tcpreplay for testing network stacks
Vijay Kumar Banerjee
vijay at rtems.org
Wed Apr 28 22:54:46 UTC 2021
On Wed, Apr 28, 2021 at 3:27 PM Chris Johns <chrisj at rtems.org> wrote:
> On 29/4/21 3:00 am, Vijay Kumar Banerjee wrote:
> > On Wed, Apr 28, 2021 at 10:49 AM Christian Mauderer <oss at c-mauderer.de> wrote:
> >> Hello Vijay,
> >> On 28/04/2021 18:25, Vijay Kumar Banerjee wrote:
> >>> On Wed, Apr 28, 2021 at 12:41 AM Christian MAUDERER
> >>> <christian.mauderer at embedded-brains.de> wrote:
> >>>> Hello Vijay,
> >>>> Am 27.04.21 um 18:48 schrieb Vijay Kumar Banerjee:
> >>>>> Hi,
> >>>>> I came across the tcpreplay tool and it looks like a nice tool for
> >>>>> testing the network stacks. It can be used to capture network traffic
> >>>>> and then play it back, this will help with testing the network packets
> >>>>> from different network stacks.
> >>>> Sounds like an interesting tool.
> >>>>> My proposal is to add the tcpreply as a host-side tool in rtems-tools
> >>>>> and use it with the network interface where the network application is
> >>>>> running. The only issue that I see with the whole idea is that the
> >>>>> tcpreplay is GPLv3 licensed. Will that be compatible for rtems-tools?
> >>>>> The github repository says that it's compatible with UNIX and Windows
> >>>>> with cygwin.
> >>>> The more difficult problem could be the missing Mac and FreeBSD support.
> >>> That's a good point.
> >>>> What would be the advantage of having tcpreply in rtems-tools? Do you
> >>>> want to use it for automated tests?
> >>> Yes. I was thinking about capturing the pcap format packets in
> >>> temporary files and then running tcpreplay to check for any network
> >>> issues. I haven't planned exactly how that will be implemented but
> >>> roughly this is the idea.
> >> In what form would you automate that? Some test case in RTEMS or some
> >> special repository? I assume that you need some special setup for
> >> specific (simulator) targets anyway, don't you? So a general purpose
> >> test for all targets will be difficult.
> > I was not thinking about a special repository. It would be nice to
> > have it as test case or as an rtems-test config where the script will
> > capture the packets and feed them to tcpreplay.
> Capture from where? How do these traces deal with the differences in networks?
more tools :). What I was attempting is tcpdump to get the pcap and
then tcpreplay. I was basically in search of some way to effectively
test the network stacks.
> Does tcpreply rewrite various fields, for example a DHCP server response? I
> suspect it does not.
I'm not sure.
> Tcpreplay may work out to be a good tool we use but I think there needs to be
> some more ground work to see if you can "virtualize" a network. If you can do
> this you control the arena the devices operate in and all the characteristics
> and then play back would be possible and portable.
> VDE may be an interesting part of this. I seem to remember it has a DHCP server
> so if you use this with a tap that VDE manages rtems-test could use that interface.
That sounds like a great idea.
> A tricky area to look into is if a VDE port can map to a physical port? If this
> can be done you could mix simulation and real hardware and that would be amazing
> to have.
I'll search about this.
Thanks for the great ideas, I'm indeed getting some direction.
Best regards,
Vijay
> >> If it is about testing the stacks and not the drivers, it might would be
> >> possible to write some kind of dummy network driver that can read pcap
> >> format (or some other raw packet format) directly and hands the packets
> >> to the network stack. Such a driver maybe could even provide packets to
> >> a test frame again so that you can check responses.
> > The objective is to test the stacks. The dummy network driver sounds
> > like a great idea, thanks. I'll explore this direction more.
> I prefer real drivers are used as it lets us extend testing to VLAN and
> multicast (driver hashes and filter testing).
> A solution needs to find a suitable lowest common denominator. This means
> hardware and simulation and possibly the different networking stack options we have.
> Chris
