsInterruptLockDestroy:
+rtems_interrupt_lock_destroy()
-.. index:: rtems_interrupt_lock_release_isr
+Destroys the ISR lock.
-.. _rtems_interrupt_lock_release_isr:
-INTERRUPT_LOCK_RELEASE_ISR - Release an ISR Lock from ISR
+.. code-block:: c
-CALLING SEQUENCE:
- .. code-block:: c
+ #define rtems_interrupt_lock_destroy( lock )
- void rtems_interrupt_lock_release_isr(
- NONE
+``lock``
+ This parameter is the ISR lock to destroy.
-DESCRIPTION:
+.. rubric:: NOTES:
-NOTES:
+The lock must have been dynamically initialized by
+:ref:`InterfaceRtemsInterruptLockInitialize`, statically defined by
+:ref:`InterfaceRTEMSINTERRUPTLOCKDEFINE`, or statically initialized by
+Concurrent lock use during the destruction or concurrent destruction leads to
+unpredictable results.
+.. Generated from spec:/rtems/intr/if/lock-acquire
.. raw:: latex
- \clearpage
+ \clearpage
-.. index:: is interrupt in progress
-.. index:: rtems_interrupt_is_in_progress
+.. index:: rtems_interrupt_lock_acquire()
+.. _InterfaceRtemsInterruptLockAcquire:
+rtems_interrupt_lock_acquire()
+Acquires the ISR lock.
+.. code-block:: c
+ #define rtems_interrupt_lock_acquire( lock, lock_context )
+``lock``
+ This parameter is the ISR lock to acquire.
+``lock_context``
+ This parameter is the ISR lock context. This lock context shall be used to
+ release the lock by calling :ref:`InterfaceRtemsInterruptLockRelease`.
+This directive acquires the ISR lock specified by ``lock`` using the lock
+context provided by ``lock_context``. Maskable interrupts will be disabled on
+the current processor.
+.. rubric:: NOTES:
+A caller-specific lock context shall be provided for each acquire/release pair,
+for example an automatic variable.
+Where the system was built with SMP support enabled, this directive acquires an
+SMP lock. An attempt to recursively acquire the lock may result in an infinite
+loop with maskable interrupts disabled.
+This directive establishes a non-preemptive critical section with system wide
+mutual exclusion on the local node in all RTEMS build configurations.
+.. code-block:: c
+ :linenos:
+ void critical_section( rtems_interrupt_lock *lock )
+ rtems_interrupt_lock_context lock_context;
+ rtems_interrupt_lock_acquire( lock, &lock_context );
+ // Here is the critical section. Maskable interrupts are disabled.
+ // Where the system was built with SMP support enabled, this section
+ // is protected by an SMP lock.
+ rtems_interrupt_lock_release( lock, &lock_context );
+.. Generated from spec:/rtems/intr/if/lock-release
+.. raw:: latex
+ \clearpage
+.. index:: rtems_interrupt_lock_release()
+.. _InterfaceRtemsInterruptLockRelease:
+rtems_interrupt_lock_release()
+Releases the ISR lock.
+.. code-block:: c
+ #define rtems_interrupt_lock_release( lock, lock_context )
+``lock``
+ This parameter is the ISR lock to release.
+``lock_context``
+ This parameter is the ISR lock context. This lock context shall have been
+ used to acquire the lock by calling
+ :ref:`InterfaceRtemsInterruptLockAcquire`.
+This directive releases the ISR lock specified by ``lock`` using the lock
+context provided by ``lock_context``. The previous interrupt level will be
+restored on the current processor.
+.. rubric:: NOTES:
+The lock context shall be the one used to acquire the lock, otherwise the
+result is unpredictable.
+Where the system was built with SMP support enabled, this directive releases an
+SMP lock.
+.. Generated from spec:/rtems/intr/if/lock-acquire-isr
+.. raw:: latex
+ \clearpage
+.. index:: rtems_interrupt_lock_acquire_isr()
+.. _InterfaceRtemsInterruptLockAcquireIsr:
+rtems_interrupt_lock_acquire_isr()
+Acquires the ISR lock from within an ISR.
+.. code-block:: c
+ #define rtems_interrupt_lock_acquire_isr( lock, lock_context )
+``lock``
+ This parameter is the ISR lock to acquire within an ISR.
+``lock_context``
+ release the lock by calling :ref:`InterfaceRtemsInterruptLockReleaseIsr`.
+context provided by ``lock_context``. The interrupt level will remain
+unchanged.
+.. rubric:: NOTES:
+loop.
+This directive is intended for device drivers and should be called from the
+corresponding interrupt service routine.
+In case the corresponding interrupt service routine can be interrupted by
+higher priority interrupts and these interrupts enter the critical section
+protected by this lock, then the result is unpredictable. This directive may
+be used under specific circumstances as an optimization. In doubt, use
+:ref:`InterfaceRtemsInterruptLockAcquire` and
+:ref:`InterfaceRtemsInterruptLockRelease`.
