[PATCH] c-user: Generate task manager documentation
Sebastian Huber
Tue Apr 27 09:31:23 UTC 2021
The documentation is a consolidation of the comments in Doxygen markup
and the documentation sources in Sphinx markup. The documentation was
transfered to interface specification items. The documentation source
files were generated from the items by a script.
Update #3993.
Here is the updated document for review:
https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
c-user/fatal-error/background.rst | 2 +
c-user/task/directives.rst | 2852 +++++++++++++++++------------
c-user/task/introduction.rst | 104 +-
3 files changed, 1764 insertions(+), 1194 deletions(-)
diff --git a/c-user/fatal-error/background.rst b/c-user/fatal-error/background.rst
index 571da10..6932846 100644
--- a/c-user/fatal-error/background.rst
+++ b/c-user/fatal-error/background.rst
@@ -44,6 +44,8 @@ a register), and halt the processor. The precise actions of the RTEMS fatal
error are discussed in the Default Fatal Error Processing chapter of the
Applications Supplement document for a specific target processor.
+.. _FatalErrorSources:
Fatal Sources
diff --git a/c-user/task/directives.rst b/c-user/task/directives.rst
index b5574e9..5132c61 100644
--- a/c-user/task/directives.rst
+++ b/c-user/task/directives.rst
@@ -1,1454 +1,1966 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+.. Copyright (C) 2020, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 1988, 2017 On-Line Applications Research Corporation (OAR)
+.. This file is part of the RTEMS quality process and was automatically
+.. generated. If you find something that needs to be fixed or
+.. worded better please post a report or patch to an RTEMS mailing list
+.. or raise a bug report:
+.. https://www.rtems.org/bugs.html
+.. For information on updating and regenerating please refer to the How-To
+.. section in the Software Requirements Engineering chapter of the
+.. RTEMS Software Engineering manual. The manual is provided as a part of
+.. a release. For development sources please refer to the online
+.. documentation at:
+.. https://docs.rtems.org
+.. _TaskManagerDirectives:
Directives
-This section details the task manager's directives. A subsection is dedicated
-to each of this manager's directives and describes the calling sequence,
-related constants, usage, and status codes.
+This section details the directives of the Task Manager. A subsection is
+dedicated to each of this manager's directives and lists the calling sequence,
+parameters, description, return values, and notes of the directive.
+.. Generated from spec:/rtems/task/if/create
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_create()
.. index:: create a task
-.. index:: rtems_task_create
-.. _rtems_task_create:
-TASK_CREATE - Create a task
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_create(
- rtems_name name,
- rtems_task_priority initial_priority,
- size_t stack_size,
- rtems_mode initial_modes,
- rtems_attribute attribute_set,
- rtems_id *id
-DIRECTIVE STATUS CODES:
- .. list-table::
- :class: rtems-table
- * - ``RTEMS_SUCCESSFUL``
- - task created successfully
- * - ``RTEMS_INVALID_ADDRESS``
- - ``id`` is NULL
- * - ``RTEMS_INVALID_NAME``
- - invalid task name
- * - ``RTEMS_INVALID_PRIORITY``
- - invalid task priority
- * - ``RTEMS_TOO_MANY``
- - too many tasks created
- * - ``RTEMS_UNSATISFIED``
- - not enough memory for stack/FP context
- - non-preemption mode not supported on SMP system
- - interrupt level mode not supported on SMP system
- - too many global objects
-DESCRIPTION:
- This directive creates a task which resides on the local node. It
- allocates and initializes a TCB, a stack, and an optional floating point
- context area. The mode parameter contains values which sets the task's
- initial execution mode. The ``RTEMS_FLOATING_POINT`` attribute should be
- specified if the created task is to use a numeric coprocessor. For
- performance reasons, it is recommended that tasks not using the numeric
- coprocessor should specify the ``RTEMS_NO_FLOATING_POINT`` attribute. If
- the ``RTEMS_GLOBAL`` attribute is specified, the task can be accessed from
- remote nodes. The task id, returned in id, is used in other task related
- directives to access the task. When created, a task is placed in the
- dormant state and can only be made ready to execute using the directive
- ``rtems_task_start``.
-NOTES:
- This directive may cause the calling task to be preempted.
- The scheduler of the new task is the scheduler of the executing task at
- some point during the task creation. The specified task priority must be
- valid for the selected scheduler.
- The task processor affinity is initialized to the set of online processors.
- If the requested stack size is less than the configured minimum stack size,
- then RTEMS will use the configured minimum as the stack size for this task.
- In addition to being able to specify the task stack size as a integer,
- there are two constants which may be specified:
- ``RTEMS_MINIMUM_STACK_SIZE``
- The minimum stack size *RECOMMENDED* for use on this processor. This
- value is selected by the RTEMS developers conservatively to minimize the
- risk of blown stacks for most user applications. Using this constant
- when specifying the task stack size, indicates that the stack size will
- be at least ``RTEMS_MINIMUM_STACK_SIZE`` bytes in size. If the user
- configured minimum stack size is larger than the recommended minimum,
- then it will be used.
- ``RTEMS_CONFIGURED_MINIMUM_STACK_SIZE``
- Indicates this task is to be created with a stack size of the minimum
- stack size that was configured by the application. If not explicitly
- configured by the application, the default configured minimum stack size
- is the processor dependent value ``RTEMS_MINIMUM_STACK_SIZE``. Since
- this uses the configured minimum stack size value, you may get a stack
- size that is smaller or larger than the recommended minimum. This can be
- used to provide large stacks for all tasks on complex applications or
- small stacks on applications that are trying to conserve memory.
- Application developers should consider the stack usage of the device
- drivers when calculating the stack size required for tasks which utilize
- the driver.
- The following task attribute constants are defined by RTEMS:
- .. list-table::
- * - ``RTEMS_NO_FLOATING_POINT``
- - does not use coprocessor (default)
- * - ``RTEMS_FLOATING_POINT``
- - uses numeric coprocessor
- * - ``RTEMS_LOCAL``
- - local task (default)
- * - ``RTEMS_GLOBAL``
- - global task
- The following task mode constants are defined by RTEMS:
- .. list-table::
- * - ``RTEMS_PREEMPT``
- - enable preemption (default)
- * - ``RTEMS_NO_PREEMPT``
- - disable preemption
- * - ``RTEMS_NO_TIMESLICE``
- - disable timeslicing (default)
- * - ``RTEMS_TIMESLICE``
- - enable timeslicing
- * - ``RTEMS_ASR``
- - enable ASR processing (default)
- * - ``RTEMS_NO_ASR``
- - disable ASR processing
- * - ``RTEMS_INTERRUPT_LEVEL(0)``
- - enable all interrupts (default)
- * - ``RTEMS_INTERRUPT_LEVEL(n)``
- - execute at interrupt level ``n``
- The interrupt level portion of the task execution mode supports a maximum
- of 256 interrupt levels. These levels are mapped onto the interrupt
- levels actually supported by the target processor in a processor dependent
- fashion.
- Tasks should not be made global unless remote tasks must interact with
- them. This avoids the system overhead incurred by the creation of a
- global task. When a global task is created, the task's name and id must
- be transmitted to every node in the system for insertion in the local copy
- of the global object table.
- The total number of global objects, including tasks, is limited by the
- maximum_global_objects field in the Configuration Table.
+.. _InterfaceRtemsTaskCreate:
+rtems_task_create()
+Creates a task.
+.. rubric:: CALLING SEQUENCE:
+.. code-block:: c
+ rtems_status_code rtems_task_create(
+ rtems_name name,
+ rtems_task_priority initial_priority,
+ size_t stack_size,
+ rtems_mode initial_modes,
+ rtems_attribute attribute_set,
+ rtems_id *id
+.. rubric:: PARAMETERS:
+``name``
+ This parameter is the object name of the task.
+``initial_priority``
+ This parameter is the initial task priority.
+``stack_size``
+ This parameter is the task stack size in bytes.
+``initial_modes``
+ This parameter is the initial mode set of the task.
+``attribute_set``
+ This parameter is the attribute set of the task.
+``id``
+ This parameter is the pointer to an object identifier variable. When the
+ directive call is successful, the identifier of the created task will be
+ stored in this variable.
+.. rubric:: DESCRIPTION:
+This directive creates a task which resides on the local node. The task has
+the user-defined object name specified in ``name``. The assigned object
+identifier is returned in ``id``. This identifier is used to access the task
+with other task related directives.
+The **initial priority** of the task is specified in ``initial_priority``. The
+scheduler of the created task is the scheduler of the calling task at some
+point during the task creation. The initial task priority specified in
+``initial_priority`` shall be valid for this scheduler.
+The **stack size** of the task is specified in ``stack_size``. If the
+requested stack size is less than the configured minimum stack size, then RTEMS
+will use the configured minimum as the stack size for this task. The
+configured minimum stack size is defined by the
+:ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE` application configuration option. In
+addition to being able to specify the task stack size as a integer, there are
+two constants which may be specified:
+* The :c:macro:`RTEMS_MINIMUM_STACK_SIZE` constant can be specified to use the
+ **recommended minimum stack size** for the target processor. This value is
+ selected by the RTEMS maintainers conservatively to minimize the risk of
+ blown stacks for most user applications. Using this constant when specifying
+ the task stack size, indicates that the stack size will be at least
+ :c:macro:`RTEMS_MINIMUM_STACK_SIZE` bytes in size. If the user configured
+ minimum stack size is larger than the recommended minimum, then it will be
+ used.
+* The :c:macro:`RTEMS_CONFIGURED_MINIMUM_STACK_SIZE` constant can be specified
+ to use the minimum stack size that was configured by the application. If not
+ explicitly configured by the application, the default configured minimum
+ stack size is the target processor dependent value
+ :c:macro:`RTEMS_MINIMUM_STACK_SIZE`. Since this uses the configured minimum
+ stack size value, you may get a stack size that is smaller or larger than the
+ recommended minimum. This can be used to provide large stacks for all tasks
+ on complex applications or small stacks on applications that are trying to
+ conserve memory.
