[PATCH v3 0/2] powerpc/shared/console: Console baud rate fixes
Tue Apr 27 20:22:13 UTC 2021
ok, vijay, please check the build and push if all good
On Tue, Apr 27, 2021 at 11:48 AM <dufault at hda.com> wrote:
> From: Peter Dufault <dufault at hda.com>
> With these two changes the "powerpc/shared/console" code supports a
> configurable baud rate.
> Peter Dufault (2):
>   powerpc/shared/console: Make console baud rate configurable.
>   powerpc/shared/console: "termios" first open sets console baud to 9600
>  bsps/powerpc/shared/console/console.c                  | 4 ++--
>  bsps/powerpc/shared/console/uart.c                     | 6 +++++-
>  c/src/lib/libbsp/powerpc/beatnik/configure.ac          | 4 ++++
>  c/src/lib/libbsp/powerpc/haleakala/configure.ac        | 4 ++++
>  c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac | 4 ++++
>  c/src/lib/libbsp/powerpc/mvme3100/configure.ac         | 4 ++++
>  c/src/lib/libbsp/powerpc/mvme5500/configure.ac         | 4 ++++
>  spec/build/bsps/optconsolebaud.yml                     | 5 +++++
>  spec/build/bsps/powerpc/beatnik/bspbeatnik.yml         | 2 ++
>  spec/build/bsps/powerpc/haleakala/bsphaleakala.yml     | 2 ++
>  spec/build/bsps/powerpc/motorola_powerpc/obj.yml       | 4 +++-
>  spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml       | 2 ++
>  spec/build/bsps/powerpc/mvme5500/bspmvme5500.yml       | 2 ++
>  13 files changed, 43 insertions(+), 4 deletions(-)
> 1.8.3.1
> devel mailing list
> devel at rtems.org