+.. Generated from spec:/rtems/intr/if/lock-release-isr
+.. raw:: latex
+ \clearpage
+.. index:: rtems_interrupt_lock_release_isr()
+.. _InterfaceRtemsInterruptLockReleaseIsr:
+rtems_interrupt_lock_release_isr()
+Releases the ISR lock from within an ISR.
+.. code-block:: c
+ #define rtems_interrupt_lock_release_isr( lock, lock_context )
+``lock``
+ This parameter is the ISR lock to release within an ISR.
+``lock_context``
+ :ref:`InterfaceRtemsInterruptLockAcquireIsr`.
+unchanged.
+.. rubric:: NOTES:
+SMP lock.
+.. Generated from spec:/rtems/intr/if/lock-isr-disable
+.. raw:: latex
+ \clearpage
+.. index:: rtems_interrupt_lock_interrupt_disable()
+.. _InterfaceRtemsInterruptLockInterruptDisable:
+rtems_interrupt_lock_interrupt_disable()
+Disables maskable interrupts on the current processor.
+.. code-block:: c
+ #define rtems_interrupt_lock_interrupt_disable( lock_context )
+``lock_context``
+ This parameter is the ISR lock context for an acquire and release pair.
+This directive disables maskable interrupts on the current processor and stores
+the previous interrupt level in ``lock_context``.
+.. Generated from spec:/rtems/intr/if/lock-declare
+.. raw:: latex
+ \clearpage
+.. index:: RTEMS_INTERRUPT_LOCK_DECLARE()
+.. _InterfaceRTEMSINTERRUPTLOCKDECLARE:
+RTEMS_INTERRUPT_LOCK_DECLARE()
+Declares an ISR lock object.
+.. code-block:: c
+ #define RTEMS_INTERRUPT_LOCK_DECLARE( specifier, designator )
+``specifier``
+ This parameter is the storage-class specifier for the ISR lock to declare,
+ for example ``extern`` or ``static``.
+``designator``
+ This parameter is the ISR lock object designator.
+.. rubric:: NOTES:
+Do not add a ";" after this macro.
+.. Generated from spec:/rtems/intr/if/lock-define
+.. raw:: latex
+ \clearpage
+.. index:: RTEMS_INTERRUPT_LOCK_DEFINE()
+.. _InterfaceRTEMSINTERRUPTLOCKDEFINE:
+RTEMS_INTERRUPT_LOCK_DEFINE()
+Defines an ISR lock object.
+.. code-block:: c
+ #define RTEMS_INTERRUPT_LOCK_DEFINE( specifier, designator, name )
+``specifier``
+``designator``
+``name``
+.. rubric:: NOTES:
+ISR locks may also be dynamically initialized by
+:ref:`InterfaceRtemsInterruptLockInitialize` or statically by
+.. Generated from spec:/rtems/intr/if/lock-initializer
+.. raw:: latex
+ \clearpage
+.. index:: RTEMS_INTERRUPT_LOCK_INITIALIZER()
+.. _InterfaceRTEMSINTERRUPTLOCKINITIALIZER:
+RTEMS_INTERRUPT_LOCK_INITIALIZER()
+Statically initializes an ISR lock object.
+.. code-block:: c
+ #define RTEMS_INTERRUPT_LOCK_INITIALIZER( name )
+``name``
+.. rubric:: NOTES:
+:ref:`InterfaceRtemsInterruptLockInitialize` or statically defined by
+:ref:`InterfaceRTEMSINTERRUPTLOCKDEFINE`.
+.. Generated from spec:/rtems/intr/if/lock-member
+.. raw:: latex
+ \clearpage
+.. index:: RTEMS_INTERRUPT_LOCK_MEMBER()
+.. _InterfaceRTEMSINTERRUPTLOCKMEMBER:
+RTEMS_INTERRUPT_LOCK_MEMBER()
+Defines an ISR lock member.
+.. code-block:: c
+ #define RTEMS_INTERRUPT_LOCK_MEMBER( designator )
+``designator``
+ This parameter is the ISR lock member designator.
+.. rubric:: NOTES:
+.. Generated from spec:/rtems/intr/if/lock-reference
+.. raw:: latex
+ \clearpage
+.. index:: RTEMS_INTERRUPT_LOCK_REFERENCE()
+.. _InterfaceRTEMSINTERRUPTLOCKREFERENCE:
+RTEMS_INTERRUPT_LOCK_REFERENCE()
+Defines an ISR lock object reference.
-.. _rtems_interrupt_is_in_progress:
+.. code-block:: c
-INTERRUPT_IS_IN_PROGRESS - Is an ISR in Progress
+ #define RTEMS_INTERRUPT_LOCK_REFERENCE( designator, target )
-CALLING SEQUENCE:
- .. code-block:: c
- bool rtems_interrupt_is_in_progress( void );
+``designator``
+ This parameter is the ISR lock reference designator.
- NONE
+``target``
+ This parameter is the target object to reference.
-DESCRIPTION:
- This directive returns ``TRUE`` if the processor is currently servicing an
- interrupt and ``FALSE`` otherwise. A return value of ``TRUE`` indicates
- that the caller is an interrupt service routine, *NOT* a task. The
- directives available to an interrupt service routine are restricted.