+The **initial mode set** specified in ``initial_modes`` is built through a
+*bitwise or* of the mode constants described below. Not all combinations of
+modes are allowed. Some modes are mutually exclusive. If mutually exclusive
+modes are combined, the behaviour is undefined. Default task modes can be
+selected by using the :c:macro:`RTEMS_DEFAULT_MODES` constant. The task mode
+set defines
+* the preemption mode of the task: :c:macro:`RTEMS_PREEMPT` (default) or
+ :c:macro:`RTEMS_NO_PREEMPT`,
+* the timeslicing mode of the task: :c:macro:`RTEMS_TIMESLICE` or
+ :c:macro:`RTEMS_NO_TIMESLICE` (default),
+* the :term:`ASR` processing mode of the task: :c:macro:`RTEMS_ASR` (default)
+ or :c:macro:`RTEMS_NO_ASR`,
+* the interrupt level of the task: :c:func:`RTEMS_INTERRUPT_LEVEL` with a
+ default of ``RTEMS_INTERRUPT_LEVEL( 0 )`` which is associated with enabled
+ interrupts.
+The **initial preemption mode** of the task is enabled or disabled.
+* An **enabled preemption** is the default and can be emphasized through the
+ use of the :c:macro:`RTEMS_PREEMPT` mode constant.
+* A **disabled preemption** is set by the :c:macro:`RTEMS_NO_PREEMPT` mode
+ constant.
+The **initial timeslicing mode** of the task is enabled or disabled.
+* A **disabled timeslicing** is the default and can be emphasized through the
+ use of the :c:macro:`RTEMS_NO_TIMESLICE` mode constant.
+* An **enabled timeslicing** is set by the :c:macro:`RTEMS_TIMESLICE` mode
+ constant.
+The **initial ASR processing mode** of the task is enabled or disabled.
+* An **enabled ASR processing** is the default and can be emphasized through
+ the use of the :c:macro:`RTEMS_ASR` mode constant.
+* A **disabled ASR processing** is set by the :c:macro:`RTEMS_NO_ASR` mode
+ constant.
+The **initial interrupt level mode** of the task is defined by
+:c:func:`RTEMS_INTERRUPT_LEVEL`.
+* Task execution with **interrupts enabled** the default and can be emphasized
+ through the use of the :c:func:`RTEMS_INTERRUPT_LEVEL` mode macro with a
+ value of zero (0) for the parameter. An interrupt level of zero is
+ associated with enabled interrupts on all target processors.
+* Task execution at a **non-zero interrupt level** can be specified by the
+ :c:func:`RTEMS_INTERRUPT_LEVEL` mode macro with a non-zero value for the
+ parameter. The interrupt level portion of the task mode supports a maximum
+ of 256 interrupt levels. These levels are mapped onto the interrupt levels
+ actually supported by the target processor in a processor dependent fashion.
+The **attribute set** specified in ``attribute_set`` is built through a
+*bitwise or* of the attribute constants described below. Not all combinations
+of attributes are allowed. Some attributes are mutually exclusive. If
+mutually exclusive attributes are combined, the behaviour is undefined.
+Attributes not mentioned below are not evaluated by this directive and have no
+effect. Default attributes can be selected by using the
+:c:macro:`RTEMS_DEFAULT_ATTRIBUTES` constant. The attribute set defines
+* the scope of the task: :c:macro:`RTEMS_LOCAL` (default) or
+ :c:macro:`RTEMS_GLOBAL` and
+* the floating-point unit use of the task: :c:macro:`RTEMS_FLOATING_POINT` or
+ :c:macro:`RTEMS_NO_FLOATING_POINT` (default).
+The task has a local or global **scope** in a multiprocessing network (this
+attribute does not refer to SMP systems). The scope is selected by the
+mutually exclusive :c:macro:`RTEMS_LOCAL` and :c:macro:`RTEMS_GLOBAL`
+attributes.
+* A **local scope** is the default and can be emphasized through the use of the
+ :c:macro:`RTEMS_LOCAL` attribute. A local task can be only used by the node
+ which created it.
+* A **global scope** is established if the :c:macro:`RTEMS_GLOBAL` attribute is
+ set. Setting the global attribute in a single node system has no effect.the
+The **use of the floating-point unit** is selected by the mutually exclusive
+:c:macro:`RTEMS_FLOATING_POINT` and :c:macro:`RTEMS_NO_FLOATING_POINT`
+attributes. On some target processors, the use of the floating-point unit can
+be enabled or disabled for each task. Other target processors may have no
+hardware floating-point unit or enable the use of the floating-point unit for
+all tasks. Consult the *RTEMS CPU Architecture Supplement* for the details.
+* A **disabled floating-point unit** is the default and can be emphasized
+ through use of the :c:macro:`RTEMS_NO_FLOATING_POINT` attribute. For
+ performance reasons, it is recommended that tasks not using the
+ floating-point unit should specify this attribute.
+* An **enabled floating-point unit** is selected by the
+ :c:macro:`RTEMS_FLOATING_POINT` attribute.
+.. rubric:: RETURN VALUES:
+:c:macro:`RTEMS_SUCCESSFUL`
+ The requested operation was successful.
+:c:macro:`RTEMS_INVALID_NAME`
+ The ``name`` parameter was invalid.
+:c:macro:`RTEMS_INVALID_ADDRESS`
+ The ``id`` parameter was `NULL
+ <https://en.cppreference.com/w/c/types/NULL>`_.
+:c:macro:`RTEMS_INVALID_PRIORITY`
+ The ``initial_priority`` was invalid.
+:c:macro:`RTEMS_TOO_MANY`
+ There was no inactive object available to create a task. The number of
+ tasks available to the application is configured through the
+ :ref:`CONFIGURE_MAXIMUM_TASKS` application configuration option.
+ In multiprocessing configurations, there was no inactive global object
+ available to create a global task. The number of global objects available
+ to the application is configured through the
+ :ref:`CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS` application configuration
+ option.
+:c:macro:`RTEMS_UNSATISFIED`
+ There was not enough memory to allocate the task storage area. The task
+ storage area contains the task stack, the thread-local storage, and the
+ floating point context.
+ One of the task create extensions failed to create the task.
+ In SMP configurations, the non-preemption mode was not supported.
+ In SMP configurations, the interrupt level mode was not supported.
+.. rubric:: NOTES:
+The task processor affinity is initialized to the set of online processors.
+When created, a task is placed in the dormant state and can only be made ready
+to execute using the directive :ref:`InterfaceRtemsTaskStart`.
+Application developers should consider the stack usage of the device drivers
+when calculating the stack size required for tasks which utilize the driver.
+The task stack size shall account for an target processor dependent interrupt
+stack frame which may be placed on the stack of the interrupted task while
+servicing an interrupt. The stack checker may be used to monitor the stack
+usage, see :ref:`CONFIGURE_STACK_CHECKER_ENABLED`.
+For control and maintenance of the task, RTEMS allocates a :term:`TCB` from the
+local TCB free pool and initializes it.
+The TCB for a global task is allocated on the local node. Task should not be
+made global unless remote tasks must interact with the task. This is to avoid
+the system overhead incurred by the creation of a global task. When a global
+task is created, the task's name and identifier must be transmitted to every
+node in the system for insertion in the local copy of the global object table.
+.. rubric:: CONSTRAINTS:
+The following constraints apply to this directive:
+* The directive may be called from within device driver initialization context.
+* The directive may be called from within task context.
+* The directive may obtain and release the object allocator mutex. This may
+ cause the calling task to be preempted.
+* When the directive operates on a global object, the directive sends a message
+ to remote nodes. This may preempt the calling task.
+* The number of tasks available to the application is configured through the
+* Where the object class corresponding to the directive is configured to use
+ unlimited objects, the directive may allocate memory from the RTEMS
+ Workspace.
+* The number of global objects available to the application is configured
+ through the :ref:`CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS` application
+ configuration option.
+.. Generated from spec:/rtems/task/if/construct
+.. raw:: latex
+ \clearpage
+.. index:: rtems_task_construct()
+.. _InterfaceRtemsTaskConstruct:
+rtems_task_construct()
+Constructs a task from the specified the task configuration.
+.. code-block:: c
+ rtems_status_code rtems_task_construct(
+ const rtems_task_config *config,
+ rtems_id *id
+``config``
+ This parameter is the task configuration.
+``id``
+ directive call is successful, the identifier of the constructed task will
+ be stored in this variable.
+ The ``config`` parameter was `NULL
+ The task name was invalid.
+ The initial task priority was invalid.
+:c:macro:`RTEMS_INVALID_SIZE`
+ The thread-local storage size is greater than the maximum thread-local
+ storage size specified in the task configuration. The thread-local storage
+ size is determined by the thread-local variables used by the application
+ and :ref:`CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE`.
+ The task storage area was too small to provide a task stack of the
+ configured minimum size, see :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE`. The
+ task storage area contains the task stack, the thread-local storage, and
+ the floating-point context on architectures with a separate floating-point
+ context.
+ There was no inactive task object available to construct a task.
+ available to construct a global task.
+ One of the task create extensions failed during the task construction.
+.. rubric:: NOTES:
+In contrast to tasks created by :ref:`InterfaceRtemsTaskCreate`, the tasks
+constructed by this directive use a user-provided task storage area. The task
+storage area contains the task stack, the thread-local storage, and the
+floating-point context on architectures with a separate floating-point context.
