[PATCH] Return status code for _Scheduler_Set_affinity()
Gedare Bloom
gedare at rtems.org
Tue Apr 27 16:07:17 UTC 2021
ok
On Mon, Apr 26, 2021 at 5:55 AM Sebastian Huber
> This avoids having conditional statements to get the API-specific status
> code.
> cpukit/include/rtems/score/scheduler.h | 12 ++++++---
> cpukit/include/rtems/score/scheduleredfsmp.h | 9 ++++---
> cpukit/include/rtems/score/schedulerimpl.h | 27 ++++++++++++-------
> .../score/schedulerpriorityaffinitysmp.h | 6 ++---
> cpukit/posix/src/pthreadcreate.c | 4 +--
> cpukit/posix/src/pthreadsetaffinitynp.c | 7 ++---
> cpukit/rtems/src/tasksetaffinity.c | 7 ++---
> .../score/src/schedulerdefaultsetaffinity.c | 2 +-
> cpukit/score/src/scheduleredfsmp.c | 6 ++---
> .../score/src/schedulerpriorityaffinitysmp.c | 8 +++---
> cpukit/score/src/schedulersetaffinity.c | 20 +++++++-------
> 11 files changed, 63 insertions(+), 45 deletions(-)
> diff --git a/cpukit/include/rtems/score/scheduler.h b/cpukit/include/rtems/score/scheduler.h
> index 7a566cf44d..da1e030ab8 100644
> --- a/cpukit/include/rtems/score/scheduler.h
> +++ b/cpukit/include/rtems/score/scheduler.h
> @@ -21,6 +21,7 @@
> #define _RTEMS_SCORE_SCHEDULER_H
> #include <rtems/score/thread.h>
> +#include <rtems/score/status.h>
> #ifdef __cplusplus
> extern "C" {
> @@ -228,7 +229,7 @@ typedef struct {
> #if defined(RTEMS_SMP)
> /** @see _Scheduler_Set_affinity() */
> - bool ( *set_affinity )(
> + Status_Control ( *set_affinity )(
> const Scheduler_Control *,
> Thread_Control *,
> Scheduler_Node *,
> @@ -581,10 +582,13 @@ void _Scheduler_default_Start_idle(
> * @param node This parameter is unused.
> * @param affinity The new processor affinity set for the thread.
> - * @retval true The processor set of the scheduler is a subset of the affinity set.
> - * @retval false The processor set of the scheduler is not a subset of the affinity set.
> + * @retval STATUS_SUCCESSFUL The affinity is a subset of the online
> + * processors.
> + * @retval STATUS_INVALID_NUMBER The affinity is not a subset of the online
> + * processors.
> - bool _Scheduler_default_Set_affinity(
> + Status_Control _Scheduler_default_Set_affinity(
> const Scheduler_Control *scheduler,
> Thread_Control *thread,
> Scheduler_Node *node,
> diff --git a/cpukit/include/rtems/score/scheduleredfsmp.h b/cpukit/include/rtems/score/scheduleredfsmp.h
> index 69dcd1ab3f..6fef6fb86a 100644
> --- a/cpukit/include/rtems/score/scheduleredfsmp.h
> +++ b/cpukit/include/rtems/score/scheduleredfsmp.h
> @@ -330,10 +330,13 @@ void _Scheduler_EDF_SMP_Start_idle(
> + * @retval STATUS_SUCCESSFUL The processor set of the scheduler is a subset of
> + * the affinity set.
> + * @retval STATUS_INVALID_NUMBER The processor set of the scheduler is not a
> + * subset of the affinity set.
> -bool _Scheduler_EDF_SMP_Set_affinity(
> +Status_Control _Scheduler_EDF_SMP_Set_affinity(
> diff --git a/cpukit/include/rtems/score/schedulerimpl.h b/cpukit/include/rtems/score/schedulerimpl.h
> index 65c600b583..595d6291b4 100644
> --- a/cpukit/include/rtems/score/schedulerimpl.h
> +++ b/cpukit/include/rtems/score/schedulerimpl.h
> @@ -711,10 +711,12 @@ Status_Control _Scheduler_Get_affinity(
> * @param affinity The processor mask to check.
> - * @retval true @a affinity is a subset of the online processors.
> - * @retval false @a affinity is not a subset of the online processors.
> + * @retval STATUS_SUCCESSFUL The affinity is a subset of the online processors.
> + * processors.
> -RTEMS_INLINE_ROUTINE bool _Scheduler_default_Set_affinity_body(
> +RTEMS_INLINE_ROUTINE Status_Control _Scheduler_default_Set_affinity_body(
> Thread_Control *the_thread,
> @@ -724,7 +726,12 @@ RTEMS_INLINE_ROUTINE bool _Scheduler_default_Set_affinity_body(
> (void) scheduler;
> (void) the_thread;
> (void) node;
> - return _Processor_mask_Is_subset( affinity, _SMP_Get_online_processors() );
> + if ( !_Processor_mask_Is_subset( affinity, _SMP_Get_online_processors() ) ) {
> + return STATUS_INVALID_NUMBER;
> + return STATUS_SUCCESSFUL;
> @@ -734,10 +741,12 @@ RTEMS_INLINE_ROUTINE bool _Scheduler_default_Set_affinity_body(
> * @param cpusetsize The size of @a cpuset.