+.. rubric:: NOTES:
-NOTES:
diff --git a/c-user/interrupt/introduction.rst b/c-user/interrupt/introduction.rst
index 272eba2..3d5c71d 100644
--- a/c-user/interrupt/introduction.rst
+++ b/c-user/interrupt/introduction.rst
@@ -1,37 +1,110 @@
+.. Generated from spec:/rtems/intr/if/group
+.. _InterruptManagerIntroduction:
Introduction
+.. The following list was generated from:
+.. spec:/rtems/intr/if/catch
+.. spec:/rtems/intr/if/disable
+.. spec:/rtems/intr/if/enable
+.. spec:/rtems/intr/if/flash
+.. spec:/rtems/intr/if/local-disable
+.. spec:/rtems/intr/if/local-enable
+.. spec:/rtems/intr/if/is-in-progress
+.. spec:/rtems/intr/if/cause
+.. spec:/rtems/intr/if/clear
+.. spec:/rtems/intr/if/lock-initialize
+.. spec:/rtems/intr/if/lock-destroy
+.. spec:/rtems/intr/if/lock-acquire
+.. spec:/rtems/intr/if/lock-release
+.. spec:/rtems/intr/if/lock-acquire-isr
+.. spec:/rtems/intr/if/lock-release-isr
+.. spec:/rtems/intr/if/lock-isr-disable
+.. spec:/rtems/intr/if/lock-declare
+.. spec:/rtems/intr/if/lock-define
+.. spec:/rtems/intr/if/lock-initializer
+.. spec:/rtems/intr/if/lock-member
+.. spec:/rtems/intr/if/lock-reference
Any real-time executive must provide a mechanism for quick response to
externally generated interrupts to satisfy the critical time constraints of the
-application. The interrupt manager provides this mechanism for RTEMS. This
+application. The Interrupt Manager provides this mechanism for RTEMS. This
manager permits quick interrupt response times by providing the critical
ability to alter task execution which allows a task to be preempted upon exit
-from an ISR. The interrupt manager includes the following directive:
+from an ISR. The directives provided by the Interrupt Manager are:
+* :ref:`InterfaceRtemsInterruptCatch` - Establishes an interrupt service
+ routine.
+* :ref:`InterfaceRtemsInterruptDisable` - Disables the maskable interrupts on
+ the current processor.
+* :ref:`InterfaceRtemsInterruptEnable` - Restores the previous interrupt level
+ on the current processor.
+* :ref:`InterfaceRtemsInterruptFlash` - Flashes interrupts on the current
+ processor.
+* :ref:`InterfaceRtemsInterruptLocalDisable` - Disables the maskable interrupts
+* :ref:`InterfaceRtemsInterruptLocalEnable` - Restores the previous interrupt
+ level on the current processor.
+* :ref:`InterfaceRtemsInterruptIsInProgress` - Checks if an ISR is in progress
+* :ref:`InterfaceRtemsInterruptCause` - Causes the interrupt.
+* :ref:`InterfaceRtemsInterruptClear` - Clears the interrupt.
-- :ref:`rtems_interrupt_catch`
+* :ref:`InterfaceRtemsInterruptLockInitialize` - Initializes the ISR lock.
-- :ref:`rtems_interrupt_disable`
+* :ref:`InterfaceRtemsInterruptLockDestroy` - Destroys the ISR lock.
-- :ref:`rtems_interrupt_enable`
+* :ref:`InterfaceRtemsInterruptLockAcquire` - Acquires the ISR lock.
-- :ref:`rtems_interrupt_flash`
+* :ref:`InterfaceRtemsInterruptLockRelease` - Releases the ISR lock.
-- :ref:`rtems_interrupt_local_disable`
+* :ref:`InterfaceRtemsInterruptLockAcquireIsr` - Acquires the ISR lock from
+ within an ISR.
-- :ref:`rtems_interrupt_local_enable`
+* :ref:`InterfaceRtemsInterruptLockReleaseIsr` - Releases the ISR lock from
+ within an ISR.
-- :ref:`rtems_interrupt_lock_initialize`
+* :ref:`InterfaceRtemsInterruptLockInterruptDisable` - Disables maskable
+ interrupts on the current processor.
-- :ref:`rtems_interrupt_lock_acquire`
+* :ref:`InterfaceRTEMSINTERRUPTLOCKDECLARE` - Declares an ISR lock object.
-- :ref:`rtems_interrupt_lock_release`
+* :ref:`InterfaceRTEMSINTERRUPTLOCKDEFINE` - Defines an ISR lock object.
-- :ref:`rtems_interrupt_lock_acquire_isr`
+* :ref:`InterfaceRTEMSINTERRUPTLOCKINITIALIZER` - Statically initializes an ISR
+ lock object.
-- :ref:`rtems_interrupt_lock_release_isr`
+* :ref:`InterfaceRTEMSINTERRUPTLOCKMEMBER` - Defines an ISR lock member.
-- :ref:`rtems_interrupt_is_in_progress`
+* :ref:`InterfaceRTEMSINTERRUPTLOCKREFERENCE` - Defines an ISR lock object
+ reference.
2.26.2