+This directive is intended for applications which do not want to use the RTEMS
+Workspace and instead statically allocate all operating system resources. It
+is not recommended to use :ref:`InterfaceRtemsTaskCreate` and
+:ref:`InterfaceRtemsTaskConstruct` together in an application. It is also not
+recommended to use :ref:`InterfaceRtemsTaskConstruct` for drivers or general
+purpose libraries. The reason for these recommendations is that the task
+configuration needs settings which can be only given with a through knowledge
+of the application resources.
+An application based solely on static allocation can avoid any runtime memory
+allocators. This can simplify the application architecture as well as any
+analysis that may be required.
+The stack space estimate done by <rtems/confdefs.h> assumes that all tasks are
+created by :ref:`InterfaceRtemsTaskCreate`. The estimate can be adjusted to
+take user-provided task storage areas into account through the
+:ref:`CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE` application
+configuration option.
+The :ref:`CONFIGURE_MAXIMUM_TASKS` should include tasks constructed by
+:ref:`InterfaceRtemsTaskConstruct`.
+ Workspace.
+.. Generated from spec:/rtems/task/if/ident
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_ident()
+.. _InterfaceRtemsTaskIdent:
+rtems_task_ident()
+Identifies a task by the object name.
+.. code-block:: c
-.. index:: get ID of a task
-.. index:: rtems_task_ident
+ rtems_status_code rtems_task_ident(
+ rtems_name name,
+ uint32_t node,
+ rtems_id *id
-.. _rtems_task_ident:
-TASK_IDENT - Get ID of a task
+``name``
+ This parameter is the object name to look up.
-CALLING SEQUENCE:
- .. code-block:: c
+``node``
+ This parameter is the node or node set to search for a matching object.
- rtems_status_code rtems_task_ident(
- rtems_name name,
- uint32_t node,
- rtems_id *id
+``id``
+ directive call is successful, the object identifier of an object with the
+ specified name will be stored in this variable.
- .. list-table::
- - task identified successfully
- - ``id`` is NULL
- * - ``RTEMS_INVALID_NODE``
- - invalid node id
+This directive obtains a task identifier associated with the task name
+specified in ``name``.
-DESCRIPTION:
- This directive obtains the task id associated with the task name specified
- in name. A task may obtain its own id by specifying ``RTEMS_SELF`` or its
- own task name in name. If the task name is not unique, then the task id
- returned will match one of the tasks with that name. However, this task id
- is not guaranteed to correspond to the desired task. The task id, returned
- in id, is used in other task related directives to access the task.
+A task may obtain its own identifier by specifying :c:macro:`RTEMS_SELF` for
+the name.
-NOTES:
- This directive will not cause the running task to be preempted.
+The node to search is specified in ``node``. It shall be
- If node is ``RTEMS_SEARCH_ALL_NODES``, all nodes are searched with the
- local node being searched first. All other nodes are searched with the
- lowest numbered node searched first.
+* a valid node number,
- If node is a valid node number which does not represent the local node,
- then only the tasks exported by the designated node are searched.
+* the constant :c:macro:`RTEMS_SEARCH_ALL_NODES` to search in all nodes,
- This directive does not generate activity on remote nodes. It accesses
- only the local copy of the global object table.
+* the constant :c:macro:`RTEMS_SEARCH_LOCAL_NODE` to search in the local node
+ only, or
+* the constant :c:macro:`RTEMS_SEARCH_OTHER_NODES` to search in all nodes
+ except the local node.
+ There was no object with the specified name on the specified nodes.
+:c:macro:`RTEMS_INVALID_NODE`
+ In multiprocessing configurations, the specified node was invalid.
+.. rubric:: NOTES:
+If the task name is not unique, then the task identifier will match the first
+task with that name in the search order. However, this task identifier is not
+guaranteed to correspond to the desired task.
+The objects are searched from lowest to the highest index. If ``node`` is
+:c:macro:`RTEMS_SEARCH_ALL_NODES`, all nodes are searched with the local node
+being searched first. All other nodes are searched from lowest to the highest
+node number.
+If node is a valid node number which does not represent the local node, then
+only the tasks exported by the designated node are searched.
+This directive does not generate activity on remote nodes. It accesses only
+the local copy of the global object table.
+The task identifier is used with other task related directives to access the
+task.
+* The directive may be called from within any runtime context.
+* The directive will not cause the calling task to be preempted.
+.. Generated from spec:/rtems/task/if/self
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_self()
.. index:: obtain ID of caller
-.. index:: rtems_task_self
-.. _rtems_task_self:
+.. _InterfaceRtemsTaskSelf:
+rtems_task_self()
+Gets the task identifier of the calling task.
+.. code-block:: c
+ rtems_id rtems_task_self( void );
-TASK_SELF - Obtain ID of caller
-CALLING SEQUENCE:
- .. code-block:: c
+This directive returns the task identifier of the calling task.
- rtems_id rtems_task_self(void);
- Returns the object Id of the calling task.
+Returns the task identifier of the calling task.
-DESCRIPTION:
- This directive returns the Id of the calling task.
-NOTES:
- If called from an interrupt service routine, this directive will return the
- Id of the interrupted task.
+.. Generated from spec:/rtems/task/if/start
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_start()
.. index:: starting a task
-.. index:: rtems_task_start
-.. _rtems_task_start:
+.. _InterfaceRtemsTaskStart:
-TASK_START - Start a task
+rtems_task_start()
+Starts the task.
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_start(
- rtems_id id,
- rtems_task_entry entry_point,
- rtems_task_argument argument
- .. list-table::
- - ask started successfully
- - invalid task entry point
- * - ``RTEMS_INVALID_ID``
- - invalid task id
- * - ``RTEMS_INCORRECT_STATE``
- - task not in the dormant state
- * - ``RTEMS_ILLEGAL_ON_REMOTE_OBJECT``
- - cannot start remote task
-DESCRIPTION:
- This directive readies the task, specified by ``id``, for execution based
- on the priority and execution mode specified when the task was created.
- The starting address of the task is given in ``entry_point``. The task's
- starting argument is contained in argument. This argument can be a single
- value or used as an index into an array of parameter blocks. The type of
- this numeric argument is an unsigned integer type with the property that
- any valid pointer to void can be converted to this type and then converted
- back to a pointer to void. The result will compare equal to the original
- pointer.
-NOTES:
- The calling task will be preempted if its preemption mode is enabled and
- the task being started has a higher priority.
- Any actions performed on a dormant task such as suspension or change of
- priority are nullified when the task is initiated via the
- ``rtems_task_start`` directive.
+.. code-block:: c
+ rtems_status_code rtems_task_start(
+ rtems_id id,
+ rtems_task_entry entry_point,
+ rtems_task_argument argument
+``id``
+ This parameter is the task identifier. The constant :c:macro:`RTEMS_SELF`
+ may be used to specify the calling task.
+``entry_point``
+ This parameter is the task entry point.
+``argument``
+ This parameter is the task entry point argument.
+This directive readies the task, specified by ``id``, for execution based on
+the priority and execution mode specified when the task was created. The entry
+point of the task is given in ``entry_point``. The task's entry point argument
+is contained in ``argument``.
+ The ``entry_point`` parameter was `NULL
+:c:macro:`RTEMS_INVALID_ID`
+ There was no task associated with the identifier specified by ``id``.
+:c:macro:`RTEMS_INCORRECT_STATE`
+ The task was not in the dormant state.
+:c:macro:`RTEMS_ILLEGAL_ON_REMOTE_OBJECT`
+ The task resided on a remote node.
+.. rubric:: NOTES:
+The entry point argument may be a single value or used as an index into an
+array of parameter blocks. The type of this numeric argument is an unsigned
+integer type with the property that any valid pointer to ``void`` can be
+converted to this type and then converted back to a pointer to ``void``. The
+result will compare equal to the original pointer.
+Any actions performed on a dormant task such as suspension or change of
+priority are nullified when the task is initiated via the
+:ref:`InterfaceRtemsTaskStart` directive.
+* The directive may be called from within interrupt context.
+* The directive may unblock a task. This may cause the calling task to be
+ preempted.
+.. Generated from spec:/rtems/task/if/restart
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_restart()
.. index:: restarting a task
-.. index:: rtems_task_restart
-.. _rtems_task_restart:
-TASK_RESTART - Restart a task
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_restart(
- rtems_id id,
- .. list-table::
- - task restarted successfully
- - task id invalid
- - task never started
- - cannot restart remote task
-DESCRIPTION:
- This directive resets the task specified by id to begin execution at its
- original starting address. The task's priority and execution mode are set
- to the original creation values. If the task is currently blocked, RTEMS
- automatically makes the task ready. A task can be restarted from any
- state, except the dormant state.
- The task's starting argument is contained in argument. This argument can
- be a single value or an index into an array of parameter blocks. The type
- of this numeric argument is an unsigned integer type with the property that
- pointer. This new argument may be used to distinguish between the initial
- ``rtems_task_start`` of the task and any ensuing calls to
- ``rtems_task_restart`` of the task. This can be beneficial in deleting a
- task. Instead of deleting a task using the ``rtems_task_delete``
- directive, a task can delete another task by restarting that task, and
- allowing that task to release resources back to RTEMS and then delete
- itself.
-NOTES:
- If id is ``RTEMS_SELF``, the calling task will be restarted and will not
- return from this directive.
- the task being restarted has a higher priority.
- The task must reside on the local node, even if the task was created with
- the ``RTEMS_GLOBAL`` option.
+.. _InterfaceRtemsTaskRestart:
+rtems_task_restart()
+Restarts the task.
+.. code-block:: c
+ rtems_status_code rtems_task_restart(
+ rtems_id id,
+``id``
+``argument``
+This directive resets the task specified by ``id`` to begin execution at its
+original entry point. The task's priority and execution mode are set to the
+original creation values. If the task is currently blocked, RTEMS
+automatically makes the task ready. A task can be restarted from any state,
+except the dormant state. The task's entry point argument is contained in
+``argument``.
