[PATCH] riscv/console: Updated the console-config.c file
Somesh Deshmukh
someshdeshmukh07 at gmail.com
Wed Apr 28 13:22:34 UTC 2021
- Parsing the sub-node should be available generic not specific to Freedom
Arty310 board. If we remove the Freedom Arty macro now, it will lose
backward compatibility.The proposed change will retain the backward
compatibility and also adds the necessary fix for parsing sub-node.
- Line 234 and 235 in riscv_console_probe() uses polled handlers for ns16550
read and write while, the console_initialize function uses ns16550
interrupt handler. Proposing a fix to make polled handlers consistant
through out the console-config.c
bsps/riscv/riscv/console/console-config.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
index d962a5a418..f203f0be7d 100644
--- a/bsps/riscv/riscv/console/console-config.c
+++ b/bsps/riscv/riscv/console/console-config.c
@@ -91,7 +91,7 @@ static int riscv_get_console_node(const void *fdt)
stdout_path = "";
-#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
+#if ((RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0) || (RISCV_CONSOLE_MAX_NS16550_DEVICES > 0))
int root;
int soc;
root = fdt_path_offset(fdt, "/");
@@ -318,7 +318,7 @@ rtems_status_code console_initialize(
rtems_termios_device_install(
path,
- &ns16550_handler_interrupt,
+ &ns16550_handler_polled,
NULL,
&ctx->base
2.25.1