> * @param cpuset The cpuset to set the affinity.
> - * @retval true The operation succeeded.
> - * @retval false The operation did not succeed.
> + * @retval STATUS_SUCCESSFUL The operation succeeded.
> + * @retval STATUS_INVALID_NUMBER The processor set was not a valid new
> + * processor affinity set for the thread.
> -bool _Scheduler_Set_affinity(
> +Status_Control _Scheduler_Set_affinity(
> size_t cpusetsize,
> const cpu_set_t *cpuset
> @@ -1318,12 +1327,12 @@ RTEMS_INLINE_ROUTINE Status_Control _Scheduler_Set(
> if (
> _Scheduler_Get_processor_count( new_scheduler ) == 0
> - || !( *new_scheduler->Operations.set_affinity )(
> + || ( *new_scheduler->Operations.set_affinity )(
> new_scheduler,
> the_thread,
> new_scheduler_node,
> &the_thread->Scheduler.Affinity
> + ) != STATUS_SUCCESSFUL
> _Scheduler_Release_critical( new_scheduler, &lock_context );
> _Priority_Plain_insert(
> diff --git a/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
> index 3d5ccaae10..772a83f541 100644
> --- a/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
> +++ b/cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
> @@ -213,10 +213,10 @@ Thread_Control *_Scheduler_priority_affinity_SMP_Remove_processor(
> * @param[in, out] node The scheduler node.
> * @param affinity The new affinity set.
> - * @retval true if successful
> - * @retval false if unsuccessful
> + * @retval STATUS_SUCCESSFUL if successful
> + * @retval STATUS_INVALID_NUMBER if unsuccessful
> -bool _Scheduler_priority_affinity_SMP_Set_affinity(
> +Status_Control _Scheduler_priority_affinity_SMP_Set_affinity(
> diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
> index 75d3c64676..f53cd5e310 100644
> --- a/cpukit/posix/src/pthreadcreate.c
> +++ b/cpukit/posix/src/pthreadcreate.c
> @@ -251,13 +251,13 @@ int pthread_create(
> the_thread->Life.state |= THREAD_LIFE_CHANGE_DEFERRED;
> _ISR_lock_ISR_disable( &lock_context );
> - ok = _Scheduler_Set_affinity(
> + status = _Scheduler_Set_affinity(
> the_thread,
> the_attr->affinitysetsize,
> _ISR_lock_ISR_enable( &lock_context );
> - if ( !ok ) {
> + if ( status != STATUS_SUCCESSFUL ) {
> _Thread_Free( &_POSIX_Threads_Information, the_thread );
> _RTEMS_Unlock_allocator();
> return EINVAL;
> diff --git a/cpukit/posix/src/pthreadsetaffinitynp.c b/cpukit/posix/src/pthreadsetaffinitynp.c
> index ae91d135e1..9cb29ac167 100644
> --- a/cpukit/posix/src/pthreadsetaffinitynp.c
> +++ b/cpukit/posix/src/pthreadsetaffinitynp.c
> @@ -28,6 +28,7 @@
> #include <rtems/score/threadimpl.h>
> #include <rtems/score/schedulerimpl.h>
> +#include <rtems/posix/posixapi.h>
> int pthread_setaffinity_np(
> pthread_t thread,
> @@ -38,7 +39,7 @@ int pthread_setaffinity_np(
> Thread_Control *the_thread;
> ISR_lock_Context lock_context;
> Per_CPU_Control *cpu_self;
> - bool ok;
> + Status_Control status;
> if ( cpuset == NULL ) {
> return EFAULT;
> @@ -53,7 +54,7 @@ int pthread_setaffinity_np(
> cpu_self = _Thread_Dispatch_disable_critical( &lock_context );
> _Thread_State_acquire_critical( the_thread, &lock_context );
> the_thread,
> cpusetsize,
> cpuset
> @@ -61,6 +62,6 @@ int pthread_setaffinity_np(
> _Thread_State_release( the_thread, &lock_context );
> _Thread_Dispatch_enable( cpu_self );
> - return ok ? 0 : EINVAL;
> + return _POSIX_Get_error( status );
> #endif
> diff --git a/cpukit/rtems/src/tasksetaffinity.c b/cpukit/rtems/src/tasksetaffinity.c
> index c3cfbf08cb..84071b2f51 100644
> --- a/cpukit/rtems/src/tasksetaffinity.c
> +++ b/cpukit/rtems/src/tasksetaffinity.c
> @@ -21,6 +21,7 @@
> #endif
> #include <rtems/rtems/tasks.h>
> +#include <rtems/rtems/statusimpl.h>
> @@ -33,7 +34,7 @@ rtems_status_code rtems_task_set_affinity(
> - bool ok;
> return RTEMS_INVALID_ADDRESS;
> @@ -54,7 +55,7 @@ rtems_status_code rtems_task_set_affinity(
