[PATCH] posix: Use alias for pthread_self()
Tue Apr 27 16:23:16 UTC 2021
PS: the git-rm is missing?
On Tue, Apr 27, 2021, 10:09 AM Gedare Bloom <gedare at rtems.org> wrote:
> @Joel: you ok with this cross-link between classic and posix layers?
> On Tue, Apr 27, 2021 at 3:12 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > This may reduce the code size a bit.
> >  cpukit/Makefile.am                | 1 -
> >  cpukit/rtems/src/taskself.c       | 4 ++++
> >  spec/build/cpukit/librtemscpu.yml | 1 -
> >  3 files changed, 4 insertions(+), 2 deletions(-)
> > diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> > index a8cce3c287..2ae7057d21 100644
> > --- a/cpukit/Makefile.am
> > +++ b/cpukit/Makefile.am
> > @@ -627,7 +627,6 @@ librtemscpu_a_SOURCES +=
> posix/src/pthreadgetschedparam.c
> >  librtemscpu_a_SOURCES += posix/src/pthreadinitthreads.c
> >  librtemscpu_a_SOURCES += posix/src/pthreadjoin.c
> >  librtemscpu_a_SOURCES += posix/src/pthreadonce.c
> > -librtemscpu_a_SOURCES += posix/src/pthreadself.c
> >  librtemscpu_a_SOURCES += posix/src/pthreadsetaffinitynp.c
> >  librtemscpu_a_SOURCES += posix/src/pthreadsetnamenp.c
> >  librtemscpu_a_SOURCES += posix/src/pthreadsetschedparam.c
> > diff --git a/cpukit/rtems/src/taskself.c b/cpukit/rtems/src/taskself.c
> > index 193e691ce5..2eb282ce8d 100644
> > --- a/cpukit/rtems/src/taskself.c
> > +++ b/cpukit/rtems/src/taskself.c
> > @@ -22,7 +22,11 @@
> >  #include <rtems/rtems/tasksimpl.h>
> > +#include <pthread.h>
> >  rtems_id rtems_task_self(void)
> >     return _Thread_Get_executing()->Object.id;
> > +RTEMS_ALIAS( rtems_task_self ) pthread_t pthread_self( void );
> > diff --git a/spec/build/cpukit/librtemscpu.yml
> b/spec/build/cpukit/librtemscpu.yml
> > index a3a9ee42e3..5842bf7ac2 100644
> > --- a/spec/build/cpukit/librtemscpu.yml
> > +++ b/spec/build/cpukit/librtemscpu.yml
> > @@ -1119,7 +1119,6 @@ source:
> >  - cpukit/posix/src/pthreadinitthreads.c
> >  - cpukit/posix/src/pthreadjoin.c
> >  - cpukit/posix/src/pthreadonce.c
> > -- cpukit/posix/src/pthreadself.c
> >  - cpukit/posix/src/pthreadsetaffinitynp.c
> >  - cpukit/posix/src/pthreadsetnamenp.c
> >  - cpukit/posix/src/pthreadsetschedparam.c
> > 2.26.2
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210427/c24900e1/attachment.html>