+ The task never started.
+.. rubric:: NOTES:
+The task entry point argument may be a single value or an index into an array
+of parameter blocks. The type of this numeric argument is an unsigned integer
+type with the property that any valid pointer to ``void`` can be converted to
+this type and then converted back to a pointer to ``void``. The result will
+compare equal to the original pointer. This new argument may be used to
+distinguish between the initial :ref:`InterfaceRtemsTaskStart` of the task and
+any ensuing calls to :ref:`InterfaceRtemsTaskRestart` of the task. This can be
+beneficial in deleting a task. Instead of deleting a task using the
+:ref:`InterfaceRtemsTaskDelete` directive, a task can delete another task by
+restarting that task, and allowing that task to release resources back to RTEMS
+and then delete itself.
+* The directive may change the priority of a task. This may cause the calling
+ task to be preempted.
+ preempted.
+.. Generated from spec:/rtems/task/if/delete
.. raw:: latex
- \clearpage
+ \clearpage
-.. index:: deleting a task
-.. index:: rtems_task_delete
-.. _rtems_task_delete:
-TASK_DELETE - Delete a task
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_delete(
- rtems_id id
- .. list-table::
- - task deleted successfully
- - task id invalid
-DESCRIPTION:
- This directive deletes a task, either the calling task or another task, as
- specified by id. RTEMS stops the execution of the task and reclaims the
- stack memory, any allocated delay or timeout timers, the TCB, and, if the
- task is ``RTEMS_FLOATING_POINT``, its floating point context area. RTEMS
- does not reclaim the following resources: region segments, partition
- buffers, semaphores, timers, or rate monotonic periods.
-NOTES:
- A task is responsible for releasing its resources back to RTEMS before
- deletion. To insure proper deallocation of resources, a task should not be
- deleted unless it is unable to execute or does not hold any RTEMS
- resources. If a task holds RTEMS resources, the task should be allowed to
- deallocate its resources before deletion. A task can be directed to
- release its resources and delete itself by restarting it with a special
- argument or by sending it a message, an event, or a signal.
- Deletion of the current task (``RTEMS_SELF``) will force RTEMS to select
- another task to execute.
- When a global task is deleted, the task id must be transmitted to every
- node in the system for deletion from the local copy of the global object
- table.
+.. index:: rtems_task_delete()
+.. index:: delete a task
+.. _InterfaceRtemsTaskDelete:
+rtems_task_delete()
+Deletes the task.
+.. code-block:: c
+ rtems_status_code rtems_task_delete( rtems_id id );
+``id``
+This directive deletes the task, either the calling task or another task, as
+specified by ``id``.
+.. rubric:: NOTES:
+RTEMS stops the execution of the task and reclaims the stack memory, any
+allocated delay or timeout timers, the TCB, and, if the task is
+:c:macro:`RTEMS_FLOATING_POINT`, its floating point context area. RTEMS
+explicitly does not reclaim the following resources: region segments, partition
+buffers, semaphores, timers, or rate monotonic periods.
+A task is responsible for releasing its resources back to RTEMS before
+deletion. To insure proper deallocation of resources, a task should not be
+deleted unless it is unable to execute or does not hold any RTEMS resources. If
+a task holds RTEMS resources, the task should be allowed to deallocate its
+resources before deletion. A task can be directed to release its resources and
+delete itself by restarting it with a special argument or by sending it a
+message, an event, or a signal.
+Deletion of the current task (:c:macro:`RTEMS_SELF`) will force RTEMS to select
+another task to execute.
+The :term:`TCB` for the deleted task is reclaimed by RTEMS.
+When a global task is deleted, the task identifier must be transmitted to every
+node in the system for deletion from the local copy of the global object table.
+The task must reside on the local node, even if the task was created with the
+:c:macro:`RTEMS_GLOBAL` attribute.
+* The calling task does not have to be the task that created the object. Any
+ local task that knows the object identifier can delete the object.
+ unlimited objects, the directive may free memory to the RTEMS Workspace.
+.. Generated from spec:/rtems/task/if/exit
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_exit()
-.. index:: rtems_task_exit
-.. _rtems_task_exit:
+.. _InterfaceRtemsTaskExit:
+rtems_task_exit()
+Deletes the calling task.
+.. code-block:: c
-TASK_EXIT - Delete the calling task
+ void rtems_task_exit( void );
-CALLING SEQUENCE:
- .. code-block:: c
- void rtems_task_exit( void ) RTEMS_NO_RETURN;
+This directive deletes the calling task.
- NONE - This function will not return to the caller.
+.. rubric:: NOTES:
-DESCRIPTION:
- This directive deletes the calling task.
+The directive is an optimized variant of the following code sequences, see also
+:ref:`InterfaceRtemsTaskDelete`:
-NOTES:
- This directive must be called from a regular task context with enabled
- interrupts, otherwise one of the fatal errors
+.. code-block:: c
- * :ref:`INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL <internal_errors>`, or
- * :ref:`INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT <internal_errors>`
+ #include <pthread.h>
+ #include <rtems.h>
- will occur.
+ void classic_delete_self( void )
+ (void) rtems_task_delete( RTEMS_SELF );
- The ``rtems_task_exit()`` call is equivalent to the following code
- sequence:
+ void posix_delete_self( void )
+ (void) pthread_detach( pthread_self() );
+ (void) pthread_exit( NULL);
- .. code-block:: c
- pthread_detach(pthread_self());
- pthread_exit(NULL);
- See also :ref:`rtems_task_delete() <rtems_task_delete>`.
+* The directive will not return to the caller.
+* While thread dispatching is disabled, if the directive performs a thread
+ dispatch, then the fatal error with the fatal source
+ :ref:`INTERNAL_ERROR_CORE <FatalErrorSources>` and the fatal code
+ :ref:`INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL <internal_errors>`
+ will occur.
+.. Generated from spec:/rtems/task/if/suspend
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_suspend()
.. index:: suspending a task
-.. index:: rtems_task_suspend
-.. _rtems_task_suspend:
+.. _InterfaceRtemsTaskSuspend:
+rtems_task_suspend()
+Suspends the task.
+.. code-block:: c
+ rtems_status_code rtems_task_suspend( rtems_id id );
+``id``
+This directive suspends the task specified by ``id`` from further execution by
+placing it in the suspended state. This state is additive to any other blocked
+state that the task may already be in. The task will not execute again until
+another task issues the :ref:`InterfaceRtemsTaskResume` directive for this task
+and any blocked state has been removed. The :ref:`InterfaceRtemsTaskRestart`
+directive will also remove the suspended state.
-TASK_SUSPEND - Suspend a task
+:c:macro:`RTEMS_ALREADY_SUSPENDED`
+ The task was already suspended.
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_suspend(
- rtems_id id
+.. rubric:: NOTES:
- .. list-table::
+The requesting task can suspend itself for example by specifying
+:c:macro:`RTEMS_SELF` as ``id``. In this case, the task will be suspended and
+a successful return code will be returned when the task is resumed.
- - task suspended successfully
- - task id invalid
- * - ``RTEMS_ALREADY_SUSPENDED``
- - task already suspended
-DESCRIPTION:
- This directive suspends the task specified by id from further execution by
- placing it in the suspended state. This state is additive to any other
- blocked state that the task may already be in. The task will not execute
- again until another task issues the ``rtems_task_resume`` directive for
- this task and any blocked state has been removed.
-NOTES:
- The requesting task can suspend itself by specifying ``RTEMS_SELF`` as id.
- In this case, the task will be suspended and a successful return code will
- be returned when the task is resumed.
- Suspending a global task which does not reside on the local node will
- generate a request to the remote node to suspend the specified task.
- If the task specified by id is already suspended, then the
- ``RTEMS_ALREADY_SUSPENDED`` status code is returned.
+* When the directive operates on a remote object, the directive sends a message
+ to the remote node and waits for a reply. This will preempt the calling
+ task.
+.. Generated from spec:/rtems/task/if/resume
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_resume()
.. index:: resuming a task
-.. index:: rtems_task_resume
-.. _rtems_task_resume:
+.. _InterfaceRtemsTaskResume:
-TASK_RESUME - Resume a task
+rtems_task_resume()
-CALLING SEQUENCE:
- .. code-block:: c
+Resumes the task.
- rtems_status_code rtems_task_resume(
- rtems_id id
- .. list-table::
+.. code-block:: c
- - task resumed successfully
- - task id invalid
- - task not suspended
+ rtems_status_code rtems_task_resume( rtems_id id );
-DESCRIPTION:
- This directive removes the task specified by id from the suspended state.
- If the task is in the ready state after the suspension is removed, then it
- will be scheduled to run. If the task is still in a blocked state after
- the suspension is removed, then it will remain in that blocked state.
-NOTES:
- The running task may be preempted if its preemption mode is enabled and the
- local task being resumed has a higher priority.
+``id``
- Resuming a global task which does not reside on the local node will
- generate a request to the remote node to resume the specified task.
- If the task specified by id is not suspended, then the
- ``RTEMS_INCORRECT_STATE`` status code is returned.
+This directive removes the task specified by ``id`` from the suspended state.
+If the task is in the ready state after the suspension is removed, then it will
+be scheduled to run. If the task is still in a blocked state after the
+suspension is removed, then it will remain in that blocked state.
-.. raw:: latex
- \clearpage
-.. index:: is task suspended
-.. index:: rtems_task_is_suspended
+ The task was not suspended.
-.. _rtems_task_is_suspended:
-TASK_IS_SUSPENDED - Determine if a task is Suspended
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_is_suspended(
- rtems_id id
- .. list-table::
- - task is NOT suspended
- - task is currently suspended
- - task id invalid
- - not supported on remote tasks
+ preempted.
-DESCRIPTION:
- This directive returns a status code indicating whether or not the
- specified task is currently suspended.
