[PATCH] Return status code for _Thread_Start()
Tue Apr 27 16:06:37 UTC 2021
ok
On Mon, Apr 26, 2021 at 5:54 AM Sebastian Huber
> This avoids having conditional statements to get the API-specific status
> code.
>  cpukit/include/rtems/score/threadimpl.h | 7 +++----
>  cpukit/posix/src/pthreadcreate.c        | 5 ++---
>  cpukit/rtems/src/taskstart.c            | 7 ++++---
>  cpukit/score/src/threadstart.c          | 6 +++---
>  4 files changed, 12 insertions(+), 13 deletions(-)
> diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
> index d9c0779b08..5dfd142b92 100644
> --- a/cpukit/include/rtems/score/threadimpl.h
> +++ b/cpukit/include/rtems/score/threadimpl.h
> @@ -260,12 +260,11 @@ void _Thread_Free(
>   * @param[in, out] is the ISR lock context which shall be used to disable the
>   *   local interrupts before the call of this routine.
> - * @retval true The thread was in the dormant state and was sucessefully
> - *   started.
> + * @retval STATUS_SUCCESSFUL The thread start was successful.
> - * @retval false Otherwise.
> + * @retval STATUS_INCORRECT_STATE The thread was already started.
> -bool _Thread_Start(
> +Status_Control _Thread_Start(
>    Thread_Control                 *the_thread,
>    const Thread_Entry_information *entry,
>    ISR_lock_Context               *lock_context
> diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
> index f53cd5e310..055d304699 100644
> --- a/cpukit/posix/src/pthreadcreate.c
> +++ b/cpukit/posix/src/pthreadcreate.c
> @@ -74,7 +74,6 @@ int pthread_create(
>    bool                                valid;
>    Thread_Configuration                config;
>    Status_Control                      status;
> -  bool                                ok;
>    Thread_Control                     *the_thread;
>    Thread_Control                     *executing;
>    int                                 schedpolicy = SCHED_RR;
> @@ -289,7 +288,7 @@ int pthread_create(
>     *  POSIX threads are allocated and started in one operation.
>    _ISR_lock_ISR_disable( &lock_context );
> -  ok = _Thread_Start( the_thread, &entry, &lock_context );
> +  status = _Thread_Start( the_thread, &entry, &lock_context );
>    #if defined(RTEMS_DEBUG)
> @@ -298,7 +297,7 @@ int pthread_create(
>       *  NOTE: This can only happen if someone slips in and touches the
>       *        thread while we are creating it.
> -    if ( !ok ) {
> +    if ( status != STATUS_SUCCESSFUL ) {
>        _Thread_Free( &_POSIX_Threads_Information, the_thread );
>        _Objects_Allocator_unlock();
>        return EINVAL;
> diff --git a/cpukit/rtems/src/taskstart.c b/cpukit/rtems/src/taskstart.c
> index da29240961..eca9b5795d 100644
> --- a/cpukit/rtems/src/taskstart.c
> +++ b/cpukit/rtems/src/taskstart.c
> @@ -21,6 +21,7 @@
>  #endif
>  #include <rtems/rtems/tasks.h>
> +#include <rtems/rtems/statusimpl.h>
>  #include <rtems/score/threadimpl.h>
>  rtems_status_code rtems_task_start(
> @@ -40,7 +41,7 @@ rtems_status_code rtems_task_start(
>    ISR_lock_Context  lock_context;
> -  bool              ok;
> +  Status_Control    status;
>    the_thread = _Thread_Get( id, &lock_context );
> @@ -54,7 +55,7 @@ rtems_status_code rtems_task_start(
>      return RTEMS_INVALID_ID;
> -  return ok ? RTEMS_SUCCESSFUL : RTEMS_INCORRECT_STATE;
> +  return _Status_Get( status );
> diff --git a/cpukit/score/src/threadstart.c b/cpukit/score/src/threadstart.c
> index e75c536a2c..8c1732a35a 100644
> --- a/cpukit/score/src/threadstart.c
> +++ b/cpukit/score/src/threadstart.c
> @@ -24,7 +24,7 @@
>  #include <rtems/score/isrlevel.h>
>  #include <rtems/score/userextimpl.h>
> @@ -36,7 +36,7 @@ bool _Thread_Start(
>    if ( !_States_Is_dormant( the_thread->current_state ) ) {
>      _Thread_State_release( the_thread, lock_context );
> -    return false;
> +    return STATUS_INCORRECT_STATE;
>    the_thread->Start.Entry = *entry;
> @@ -49,5 +49,5 @@ bool _Thread_Start(
>    _User_extensions_Thread_start( the_thread );
>    _Thread_Dispatch_enable( cpu_self );
> -  return true;
> +  return STATUS_SUCCESSFUL;
> 2.26.2
> devel mailing list
> devel at rtems.org
