[PATCH 0/2] powerpc/shared/console: Console buad rate fixes
dufault at hda.com
dufault at hda.com
Tue Apr 27 17:44:05 UTC 2021
I forgot to specify V2. I'll try again, sorry for the noise.
> On Apr 27, 2021, at 13:40 , <dufault at hda.com> <dufault at hda.com> wrote:
> From: Peter Dufault <dufault at hda.com>
> With these two changes the "powerpc/shared/console" code supports a
> configurable baud rate.
> - Remove hard-wired start-up baud of 9600.
> - Fix "termios" first-open that resets baud rate to 9600.
> Peter Dufault (2):
> powerpc/shared/console: Make console baud rate configurable.
> powerpc/shared/console: "termios" first open sets console baud to 9600
> bsps/powerpc/shared/console/console.c | 4 ++--
> bsps/powerpc/shared/console/uart.c | 6 +++++-
> c/src/lib/libbsp/powerpc/beatnik/configure.ac | 4 ++++
> c/src/lib/libbsp/powerpc/haleakala/configure.ac | 4 ++++
> c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac | 4 ++++
> c/src/lib/libbsp/powerpc/mvme3100/configure.ac | 4 ++++
> c/src/lib/libbsp/powerpc/mvme5500/configure.ac | 4 ++++
> spec/build/bsps/optconsolebaud.yml | 5 +++++
> spec/build/bsps/powerpc/beatnik/bspbeatnik.yml | 2 ++
> spec/build/bsps/powerpc/haleakala/bsphaleakala.yml | 2 ++
> spec/build/bsps/powerpc/motorola_powerpc/obj.yml | 4 +++-
> spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml | 2 ++
> spec/build/bsps/powerpc/mvme5500/bspmvme5500.yml | 2 ++
> 13 files changed, 43 insertions(+), 4 deletions(-)
> 1.8.3.1
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210427/ac803214/attachment.bin>