+ task.
-NOTES:
- This operation is not currently supported on remote tasks.
+.. Generated from spec:/rtems/task/if/is-suspended
.. raw:: latex
- \clearpage
+ \clearpage
-.. index:: rtems_task_set_priority
-.. index:: current task priority
-.. index:: set task priority
-.. index:: get task priority
-.. index:: obtain task priority
+.. index:: rtems_task_is_suspended()
-.. _rtems_task_set_priority:
-TASK_SET_PRIORITY - Set task priority
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_set_priority(
- rtems_id id,
- rtems_task_priority new_priority,
- rtems_task_priority *old_priority
- .. list-table::
- - task priority set successfully
- - invalid task id
- - invalid return argument pointer
-DESCRIPTION:
- This directive manipulates the priority of the task specified by id. An id
- of ``RTEMS_SELF`` is used to indicate the calling task. When new_priority
- is not equal to ``RTEMS_CURRENT_PRIORITY``, the specified task's previous
- priority is returned in old_priority. When new_priority is
- ``RTEMS_CURRENT_PRIORITY``, the specified task's current priority is
- returned in old_priority. Valid priorities range from a high of 1 to a low
- of 255.
-NOTES:
- The calling task may be preempted if its preemption mode is enabled and it
- lowers its own priority or raises another task's priority.
- In case the new priority equals the current priority of the task, then
- nothing happens.
- Setting the priority of a global task which does not reside on the local
- node will generate a request to the remote node to change the priority of
- the specified task.
- If the task specified by id is currently holding any binary semaphores
- which use the priority inheritance algorithm, then the task's priority
- cannot be lowered immediately. If the task's priority were lowered
- immediately, then priority inversion results. The requested lowering of
- the task's priority will occur when the task has released all priority
- inheritance binary semaphores. The task's priority can be increased
- regardless of the task's use of priority inheritance binary semaphores.
+.. _InterfaceRtemsTaskIsSuspended:
-.. raw:: latex
+rtems_task_is_suspended()
- \clearpage
+Checks if the task is suspended.
-.. index:: rtems_task_get_priority
+.. code-block:: c
-.. _rtems_task_get_priority:
-TASK_GET_PRIORITY - Get task priority
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_get_priority(
- rtems_id task_id,
- rtems_id scheduler_id,
- rtems_task_priority *priority
- .. list-table::
- - Successful operation.
- - Directive is illegal on remote tasks.
- - The priority parameter is NULL.
- - Invalid task or scheduler identifier.
- * - ``RTEMS_NOT_DEFINED``
- - The task has no priority within the specified scheduler instance.
- This error is only possible in SMP configurations.
-DESCRIPTION:
- This directive returns the current priority of the task specified by
- :c:data:`task_id` with respect to the scheduler instance specified by
- :c:data:`scheduler_id`. A task id of :c:macro:`RTEMS_SELF` is used to
- indicate the calling task.
-NOTES:
- The current priority reflects temporary priority adjustments due to locking
- protocols, the rate-monotonic period objects on some schedulers and other
- mechanisms.
+ rtems_status_code rtems_task_is_suspended( rtems_id id );
+``id``
+This directive returns a status code indicating whether or not the task
+specified by ``id`` is currently suspended.
+ The task was **not** suspended.
+ The task was suspended.
+.. Generated from spec:/rtems/task/if/mode
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_mode()
.. index:: current task mode
.. index:: set task mode
.. index:: get task mode
.. index:: set task preemption mode
.. index:: get task preemption mode
.. index:: obtain task mode
-.. index:: rtems_task_mode
-.. _rtems_task_mode:
-TASK_MODE - Change the current task mode
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_mode(
- rtems_mode mode_set,
- rtems_mode mask,
- rtems_mode *previous_mode_set
- .. list-table::
- - task mode set successfully
- - ``previous_mode_set`` is NULL
- * - ``RTEMS_NOT_IMPLEMENTED``
-DESCRIPTION:
- This directive manipulates the execution mode of the calling task. A
- task's execution mode enables and disables preemption, timeslicing,
- asynchronous signal processing, as well as specifying the current interrupt
- level. To modify an execution mode, the mode class(es) to be changed must
- be specified in the mask parameter and the desired mode(s) must be
- specified in the mode parameter.
-NOTES:
- The calling task will be preempted if it enables preemption and a higher
- priority task is ready to run.
- Enabling timeslicing has no effect if preemption is disabled. For a task
- to be timesliced, that task must have both preemption and timeslicing
- enabled.
- A task can obtain its current execution mode, without modifying it, by
- calling this directive with a mask value of ``RTEMS_CURRENT_MODE``.
- To temporarily disable the processing of a valid ASR, a task should call
- this directive with the ``RTEMS_NO_ASR`` indicator specified in mode.
- The set of task mode constants and each mode's corresponding mask constant
- is provided in the following table:
- .. list-table::
- - is masked by ``RTEMS_PREEMPT_MASK`` and enables preemption
- - is masked by ``RTEMS_PREEMPT_MASK`` and disables preemption
- - is masked by ``RTEMS_TIMESLICE_MASK`` and disables timeslicing
- - is masked by ``RTEMS_TIMESLICE_MASK`` and enables timeslicing
- * - ``RTEMS_ASR``
- - is masked by ``RTEMS_ASR_MASK`` and enables ASR processing
- - is masked by ``RTEMS_ASR_MASK`` and disables ASR processing
- - is masked by ``RTEMS_INTERRUPT_MASK`` and enables all interrupts
- - is masked by ``RTEMS_INTERRUPT_MASK`` and sets interrupts level n
+.. _InterfaceRtemsTaskMode:
+rtems_task_mode()
+Gets and optionally sets the mode of the calling task.
+.. code-block:: c
+ rtems_status_code rtems_task_mode(
+ rtems_mode mode_set,
+ rtems_mode mask,
+ rtems_mode *previous_mode_set
+``mode_set``
+ This parameter is the mode set to apply to the calling task. When ``mask``
+ is set to :c:macro:`RTEMS_CURRENT_MODE`, the value of this parameter is
+ ignored. Only modes requested by ``mask`` are applied to the calling task.
+``mask``
+ This parameter is the mode mask which specifies which modes in ``mode_set``
+ are applied to the calling task. When the value is
+ :c:macro:`RTEMS_CURRENT_MODE`, the mode of the calling task is not changed.
+``previous_mode_set``
+ This parameter is the pointer to a mode variable. When the directive call
+ is successful, the mode of the task before any mode changes done by the
+ directive call will be stored in this variable.
+This directive queries and optionally manipulates the execution mode of the
+calling task. A task's execution mode enables and disables preemption,
+timeslicing, asynchronous signal processing, as well as specifying the
+interrupt level. To modify an execution mode, the mode class(es) to be changed
+must be specified in the ``mask`` parameter and the desired mode(s) must be
+specified in the ``mode_set`` parameter.
+A task can obtain its current execution mode, without modifying it, by calling
+this directive with a ``mask`` value of :c:macro:`RTEMS_CURRENT_MODE`.
+The **mode set** specified in ``mode_set`` is built through a *bitwise or* of
+the mode constants described below. Not all combinations of modes are allowed.
+Some modes are mutually exclusive. If mutually exclusive modes are combined,
+the behaviour is undefined. Default task modes can be selected by using the
+:c:macro:`RTEMS_DEFAULT_MODES` constant. The task mode set defines
+ interrupts.
+The **mode mask** specified in ``mask`` is built through a *bitwise or* of the
+mode mask constants described below.
+When the :c:macro:`RTEMS_PREEMPT_MASK` is set in ``mask``, the **preemption
+mode** of the calling task is
+* enabled by using the :c:macro:`RTEMS_PREEMPT` mode constant in ``mode_set``
+ and
+* disabled by using the :c:macro:`RTEMS_NO_PREEMPT` mode constant in
+ ``mode_set``.
+When the :c:macro:`RTEMS_TIMESLICE_MASK` is set in ``mask``, the **timeslicing
+* enabled by using the :c:macro:`RTEMS_TIMESLICE` mode constant in ``mode_set``
+ and
+* disabled by using the :c:macro:`RTEMS_NO_TIMESLICE` mode constant in
+ ``mode_set``.
+Enabling timeslicing has no effect if preemption is disabled. For a task to be
+timesliced, that task must have both preemption and timeslicing enabled.
+When the :c:macro:`RTEMS_ASR_MASK` is set in ``mask``, the **ASR processing
+* enabled by using the :c:macro:`RTEMS_ASR` mode constant in ``mode_set`` and
+* disabled by using the :c:macro:`RTEMS_NO_ASR` mode constant in ``mode_set``.
+When the :c:macro:`RTEMS_INTERRUPT_MASK` is set in ``mask``, **interrupts** of
+the calling task are
+* enabled by using the :c:func:`RTEMS_INTERRUPT_LEVEL` mode macro with a value
+ of zero (0) in ``mode_set`` and
+* disabled up to the specified level by using the
+ :c:func:`RTEMS_INTERRUPT_LEVEL` mode macro with a positive value in
+ ``mode_set``.
+An interrupt level of zero is associated with enabled interrupts on all target
+processors. The interrupt level portion of the task mode supports a maximum of
+256 interrupt levels. These levels are mapped onto the interrupt levels
+actually supported by the target processor in a processor dependent fashion.
+:c:macro:`RTEMS_NOT_IMPLEMENTED`
+ The :c:macro:`RTEMS_NO_PREEMPT` was set in ``mode_set`` and setting the
+ preemption mode was requested by :c:macro:`RTEMS_PREEMPT_MASK` in ``mask``
+ and the system configuration had no implementation for this mode.
+ The :c:func:`RTEMS_INTERRUPT_LEVEL` was set to a positive level in
+ ``mode_set`` and setting the interrupt level was requested by
+ :c:macro:`RTEMS_INTERRUPT_MASK` in ``mask`` and the system configuration
+ had no implementation for this mode.
