[PATCH 0/2] powerpc/shared/console: Console buad rate fixes
dufault at hda.com
dufault at hda.com
Tue Apr 27 17:40:41 UTC 2021
With these two changes the "powerpc/shared/console" code supports a
configurable baud rate.
- Remove hard-wired start-up baud of 9600.
- Fix "termios" first-open that resets baud rate to 9600.
Peter Dufault (2):
powerpc/shared/console: Make console baud rate configurable.
powerpc/shared/console: "termios" first open sets console baud to 9600
bsps/powerpc/shared/console/console.c | 4 ++--
bsps/powerpc/shared/console/uart.c | 6 +++++-
c/src/lib/libbsp/powerpc/beatnik/configure.ac | 4 ++++
c/src/lib/libbsp/powerpc/haleakala/configure.ac | 4 ++++
c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac | 4 ++++
c/src/lib/libbsp/powerpc/mvme3100/configure.ac | 4 ++++
c/src/lib/libbsp/powerpc/mvme5500/configure.ac | 4 ++++
spec/build/bsps/optconsolebaud.yml | 5 +++++
spec/build/bsps/powerpc/beatnik/bspbeatnik.yml | 2 ++
spec/build/bsps/powerpc/haleakala/bsphaleakala.yml | 2 ++
spec/build/bsps/powerpc/motorola_powerpc/obj.yml | 4 +++-
spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml | 2 ++
spec/build/bsps/powerpc/mvme5500/bspmvme5500.yml | 2 ++
13 files changed, 43 insertions(+), 4 deletions(-)
1.8.3.1