> the_thread,
> cpusetsize,
> cpuset
> @@ -62,5 +63,5 @@ rtems_status_code rtems_task_set_affinity(
> - return ok ? RTEMS_SUCCESSFUL : RTEMS_INVALID_NUMBER;
> + return _Status_Get( status );
> diff --git a/cpukit/score/src/schedulerdefaultsetaffinity.c b/cpukit/score/src/schedulerdefaultsetaffinity.c
> index 6399b1e352..7583fc1c8f 100644
> --- a/cpukit/score/src/schedulerdefaultsetaffinity.c
> +++ b/cpukit/score/src/schedulerdefaultsetaffinity.c
> @@ -22,7 +22,7 @@
> -bool _Scheduler_default_Set_affinity(
> +Status_Control _Scheduler_default_Set_affinity(
> diff --git a/cpukit/score/src/scheduleredfsmp.c b/cpukit/score/src/scheduleredfsmp.c
> index b8b1d9de95..13d512118e 100644
> --- a/cpukit/score/src/scheduleredfsmp.c
> +++ b/cpukit/score/src/scheduleredfsmp.c
> @@ -723,7 +723,7 @@ void _Scheduler_EDF_SMP_Unpin(
> node->pinning_ready_queue_index = 0;
> Scheduler_Node *node_base,
> @@ -739,7 +739,7 @@ bool _Scheduler_EDF_SMP_Set_affinity(
> _Processor_mask_And( &local_affinity, &context->Processors, affinity );
> if ( _Processor_mask_Is_zero( &local_affinity ) ) {
> - return false;
> if ( _Processor_mask_Is_equal( affinity, &_SMP_Online_processors ) ) {
> @@ -766,5 +766,5 @@ bool _Scheduler_EDF_SMP_Set_affinity(
> - return true;
> diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
> index 2511b6bbed..10f6808a75 100644
> --- a/cpukit/score/src/schedulerpriorityaffinitysmp.c
> +++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
> @@ -541,7 +541,7 @@ Thread_Control *_Scheduler_priority_affinity_SMP_Remove_processor(
> @@ -557,7 +557,7 @@ bool _Scheduler_priority_affinity_SMP_Set_affinity(
> _Processor_mask_And( &my_affinity, &context->Processors, affinity );
> if ( _Processor_mask_Count( &my_affinity ) == 0 ) {
> - return false;
> node = _Scheduler_priority_affinity_SMP_Node_downcast( node_base );
> @@ -567,7 +567,7 @@ bool _Scheduler_priority_affinity_SMP_Set_affinity(
> * doing anything.
> if ( _Processor_mask_Is_equal( &node->Affinity, affinity ) )
> - return true;
> current_state = thread->current_state;
> @@ -584,5 +584,5 @@ bool _Scheduler_priority_affinity_SMP_Set_affinity(
> (void) _Scheduler_priority_affinity_SMP_Unblock( scheduler, thread, &node->Base.Base.Base );
> - return true;
> diff --git a/cpukit/score/src/schedulersetaffinity.c b/cpukit/score/src/schedulersetaffinity.c
> index 8d16af3ed3..24d13feee7 100644
> --- a/cpukit/score/src/schedulersetaffinity.c
> +++ b/cpukit/score/src/schedulersetaffinity.c
> @@ -27,22 +27,22 @@
> size_t cpusetsize,
> Processor_mask affinity;
> - Processor_mask_Copy_status status;
> + Processor_mask_Copy_status copy_status;
> const Scheduler_Control *scheduler;
> Scheduler_Node *node;
> - bool ok;
> - status = _Processor_mask_From_cpu_set_t( &affinity, cpusetsize, cpuset );
> - if ( !_Processor_mask_Is_at_most_partial_loss( status ) ) {
> - return false;
> + copy_status = _Processor_mask_From_cpu_set_t( &affinity, cpusetsize, cpuset );
> + if ( !_Processor_mask_Is_at_most_partial_loss( copy_status ) ) {
> @@ -57,18 +57,18 @@ bool _Scheduler_Set_affinity(
> node = _Thread_Scheduler_get_home_node( the_thread );
> - ok = ( *scheduler->Operations.set_affinity )(
> + status = ( *scheduler->Operations.set_affinity )(
> scheduler,
> the_thread,
> node,
> &affinity
> - if ( ok ) {
> + if ( status == STATUS_SUCCESSFUL ) {
> _Processor_mask_Assign( &the_thread->Scheduler.Affinity, &affinity );
> #else
> - ok = _Scheduler_default_Set_affinity_body(
> + status = _Scheduler_default_Set_affinity_body(
> scheduler,
> the_thread,
> node,
> @@ -77,5 +77,5 @@ bool _Scheduler_Set_affinity(
> #endif
> _Scheduler_Release_critical( scheduler, &lock_context );
> - return ok;
> + return status;
> 2.26.2
> devel mailing list
> devel at rtems.org