+* When the directive enables preemption for the calling task, another task may
+ preempt the calling task.
+ will occur.
+.. Generated from spec:/rtems/task/if/wake-after
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_wake_after()
.. index:: delay a task for an interval
.. index:: wake up after an interval
-.. index:: rtems_task_wake_after
-.. _rtems_task_wake_after:
+.. _InterfaceRtemsTaskWakeAfter:
+rtems_task_wake_after()
+Wakes up after an interval in :term:`clock ticks <clock tick>` or yields the
+processor.
+.. code-block:: c
-TASK_WAKE_AFTER - Wake up after interval
+ rtems_status_code rtems_task_wake_after( rtems_interval ticks );
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_wake_after(
- rtems_interval ticks
+``ticks``
+ This parameter is the interval in :term:`clock ticks <clock tick>` to delay
+ the task or :c:macro:`RTEMS_YIELD_PROCESSOR` to yield the processor.
- .. list-table::
- - always successful
+This directive blocks the calling task for the specified ``ticks`` of clock
+ticks if the value is not equal to :c:macro:`RTEMS_YIELD_PROCESSOR`. When the
+requested interval has elapsed, the task is made ready. The clock tick
+directives automatically updates the delay period. The calling task may give
+up the processor and remain in the ready state by specifying a value of
+:c:macro:`RTEMS_YIELD_PROCESSOR` in ``ticks``.
-DESCRIPTION:
- This directive blocks the calling task for the specified number of system
- clock ticks. When the requested interval has elapsed, the task is made
- ready. The clock tick directives automatically updates the delay period.
-NOTES:
- Setting the system date and time with the ``rtems_clock_set`` directive has
- no effect on a ``rtems_task_wake_after`` blocked task.
- A task may give up the processor and remain in the ready state by
- specifying a value of ``RTEMS_YIELD_PROCESSOR`` in ticks.
+.. rubric:: NOTES:
- The maximum timer interval that can be specified is the maximum value which
- can be represented by the uint32_t type.
+Setting the system date and time with the :ref:`InterfaceRtemsClockSet`
+directive and similar directives which set :term:`CLOCK_REALTIME` have no
+effect on a :ref:`InterfaceRtemsTaskWakeAfter` blocked task.
- A clock tick is required to support the functionality of this directive.
+* The directive requires a :term:`Clock Driver`.
+ will occur.
+.. Generated from spec:/rtems/task/if/wake-when
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_wake_when()
.. index:: delay a task until a wall time
.. index:: wake up at a wall time
-.. index:: rtems_task_wake_when
-.. _rtems_task_wake_when:
+.. _InterfaceRtemsTaskWakeWhen:
-TASK_WAKE_WHEN - Wake up when specified
+rtems_task_wake_when()
-CALLING SEQUENCE:
- .. code-block:: c
+Wakes up when specified.
- rtems_status_code rtems_task_wake_when(
- rtems_time_of_day *time_buffer
- .. list-table::
+.. code-block:: c
- - awakened at date/time successfully
- - ``time_buffer`` is NULL
- * - ``RTEMS_INVALID_TIME_OF_DAY``
- - invalid time buffer
- - system date and time is not set
+ rtems_status_code rtems_task_wake_when( rtems_time_of_day *time_buffer );
-DESCRIPTION:
- This directive blocks a task until the date and time specified in
- time_buffer. At the requested date and time, the calling task will be
- unblocked and made ready to execute.
-NOTES:
- The ticks portion of time_buffer structure is ignored. The timing
- granularity of this directive is a second.
+``time_buffer``
+ This parameter is the date and time to wake up.
-.. raw:: latex
+This directive blocks a task until the date and time specified in
+``time_buffer``. At the requested date and time, the calling task will be
+unblocked and made ready to execute.
- \clearpage
-.. _rtems_task_get_scheduler:
-TASK_GET_SCHEDULER - Get scheduler of a task
+:c:macro:`RTEMS_NOT_DEFINED`
+ The system date and time was not set.
-CALLING SEQUENCE:
- .. code-block:: c
+ The ``time_buffer`` parameter was `NULL
- rtems_status_code rtems_task_get_scheduler(
- rtems_id task_id,
- rtems_id *scheduler_id
+:c:macro:`RTEMS_INVALID_CLOCK`
+ The time of day was invalid.
- .. list-table::
+.. rubric:: NOTES:
- - successful operation
- - ``scheduler_id`` is NULL
- - invalid task id
+The ticks portion of ``time_buffer`` structure is ignored. The timing
+granularity of this directive is a second.
-DESCRIPTION:
- Returns the scheduler identifier of a task identified by ``task_id`` in
- ``scheduler_id``.
-NOTES:
- None.
-.. raw:: latex
- \clearpage
-.. _rtems_task_set_scheduler:
-.. _TASK_SET_SCHEDULER - Set scheduler of a task:
-TASK_SET_SCHEDULER - Set scheduler of a task
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_set_scheduler(
- rtems_id task_id,
- rtems_task_priority priority
- .. list-table::
- - invalid task or scheduler id
- * - ``RTEMS_RESOURCE_IN_USE``
- - the task is in the wrong state to perform a scheduler change
- - the processor set of the scheduler is empty
-DESCRIPTION:
- Sets the scheduler of a task identified by ``task_id`` to the scheduler
- identified by ``scheduler_id``. The scheduler of a task is initialized to
- the scheduler of the task that created it. The priority of the task is set
- to ``priority``.
-NOTES:
- It is recommended to set the scheduler of a task before it is started or in
- case it is guaranteed that the task owns no resources. Otherwise, sporadic
- ``RTEMS_RESOURCE_IN_USE`` errors may occur.
-EXAMPLE:
- .. code-block:: c
- :linenos:
- #include <rtems.h>
- #include <assert.h>
- rtems_task task( rtems_task_argument arg );
- void example( void )
- rtems_status_code sc;
- rtems_id task_id;
- rtems_id scheduler_id;
- rtems_name scheduler_name;
- scheduler_name = rtems_build_name( 'W', 'O', 'R', 'K' );
- sc = rtems_scheduler_ident( scheduler_name, &scheduler_id );
- assert( sc == RTEMS_SUCCESSFUL );
- sc = rtems_task_create(
- rtems_build_name( 'T', 'A', 'S', 'K' ),
- 1,
- RTEMS_MINIMUM_STACK_SIZE,
- RTEMS_DEFAULT_MODES,
- RTEMS_DEFAULT_ATTRIBUTES,
- &task_id
- sc = rtems_task_set_scheduler( task_id, scheduler_id, 2 );
- sc = rtems_task_start( task_id, task, 0 );
+ will occur.
+.. Generated from spec:/rtems/task/if/get-scheduler
.. raw:: latex
- \clearpage
+ \clearpage
-.. _rtems_task_get_affinity:
+.. index:: rtems_task_get_scheduler()
-TASK_GET_AFFINITY - Get task processor affinity
+.. _InterfaceRtemsTaskGetScheduler:
-CALLING SEQUENCE:
- .. code-block:: c
+rtems_task_get_scheduler()
- rtems_status_code rtems_task_get_affinity(
- rtems_id id,
- size_t cpusetsize,
- cpu_set_t *cpuset
+Gets the home scheduler of the task.
- .. list-table::
- - ``cpuset`` is NULL
- - invalid task id
- * - ``RTEMS_INVALID_NUMBER``
- - the affinity set buffer is too small for the current processor affinity
- set of the task
+.. code-block:: c
-DESCRIPTION:
- Returns the current processor affinity set of the task in ``cpuset``. A
- set bit in the affinity set means that the task can execute on this
- processor and a cleared bit means the opposite.
+ rtems_status_code rtems_task_get_scheduler(
+ rtems_id task_id,
+ rtems_id *scheduler_id
-NOTES:
-.. raw:: latex
+``task_id``
+``scheduler_id``
+ This parameter is the pointer to an :c:type:`rtems_id` variable. When the
+ directive call is successful, the identifier of the :term:`home scheduler`
+ of the task will be stored in this variable.
+This directive returns the identifier of the :term:`home scheduler` of the task
+specified by ``task_id`` in ``scheduler_id``.
+ The ``scheduler_id`` parameter was `NULL
+ There was no task associated with the identifier specified by ``task_id``.
- \clearpage
-.. _rtems_task_set_affinity:
-TASK_SET_AFFINITY - Set task processor affinity
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_set_affinity(
- rtems_id id,
- const cpu_set_t *cpuset
- .. list-table::
- - invalid task id
- - invalid processor affinity set
-DESCRIPTION:
- Sets the processor affinity set for the task specified by ``cpuset``. A
-NOTES:
- This function will not change the scheduler of the task. The intersection
- of the processor affinity set and the set of processors owned by the
- scheduler of the task must be non-empty. It is not an error if the
- processor affinity set contains processors that are not part of the set of
- processors owned by the scheduler instance of the task. A task will simply
- not run under normal circumstances on these processors since the scheduler
- ignores them. Some locking protocols may temporarily use processors that
- are not included in the processor affinity set of the task. It is also not
- an error if the processor affinity set contains processors that are not
- part of the system.
- In case a scheduler without support for task affinites is used for the
- task, then the task processor affinity set must contain all online
- processors of the system. This prevents odd corner cases if processors are
- added/removed at run-time to/from scheduler instances.
+.. Generated from spec:/rtems/task/if/set-scheduler
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_set_scheduler()
+.. _InterfaceRtemsTaskSetScheduler:
+rtems_task_set_scheduler()
+Sets the home scheduler for the task.
-.. index:: iterate over all threads
-.. index:: rtems_task_iterate
-.. _rtems_task_iterate:
+.. code-block:: c
-TASK_ITERATE - Iterate Over Tasks
+ rtems_status_code rtems_task_set_scheduler(
+ rtems_id task_id,
+ rtems_id scheduler_id,
+ rtems_task_priority priority
-CALLING SEQUENCE:
- .. code-block:: c
- typedef bool ( *rtems_task_visitor )( rtems_tcb *tcb, void *arg );
+``task_id``
- void rtems_task_iterate(
- rtems_task_visitor visitor,
- void *arg
+``scheduler_id``
+ This parameter is the scheduler identifier of the new :term:`home
+ scheduler` for the task specified by ``task_id``.
+``priority``
+ This parameter is the new real priority for the task with respect to the
+ scheduler specified by ``scheduler_id``.
+This directive sets the :term:`home scheduler` to the scheduler specified by
+``scheduler_id`` for the task specified by ``task_id``.
+ There was no scheduler associated with the identifier specified by
+ ``scheduler_id``.
- NONE
+ There task priority specified in ``priority`` was invalid with respect to
+ the scheduler specified by ``scheduler_id``.
-DESCRIPTION:
- Iterates over all tasks in the system. This operation covers all tasks of
- all APIs. The user should be careful in accessing the contents of the
- thread control block :c:data:`tcb`. The visitor argument :c:data:`arg` is
- passed to all invocations of :c:data:`visitor` in addition to the thread
- control block. The iteration stops immediately in case the visitor
- function returns true.
-NOTES:
- Must be called from task context. This operation obtains and releases the
- objects allocator lock. The task visitor is called while owning the objects
- allocator lock. It is possible to perform blocking operations in the task
- visitor, however, take care that no deadlocks via the object allocator lock
- can occur.
-Deprecated Directives
+.. Generated from spec:/rtems/task/if/get-affinity
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_get_affinity()
+.. _InterfaceRtemsTaskGetAffinity:
+rtems_task_get_affinity()
+Gets the processor affinity of the task.
+.. code-block:: c
+ rtems_status_code rtems_task_get_affinity(
+ rtems_id id,
+ size_t cpusetsize,
+ cpu_set_t *cpuset
-.. index:: rtems_iterate_over_all_threads
-.. _rtems_iterate_over_all_threads:
+``id``
-ITERATE_OVER_ALL_THREADS - Iterate Over Tasks
+``cpusetsize``
+ This parameter is the size of the referenced processor set variable in
+ bytes.
-.. warning::
+``cpuset``
+ This parameter is the pointer to a processor set variable. When the
+ directive call is successful, the processor affinity set of the task will
+ be stored in this variable. A set bit in the processor set means that the
+ corresponding processor is in the processor affinity set of the task,
+ otherwise the bit is cleared.
- This directive is deprecated. Its use is unsafe. Use
- :ref:`rtems_task_iterate` instead.
-CALLING SEQUENCE:
- .. code-block:: c
+This directive returns the processor affinity of the task in ``cpuset`` of the
+task specified by ``id``.
- typedef void (*rtems_per_thread_routine)(Thread_Control *the_thread);
- void rtems_iterate_over_all_threads(
- rtems_per_thread_routine routine
-DIRECTIVE STATUS CODES:
- NONE
-DESCRIPTION:
- This directive iterates over all of the existant threads in the system and
- invokes ``routine`` on each of them. The user should be careful in
- accessing the contents of ``the_thread``.
+ The ``cpuset`` parameter was `NULL
- This routine is intended for use in diagnostic utilities and is not
- intented for routine use in an operational system.
-NOTES:
- There is **no protection** while this routine is called. The thread
- control block may be in an inconsistent state or may change due to
- interrupts or activity on other processors.
+ The provided processor set was too small for the processor affinity set of
+ the task.
-Removed Directives
+.. Generated from spec:/rtems/task/if/set-affinity
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_set_affinity()
+.. _InterfaceRtemsTaskSetAffinity:
+rtems_task_set_affinity()
+Sets the processor affinity of the task.
+.. code-block:: c
-.. index:: get task notepad entry
-.. index:: rtems_task_get_note
+ rtems_status_code rtems_task_set_affinity(
+ rtems_id id,
+ const cpu_set_t *cpuset
-.. _rtems_task_get_note:
-TASK_GET_NOTE - Get task notepad entry
+``id``
-.. warning::
+``cpusetsize``
+ bytes.
- This directive was removed in RTEMS 5.1.
+``cpuset``
+ This parameter is the pointer to a processor set variable. The processor
+ set defines the new processor affinity set of the task. A set bit in the
+ processor set means that the corresponding processor shall be in the
+ processor affinity set of the task, otherwise the bit shall be cleared.
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_get_note(
- rtems_id id,
- uint32_t notepad,
- uint32_t *note
+This directive sets the processor affinity of the task specified by ``id``.
- .. list-table::
- :class: rtems-table
- * - ``RTEMS_SUCCESSFUL``
- - note value obtained successfully
- * - ``RTEMS_INVALID_ADDRESS``
- - ``note`` parameter is NULL
- - invalid task id
- - invalid notepad location
-DESCRIPTION:
- This directive returns the note contained in the notepad location of the
- task specified by id.
-NOTES:
- If id is set to ``RTEMS_SELF``, the calling task accesses its own notepad.
+:c:macro:`RTEMS_INVALID_NUMBER`
+ The referenced processor set was not a valid new processor affinity set for
+ the task.
- The sixteen notepad locations can be accessed using the constants
- ``RTEMS_NOTEPAD_0`` through ``RTEMS_NOTEPAD_15``.
- Getting a note of a global task which does not reside on the local node
- will generate a request to the remote node to obtain the notepad entry of
+* The directive may change the processor affinity of a task. This may cause
+ the calling task to be preempted.
+.. Generated from spec:/rtems/task/if/iterate
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_iterate()
-.. index:: set task notepad entry
-.. index:: rtems_task_set_note
+.. _InterfaceRtemsTaskIterate:
-.. _rtems_task_set_note:
+rtems_task_iterate()
-TASK_SET_NOTE - Set task notepad entry
+Iterates over all tasks and invokes the visitor routine for each task.
-.. warning::
+.. code-block:: c
-CALLING SEQUENCE:
- .. code-block:: c
+ void rtems_task_iterate( rtems_task_visitor visitor, void *arg );
- rtems_status_code rtems_task_set_note(
- rtems_id id,
- uint32_t notepad,
- uint32_t note
- .. list-table::
+``visitor``
+ This parameter is the visitor routine invoked for each task.
- - note set successfully
- - invalid task id
+``arg``
+ This parameter is the argument passed to each visitor routine invocation
+ during the iteration.
-DESCRIPTION:
- This directive sets the notepad entry for the task specified by id to the
- value note.
-NOTES:
- If ``id`` is set to ``RTEMS_SELF``, the calling task accesses its own
- notepad.
+This directive iterates over all tasks in the system. This operation covers
+all tasks of all APIs. The user should be careful in accessing the contents of
+the :term:`TCB`. The visitor argument ``arg`` is passed to all invocations of
+``visitor`` in addition to the TCB. The iteration stops immediately in case the
+visitor routine returns true.
+.. rubric:: NOTES:
+The visitor routine is invoked while owning the objects allocator lock. It is
+allowed to perform blocking operations in the visitor routine, however, care
+must be taken so that no deadlocks via the object allocator lock can occur.
- Setting a note of a global task which does not reside on the local node
- will generate a request to the remote node to set the notepad entry of the
- specified task.
+.. Generated from spec:/rtems/task/if/get-priority
.. raw:: latex
- \clearpage
-.. index:: per-task variable
-.. index:: task private variable
-.. index:: task private data
-.. index:: rtems_task_variable_add
-.. _rtems_task_variable_add:
-TASK_VARIABLE_ADD - Associate per task variable
-.. warning::
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_task_variable_add(
- rtems_id tid,
- void **task_variable,
- void (*dtor)(void *)
- .. list-table::
- - per task variable added successfully
- - ``task_variable`` is NULL
- - invalid task id
- * - ``RTEMS_NO_MEMORY``
- - invalid task id
-DESCRIPTION:
- This directive adds the memory location specified by the ptr argument to
- the context of the given task. The variable will then be private to the
- task. The task can access and modify the variable, but the modifications
- will not appear to other tasks, and other tasks' modifications to that
- variable will not affect the value seen by the task. This is accomplished
- by saving and restoring the variable's value each time a task switch occurs
- to or from the calling task. If the dtor argument is non-NULL it specifies
- the address of a 'destructor' function which will be called when the task
- is deleted. The argument passed to the destructor function is the task's
- value of the variable.
-NOTES:
- Task variables increase the context switch time to and from the tasks that
- own them so it is desirable to minimize the number of task variables. One
- efficient method is to have a single task variable that is a pointer to a
- dynamically allocated structure containing the task's private 'global'
- data. In this case the destructor function could be 'free'.
- Per-task variables are disabled in SMP configurations and this service is
- not available.
+ \clearpage
+.. index:: rtems_task_get_priority()
+.. index:: current task priority
+.. index:: get task priority
+.. index:: obtain task priority
+.. _InterfaceRtemsTaskGetPriority:
+rtems_task_get_priority()
+Gets the current priority of the task with respect to the scheduler.
+.. rubric:: CALLING SEQUENCE:
+.. code-block:: c
+ rtems_status_code rtems_task_get_priority(
+ rtems_id task_id,
+ rtems_task_priority *priority
+.. rubric:: PARAMETERS:
+``task_id``
+``scheduler_id``
+ This parameter is the scheduler identifier.
+``priority``
+ This parameter is the pointer to an :c:type:`rtems_task_priority` variable.
+ When the directive call is successful, the current priority of the task
+ with respect to the specified scheduler will be stored in this variable.
+.. rubric:: DESCRIPTION:
+This directive returns the current priority in ``priority`` of the task
+specified by ``task_id`` with respect to the scheduler specified by
+``scheduler_id``.
+ The ``priority`` parameter was `NULL
+ ``scheduler_id``.
+ The task had no priority with respect to the scheduler.
+.. rubric:: NOTES:
+The current priority reflects temporary priority adjustments due to locking
+protocols, the rate-monotonic period objects on some schedulers, and other
+mechanisms.
+.. Generated from spec:/rtems/task/if/set-priority
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_task_set_priority()
+.. index:: set task priority
+.. _InterfaceRtemsTaskSetPriority:
+rtems_task_set_priority()
+Sets the real priority or gets the current priority of the task.
-.. index:: get per-task variable
-.. index:: obtain per-task variable
-.. index:: rtems_task_variable_get
+.. code-block:: c
-.. _rtems_task_variable_get:
+ rtems_status_code rtems_task_set_priority(
+ rtems_id id,
+ rtems_task_priority new_priority,
+ rtems_task_priority *old_priority
-TASK_VARIABLE_GET - Obtain value of a per task variable
-.. warning::
+``id``
+``new_priority``
+ This parameter is the new real priority or
+ :c:macro:`RTEMS_CURRENT_PRIORITY` to get the current priority.
-CALLING SEQUENCE:
- .. code-block:: c
+``old_priority``
+ When the directive call is successful, the current or previous priority of
+ the task with respect to its :term:`home scheduler` will be stored in this
+ variable.
- rtems_status_code rtems_task_variable_get(
- rtems_id tid,
- void **task_variable_value
- .. list-table::
+This directive manipulates the priority of the task specified by ``id``. When
+``new_priority`` is not equal to :c:macro:`RTEMS_CURRENT_PRIORITY`, the
+specified task's previous priority is returned in ``old_priority``. When
+``new_priority`` is :c:macro:`RTEMS_CURRENT_PRIORITY`, the specified task's
+current priority is returned in ``old_priority``.
- - per task variable obtained successfully
- - ``task_variable_value`` is NULL
- - ``task_variable`` is not found
- - invalid task id
-DESCRIPTION:
- This directive looks up the private value of a task variable for a
- specified task and stores that value in the location pointed to by the
- result argument. The specified task is usually not the calling task, which
- can get its private value by directly accessing the variable.
-NOTES:
- If you change memory which ``task_variable_value`` points to, remember to
- declare that memory as volatile, so that the compiler will optimize it
- correctly. In this case both the pointer ``task_variable_value`` and data
- referenced by ``task_variable_value`` should be considered volatile.
+ The ``old_priority`` parameter was `NULL
- not available.
+ The task priority specified in ``new_priority`` was invalid with respect to
+ the :term:`home scheduler` of the task.
+.. rubric:: NOTES:
+Valid priorities range from one to a maximum value which depends on the
+configured scheduler. The lower the priority value the higher is the
+importance of the task.
+If the task is currently holding any binary semaphores which use a locking
+protocol, then the task's priority cannot be lowered immediately. If the
+task's priority were lowered immediately, then this could violate properties of
+the locking protocol and may result in priority inversion. The requested
+lowering of the task's priority will occur when the task has released all
+binary semaphores which make the task more important. The task's priority can
+be increased regardless of the task's use of binary semaphores with locking
+protocols.
+ task.
+.. Generated from spec:/rtems/task/if/storage-size
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: RTEMS_TASK_STORAGE_SIZE()
-.. index:: rtems_task_variable_delete
+.. _InterfaceRTEMSTASKSTORAGESIZE:
-.. _rtems_task_variable_delete:
+RTEMS_TASK_STORAGE_SIZE()
-TASK_VARIABLE_DELETE - Remove per task variable
+Gets the recommended task storage area size for the size and task attributes.
-.. warning::
+.. code-block:: c
-CALLING SEQUENCE:
- .. code-block:: c
+ #define RTEMS_TASK_STORAGE_SIZE( size, attributes )
- rtems_status_code rtems_task_variable_delete(
- rtems_id id,
- .. list-table::
+``size``
+ This parameter is the size dedicated to the task stack and thread-local
+ storage in bytes.
- - per task variable deleted successfully
- - invalid task id
- - invalid task id
+``attributes``
+ This parameter is the attribute set of the task using the storage area.
-DESCRIPTION:
- This directive removes the given location from a task's context.
+.. rubric:: RETURN VALUES:
-NOTES:
- not available.
+Returns the recommended task storage area size calculated from the input
+parameters.
diff --git a/c-user/task/introduction.rst b/c-user/task/introduction.rst
index 449b335..97b7517 100644
--- a/c-user/task/introduction.rst
+++ b/c-user/task/introduction.rst
@@ -1,50 +1,106 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+.. Copyright (C) 2020, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 1988, 2017 On-Line Applications Research Corporation (OAR)
+.. This file is part of the RTEMS quality process and was automatically
+.. generated. If you find something that needs to be fixed or
+.. worded better please post a report or patch to an RTEMS mailing list
+.. or raise a bug report:
+.. https://www.rtems.org/bugs.html
+.. For information on updating and regenerating please refer to the How-To
+.. section in the Software Requirements Engineering chapter of the
+.. RTEMS Software Engineering manual. The manual is provided as a part of
+.. a release. For development sources please refer to the online
+.. documentation at:
+.. https://docs.rtems.org
+.. Generated from spec:/rtems/task/if/group
+.. _TaskManagerIntroduction:
Introduction
-The task manager provides a comprehensive set of directives to create, delete,
-and administer tasks. The directives provided by the task manager are:
+.. The following list was generated from:
+.. spec:/rtems/task/if/create
+.. spec:/rtems/task/if/construct
+.. spec:/rtems/task/if/ident
+.. spec:/rtems/task/if/self
+.. spec:/rtems/task/if/start
+.. spec:/rtems/task/if/restart
+.. spec:/rtems/task/if/delete
+.. spec:/rtems/task/if/exit
+.. spec:/rtems/task/if/suspend
+.. spec:/rtems/task/if/resume
+.. spec:/rtems/task/if/is-suspended
+.. spec:/rtems/task/if/mode
+.. spec:/rtems/task/if/wake-after
+.. spec:/rtems/task/if/wake-when
+.. spec:/rtems/task/if/get-scheduler
+.. spec:/rtems/task/if/set-scheduler
+.. spec:/rtems/task/if/get-affinity
+.. spec:/rtems/task/if/set-affinity
+.. spec:/rtems/task/if/iterate
+.. spec:/rtems/task/if/get-priority
+.. spec:/rtems/task/if/set-priority
+.. spec:/rtems/task/if/storage-size
-- :ref:`rtems_task_create`
+The Task Manager provides a comprehensive set of directives to create, delete,
+and administer tasks. The directives provided by the Task Manager are:
-- :ref:`rtems_task_ident`
+* :ref:`InterfaceRtemsTaskCreate` - Creates a task.
-- :ref:`rtems_task_self`
+* :ref:`InterfaceRtemsTaskConstruct` - Constructs a task from the specified the
+ task configuration.
-- :ref:`rtems_task_start`
+* :ref:`InterfaceRtemsTaskIdent` - Identifies a task by the object name.
-- :ref:`rtems_task_restart`
+* :ref:`InterfaceRtemsTaskSelf` - Gets the task identifier of the calling task.
-- :ref:`rtems_task_delete`
+* :ref:`InterfaceRtemsTaskStart` - Starts the task.
-- :ref:`rtems_task_exit`
+* :ref:`InterfaceRtemsTaskRestart` - Restarts the task.
-- :ref:`rtems_task_suspend`
+* :ref:`InterfaceRtemsTaskDelete` - Deletes the task.
-- :ref:`rtems_task_resume`
+* :ref:`InterfaceRtemsTaskExit` - Deletes the calling task.
-- :ref:`rtems_task_is_suspended`
+* :ref:`InterfaceRtemsTaskSuspend` - Suspends the task.
-- :ref:`rtems_task_set_priority`
+* :ref:`InterfaceRtemsTaskResume` - Resumes the task.
-- :ref:`rtems_task_get_priority`
+* :ref:`InterfaceRtemsTaskIsSuspended` - Checks if the task is suspended.
-- :ref:`rtems_task_mode`
+* :ref:`InterfaceRtemsTaskMode` - Gets and optionally sets the mode of the
+ calling task.
-- :ref:`rtems_task_wake_after`
+* :ref:`InterfaceRtemsTaskWakeAfter` - Wakes up after an interval in
+ :term:`clock ticks <clock tick>` or yields the processor.
-- :ref:`rtems_task_wake_when`
+* :ref:`InterfaceRtemsTaskWakeWhen` - Wakes up when specified.
-- :ref:`rtems_task_get_scheduler`
+* :ref:`InterfaceRtemsTaskGetScheduler` - Gets the home scheduler of the task.
-- :ref:`rtems_task_set_scheduler`
+* :ref:`InterfaceRtemsTaskSetScheduler` - Sets the home scheduler for the task.
-- :ref:`rtems_task_get_affinity`
+* :ref:`InterfaceRtemsTaskGetAffinity` - Gets the processor affinity of the
+ task.
-- :ref:`rtems_task_set_affinity`
+* :ref:`InterfaceRtemsTaskSetAffinity` - Sets the processor affinity of the
+ task.
-- :ref:`rtems_task_iterate`
+* :ref:`InterfaceRtemsTaskIterate` - Iterates over all tasks and invokes the
+ visitor routine for each task.
+* :ref:`InterfaceRtemsTaskGetPriority` - Gets the current priority of the task
+ with respect to the scheduler.
+* :ref:`InterfaceRtemsTaskSetPriority` - Sets the real priority or gets the
+ current priority of the task.
+* :ref:`InterfaceRTEMSTASKSTORAGESIZE` - Gets the recommended task storage area
+ size for the size and task attributes.
2.26.2
